I use it with a jetson TX2 board and a virtual machine(ubuntu), passed the 3.0 cable plug J19.I find ethernet speed(12MB/s --18MB/s),Others test up to 70MB/s.Please help me see how to solve it.on ubuntu side, execute (dmesg),I find (xhci_hcd 0000:03:00.0: ERROR unknown event type 37).
I refer to the following methods.
link:
kernel and rootfs use version:
Tegra_Linux_Sample-Root-Filesystem_R28.1.0_aarch64
Tegra186_Linux_R28.1.0_aarch64
kernel-4.4
I steps and debugging information.
ubuntu(vmware) side:
root@zgq-virtual-machine:/home/nuctech# ifconfig ens160u1 192.168.55.5
root@zgq-virtual-machine:/home/nuctech# dd if=/dev/zero bs=1024K count=512 | nc -v 192.168.55.21 8888
Connection to 192.168.55.21 8888 port [tcp/*] succeeded!
512+0 records in
512+0 records out
536870912 bytes (537 MB, 512 MiB) copied, 32.1936 s, 16.7 MB/s
root@zgq-virtual-machine:/home/nuctech# lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 1: Dev 26, If 0, Class=Communications, Driver=rndis_host, 5000M
|__ Port 1: Dev 26, If 1, Class=CDC Data, Driver=rndis_host, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 4, If 0, Class=Hub, Driver=hub/7p, 12M
|__ Port 4: Dev 5, If 0, Class=Hub, Driver=hub/7p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/7p, 12M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/6p, 480M
root@zgq-virtual-machine:/home/nuctech# usb-devices
T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 26 Spd=5000 MxCh= 0
D: Ver= 3.10 Cls=ef(misc ) Sub=02 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=0955 ProdID=7020 Rev=00.01
S: Manufacturer=NVIDIA
S: Product=Linux for Tegra
S: SerialNumber=0421118035065
C: #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=8mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=ff Driver=rndis_host
I: If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=rndis_host
ens160u1 Link encap:Ethernet HWaddr 06:aa:bb:34:ad:90
inet addr:192.168.55.5 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::4aa:bbff:fe34:ad90/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:217086 errors:0 dropped:0 overruns:0 frame:0
TX packets:401116 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:11304351 (11.3 MB) TX bytes:581107521 (581.1 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:13271 errors:0 dropped:0 overruns:0 frame:0
TX packets:13271 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:816231 (816.2 KB) TX bytes:816231 (816.2 KB)
root@zgq-virtual-machine:/home/nuctech# dmesg
[115583.245046] usb 4-1: new SuperSpeed USB device number 25 using xhci_hcd
[115583.275652] usb 4-1: New USB device found, idVendor=0955, idProduct=7020
[115583.275656] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[115583.275711] usb 4-1: Product: Linux for Tegra
[115583.275715] usb 4-1: Manufacturer: NVIDIA
[115583.275718] usb 4-1: SerialNumber: 0421118035065
[115583.417437] rndis_host 4-1:1.0 usb0: register ‘rndis_host’ at usb-0000:03:00.0-1, RNDIS device, 22:a3:f0:28:d7:28
[115583.800072] rndis_host 4-1:1.0 ens160u1: renamed from usb0
[115584.725193] IPv6: ADDRCONF(NETDEV_UP): ens160u1: link is not ready
[115703.382728] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115704.695709] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115711.939512] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115712.885806] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115715.570756] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115715.838726] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115715.845269] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115716.082096] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115716.093517] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115716.118601] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115717.947446] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115720.538324] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.045077] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.083227] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.104719] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.121738] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.139556] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.157480] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.173985] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
[115745.192965] xhci_hcd 0000:03:00.0: ERROR unknown event type 37
TX2 side:
nvidia@tegra-ubuntu:~$ sudo /home/configfs.sh
nvidia@tegra-ubuntu:~$ sudo ifconfig usb0 192.168.55.21
nvidia@tegra-ubuntu:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:04:4b:a5:0d:10
inet addr:10.15.165.199 Bcast:10.15.165.255 Mask:255.255.254.0
inet6 addr: fe80::204:4bff:fea5:d10/64 Scope:Link
RX packets:23154 errors:0 dropped:359 overruns:0 frame:0
TX packets:18104 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1483900 (1.4 MB) TX bytes:675990893 (675.9 MB)
Interrupt:42
l4tbr0 Link encap:Ethernet HWaddr ba:f3:ad:ae:c5:50
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::dc9f:70ff:fe06:362f/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1381 (1.3 KB)
RX packets:11 errors:0 dropped:0 overruns:0 frame:0
TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:753 (753.0 B) TX bytes:753 (753.0 B)
usb0 Link encap:Ethernet HWaddr ba:f3:ad:ae:c5:50
inet addr:192.168.55.21 Bcast:192.168.55.255 Mask:255.255.255.0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
nvidia@tegra-ubuntu:~$ sudo su
root@tegra-ubuntu:/home/nvidia# echo 0x1 > /sys/class/extcon/extcon0/state
root@tegra-ubuntu:/home/nvidia# nc -v -l 8888 > /dev/null
Listening on [0.0.0.0] (family 0, port 8888)
Connection from [192.168.55.5] port 8888 [tcp/*] accepted (family 2, sport 35326)
root@tegra-ubuntu:/home/nvidia# dmesg
[ 154.536389] using random self ethernet address
[ 154.540931] using random host ethernet address
[ 154.551915] usb0: HOST MAC da:24:96:84:c8:ee
[ 154.556359] usb0: MAC ba:f3:ad:ae:c5:50
[ 154.561599] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 154.570142] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 154.575717] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 154.582609] tegra-xudc-new 3550000.xudc: entering ELPG
[ 154.589828] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 154.597287] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 154.605594] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 154.611228] tegra-xudc-new 3550000.xudc: entering ELPG
[ 154.618389] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 154.636328] device usb0 entered promiscuous mode
[ 154.645680] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 192.776633] tegra-xotg xotg: update_vbus_state: VBUS detected
[ 193.321195] tegra186-padctl 3520000.pinctrl: tegra18x_phy_xusb_utmi_pad_dcd: DCD timeout 418 ms
[ 193.371178] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 193.377301] tegra-usb-cd usb_cd: set current 0ma
[ 193.382022] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 193.389505] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 193.395117] tegra-xudc-new 3550000.xudc: device mode on
[ 195.383252] tegra-usb-cd usb_cd: notification status (0x1, 0x20)
[ 195.389349] tegra-usb-cd usb_cd: connected to non-standard charger
[ 195.395622] tegra-usb-cd usb_cd: set current 500ma
[ 225.826992] android_work: did not send uevent (0 0 (null))
[ 226.036466] android_work: sent uevent USB_STATE=CONNECTED
[ 226.394403] android_work: sent uevent USB_STATE=DISCONNECTED
[ 226.449659] android_work: sent uevent USB_STATE=CONNECTED
[ 226.478186] tegra-xudc-new 3550000.xudc: setup request failed: -22
[ 226.485610] tegra-xudc-new 3550000.xudc: setup request failed: -22
[ 226.658881] configfs-gadget gadget: super-speed config #1: b
[ 226.664825] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 226.671661] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 226.678489] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 226.686836] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 226.694189] l4tbr0: port 1(usb0) entered forwarding state
[ 226.699977] l4tbr0: port 1(usb0) entered forwarding state
[ 226.706411] android_work: sent uevent USB_STATE=CONFIGURED
[ 241.706897] l4tbr0: port 1(usb0) entered forwarding state
[ 516.449373] tegradc 15210000.nvdisplay: blank - powerdown
hardware-nvidia-platform-t18x-quill.patch.txt (3.54 KB)
hardware-nvidia-platform-t18x-common.patch.txt (1.4 KB)
TX2_device_log.txt (4.85 KB)
vmware_host_log.txt (4.53 KB)
configfs.sh.txt (6.38 KB)
