I’m able to execute the URL filtering application. However, the application showed the failure and was aborted when executing ‘commit database’ command. I seek for the assistance about this failure. Detail is described as follows.
Able to execute the URL filtering application
$ sudo /opt/mellanox/doca/examples/url_filter/bin/doca_url_filter -a 0000:03:00.0,class=regex -a
auxiliary:mlx5_core.sf.3,sft_en=1 -a auxiliary:mlx5_core.sf.4,sft_en=1 -c3 – -p
EAL: Detected 8 lcore(s)
EAL: Detected 1 NUMA nodes
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode ‘PA’
EAL: No available hugepages reported in hugepages-32768kB
EAL: No available hugepages reported in hugepages-64kB
EAL: No available hugepages reported in hugepages-1048576kB
EAL: Probing VFIO support…
EAL: VFIO support initialized
EAL: Device is not NUMA-aware, defaulting socket to 0
EAL: Probe PCI driver: mlx5_pci (15b3:a2d6) device: 0000:03:00.0 (socket 0)
EAL: No legacy callbacks, legacy socket not created
Temporary WARN - Destination table level lower than Source
[01:49:52:893055][DOCA][I][DWRKR]: 1 cores are used as DPI workers
URL FILTER>> -
Create an empty database and the http filter signature
URL FILTER>> create database
URL FILTER>> filter http test www.slashdot.orgThe command ‘filter http test www.slashdot.org’ will create the following signature in /tmp/signature.txt. (The following command is executed in another terminal)
$ cat /tmp/signature.txt
drop tcp any any → any any (msg:“test”; flow:to_server; pcre:“/www.slashdot.org/I”; sid:1;)
drop tcp any any → any any (msg:“test”; flow:to_server; tls.sni; pcre:“/www.slashdot.org/”; sid:2;) -
Execute ‘commit database’ command. The application showed the failure and was aborted.
URL FILTER>> commit database /tmp/signature.txt
/tmp/265053/signatures.rules
rules file is /tmp/265053/signatures.rules
Info: Setting target hardware version to v5.7…done
Info: Setting virtual prefix mode to 0…done
Info: Setting prefix capacity to 32K…done
Info: Setting compiler objective value to 5…done
Info: Setting number of threads for compilation to 1…done
Info: Reading ruleset…done
Info: Detected 2 rules
Info: Enabling global single-line mode…done
Info: Setting maximum TPE data width to 4…done
Info: Scanning rules…[==============================]…done
Info: Analising possible prefix usage…[==============================]…done
Info: Mapping prefixes, phase 1…[==============================]…done
Info: Mapping prefixes, phase 2…[==============================]…done
Info: Running rules analysis…[==============================]…done
Info: Optimizing memory map…[==============================]…done
Info: Analyzing memory map…[==============================]…done
Info: Calculating thread instructions…[==============================]…done
Info: Beginning to write memory map for ROF2…done
Info: PPE total 1-byte prefix usage: 0/256 (0%)
Info: PPE total 2-byte prefix usage: 0/2048 (0%)
Info: PPE total 3-byte prefix usage: 0/2048 (0%)
Info: PPE total 4-byte prefix usage: 1/32768 (0.00305176%)
Info: TPE instruction RAM TCM partition usage: 2048/2048 (100%)
Info: TPE instruction RAM external memory partition usage: 6218/13M (0.045615%)
Info: TPE class RAM usage: 2/256 (0.78125%)
Info: Estimated threads/byte: 5.183e-10
Info: Finalizing memory map for ROF2…done
Info: Storing ROF2 data…done
Info: Number of rules compiled = 2/2
Info: Writing ROF2 file to /tmp/265053/rof/signatures_compiled.rof2
Info: Writing binary ROF2 file to /tmp/265053/rof/signatures_compiled.rof2.binary…done
mlx5_regex: Rules program failed 22
mlx5_regex: Failed to program rxp rules.
[02:25:01:105139][DOCA][E][UFLTR::Core]: Loading DPI signature failed$
[My configuration steps]
Create a scalable function interface
$ sudo /opt/mellanox/iproute2/sbin/mlxdevm port add pci/0000:03:00.0 flavour pcisf pfnum 0 sfnum 4
pci/0000:03:00.0/294928: type eth netdev eth0 flavour pcisf controller 0 pfnum 0 sfnum 4
function:
hw_addr 02:71:0e:09:0e:2c state inactive opstate detached roce true max_uc_macs 128 trust off
$ sudo /opt/mellanox/iproute2/sbin/mlxdevm port function set pci/0000:03:00.0/294928 hw_addr
02:25:f2:8d:a2:4c trust on state active
$ sudo sh -c ‘echo mlx5_core.sf.3 > /sys/bus/auxiliary/drivers/mlx5_core.sf_cfg/unbind’
$ sudo sh -c ‘echo mlx5_core.sf.3 > /sys/bus/auxiliary/drivers/mlx5_core.sf/bind’ -
Create another scalable function interface
$ sudo /opt/mellanox/iproute2/sbin/mlxdevm port add pci/0000:03:00.0 flavour pcisf pfnum 0 sfnum 5
pci/0000:03:00.0/294929: type eth netdev eth0 flavour pcisf controller 0 pfnum 0 sfnum 5
function:
hw_addr 00:00:00:00:00:00 state inactive opstate detached roce true max_uc_macs 128 trust off
$ sudo /opt/mellanox/iproute2/sbin/mlxdevm port function set pci/0000:03:00.0/294929 hw_addr 02:25:f2:8d:a2:5c trust on state active
$ sudo sh -c ‘echo mlx5_core.sf.4 > /sys/bus/auxiliary/drivers/mlx5_core.sf_cfg/unbind’
$ sudo sh -c ‘echo mlx5_core.sf.4 > /sys/bus/auxiliary/drivers/mlx5_core.sf/bind’ -
List scalable function ports
$ sudo mlnx-sf --action show
SF Index: pci/0000:03:00.0/294928
Parent PCI dev: 0000:03:00.0
Representor netdev: en3f0pf0sf4
Function HWADDR: 02:25:f2:8d:a2:4c
Auxiliary device: mlx5_core.sf.3
netdev: enp3s0f0s4
RDMA dev: mlx5_3SF Index: pci/0000:03:00.0/294929
Representor netdev: en3f0pf0sf5
Function HWADDR: 02:25:f2:8d:a2:5c
Auxiliary device: mlx5_core.sf.4
netdev: enp3s0f0s5
RDMA dev: mlx5_4 -
OVS configuration
$ sudo ovs-vsctl add-br ovsbr1
$ sudo ovs-vsctl add-br ovsbr2
$ sudo ovs-vsctl add-port ovsbr1 pf0hpf
$ sudo ovs-vsctl add-port ovsbr1 en3f0pf0sf4
$ sudo ovs-vsctl add-port ovsbr2 p0
$ sudo ovs-vsctl add-port ovsbr2 en3f0pf0sf5 -
Show OVS info
$ sudo ovs-vsctl show
cd52839a-d5f5-4987-bec0-b7ed3678502f
Bridge ovsbr1
Port pf0hpf
Interface pf0hpf
Port ovsbr1
Interface ovsbr1
type: internal
Port en3f0pf0sf4
Interface en3f0pf0sf4
Bridge ovsbr2
Port ovsbr2
Interface ovsbr2
type: internal
Port p0
Interface p0
Port en3f0pf0sf5
Interface en3f0pf0sf5
ovs_version: “2.14.1” -
Activate all interfaces (ovsbr1, pf0hpf, en3f0pf0sf4, ovsbr2, p0, en3f0pf0sf5) by executing “ifconfig network_interface up”.
Start the ‘mlx-regex.service’ if it is not started.
$ sudo sh -c ‘echo 2048 > /sys/kernel/mm/hugepages/hugepages-2048kB/nr_hugepages’
Run URL filtering application
