Deepstream multiple RTSP sources, freeze when one is deconnected
• Hardware Platform (Jetson / GPU)= GPU Tesla T4
**• DeepStream Version=6.1
• NVIDIA GPU Driver Version (valid for GPU only)= 525.60.13
**• Issue Type =questions
**• How to reproduce the issue ?
I have a Deepstream 6.1 Python application, in which I provide multiple RTSP sources on input, and my issue is that, when one of the RTSP links is disconnected, the application is freezing. I want to know if this is the desired behavior and If it so, is there something that can be done to avoid the freeze?
I have the following pipeline: rtspsrc ! rtph264depay ! nvv4l2decoder ! streammux ! nvinfer
How did you disconnect the input? I mean is this some behaviour you do with the pipeline or you just pull out the cable of your camera physically?
I simulate the stream, it is not a real camera. I disconnect by stopping the simulation, and restart the script.
How did you restart the script? We already have sample of RTSP source reconnection in our deepstream-app sample. Please refer to the source code. DeepStream Reference Application - deepstream-app — DeepStream 6.3 Release documentation
