I have a sensor that uses an OTG connection to create a USB ethernet connection.
In lsusb it shows up as: Netchip Technology, Inc. Linux-USB Ethernet/RNDIS Gadget
I am unable to get the USB ethernet connection to form on the Jetson TX2 so I cannot ping the device. The device does work on the Raspberry Pi 3, a standard Ubuntu machine, and a Ubuntu VM.
I tried installing the following drivers to resolve the problem:
CONFIG_USB_ETH
CONFIG_USB_ETH_RNDIS
and many other gadget drivers, however I do not think this is the issue as these drivers must be on the target, not the host machine.
The device’s IP is 192.168.7.2, which is a statically set IP from the manufacturer. I have tried setting the port to 192.168.7.10 and 192.168.7.11 and 192.168.7.1 manually as the manufacturer suggested, but am still unable to reach the device.
Has anyone else worked with a similar device or have suggestions on what I can do to ping the device from the Jetson?
Thanks,
sathyas
