Uridecodebin not linked in pipeline
• Hardware Platform (Jetson / GPU) Tesla T4
• DeepStream Version 6.1.1 - 6.2
• TensorRT Version 8.5.2-1
• NVIDIA GPU Driver Version (valid for GPU only) 11.8
• Issue Type( questions, new requirements, bugs) questions
Hello, I am facing a problem. I use example: runtime_add_del. Periodically, some sources sometimes don’t connect to my pipeline. Help to understand what could be the problem?
What can be done with such sources?
If you try to stop such a source, the pipeline freezes.
Check_state.pdf (212.6 KB)
how do you know that? are you using C code or python code? what is your start command?
