RTSP disconnection crashed entire pipeline
• Hardware Platform (Jetson / GPU) Jetson Orin NX
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.2
I am using the Python DeepStream SDK to create a pipeline that utilizes 20 RTSP input streams from IP cameras. My pipeline is able to add or delete sources dynamically. If I run my pipeline with a small number of cameras, it works as expected. However, if I increase the number of inputs to above 10, I encounter the following error after some runtime.
 2024-04-17 02:15:23    ERROR - Error: gst-resource-error-quark: Could not read from resource. (9): gstrtspsrc.c(5560): gst_rtspsrc_loop_interleaved (): /GstPipeline:pipeline0/GstBin:source-bin-3/GstURIDecodeBin:uri-decode-bin/GstRTSPSrc:source:
Could not receive message. (Parse error)
I have two questions:
  1. What is the root cause of this issue?
  2. Is there a way to delete and re-add the erroneous input or reconnect to that source?
Thanks a lot.
  1. this is Gstreamer error log, which mean rtsp abnormal connection, the client can’t receive message from server.
  2. please refer to this topic for rtsp reconenction in python.
