Handle RTSP Disconnect When Processing Multiple RTSP Streams Without Stopping Whole Application?
GPU
• DeepStream Version
6.2
n/a
• TensorRT Version
8.5.2
520.61.05
Question
Hi all,
We’re currently using Deepstream for object detection across multiple RTSP streams. Unfortunately, due to network inconsistencies, it’s likely that one of the RTSP connections may fail at some point. When this happens, the entire Deepstream Application stops.
Our ideal scenario is as follows: If an RTSP connection dies, we want the Deepstream Application to continue processing the remaining streams while attempting to reconnect with the failed stream.
How could we solve this?
Configuration:
sources1_demo_live_sgp.txt (1.4 KB)
source1_demo_live.txt (9.2 KB)
config_metamux_demo.txt (1.7 KB)
seems you are testing deepstream_parallel_inference_app, what is the whole media pipeline. there is no reconnection functionality in this sample. please refer to deepstream-app. deepstream-app uses rtspsrc_monitor_probe_func to monitor src’s data receiving and reconnect rtsp srouce in watch_source_status when not receiving data in a specific time.
