• Hardware Platform Jetson
• DeepStream Version 6.3
• JetPack Version 5.1
• TensorRT Version 5.1
Suddenly, I started getting this error when I run my application:
Resetting source rtsp://XXX 2024-07-25 12:45:49.644 | WARNING | utils.bus_call:bus_call:30 - Warning: gst-stream-error-quark: No data from source rtsp://XXX since last 11 sec. Trying reconnection (1): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvdsbins/gstdsnvurisrcbin.cpp(1266): watch_source_status (): /GstPipeline:pipeline0/GstBin:source-bin-0/GstDsNvUriSrcBin:uri-decode-bin 2024-07-25 12:45:49.645 | WARNING | utils.probe_util:on_warning:536 - ------> uri-decode-bin 2024-07-25 12:45:49.646 | WARNING | utils.bus_call:bus_call:30 - Warning: gst-resource-error-quark: Could not open resource for reading and writing. (7): gstrtspsrc.c(7893): gst_rtspsrc_retrieve_sdp (): /GstPipeline:pipeline0/GstBin:source-bin-0/GstDsNvUriSrcBin:uri-decode-bin/GstRTSPSrc:src: Failed to connect. (Generic error)
This happens when I application tries to connect to RTSP stream, after this warning FPS is 0 and no frames are processed. It only happens with RTSP stream, when I feed the video file into the app it works correctly and there’s no error. Pipeline is similar to deepstream test 3 example.
How can I get pipeline working again?
