The lcd example successfully ran after decreasing the batch size, but the output URL to display the results does not work.
Hi @nga77
If you are running a local machine, you should go to the local url that Tensorboard prints at the bottom. If your’re running on a remote machine, you will need to set up a port forward. Alternatively you could download the Tensorboard file to your local machine and serve it there.
I was running it on a local machine, and the local URL for the tensorboard that is listed next to “Tensorboard 2.9.1” did not work
