Can't connect to Jetson TX2 to install SDK componets on target device after OS is successfully flash...
I am unable to connect to Jetson TX2 to install the SDk componets on target device which is the last step of setting up Jetson TX2. I have already created a new user and Jetson boots up just fine. Ubuntu 18.04 desktop is shown on the HDMI monitor. USB cable is connected between host PC and TX2 (running Ubuntu 18.04).
lsusb does not show Nvidia as connected. But it showed when I started the setup process.
The following is the output of dmesg:
[code][39366.196172] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[39708.149426] usb 2-1.3: USB disconnect, device number 3
[45837.850841] perf: interrupt took too long (2509 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
[53493.889834] perf: interrupt took too long (3151 > 3136), lowering kernel.perf_event_max_sample_rate to 63250
[70081.513342] perf: interrupt took too long (3949 > 3938), lowering kernel.perf_event_max_sample_rate to 50500
[73248.104658] usb 1-1.1: new low-speed USB device number 9 using ehci-pci
[73248.216513] usb 1-1.1: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[73248.216516] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[73248.216518] usb 1-1.1: Product: USB Optical Mouse
[73248.219328] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:04B3:310C.0003/input/input9
[73248.219538] hid-generic 0003:04B3:310C.0003: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.1/input0
[81224.998120] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[81905.472190] usb 1-1.2: new high-speed USB device number 10 using ehci-pci
[81905.595756] usb 1-1.2: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[81905.595759] usb 1-1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[81905.595762] usb 1-1.2: Product: Transcend
[81905.595764] usb 1-1.2: Manufacturer: TS-RDF8
[81905.595766] usb 1-1.2: SerialNumber: 000000079
[81905.596308] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[81905.596626] scsi host6: usb-storage 1-1.2:1.0
[81906.605778] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[81906.606683] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[81906.607414] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[81906.607679] sd 6:0:0:0: Attached scsi generic sg2 type 0
[81906.607930] sd 6:0:0:1: Attached scsi generic sg3 type 0
[81906.608242] sd 6:0:0:2: Attached scsi generic sg4 type 0
[81906.903053] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[81906.904001] sd 6:0:0:1: [sdc] Write Protect is off
[81906.904003] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[81906.905374] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[81906.907859] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[81906.910215] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[81906.930260] sdc: sdc1 sdc2
[81906.933614] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[125411.213837] perf: interrupt took too long (5012 > 4936), lowering kernel.perf_event_max_sample_rate to 39750
[146788.882052] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[146788.886992] JFS: nTxBlock = 8192, nTxLock = 65536
[146788.971627] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[146789.019424] QNX4 filesystem 0.2.3 registered.
[146789.080642] raid6: avx2x4 gen() 32765 MB/s
[146789.128642] raid6: avx2x4 xor() 21704 MB/s
[146789.176643] raid6: avx2x2 gen() 29751 MB/s
[146789.224654] raid6: avx2x2 xor() 17791 MB/s
[146789.272641] raid6: avx2x1 gen() 25628 MB/s
[146789.320643] raid6: avx2x1 xor() 17400 MB/s
[146789.368643] raid6: sse2x4 gen() 18341 MB/s
[146789.416660] raid6: sse2x4 xor() 11458 MB/s
[146789.464656] raid6: sse2x2 gen() 15541 MB/s
[146789.512655] raid6: sse2x2 xor() 10068 MB/s
[146789.560661] raid6: sse2x1 gen() 11196 MB/s
[146789.608642] raid6: sse2x1 xor() 9208 MB/s
[146789.608654] raid6: using algorithm avx2x4 gen() 32765 MB/s
[146789.608655] raid6: … xor() 21704 MB/s, rmw enabled
[146789.608656] raid6: using avx2x2 recovery algorithm
[146789.609575] xor: automatically using best checksumming function avx
[146789.622385] Btrfs loaded, crc32c=crc32c-intel
[165048.625942] usb 1-1.2: USB disconnect, device number 10
[165048.737755] FAT-fs (sdc1): unable to read boot sector to mark fs as dirty
[165595.075843] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[166188.779744] radeon_dp_aux_transfer_native: 116 callbacks suppressed
[166194.069906] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[166227.791785] radeon_dp_aux_transfer_native: 74 callbacks suppressed
[166399.131726] radeon_dp_aux_transfer_native: 116 callbacks suppressed
[170274.823443] printk: systemd: 20 output lines suppressed due to ratelimiting
[170274.834851] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[170274.852023] systemd[1]: Detected architecture x86-64.
[170275.145165] systemd[1]: Stopping Journal Service…
[170275.145345] systemd-journald[358]: Received SIGTERM from PID 1 (systemd).
[170275.643183] systemd[1]: Stopped Journal Service.
[170275.646056] systemd[1]: Starting Journal Service…
[170275.980541] systemd[1]: Started Journal Service.
[170502.575839] kauditd_printk_skb: 2 callbacks suppressed
[170502.575840] audit: type=1400 audit(1573715321.159:51): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/snapd/snap-confine” pid=12522 comm=“apparmor_parser”
[170502.595700] audit: type=1400 audit(1573715321.179:52): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=12522 comm=“apparmor_parser”
[170772.321204] audit: type=1400 audit(1573715590.903:53): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170772.334238] audit: type=1400 audit(1573715590.915:54): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.180238] audit: type=1400 audit(1573715593.763:55): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.180947] audit: type=1400 audit(1573715593.763:56): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.181680] audit: type=1400 audit(1573715593.763:57): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.182555] audit: type=1400 audit(1573715593.763:58): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=26265 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[174362.852368] audit: type=1400 audit(1573719181.435:59): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.853219] audit: type=1400 audit(1573719181.435:60): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.896140] audit: type=1400 audit(1573719181.479:61): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.896744] audit: type=1400 audit(1573719181.479:62): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.897532] audit: type=1400 audit(1573719181.479:63): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.898390] audit: type=1400 audit(1573719181.479:64): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=27441 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[174363.263873] audit: type=1400 audit(1573719181.847:65): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.mozilla/firefox/0qyqj22m.default/cert8.db” pid=27440 comm=“soffice.bin” requested_mask=“w” denied_mask=“w” fsuid=1000 ouid=1000
[174363.274609] audit: type=1400 audit(1573719181.855:66): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.mozilla/firefox/0qyqj22m.default/key3.db” pid=27440 comm=“soffice.bin” requested_mask=“wr” denied_mask=“wr” fsuid=1000 ouid=1000
[178556.263272] e1000e: eno1 NIC Link is Down
[178600.607031] radeon_dp_aux_transfer_native: 74 callbacks suppressed
[179540.074508] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[179553.734984] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[179918.466974] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[179966.619006] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[179991.655222] e1000e: eno1 NIC Link is Down
[180003.754469] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[180060.735001] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[180892.807208] e1000e: eno1 NIC Link is Down
[180896.842443] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[180941.191181] e1000e: eno1 NIC Link is Down
[180953.290431] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[181025.863150] e1000e: eno1 NIC Link is Down
[181033.930831] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[186136.466619] usb 1-1.4: new high-speed USB device number 11 using ehci-pci
[186136.810412] usb 1-1.4: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186136.810415] usb 1-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186136.810417] usb 1-1.4: Product: Transcend
[186136.810419] usb 1-1.4: Manufacturer: TS-RDF8
[186136.810420] usb 1-1.4: SerialNumber: 000000079
[186136.811083] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[186136.811333] scsi host6: usb-storage 1-1.4:1.0
[186137.831650] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186137.832377] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186137.833124] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186137.833571] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186137.833802] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186137.833995] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186138.127781] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186138.129037] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186138.130254] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186138.134152] sd 6:0:0:1: [sdc] Write Protect is off
[186138.134155] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186138.139357] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186138.155389] sdc: sdc1 sdc2
[186138.158870] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[186139.028879] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[186501.597678] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[186534.346613] usb 1-1.4: reset high-speed USB device number 11 using ehci-pci
[186535.062996] usb 1-1.4: USB disconnect, device number 11
[186535.086609] sd 6:0:0:1: [sdc] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[186535.086614] sd 6:0:0:1: [sdc] tag#0 CDB: Write(10) 2a 00 00 01 f6 90 00 00 f0 00
[186535.086616] print_req_error: I/O error, dev sdc, sector 128656 flags 4801
[186535.086621] Buffer I/O error on dev sdc1, logical block 15058, lost async page write
[186535.086632] Buffer I/O error on dev sdc1, logical block 15059, lost async page write
[186535.086634] Buffer I/O error on dev sdc1, logical block 15060, lost async page write
[186535.086636] Buffer I/O error on dev sdc1, logical block 15061, lost async page write
[186535.086638] Buffer I/O error on dev sdc1, logical block 15062, lost async page write
[186535.086640] Buffer I/O error on dev sdc1, logical block 15063, lost async page write
[186535.086642] Buffer I/O error on dev sdc1, logical block 15064, lost async page write
[186535.086644] Buffer I/O error on dev sdc1, logical block 15065, lost async page write
[186535.086660] Buffer I/O error on dev sdc1, logical block 15066, lost async page write
[186535.086665] Buffer I/O error on dev sdc1, logical block 15067, lost async page write
[186535.086764] sd 6:0:0:1: [sdc] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[186535.086767] sd 6:0:0:1: [sdc] tag#0 CDB: Write(10) 2a 00 00 01 f7 80 00 00 80 00
[186535.086769] print_req_error: I/O error, dev sdc, sector 128896 flags 801
[186535.422550] usb 1-1.4: new full-speed USB device number 12 using ehci-pci
[186535.502557] usb 1-1.4: device descriptor read/64, error -32
[186535.690654] usb 1-1.4: device descriptor read/64, error -32
[186535.878616] usb 1-1.4: new full-speed USB device number 13 using ehci-pci
[186535.958574] usb 1-1.4: device descriptor read/64, error -32
[186536.146593] usb 1-1.4: device descriptor read/64, error -32
[186536.254749] usb 1-1-port4: attempt power cycle
[186536.862587] usb 1-1.4: new full-speed USB device number 14 using ehci-pci
[186537.278637] usb 1-1.4: device not accepting address 14, error -32
[186541.630563] usb 1-1.4: new high-speed USB device number 16 using ehci-pci
[186541.754226] usb 1-1.4: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186541.754229] usb 1-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186541.754231] usb 1-1.4: Product: Transcend
[186541.754232] usb 1-1.4: Manufacturer: TS-RDF8
[186541.754233] usb 1-1.4: SerialNumber: 000000079
[186541.754846] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[186541.755079] scsi host6: usb-storage 1-1.4:1.0
[186542.760061] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186542.760877] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186542.761608] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186542.761931] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186542.762130] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186542.762326] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186543.057530] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186543.057900] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186543.060520] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186543.062774] sd 6:0:0:1: [sdc] Write Protect is off
[186543.062776] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186543.066264] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186543.083556] sdc: sdc1 sdc2
[186543.087012] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[186713.566566] EXT4-fs (sdc): VFS: Can’t find ext4 filesystem
[186916.995375] usb 1-1.4: USB disconnect, device number 16
[186922.046555] usb 1-1.4: new high-speed USB device number 17 using ehci-pci
[186922.554562] usb 1-1.4: device not accepting address 17, error -71
[186922.842590] usb 1-1.4: new high-speed USB device number 18 using ehci-pci
[186922.962177] usb 1-1.4: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186922.962179] usb 1-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186922.962180] usb 1-1.4: Product: Transcend
[186922.962181] usb 1-1.4: Manufacturer: TS-RDF8
[186922.962181] usb 1-1.4: SerialNumber: 000000079
[186922.962676] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[186922.962816] scsi host6: usb-storage 1-1.4:1.0
[186923.975554] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186923.976346] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186923.977096] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186923.977348] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186923.977494] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186923.977675] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186924.273174] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186924.275800] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186924.278311] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186924.280549] sd 6:0:0:1: [sdc] Write Protect is off
[186924.280553] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186924.284164] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186924.298575] sdc: sdc1 sdc2
[186924.301909] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[186928.986852] usb 1-1.4: USB disconnect, device number 18
[186940.986582] usb 1-1.3: new high-speed USB device number 19 using ehci-pci
[186941.110256] usb 1-1.3: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186941.110259] usb 1-1.3: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186941.110260] usb 1-1.3: Product: Transcend
[186941.110262] usb 1-1.3: Manufacturer: TS-RDF8
[186941.110263] usb 1-1.3: SerialNumber: 000000079
[186941.110797] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[186941.110966] scsi host6: usb-storage 1-1.3:1.0
[186942.119822] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186942.120655] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186942.121430] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186942.121867] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186942.122120] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186942.122389] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186942.417382] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186942.417746] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186942.418744] sd 6:0:0:1: [sdc] Write Protect is off
[186942.418746] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186942.419975] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186942.423483] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186942.442868] sdc: sdc1 sdc2
[186942.446216] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[188030.032082] usb 1-1.1: USB disconnect, device number 9
[188034.102465] usb 1-1.2: new low-speed USB device number 20 using ehci-pci
[188034.218538] usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[188034.218540] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[188034.218542] usb 1-1.2: Product: USB Optical Mouse
[188034.223516] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310C.0004/input/input10
[188034.223729] hid-generic 0003:04B3:310C.0004: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[188038.469583] usb 2-1.4: USB disconnect, device number 4
[188044.082537] usb 1-1.1: new low-speed USB device number 21 using ehci-pci
[188044.204024] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.06
[188044.204027] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[188044.204787] usb 1-1.1: can’t set config #1, error -32
[188044.367913] usb 1-1.1: USB disconnect, device number 21
[188044.598534] usb 1-1.1: new low-speed USB device number 22 using ehci-pci
[188045.098506] usb 1-1.1: device not accepting address 22, error -32
[188045.386549] usb 1-1.1: new low-speed USB device number 23 using ehci-pci
[188045.508844] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.06
[188045.508847] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[188045.508849] usb 1-1.1: Product: Dell USB Keyboard
[188045.508850] usb 1-1.1: Manufacturer: Dell
[188045.512931] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2003.0005/input/input11
[188045.571039] hid-generic 0003:413C:2003.0005: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1a.0-1.1/input0
[188272.205819] usb 1-1.3: USB disconnect, device number 19
[198125.804966] audit: type=1400 audit(1573742944.386:67): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap-update-ns.gnome-system-monitor” pid=8301 comm=“apparmor_parser”
[198126.022867] audit: type=1400 audit(1573742944.606:68): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-system-monitor.gnome-system-monitor” pid=8302 comm=“apparmor_parser”
[198126.234609] audit: type=1400 audit(1573742944.818:69): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine” pid=8304 comm=“apparmor_parser”
[198126.234613] audit: type=1400 audit(1573742944.818:70): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=8304 comm=“apparmor_parser”
[198126.300701] audit: type=1400 audit(1573742944.882:71): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.core” pid=8306 comm=“apparmor_parser”
[198126.326176] audit: type=1400 audit(1573742944.910:72): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap.core.hook.configure” pid=8307 comm=“apparmor_parser”
[198142.102232] audit: type=1400 audit(1573742960.686:73): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap-update-ns.gnome-characters” pid=8320 comm=“apparmor_parser”
[198142.148536] audit: type=1400 audit(1573742960.730:74): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-characters.gnome-characters” pid=8321 comm=“apparmor_parser”
[198142.291857] audit: type=1400 audit(1573742960.874:75): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine” pid=8323 comm=“apparmor_parser”
[198142.291866] audit: type=1400 audit(1573742960.874:76): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=8323 comm=“apparmor_parser”
[198142.297348] audit: type=1400 audit(1573742960.878:77): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.core” pid=8325 comm=“apparmor_parser”
[198142.298280] audit: type=1400 audit(1573742960.882:78): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap.core.hook.configure” pid=8326 comm=“apparmor_parser”
[211640.747471] audit: type=1400 audit(1573756459.330:79): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-calculator.gnome-calculator” pid=19215 comm=“apparmor_parser”
[211640.794468] audit: type=1400 audit(1573756459.378:80): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-calculator” pid=19214 comm=“apparmor_parser”
[211641.330782] audit: type=1400 audit(1573756459.914:81): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-characters” pid=19217 comm=“apparmor_parser”
[211641.391055] audit: type=1400 audit(1573756459.974:82): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-characters.gnome-characters” pid=19218 comm=“apparmor_parser”
[211641.874978] audit: type=1400 audit(1573756460.458:83): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-logs” pid=19221 comm=“apparmor_parser”
[211641.962789] audit: type=1400 audit(1573756460.546:84): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-logs.gnome-logs” pid=19222 comm=“apparmor_parser”
[211642.460957] audit: type=1400 audit(1573756461.042:85): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-system-monitor” pid=19224 comm=“apparmor_parser”
[211642.533540] audit: type=1400 audit(1573756461.118:86): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-system-monitor.gnome-system-monitor” pid=19225 comm=“apparmor_parser”
[246973.535411] usb 2-1.3: new high-speed USB device number 5 using ehci-pci
[246973.645170] usb 2-1.3: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[246973.645172] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[246973.645173] usb 2-1.3: Product: Android
[246973.645174] usb 2-1.3: Manufacturer: Android
[246973.645175] usb 2-1.3: SerialNumber: 5c4626f7d140
[249662.506501] usb 2-1.3: USB disconnect, device number 5
[250014.943293] usb 2-1.3: new high-speed USB device number 6 using ehci-pci
[250015.060761] usb 2-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[250015.060765] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[250015.060767] usb 2-1.3: Product: APX
[250015.060769] usb 2-1.3: Manufacturer: NVIDIA Corp.
[250157.378125] usb 2-1.3: USB disconnect, device number 6
[257906.393412] audit: type=1400 audit(1573802724.976:87): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257906.498001] audit: type=1400 audit(1573802725.080:88): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.219834] audit: type=1400 audit(1573802725.804:89): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.220494] audit: type=1400 audit(1573802725.804:90): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.221207] audit: type=1400 audit(1573802725.804:91): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.222070] audit: type=1400 audit(1573802725.804:92): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=31910 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[257911.977617] audit: type=1400 audit(1573802730.560:93): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/profiles.ini” pid=31909 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=1000
[257912.030642] audit: type=1400 audit(1573802730.612:94): apparmor=“ALLOWED” operation=“mknod” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/secmod.db” pid=31909 comm=“soffice.bin” requested_mask=“c” denied_mask=“c” fsuid=1000 ouid=1000
[257912.030645] audit: type=1400 audit(1573802730.612:95): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/secmod.db” pid=31909 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[257912.032571] audit: type=1400 audit(1573802730.616:96): apparmor=“ALLOWED” operation=“mknod” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/cert8.db” pid=31909 comm=“soffice.bin” requested_mask=“c” denied_mask=“c” fsuid=1000 ouid=1000
[257912.032574] audit: type=1400 audit(1573802730.616:97): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/cert8.db” pid=31909 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[257912.032673] audit: type=1400 audit(1573802730.616:98): apparmor=“ALLOWED” operation=“mknod” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/key3.db” pid=31909 comm=“soffice.bin” requested_mask=“c” denied_mask=“c” fsuid=1000 ouid=1000
[257912.032675] audit: type=1400 audit(1573802730.616:99): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/key3.db” pid=31909 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[258225.131986] audit: type=1400 audit(1573803043.716:100): apparmor=“ALLOWED” operation=“connect” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“wr” denied_mask=“wr” fsuid=1000 ouid=1000
[258225.131988] audit: type=1400 audit(1573803043.716:101): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=1000
[258225.131990] audit: type=1400 audit(1573803043.716:102): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=1000
[258225.132086] audit: type=1400 audit(1573803043.716:103): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“w” denied_mask=“w” fsuid=1000 ouid=1000
[258225.132088] audit: type=1400 audit(1573803043.716:104): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“w” denied_mask=“w” fsuid=1000 ouid=1000
[264883.518477] usb 1-1.4: new high-speed USB device number 24 using ehci-pci
[264883.627356] usb 1-1.4: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[264883.627359] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[264883.627361] usb 1-1.4: Product: Android
[264883.627362] usb 1-1.4: Manufacturer: Android
[264883.627364] usb 1-1.4: SerialNumber: 5c4626f7d140
[264915.549758] usb 1-1.4: USB disconnect, device number 24
[265568.986197] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[267490.850377] usb 1-1.3: new high-speed USB device number 25 using ehci-pci
[267490.959635] usb 1-1.3: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
[267490.959637] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[267490.959638] usb 1-1.3: Product: Ultra
[267490.959639] usb 1-1.3: Manufacturer: SanDisk
[267490.959639] usb 1-1.3: SerialNumber: 4C530000101225107093
[267490.959907] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[267490.960122] scsi host6: usb-storage 1-1.3:1.0
[267491.971552] scsi 6:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[267491.971952] sd 6:0:0:0: Attached scsi generic sg2 type 0
[267491.972527] sd 6:0:0:0: [sdb] 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
[267491.973769] sd 6:0:0:0: [sdb] Write Protect is off
[267491.973771] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[267491.974782] sd 6:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[267491.985237] sdb: sdb1
[267491.989013] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[267500.277961] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[267594.819475] usb 1-1.3: USB disconnect, device number 25
[271848.438125] usb 1-1.4: new high-speed USB device number 26 using ehci-pci
[271848.547748] usb 1-1.4: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[271848.547751] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[271848.547753] usb 1-1.4: Product: Android
[271848.547754] usb 1-1.4: Manufacturer: Android
[271848.547755] usb 1-1.4: SerialNumber: 5c4626f7d140
[271857.177648] usb 1-1.4: USB disconnect, device number 26
[439250.317183] usb 1-1.4: new high-speed USB device number 27 using ehci-pci
[439250.431064] usb 1-1.4: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
[439250.431067] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[439250.431068] usb 1-1.4: Product: Ultra
[439250.431069] usb 1-1.4: Manufacturer: SanDisk
[439250.431071] usb 1-1.4: SerialNumber: 4C530000101225107093
[439250.431409] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[439250.431700] scsi host6: usb-storage 1-1.4:1.0
[439251.450560] scsi 6:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[439251.451102] sd 6:0:0:0: Attached scsi generic sg2 type 0
[439251.451634] sd 6:0:0:0: [sdb] 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
[439251.452886] sd 6:0:0:0: [sdb] Write Protect is off
[439251.452888] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[439251.453914] sd 6:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[439251.464035] sdb: sdb1
[439251.467850] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[439253.413298] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[439622.826736] usb 1-1.4: USB disconnect, device number 27
[525419.328557] usb 1-1.4: new high-speed USB device number 28 using ehci-pci
[525419.438130] usb 1-1.4: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[525419.438133] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[525419.438134] usb 1-1.4: Product: Android
[525419.438136] usb 1-1.4: Manufacturer: Android
[525419.438137] usb 1-1.4: SerialNumber: 5c4626f7d140
[525485.408017] usb 1-1.4: USB disconnect, device number 28
[526648.628506] usb 1-1.3: new high-speed USB device number 29 using ehci-pci
[526648.741342] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[526648.741344] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[526648.741346] usb 1-1.3: Product: APX
[526648.741347] usb 1-1.3: Manufacturer: NVIDIA Corp.
[529386.297861] usb 1-1.3: USB disconnect, device number 29
[530138.544596] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[592085.681026] usb 1-1.3: new high-speed USB device number 30 using ehci-pci
[592085.790529] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592085.790533] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[592085.790535] usb 1-1.3: Product: APX
[592085.790536] usb 1-1.3: Manufacturer: NVIDIA Corp.
[592142.289909] usb 1-1.3: USB disconnect, device number 30
[592142.524941] usb 1-1.3: new high-speed USB device number 31 using ehci-pci
[592142.634019] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592142.634021] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[592142.634022] usb 1-1.3: Product: APX
[592142.634023] usb 1-1.3: Manufacturer: NVIDIA Corp.
[592142.634023] usb 1-1.3: SerialNumber: 00000
[592149.113334] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[592463.054679] usb 1-1.3: USB disconnect, device number 31
[592463.276943] usb 1-1.3: new high-speed USB device number 32 using ehci-pci
[592463.389851] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592463.389853] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[592463.389853] usb 1-1.3: Product: APX
[592463.389854] usb 1-1.3: Manufacturer: NVIDIA Corp.
[592463.389855] usb 1-1.3: SerialNumber: 00000
[592681.932458] usb 1-1.3: USB disconnect, device number 32
[592843.436981] usb 1-1.3: new high-speed USB device number 33 using ehci-pci
[592843.546279] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592843.546285] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[592843.546289] usb 1-1.3: Product: APX
[592843.546291] usb 1-1.3: Manufacturer: NVIDIA Corp.
[593115.848207] usb 1-1.3: USB disconnect, device number 33
[593116.068931] usb 1-1.3: new high-speed USB device number 34 using ehci-pci
[593116.186102] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[593116.186104] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[593116.186105] usb 1-1.3: Product: APX
[593116.186107] usb 1-1.3: Manufacturer: NVIDIA Corp.
[593116.186108] usb 1-1.3: SerialNumber: 00000
[593122.054879] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[593381.061602] usb 1-1.3: USB disconnect, device number 34
[593381.356906] usb 1-1.3: new high-speed USB device number 35 using ehci-pci
[593381.466475] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[593381.466478] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[593381.466480] usb 1-1.3: Product: APX
[593381.466482] usb 1-1.3: Manufacturer: NVIDIA Corp.
[593381.466484] usb 1-1.3: SerialNumber: 00000
[593596.611486] usb 1-1.3: USB disconnect, device number 35
[595340.176818] usb 1-1.3: new high-speed USB device number 36 using ehci-pci
[595340.286327] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595340.286330] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595340.286331] usb 1-1.3: Product: APX
[595340.286333] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595569.584157] usb 1-1.3: USB disconnect, device number 36
[595573.136830] usb 1-1.3: new high-speed USB device number 37 using ehci-pci
[595573.245597] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595573.245603] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595573.245606] usb 1-1.3: Product: APX
[595573.245609] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595597.231885] usb 1-1.3: USB disconnect, device number 37
[595597.532799] usb 1-1.3: new high-speed USB device number 38 using ehci-pci
[595597.642014] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595597.642016] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595597.642018] usb 1-1.3: Product: APX
[595597.642019] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595597.999872] usb 1-1.3: USB disconnect, device number 38
[595599.244776] usb 1-1.3: new high-speed USB device number 39 using ehci-pci
[595599.357869] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595599.357871] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595599.357873] usb 1-1.3: Product: APX
[595599.357874] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595599.535838] usb 1-1.3: USB disconnect, device number 39
[595602.316794] usb 1-1.3: new high-speed USB device number 40 using ehci-pci
[595602.426301] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595602.426305] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595602.426306] usb 1-1.3: Product: APX
[595602.426308] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595766.702224] usb 1-1.3: USB disconnect, device number 40
[598963.056666] usb 1-1.3: new high-speed USB device number 41 using ehci-pci
[598963.165617] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[598963.165621] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[598963.165623] usb 1-1.3: Product: APX
[598963.165624] usb 1-1.3: Manufacturer: NVIDIA Corp.
[598967.694792] usb 1-1.3: USB disconnect, device number 41
[598971.244622] usb 1-1.3: new high-speed USB device number 42 using ehci-pci
[598971.357356] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[598971.357358] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[598971.357359] usb 1-1.3: Product: APX
[598971.357360] usb 1-1.3: Manufacturer: NVIDIA Corp.
[599268.235991] usb 1-1.3: USB disconnect, device number 42
[615904.967215] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[617088.142573] audit: type=1400 audit(1574161906.746:105): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617088.283140] audit: type=1400 audit(1574161906.886:106): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.085278] audit: type=1400 audit(1574161909.690:107): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.086121] audit: type=1400 audit(1574161909.690:108): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.087276] audit: type=1400 audit(1574161909.690:109): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.107198] audit: type=1400 audit(1574161909.710:110): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=10777 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[619337.891543] usb 1-1.4: new high-speed USB device number 43 using ehci-pci
[619338.000916] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[619338.000918] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[619338.000919] usb 1-1.4: Product: APX
[619338.000920] usb 1-1.4: Manufacturer: NVIDIA Corp.
[619923.393439] usb 1-1.4: USB disconnect, device number 43
[620247.547543] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[674868.360575] usb 1-1.4: new high-speed USB device number 44 using ehci-pci
[674868.469591] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[674868.469593] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[674868.469595] usb 1-1.4: Product: APX
[674868.469596] usb 1-1.4: Manufacturer: NVIDIA Corp.
[674941.605111] usb 1-1.4: USB disconnect, device number 44
[674941.832540] usb 1-1.4: new high-speed USB device number 45 using ehci-pci
[674941.941847] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[674941.941850] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[674941.941852] usb 1-1.4: Product: APX
[674941.941854] usb 1-1.4: Manufacturer: NVIDIA Corp.
[674941.941855] usb 1-1.4: SerialNumber: 00000
[674947.406778] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[675246.754265] usb 1-1.4: USB disconnect, device number 45
[675246.976513] usb 1-1.4: new high-speed USB device number 46 using ehci-pci
[675247.093483] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675247.093486] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[675247.093488] usb 1-1.4: Product: APX
[675247.093489] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675247.093491] usb 1-1.4: SerialNumber: 00000
[675459.488059] usb 1-1.4: USB disconnect, device number 46
[675580.288581] usb 1-1.4: new high-speed USB device number 47 using ehci-pci
[675580.397483] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675580.397487] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[675580.397490] usb 1-1.4: Product: APX
[675580.397493] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675722.397485] usb 1-1.4: USB disconnect, device number 47
[675722.628515] usb 1-1.4: new high-speed USB device number 48 using ehci-pci
[675722.741723] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675722.741725] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[675722.741726] usb 1-1.4: Product: APX
[675722.741727] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675722.741727] usb 1-1.4: SerialNumber: 00000
[675728.730547] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[675996.314771] usb 1-1.4: USB disconnect, device number 48
[675996.612487] usb 1-1.4: new high-speed USB device number 49 using ehci-pci
[675996.721364] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675996.721366] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[675996.721366] usb 1-1.4: Product: APX
[675996.721367] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675996.721368] usb 1-1.4: SerialNumber: 00000
[676210.072651] usb 1-1.4: USB disconnect, device number 49
[678560.032449] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[680275.792327] usb 1-1.4: new high-speed USB device number 50 using ehci-pci
[680275.901424] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[680275.901428] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[680275.901429] usb 1-1.4: Product: APX
[680275.901431] usb 1-1.4: Manufacturer: NVIDIA Corp.
[680505.710504] usb 1-1.4: USB disconnect, device number 50
[680505.936258] usb 1-1.4: new high-speed USB device number 51 using ehci-pci
[680506.045898] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[680506.045902] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[680506.045904] usb 1-1.4: Product: APX
[680506.045906] usb 1-1.4: Manufacturer: NVIDIA Corp.
[680506.045907] usb 1-1.4: SerialNumber: 00000
[680511.876587] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[680778.859827] usb 1-1.4: USB disconnect, device number 51
[680779.096218] usb 1-1.4: new high-speed USB device number 52 using ehci-pci
[680779.205180] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[680779.205182] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[680779.205183] usb 1-1.4: Product: APX
[680779.205184] usb 1-1.4: Manufacturer: NVIDIA Corp.
[680779.205185] usb 1-1.4: SerialNumber: 00000
[680994.409692] usb 1-1.4: USB disconnect, device number 52
[681834.081627] usb 1-1.2: USB disconnect, device number 20
[681862.208198] usb 1-1.2: new low-speed USB device number 53 using ehci-pci
[681862.320094] usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[681862.320097] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[681862.320098] usb 1-1.2: Product: USB Optical Mouse
[681862.322862] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310C.0006/input/input12
[681862.323105] hid-generic 0003:04B3:310C.0006: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[684353.596384] audit: type=1400 audit(1574229172.204:111): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684353.703363] audit: type=1400 audit(1574229172.308:112): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.647050] audit: type=1400 audit(1574229175.252:113): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.648176] audit: type=1400 audit(1574229175.256:114): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.649364] audit: type=1400 audit(1574229175.256:115): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.740805] audit: type=1400 audit(1574229175.348:116): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=21876 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[685235.232081] usb 1-1.4: new high-speed USB device number 54 using ehci-pci
[685235.340824] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[685235.340828] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[685235.340830] usb 1-1.4: Product: APX
[685235.340832] usb 1-1.4: Manufacturer: NVIDIA Corp.
[685465.661808] usb 1-1.4: USB disconnect, device number 54
[685465.887988] usb 1-1.4: new high-speed USB device number 55 using ehci-pci
[685466.005333] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[685466.005336] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[685466.005337] usb 1-1.4: Product: APX
[685466.005338] usb 1-1.4: Manufacturer: NVIDIA Corp.
[685466.005340] usb 1-1.4: SerialNumber: 00000
[685471.859933] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[685748.539080] usb 1-1.4: USB disconnect, device number 55
[685748.799957] usb 1-1.4: new high-speed USB device number 56 using ehci-pci
[685748.909735] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[685748.909737] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[685748.909739] usb 1-1.4: Product: APX
[685748.909740] usb 1-1.4: Manufacturer: NVIDIA Corp.
[685748.909741] usb 1-1.4: SerialNumber: 00000
[685963.064952] usb 1-1.4: USB disconnect, device number 56
[686139.703199] usb 1-1.2: USB disconnect, device number 53
[686195.224032] usb 1-1.2: new low-speed USB device number 57 using ehci-pci
[686195.335663] usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[686195.335668] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[686195.335671] usb 1-1.2: Product: USB Optical Mouse
[686195.338335] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310C.0007/input/input13
[686195.396323] hid-generic 0003:04B3:310C.0007: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[687052.815926] usb 1-1.3: new full-speed USB device number 58 using ehci-pci
[687052.928728] usb 1-1.3: New USB device found, idVendor=067b, idProduct=2303, bcdDevice= 3.00
[687052.928730] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[687052.928732] usb 1-1.3: Product: USB-Serial Controller
[687052.928733] usb 1-1.3: Manufacturer: Prolific Technology Inc.
[687053.177890] usbcore: registered new interface driver usbserial_generic
[687053.177898] usbserial: USB Serial support registered for generic
[687053.195735] usbcore: registered new interface driver pl2303
[687053.195745] usbserial: USB Serial support registered for pl2303
[687053.195757] pl2303 1-1.3:1.0: pl2303 converter detected
[687053.197301] usb 1-1.3: pl2303 converter now attached to ttyUSB0
[687279.042069] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0008]: -32
[687279.042439] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0009]: -32
[687279.042927] pl2303 ttyUSB0: pl2303_get_line_request - failed: -32
[687279.043302] pl2303 ttyUSB0: pl2303_set_line_request - failed: -32
[687279.043666] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0000]: -32
[687279.043892] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[687279.044056] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -32
[687279.044258] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[687279.044544] pl2303 ttyUSB0: pl2303_get_line_request - failed: -32
[687279.045039] pl2303 ttyUSB0: pl2303_set_line_request - failed: -32
[687279.045412] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0000]: -32
[687279.045787] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -32
[687288.145967] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.645858] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.676190] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.707556] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.738047] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.767930] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.797944] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.829461] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.859552] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.889927] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.919171] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.089308] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.265572] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.410041] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.586457] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.760542] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.920672] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.401691] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.577808] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.752653] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.898073] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.073415] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.573278] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.603801] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.633526] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.663771] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.694010] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.725160] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.754769] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.785426] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.816932] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.846901] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.877014] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.907786] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.938535] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.968761] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.998919] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.028006] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.059657] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.090142] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.119677] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.151055] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.180924] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.210274] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.240769] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.272764] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.302166] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.333549] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.364171] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.394176] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.424255] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.454023] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.484300] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.513270] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.544010] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.574767] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.604167] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.633520] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.664291] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.694947] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.726283] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.755905] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.786389] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.816874] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.846148] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.876281] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.907511] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.937043] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.967288] pl2303 ttyUSB0: usb_serial_generic_write_bu
Hi saques07,
Please check you can see the below USB mode address:
  • Jetson TX2: 192.168.55.1
  • Host Ubuntu: 192.168.55.100
Then you can start install sdk components.
If you still can’t see the USB mode, please try using eth0 ip address to install sdk components.
Hi saques07,
Using ifconfig to check address on your TX2 and host Ubuntu.
When the Jetson is fully booted, and the micro-B USB connects it to the host PC, then the Jetson (in part) becomes a custom network appliance. The host thinks the jetson is a router, and the router assigns address 192.168.55.100 to the host. If this does not occur, then you can verify the attempt to become a network appliance (in part) via monitoring “dmesg --follow” as you insert the cable. If an ethernet device is seen (among other things), then the next step is for the host PC to accept the device.
If you are using a VM this will fail if you haven’t configured to give everything on that USB port to the guest o/s (VMs are not officially supported).
Ubuntu itself may reject other network devices if security gets in the way. The “dmesg --follow” would show the MAC address, and from there you could enable the device from the GUI (there is a config icon in the upper right of the desktop…you’d find the ethernet device with that MAC and allow it).
what GUI are you talking about? Where is the config icon? I can’t see all that.
GUI->The ubuntu desktop
config icon → The ethernet connection setting on the upper right of your desktop.
You could try to use the command “ifconfig” and “dmesg --follow” in terminal on both host PC and tegra device and then share the results with us.
Here is demesg --follow on Host :
[code]dmesg --follow on Host
[81224.998120] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[81905.472190] usb 1-1.2: new high-speed USB device number 10 using ehci-pci
[81905.595756] usb 1-1.2: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[81905.595759] usb 1-1.2: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[81905.595762] usb 1-1.2: Product: Transcend
[81905.595764] usb 1-1.2: Manufacturer: TS-RDF8
[81905.595766] usb 1-1.2: SerialNumber: 000000079
[81905.596308] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[81905.596626] scsi host6: usb-storage 1-1.2:1.0
[81906.605778] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[81906.606683] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[81906.607414] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[81906.607679] sd 6:0:0:0: Attached scsi generic sg2 type 0
[81906.607930] sd 6:0:0:1: Attached scsi generic sg3 type 0
[81906.608242] sd 6:0:0:2: Attached scsi generic sg4 type 0
[81906.903053] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[81906.904001] sd 6:0:0:1: [sdc] Write Protect is off
[81906.904003] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[81906.905374] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[81906.907859] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[81906.910215] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[81906.930260] sdc: sdc1 sdc2
[81906.933614] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[125411.213837] perf: interrupt took too long (5012 > 4936), lowering kernel.perf_event_max_sample_rate to 39750
[146788.882052] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[146788.886992] JFS: nTxBlock = 8192, nTxLock = 65536
[146788.971627] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[146789.019424] QNX4 filesystem 0.2.3 registered.
[146789.080642] raid6: avx2x4 gen() 32765 MB/s
[146789.128642] raid6: avx2x4 xor() 21704 MB/s
[146789.176643] raid6: avx2x2 gen() 29751 MB/s
[146789.224654] raid6: avx2x2 xor() 17791 MB/s
[146789.272641] raid6: avx2x1 gen() 25628 MB/s
[146789.320643] raid6: avx2x1 xor() 17400 MB/s
[146789.368643] raid6: sse2x4 gen() 18341 MB/s
[146789.416660] raid6: sse2x4 xor() 11458 MB/s
[146789.464656] raid6: sse2x2 gen() 15541 MB/s
[146789.512655] raid6: sse2x2 xor() 10068 MB/s
[146789.560661] raid6: sse2x1 gen() 11196 MB/s
[146789.608642] raid6: sse2x1 xor() 9208 MB/s
[146789.608654] raid6: using algorithm avx2x4 gen() 32765 MB/s
[146789.608655] raid6: … xor() 21704 MB/s, rmw enabled
[146789.608656] raid6: using avx2x2 recovery algorithm
[146789.609575] xor: automatically using best checksumming function avx
[146789.622385] Btrfs loaded, crc32c=crc32c-intel
[165048.625942] usb 1-1.2: USB disconnect, device number 10
[165048.737755] FAT-fs (sdc1): unable to read boot sector to mark fs as dirty
[165595.075843] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[166188.779744] radeon_dp_aux_transfer_native: 116 callbacks suppressed
[166194.069906] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[166227.791785] radeon_dp_aux_transfer_native: 74 callbacks suppressed
[166399.131726] radeon_dp_aux_transfer_native: 116 callbacks suppressed
[170274.823443] printk: systemd: 20 output lines suppressed due to ratelimiting
[170274.834851] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[170274.852023] systemd[1]: Detected architecture x86-64.
[170275.145165] systemd[1]: Stopping Journal Service…
[170275.145345] systemd-journald[358]: Received SIGTERM from PID 1 (systemd).
[170275.643183] systemd[1]: Stopped Journal Service.
[170275.646056] systemd[1]: Starting Journal Service…
[170275.980541] systemd[1]: Started Journal Service.
[170502.575839] kauditd_printk_skb: 2 callbacks suppressed
[170502.575840] audit: type=1400 audit(1573715321.159:51): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/snapd/snap-confine” pid=12522 comm=“apparmor_parser”
[170502.595700] audit: type=1400 audit(1573715321.179:52): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=12522 comm=“apparmor_parser”
[170772.321204] audit: type=1400 audit(1573715590.903:53): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170772.334238] audit: type=1400 audit(1573715590.915:54): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.180238] audit: type=1400 audit(1573715593.763:55): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.180947] audit: type=1400 audit(1573715593.763:56): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.181680] audit: type=1400 audit(1573715593.763:57): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=26265 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[170775.182555] audit: type=1400 audit(1573715593.763:58): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=26265 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[174362.852368] audit: type=1400 audit(1573719181.435:59): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.853219] audit: type=1400 audit(1573719181.435:60): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.896140] audit: type=1400 audit(1573719181.479:61): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.896744] audit: type=1400 audit(1573719181.479:62): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.897532] audit: type=1400 audit(1573719181.479:63): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=27441 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[174362.898390] audit: type=1400 audit(1573719181.479:64): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=27441 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[174363.263873] audit: type=1400 audit(1573719181.847:65): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.mozilla/firefox/0qyqj22m.default/cert8.db” pid=27440 comm=“soffice.bin” requested_mask=“w” denied_mask=“w” fsuid=1000 ouid=1000
[174363.274609] audit: type=1400 audit(1573719181.855:66): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.mozilla/firefox/0qyqj22m.default/key3.db” pid=27440 comm=“soffice.bin” requested_mask=“wr” denied_mask=“wr” fsuid=1000 ouid=1000
[178556.263272] e1000e: eno1 NIC Link is Down
[178600.607031] radeon_dp_aux_transfer_native: 74 callbacks suppressed
[179540.074508] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[179553.734984] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[179918.466974] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[179966.619006] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[179991.655222] e1000e: eno1 NIC Link is Down
[180003.754469] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[180060.735001] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[180892.807208] e1000e: eno1 NIC Link is Down
[180896.842443] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[180941.191181] e1000e: eno1 NIC Link is Down
[180953.290431] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[181025.863150] e1000e: eno1 NIC Link is Down
[181033.930831] e1000e: eno1 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[186136.466619] usb 1-1.4: new high-speed USB device number 11 using ehci-pci
[186136.810412] usb 1-1.4: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186136.810415] usb 1-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186136.810417] usb 1-1.4: Product: Transcend
[186136.810419] usb 1-1.4: Manufacturer: TS-RDF8
[186136.810420] usb 1-1.4: SerialNumber: 000000079
[186136.811083] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[186136.811333] scsi host6: usb-storage 1-1.4:1.0
[186137.831650] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186137.832377] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186137.833124] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186137.833571] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186137.833802] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186137.833995] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186138.127781] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186138.129037] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186138.130254] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186138.134152] sd 6:0:0:1: [sdc] Write Protect is off
[186138.134155] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186138.139357] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186138.155389] sdc: sdc1 sdc2
[186138.158870] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[186139.028879] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[186501.597678] FAT-fs (sdc1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[186534.346613] usb 1-1.4: reset high-speed USB device number 11 using ehci-pci
[186535.062996] usb 1-1.4: USB disconnect, device number 11
[186535.086609] sd 6:0:0:1: [sdc] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[186535.086614] sd 6:0:0:1: [sdc] tag#0 CDB: Write(10) 2a 00 00 01 f6 90 00 00 f0 00
[186535.086616] print_req_error: I/O error, dev sdc, sector 128656 flags 4801
[186535.086621] Buffer I/O error on dev sdc1, logical block 15058, lost async page write
[186535.086632] Buffer I/O error on dev sdc1, logical block 15059, lost async page write
[186535.086634] Buffer I/O error on dev sdc1, logical block 15060, lost async page write
[186535.086636] Buffer I/O error on dev sdc1, logical block 15061, lost async page write
[186535.086638] Buffer I/O error on dev sdc1, logical block 15062, lost async page write
[186535.086640] Buffer I/O error on dev sdc1, logical block 15063, lost async page write
[186535.086642] Buffer I/O error on dev sdc1, logical block 15064, lost async page write
[186535.086644] Buffer I/O error on dev sdc1, logical block 15065, lost async page write
[186535.086660] Buffer I/O error on dev sdc1, logical block 15066, lost async page write
[186535.086665] Buffer I/O error on dev sdc1, logical block 15067, lost async page write
[186535.086764] sd 6:0:0:1: [sdc] tag#0 FAILED Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[186535.086767] sd 6:0:0:1: [sdc] tag#0 CDB: Write(10) 2a 00 00 01 f7 80 00 00 80 00
[186535.086769] print_req_error: I/O error, dev sdc, sector 128896 flags 801
[186535.422550] usb 1-1.4: new full-speed USB device number 12 using ehci-pci
[186535.502557] usb 1-1.4: device descriptor read/64, error -32
[186535.690654] usb 1-1.4: device descriptor read/64, error -32
[186535.878616] usb 1-1.4: new full-speed USB device number 13 using ehci-pci
[186535.958574] usb 1-1.4: device descriptor read/64, error -32
[186536.146593] usb 1-1.4: device descriptor read/64, error -32
[186536.254749] usb 1-1-port4: attempt power cycle
[186536.862587] usb 1-1.4: new full-speed USB device number 14 using ehci-pci
[186537.278637] usb 1-1.4: device not accepting address 14, error -32
[186541.630563] usb 1-1.4: new high-speed USB device number 16 using ehci-pci
[186541.754226] usb 1-1.4: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186541.754229] usb 1-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186541.754231] usb 1-1.4: Product: Transcend
[186541.754232] usb 1-1.4: Manufacturer: TS-RDF8
[186541.754233] usb 1-1.4: SerialNumber: 000000079
[186541.754846] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[186541.755079] scsi host6: usb-storage 1-1.4:1.0
[186542.760061] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186542.760877] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186542.761608] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186542.761931] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186542.762130] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186542.762326] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186543.057530] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186543.057900] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186543.060520] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186543.062774] sd 6:0:0:1: [sdc] Write Protect is off
[186543.062776] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186543.066264] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186543.083556] sdc: sdc1 sdc2
[186543.087012] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[186713.566566] EXT4-fs (sdc): VFS: Can’t find ext4 filesystem
[186916.995375] usb 1-1.4: USB disconnect, device number 16
[186922.046555] usb 1-1.4: new high-speed USB device number 17 using ehci-pci
[186922.554562] usb 1-1.4: device not accepting address 17, error -71
[186922.842590] usb 1-1.4: new high-speed USB device number 18 using ehci-pci
[186922.962177] usb 1-1.4: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186922.962179] usb 1-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186922.962180] usb 1-1.4: Product: Transcend
[186922.962181] usb 1-1.4: Manufacturer: TS-RDF8
[186922.962181] usb 1-1.4: SerialNumber: 000000079
[186922.962676] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[186922.962816] scsi host6: usb-storage 1-1.4:1.0
[186923.975554] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186923.976346] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186923.977096] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186923.977348] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186923.977494] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186923.977675] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186924.273174] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186924.275800] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186924.278311] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186924.280549] sd 6:0:0:1: [sdc] Write Protect is off
[186924.280553] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186924.284164] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186924.298575] sdc: sdc1 sdc2
[186924.301909] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[186928.986852] usb 1-1.4: USB disconnect, device number 18
[186940.986582] usb 1-1.3: new high-speed USB device number 19 using ehci-pci
[186941.110256] usb 1-1.3: New USB device found, idVendor=8564, idProduct=4000, bcdDevice= 0.2a
[186941.110259] usb 1-1.3: New USB device strings: Mfr=3, Product=4, SerialNumber=5
[186941.110260] usb 1-1.3: Product: Transcend
[186941.110262] usb 1-1.3: Manufacturer: TS-RDF8
[186941.110263] usb 1-1.3: SerialNumber: 000000079
[186941.110797] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[186941.110966] scsi host6: usb-storage 1-1.3:1.0
[186942.119822] scsi 6:0:0:0: Direct-Access TS-RDF8 CF Transcend TS2A PQ: 0 ANSI: 6
[186942.120655] scsi 6:0:0:1: Direct-Access TS-RDF8 SD Transcend TS2A PQ: 0 ANSI: 6
[186942.121430] scsi 6:0:0:2: Direct-Access TS-RDF8 MS Transcend TS2A PQ: 0 ANSI: 6
[186942.121867] sd 6:0:0:0: Attached scsi generic sg2 type 0
[186942.122120] sd 6:0:0:1: Attached scsi generic sg3 type 0
[186942.122389] sd 6:0:0:2: Attached scsi generic sg4 type 0
[186942.417382] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[186942.417746] sd 6:0:0:1: [sdc] 31116288 512-byte logical blocks: (15.9 GB/14.8 GiB)
[186942.418744] sd 6:0:0:1: [sdc] Write Protect is off
[186942.418746] sd 6:0:0:1: [sdc] Mode Sense: 21 00 00 00
[186942.419975] sd 6:0:0:2: [sdd] Attached SCSI removable disk
[186942.423483] sd 6:0:0:1: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[186942.442868] sdc: sdc1 sdc2
[186942.446216] sd 6:0:0:1: [sdc] Attached SCSI removable disk
[188030.032082] usb 1-1.1: USB disconnect, device number 9
[188034.102465] usb 1-1.2: new low-speed USB device number 20 using ehci-pci
[188034.218538] usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[188034.218540] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[188034.218542] usb 1-1.2: Product: USB Optical Mouse
[188034.223516] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310C.0004/input/input10
[188034.223729] hid-generic 0003:04B3:310C.0004: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[188038.469583] usb 2-1.4: USB disconnect, device number 4
[188044.082537] usb 1-1.1: new low-speed USB device number 21 using ehci-pci
[188044.204024] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.06
[188044.204027] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[188044.204787] usb 1-1.1: can’t set config #1, error -32
[188044.367913] usb 1-1.1: USB disconnect, device number 21
[188044.598534] usb 1-1.1: new low-speed USB device number 22 using ehci-pci
[188045.098506] usb 1-1.1: device not accepting address 22, error -32
[188045.386549] usb 1-1.1: new low-speed USB device number 23 using ehci-pci
[188045.508844] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.06
[188045.508847] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[188045.508849] usb 1-1.1: Product: Dell USB Keyboard
[188045.508850] usb 1-1.1: Manufacturer: Dell
[188045.512931] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2003.0005/input/input11
[188045.571039] hid-generic 0003:413C:2003.0005: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1a.0-1.1/input0
[188272.205819] usb 1-1.3: USB disconnect, device number 19
[198125.804966] audit: type=1400 audit(1573742944.386:67): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap-update-ns.gnome-system-monitor” pid=8301 comm=“apparmor_parser”
[198126.022867] audit: type=1400 audit(1573742944.606:68): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-system-monitor.gnome-system-monitor” pid=8302 comm=“apparmor_parser”
[198126.234609] audit: type=1400 audit(1573742944.818:69): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine” pid=8304 comm=“apparmor_parser”
[198126.234613] audit: type=1400 audit(1573742944.818:70): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=8304 comm=“apparmor_parser”
[198126.300701] audit: type=1400 audit(1573742944.882:71): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.core” pid=8306 comm=“apparmor_parser”
[198126.326176] audit: type=1400 audit(1573742944.910:72): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap.core.hook.configure” pid=8307 comm=“apparmor_parser”
[198142.102232] audit: type=1400 audit(1573742960.686:73): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap-update-ns.gnome-characters” pid=8320 comm=“apparmor_parser”
[198142.148536] audit: type=1400 audit(1573742960.730:74): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-characters.gnome-characters” pid=8321 comm=“apparmor_parser”
[198142.291857] audit: type=1400 audit(1573742960.874:75): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine” pid=8323 comm=“apparmor_parser”
[198142.291866] audit: type=1400 audit(1573742960.874:76): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“/snap/core/8039/usr/lib/snapd/snap-confine//mount-namespace-capture-helper” pid=8323 comm=“apparmor_parser”
[198142.297348] audit: type=1400 audit(1573742960.878:77): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.core” pid=8325 comm=“apparmor_parser”
[198142.298280] audit: type=1400 audit(1573742960.882:78): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap.core.hook.configure” pid=8326 comm=“apparmor_parser”
[211640.747471] audit: type=1400 audit(1573756459.330:79): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-calculator.gnome-calculator” pid=19215 comm=“apparmor_parser”
[211640.794468] audit: type=1400 audit(1573756459.378:80): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-calculator” pid=19214 comm=“apparmor_parser”
[211641.330782] audit: type=1400 audit(1573756459.914:81): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-characters” pid=19217 comm=“apparmor_parser”
[211641.391055] audit: type=1400 audit(1573756459.974:82): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-characters.gnome-characters” pid=19218 comm=“apparmor_parser”
[211641.874978] audit: type=1400 audit(1573756460.458:83): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-logs” pid=19221 comm=“apparmor_parser”
[211641.962789] audit: type=1400 audit(1573756460.546:84): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-logs.gnome-logs” pid=19222 comm=“apparmor_parser”
[211642.460957] audit: type=1400 audit(1573756461.042:85): apparmor=“STATUS” operation=“profile_replace” info=“same as current profile, skipping” profile=“unconfined” name=“snap-update-ns.gnome-system-monitor” pid=19224 comm=“apparmor_parser”
[211642.533540] audit: type=1400 audit(1573756461.118:86): apparmor=“STATUS” operation=“profile_replace” profile=“unconfined” name=“snap.gnome-system-monitor.gnome-system-monitor” pid=19225 comm=“apparmor_parser”
[246973.535411] usb 2-1.3: new high-speed USB device number 5 using ehci-pci
[246973.645170] usb 2-1.3: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[246973.645172] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[246973.645173] usb 2-1.3: Product: Android
[246973.645174] usb 2-1.3: Manufacturer: Android
[246973.645175] usb 2-1.3: SerialNumber: 5c4626f7d140
[249662.506501] usb 2-1.3: USB disconnect, device number 5
[250014.943293] usb 2-1.3: new high-speed USB device number 6 using ehci-pci
[250015.060761] usb 2-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[250015.060765] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[250015.060767] usb 2-1.3: Product: APX
[250015.060769] usb 2-1.3: Manufacturer: NVIDIA Corp.
[250157.378125] usb 2-1.3: USB disconnect, device number 6
[257906.393412] audit: type=1400 audit(1573802724.976:87): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257906.498001] audit: type=1400 audit(1573802725.080:88): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.219834] audit: type=1400 audit(1573802725.804:89): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.220494] audit: type=1400 audit(1573802725.804:90): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.221207] audit: type=1400 audit(1573802725.804:91): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=31910 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[257907.222070] audit: type=1400 audit(1573802725.804:92): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=31910 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[257911.977617] audit: type=1400 audit(1573802730.560:93): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/profiles.ini” pid=31909 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=1000
[257912.030642] audit: type=1400 audit(1573802730.612:94): apparmor=“ALLOWED” operation=“mknod” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/secmod.db” pid=31909 comm=“soffice.bin” requested_mask=“c” denied_mask=“c” fsuid=1000 ouid=1000
[257912.030645] audit: type=1400 audit(1573802730.612:95): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/secmod.db” pid=31909 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[257912.032571] audit: type=1400 audit(1573802730.616:96): apparmor=“ALLOWED” operation=“mknod” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/cert8.db” pid=31909 comm=“soffice.bin” requested_mask=“c” denied_mask=“c” fsuid=1000 ouid=1000
[257912.032574] audit: type=1400 audit(1573802730.616:97): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/cert8.db” pid=31909 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[257912.032673] audit: type=1400 audit(1573802730.616:98): apparmor=“ALLOWED” operation=“mknod” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/key3.db” pid=31909 comm=“soffice.bin” requested_mask=“c” denied_mask=“c” fsuid=1000 ouid=1000
[257912.032675] audit: type=1400 audit(1573802730.616:99): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.thunderbird/hgaxzttz.default/key3.db” pid=31909 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[258225.131986] audit: type=1400 audit(1573803043.716:100): apparmor=“ALLOWED” operation=“connect” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“wr” denied_mask=“wr” fsuid=1000 ouid=1000
[258225.131988] audit: type=1400 audit(1573803043.716:101): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=1000
[258225.131990] audit: type=1400 audit(1573803043.716:102): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=1000
[258225.132086] audit: type=1400 audit(1573803043.716:103): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“w” denied_mask=“w” fsuid=1000 ouid=1000
[258225.132088] audit: type=1400 audit(1573803043.716:104): apparmor=“ALLOWED” operation=“file_perm” profile=“libreoffice-oopslash” name=“/tmp/OSL_PIPE_1000_SingleOfficeIPC_5a48eaee636ee1964b7758cf8e5127e” pid=31969 comm=“oosplash” requested_mask=“w” denied_mask=“w” fsuid=1000 ouid=1000
[264883.518477] usb 1-1.4: new high-speed USB device number 24 using ehci-pci
[264883.627356] usb 1-1.4: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[264883.627359] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[264883.627361] usb 1-1.4: Product: Android
[264883.627362] usb 1-1.4: Manufacturer: Android
[264883.627364] usb 1-1.4: SerialNumber: 5c4626f7d140
[264915.549758] usb 1-1.4: USB disconnect, device number 24
[265568.986197] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[267490.850377] usb 1-1.3: new high-speed USB device number 25 using ehci-pci
[267490.959635] usb 1-1.3: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
[267490.959637] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[267490.959638] usb 1-1.3: Product: Ultra
[267490.959639] usb 1-1.3: Manufacturer: SanDisk
[267490.959639] usb 1-1.3: SerialNumber: 4C530000101225107093
[267490.959907] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[267490.960122] scsi host6: usb-storage 1-1.3:1.0
[267491.971552] scsi 6:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[267491.971952] sd 6:0:0:0: Attached scsi generic sg2 type 0
[267491.972527] sd 6:0:0:0: [sdb] 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
[267491.973769] sd 6:0:0:0: [sdb] Write Protect is off
[267491.973771] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[267491.974782] sd 6:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[267491.985237] sdb: sdb1
[267491.989013] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[267500.277961] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[267594.819475] usb 1-1.3: USB disconnect, device number 25
[271848.438125] usb 1-1.4: new high-speed USB device number 26 using ehci-pci
[271848.547748] usb 1-1.4: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[271848.547751] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[271848.547753] usb 1-1.4: Product: Android
[271848.547754] usb 1-1.4: Manufacturer: Android
[271848.547755] usb 1-1.4: SerialNumber: 5c4626f7d140
[271857.177648] usb 1-1.4: USB disconnect, device number 26
[439250.317183] usb 1-1.4: new high-speed USB device number 27 using ehci-pci
[439250.431064] usb 1-1.4: New USB device found, idVendor=0781, idProduct=5581, bcdDevice= 1.00
[439250.431067] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[439250.431068] usb 1-1.4: Product: Ultra
[439250.431069] usb 1-1.4: Manufacturer: SanDisk
[439250.431071] usb 1-1.4: SerialNumber: 4C530000101225107093
[439250.431409] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[439250.431700] scsi host6: usb-storage 1-1.4:1.0
[439251.450560] scsi 6:0:0:0: Direct-Access SanDisk Ultra 1.00 PQ: 0 ANSI: 6
[439251.451102] sd 6:0:0:0: Attached scsi generic sg2 type 0
[439251.451634] sd 6:0:0:0: [sdb] 60063744 512-byte logical blocks: (30.8 GB/28.6 GiB)
[439251.452886] sd 6:0:0:0: [sdb] Write Protect is off
[439251.452888] sd 6:0:0:0: [sdb] Mode Sense: 43 00 00 00
[439251.453914] sd 6:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[439251.464035] sdb: sdb1
[439251.467850] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[439253.413298] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[439622.826736] usb 1-1.4: USB disconnect, device number 27
[525419.328557] usb 1-1.4: new high-speed USB device number 28 using ehci-pci
[525419.438130] usb 1-1.4: New USB device found, idVendor=05c6, idProduct=9092, bcdDevice= 3.18
[525419.438133] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[525419.438134] usb 1-1.4: Product: Android
[525419.438136] usb 1-1.4: Manufacturer: Android
[525419.438137] usb 1-1.4: SerialNumber: 5c4626f7d140
[525485.408017] usb 1-1.4: USB disconnect, device number 28
[526648.628506] usb 1-1.3: new high-speed USB device number 29 using ehci-pci
[526648.741342] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[526648.741344] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[526648.741346] usb 1-1.3: Product: APX
[526648.741347] usb 1-1.3: Manufacturer: NVIDIA Corp.
[529386.297861] usb 1-1.3: USB disconnect, device number 29
[530138.544596] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[592085.681026] usb 1-1.3: new high-speed USB device number 30 using ehci-pci
[592085.790529] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592085.790533] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[592085.790535] usb 1-1.3: Product: APX
[592085.790536] usb 1-1.3: Manufacturer: NVIDIA Corp.
[592142.289909] usb 1-1.3: USB disconnect, device number 30
[592142.524941] usb 1-1.3: new high-speed USB device number 31 using ehci-pci
[592142.634019] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592142.634021] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[592142.634022] usb 1-1.3: Product: APX
[592142.634023] usb 1-1.3: Manufacturer: NVIDIA Corp.
[592142.634023] usb 1-1.3: SerialNumber: 00000
[592149.113334] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[592463.054679] usb 1-1.3: USB disconnect, device number 31
[592463.276943] usb 1-1.3: new high-speed USB device number 32 using ehci-pci
[592463.389851] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592463.389853] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[592463.389853] usb 1-1.3: Product: APX
[592463.389854] usb 1-1.3: Manufacturer: NVIDIA Corp.
[592463.389855] usb 1-1.3: SerialNumber: 00000
[592681.932458] usb 1-1.3: USB disconnect, device number 32
[592843.436981] usb 1-1.3: new high-speed USB device number 33 using ehci-pci
[592843.546279] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[592843.546285] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[592843.546289] usb 1-1.3: Product: APX
[592843.546291] usb 1-1.3: Manufacturer: NVIDIA Corp.
[593115.848207] usb 1-1.3: USB disconnect, device number 33
[593116.068931] usb 1-1.3: new high-speed USB device number 34 using ehci-pci
[593116.186102] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[593116.186104] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[593116.186105] usb 1-1.3: Product: APX
[593116.186107] usb 1-1.3: Manufacturer: NVIDIA Corp.
[593116.186108] usb 1-1.3: SerialNumber: 00000
[593122.054879] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[593381.061602] usb 1-1.3: USB disconnect, device number 34
[593381.356906] usb 1-1.3: new high-speed USB device number 35 using ehci-pci
[593381.466475] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[593381.466478] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[593381.466480] usb 1-1.3: Product: APX
[593381.466482] usb 1-1.3: Manufacturer: NVIDIA Corp.
[593381.466484] usb 1-1.3: SerialNumber: 00000
[593596.611486] usb 1-1.3: USB disconnect, device number 35
[595340.176818] usb 1-1.3: new high-speed USB device number 36 using ehci-pci
[595340.286327] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595340.286330] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595340.286331] usb 1-1.3: Product: APX
[595340.286333] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595569.584157] usb 1-1.3: USB disconnect, device number 36
[595573.136830] usb 1-1.3: new high-speed USB device number 37 using ehci-pci
[595573.245597] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595573.245603] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595573.245606] usb 1-1.3: Product: APX
[595573.245609] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595597.231885] usb 1-1.3: USB disconnect, device number 37
[595597.532799] usb 1-1.3: new high-speed USB device number 38 using ehci-pci
[595597.642014] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595597.642016] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595597.642018] usb 1-1.3: Product: APX
[595597.642019] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595597.999872] usb 1-1.3: USB disconnect, device number 38
[595599.244776] usb 1-1.3: new high-speed USB device number 39 using ehci-pci
[595599.357869] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595599.357871] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595599.357873] usb 1-1.3: Product: APX
[595599.357874] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595599.535838] usb 1-1.3: USB disconnect, device number 39
[595602.316794] usb 1-1.3: new high-speed USB device number 40 using ehci-pci
[595602.426301] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[595602.426305] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[595602.426306] usb 1-1.3: Product: APX
[595602.426308] usb 1-1.3: Manufacturer: NVIDIA Corp.
[595766.702224] usb 1-1.3: USB disconnect, device number 40
[598963.056666] usb 1-1.3: new high-speed USB device number 41 using ehci-pci
[598963.165617] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[598963.165621] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[598963.165623] usb 1-1.3: Product: APX
[598963.165624] usb 1-1.3: Manufacturer: NVIDIA Corp.
[598967.694792] usb 1-1.3: USB disconnect, device number 41
[598971.244622] usb 1-1.3: new high-speed USB device number 42 using ehci-pci
[598971.357356] usb 1-1.3: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[598971.357358] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[598971.357359] usb 1-1.3: Product: APX
[598971.357360] usb 1-1.3: Manufacturer: NVIDIA Corp.
[599268.235991] usb 1-1.3: USB disconnect, device number 42
[615904.967215] [drm:btc_dpm_set_power_state [radeon]] ERROR rv770_restrict_performance_levels_before_switch failed
[617088.142573] audit: type=1400 audit(1574161906.746:105): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617088.283140] audit: type=1400 audit(1574161906.886:106): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.085278] audit: type=1400 audit(1574161909.690:107): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.086121] audit: type=1400 audit(1574161909.690:108): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.087276] audit: type=1400 audit(1574161909.690:109): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=10777 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[617091.107198] audit: type=1400 audit(1574161909.710:110): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=10777 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[619337.891543] usb 1-1.4: new high-speed USB device number 43 using ehci-pci
[619338.000916] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[619338.000918] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[619338.000919] usb 1-1.4: Product: APX
[619338.000920] usb 1-1.4: Manufacturer: NVIDIA Corp.
[619923.393439] usb 1-1.4: USB disconnect, device number 43
[620247.547543] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[674868.360575] usb 1-1.4: new high-speed USB device number 44 using ehci-pci
[674868.469591] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[674868.469593] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[674868.469595] usb 1-1.4: Product: APX
[674868.469596] usb 1-1.4: Manufacturer: NVIDIA Corp.
[674941.605111] usb 1-1.4: USB disconnect, device number 44
[674941.832540] usb 1-1.4: new high-speed USB device number 45 using ehci-pci
[674941.941847] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[674941.941850] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[674941.941852] usb 1-1.4: Product: APX
[674941.941854] usb 1-1.4: Manufacturer: NVIDIA Corp.
[674941.941855] usb 1-1.4: SerialNumber: 00000
[674947.406778] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[675246.754265] usb 1-1.4: USB disconnect, device number 45
[675246.976513] usb 1-1.4: new high-speed USB device number 46 using ehci-pci
[675247.093483] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675247.093486] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[675247.093488] usb 1-1.4: Product: APX
[675247.093489] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675247.093491] usb 1-1.4: SerialNumber: 00000
[675459.488059] usb 1-1.4: USB disconnect, device number 46
[675580.288581] usb 1-1.4: new high-speed USB device number 47 using ehci-pci
[675580.397483] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675580.397487] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[675580.397490] usb 1-1.4: Product: APX
[675580.397493] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675722.397485] usb 1-1.4: USB disconnect, device number 47
[675722.628515] usb 1-1.4: new high-speed USB device number 48 using ehci-pci
[675722.741723] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675722.741725] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[675722.741726] usb 1-1.4: Product: APX
[675722.741727] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675722.741727] usb 1-1.4: SerialNumber: 00000
[675728.730547] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[675996.314771] usb 1-1.4: USB disconnect, device number 48
[675996.612487] usb 1-1.4: new high-speed USB device number 49 using ehci-pci
[675996.721364] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[675996.721366] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[675996.721366] usb 1-1.4: Product: APX
[675996.721367] usb 1-1.4: Manufacturer: NVIDIA Corp.
[675996.721368] usb 1-1.4: SerialNumber: 00000
[676210.072651] usb 1-1.4: USB disconnect, device number 49
[678560.032449] radeon_dp_aux_transfer_native: 32 callbacks suppressed
[680275.792327] usb 1-1.4: new high-speed USB device number 50 using ehci-pci
[680275.901424] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[680275.901428] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[680275.901429] usb 1-1.4: Product: APX
[680275.901431] usb 1-1.4: Manufacturer: NVIDIA Corp.
[680505.710504] usb 1-1.4: USB disconnect, device number 50
[680505.936258] usb 1-1.4: new high-speed USB device number 51 using ehci-pci
[680506.045898] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[680506.045902] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[680506.045904] usb 1-1.4: Product: APX
[680506.045906] usb 1-1.4: Manufacturer: NVIDIA Corp.
[680506.045907] usb 1-1.4: SerialNumber: 00000
[680511.876587] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[680778.859827] usb 1-1.4: USB disconnect, device number 51
[680779.096218] usb 1-1.4: new high-speed USB device number 52 using ehci-pci
[680779.205180] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[680779.205182] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[680779.205183] usb 1-1.4: Product: APX
[680779.205184] usb 1-1.4: Manufacturer: NVIDIA Corp.
[680779.205185] usb 1-1.4: SerialNumber: 00000
[680994.409692] usb 1-1.4: USB disconnect, device number 52
[681834.081627] usb 1-1.2: USB disconnect, device number 20
[681862.208198] usb 1-1.2: new low-speed USB device number 53 using ehci-pci
[681862.320094] usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[681862.320097] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[681862.320098] usb 1-1.2: Product: USB Optical Mouse
[681862.322862] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310C.0006/input/input12
[681862.323105] hid-generic 0003:04B3:310C.0006: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[684353.596384] audit: type=1400 audit(1574229172.204:111): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684353.703363] audit: type=1400 audit(1574229172.308:112): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.647050] audit: type=1400 audit(1574229175.252:113): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.648176] audit: type=1400 audit(1574229175.256:114): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.649364] audit: type=1400 audit(1574229175.256:115): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/usr/share/drirc.d/00-mesa-defaults.conf” pid=21876 comm=“soffice.bin” requested_mask=“r” denied_mask=“r” fsuid=1000 ouid=0
[684356.740805] audit: type=1400 audit(1574229175.348:116): apparmor=“ALLOWED” operation=“open” profile=“libreoffice-soffice” name=“/home/ashish/.cache/mesa_shader_cache/index” pid=21876 comm=“soffice.bin” requested_mask=“wrc” denied_mask=“wrc” fsuid=1000 ouid=1000
[685235.232081] usb 1-1.4: new high-speed USB device number 54 using ehci-pci
[685235.340824] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[685235.340828] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[685235.340830] usb 1-1.4: Product: APX
[685235.340832] usb 1-1.4: Manufacturer: NVIDIA Corp.
[685465.661808] usb 1-1.4: USB disconnect, device number 54
[685465.887988] usb 1-1.4: new high-speed USB device number 55 using ehci-pci
[685466.005333] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[685466.005336] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[685466.005337] usb 1-1.4: Product: APX
[685466.005338] usb 1-1.4: Manufacturer: NVIDIA Corp.
[685466.005340] usb 1-1.4: SerialNumber: 00000
[685471.859933] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[685748.539080] usb 1-1.4: USB disconnect, device number 55
[685748.799957] usb 1-1.4: new high-speed USB device number 56 using ehci-pci
[685748.909735] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[685748.909737] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[685748.909739] usb 1-1.4: Product: APX
[685748.909740] usb 1-1.4: Manufacturer: NVIDIA Corp.
[685748.909741] usb 1-1.4: SerialNumber: 00000
[685963.064952] usb 1-1.4: USB disconnect, device number 56
[686139.703199] usb 1-1.2: USB disconnect, device number 53
[686195.224032] usb 1-1.2: new low-speed USB device number 57 using ehci-pci
[686195.335663] usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[686195.335668] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[686195.335671] usb 1-1.2: Product: USB Optical Mouse
[686195.338335] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310C.0007/input/input13
[686195.396323] hid-generic 0003:04B3:310C.0007: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[687052.815926] usb 1-1.3: new full-speed USB device number 58 using ehci-pci
[687052.928728] usb 1-1.3: New USB device found, idVendor=067b, idProduct=2303, bcdDevice= 3.00
[687052.928730] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[687052.928732] usb 1-1.3: Product: USB-Serial Controller
[687052.928733] usb 1-1.3: Manufacturer: Prolific Technology Inc.
[687053.177890] usbcore: registered new interface driver usbserial_generic
[687053.177898] usbserial: USB Serial support registered for generic
[687053.195735] usbcore: registered new interface driver pl2303
[687053.195745] usbserial: USB Serial support registered for pl2303
[687053.195757] pl2303 1-1.3:1.0: pl2303 converter detected
[687053.197301] usb 1-1.3: pl2303 converter now attached to ttyUSB0
[687279.042069] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0008]: -32
[687279.042439] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0009]: -32
[687279.042927] pl2303 ttyUSB0: pl2303_get_line_request - failed: -32
[687279.043302] pl2303 ttyUSB0: pl2303_set_line_request - failed: -32
[687279.043666] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0000]: -32
[687279.043892] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[687279.044056] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -32
[687279.044258] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[687279.044544] pl2303 ttyUSB0: pl2303_get_line_request - failed: -32
[687279.045039] pl2303 ttyUSB0: pl2303_set_line_request - failed: -32
[687279.045412] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0000]: -32
[687279.045787] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -32
[687288.145967] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.645858] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.676190] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.707556] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.738047] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.767930] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.797944] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.829461] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.859552] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.889927] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687288.919171] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.089308] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.265572] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.410041] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.586457] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.760542] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687289.920672] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.401691] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.577808] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.752653] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687290.898073] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.073415] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.573278] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.603801] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.633526] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.663771] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.694010] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.725160] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.754769] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.785426] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.816932] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.846901] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.877014] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.907786] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.938535] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.968761] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687291.998919] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.028006] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.059657] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.090142] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.119677] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.151055] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.180924] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.210274] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.240769] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.272764] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.302166] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.333549] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.364171] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.394176] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.424255] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.454023] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.484300] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.513270] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.544010] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.574767] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.604167] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.633520] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.664291] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.694947] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.726283] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.755905] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.786389] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.816874] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.846148] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.876281] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.907511] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.937043] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.967288] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687292.997804] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.028165] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.058772] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.089379] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.119671] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.151289] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.181413] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.212288] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.242259] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.272395] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687293.302031] pl2303 ttyUSB0: usb_serial_generic_
Untitled Document 3.txt (2.17 KB)
[687358.183130] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687358.213380] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687392.192665] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687397.450280] pl2303 ttyUSB0: error sending break = -32
[687418.665324] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0008]: -32
[687418.665653] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0009]: -32
[687418.666017] pl2303 ttyUSB0: pl2303_get_line_request - failed: -32
[687418.666394] pl2303 ttyUSB0: pl2303_set_line_request - failed: -32
[687418.666781] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0000]: -32
[687418.666900] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[687418.667175] pl2303 ttyUSB0: pl2303_set_control_lines - failed: -32
[687418.667386] pl2303 ttyUSB0: usb_serial_generic_read_bulk_callback - urb stopped: -32
[687418.667657] pl2303 ttyUSB0: pl2303_get_line_request - failed: -32
[687418.668156] pl2303 ttyUSB0: pl2303_set_line_request - failed: -32
[687418.668533] pl2303 1-1.3:1.0: pl2303_vendor_write - failed to write [0000]: -32
[687431.998259] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687432.190429] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687437.107907] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687438.560963] pl2303 ttyUSB0: usb_serial_generic_write_bulk_callback - urb stopped: -32
[687608.104825] usb 1-1.3: USB disconnect, device number 58
[687608.107131] pl2303 ttyUSB0: error sending break = -19
[687608.107333] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[687608.107349] pl2303 1-1.3:1.0: device disconnected
[687619.591956] usb 1-1.3: new full-speed USB device number 59 using ehci-pci
[687625.995916] usb 1-1.3: new full-speed USB device number 60 using ehci-pci
[687626.075896] usb 1-1.3: device descriptor read/64, error -32
[687626.263934] usb 1-1.3: device descriptor read/64, error -32
[687626.451947] usb 1-1.3: new full-speed USB device number 61 using ehci-pci
[687626.564898] usb 1-1.3: New USB device found, idVendor=067b, idProduct=2303, bcdDevice= 3.00
[687626.564901] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[687626.564904] usb 1-1.3: Product: USB-Serial Controller
[687626.564905] usb 1-1.3: Manufacturer: Prolific Technology Inc.
[687626.565371] pl2303 1-1.3:1.0: pl2303 converter detected
[687626.567008] usb 1-1.3: pl2303 converter now attached to ttyUSB0
[687707.175840] usb 1-1.3: USB disconnect, device number 61
[687707.176081] pl2303 ttyUSB0: pl2303 converter now disconnected from ttyUSB0
[687707.176101] pl2303 1-1.3:1.0: device disconnected
[687708.683854] usb 1-1.3: new full-speed USB device number 62 using ehci-pci
[687708.763939] usb 1-1.3: device descriptor read/64, error -32
[687709.903917] usb 1-1.3: new full-speed USB device number 63 using ehci-pci
[687710.012778] usb 1-1.3: New USB device found, idVendor=067b, idProduct=2303, bcdDevice= 3.00
[687710.012779] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[687710.012780] usb 1-1.3: Product: USB-Serial Controller
[687710.012781] usb 1-1.3: Manufacturer: Prolific Technology Inc.
[687710.013066] pl2303 1-1.3:1.0: pl2303 converter detected
[687710.014467] usb 1-1.3: pl2303 converter now attached to ttyUSB0
[688854.523793] usb 1-1.4: new high-speed USB device number 64 using ehci-pci
[688854.633760] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[688854.633763] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[688854.633765] usb 1-1.4: Product: APX
[688854.633766] usb 1-1.4: Manufacturer: NVIDIA Corp.
[689207.833115] usb 1-1.4: USB disconnect, device number 64
[689208.059769] usb 1-1.4: new high-speed USB device number 65 using ehci-pci
[689208.169727] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[689208.169729] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[689208.169731] usb 1-1.4: Product: APX
[689208.169732] usb 1-1.4: Manufacturer: NVIDIA Corp.
[689208.169733] usb 1-1.4: SerialNumber: 00000
[689214.193429] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[689480.470281] usb 1-1.4: USB disconnect, device number 65
[689480.815731] usb 1-1.4: new high-speed USB device number 66 using ehci-pci
[689480.925058] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[689480.925061] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[689480.925063] usb 1-1.4: Product: APX
[689480.925065] usb 1-1.4: Manufacturer: NVIDIA Corp.
[689480.925066] usb 1-1.4: SerialNumber: 00000
[689730.067828] usb 1-1.4: USB disconnect, device number 66
[689958.929791] usb 1-1.2: USB disconnect, device number 57
[689999.087752] usb 1-1.2: new low-speed USB device number 67 using ehci-pci
[689999.207562] usb 1-1.2: New USB device found, idVendor=04b3, idProduct=310c, bcdDevice= 2.00
[689999.207563] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[689999.207565] usb 1-1.2: Product: USB Optical Mouse
[689999.209852] input: USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04B3:310C.0008/input/input14
[689999.210028] hid-generic 0003:04B3:310C.0008: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-0000:00:1a.0-1.2/input0
[694925.503506] usb 1-1.4: new high-speed USB device number 68 using ehci-pci
[694925.617374] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[694925.617377] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[694925.617379] usb 1-1.4: Product: APX
[694925.617381] usb 1-1.4: Manufacturer: NVIDIA Corp.
[694951.136734] usb 1-1.4: USB disconnect, device number 68
[694951.359494] usb 1-1.4: new high-speed USB device number 69 using ehci-pci
[694951.477502] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[694951.477505] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[694951.477507] usb 1-1.4: Product: APX
[694951.477508] usb 1-1.4: Manufacturer: NVIDIA Corp.
[694951.477509] usb 1-1.4: SerialNumber: 00000
[694957.288288] EXT4-fs (loop11): mounted filesystem with ordered data mode. Opts: (null)
[695259.869727] usb 1-1.4: USB disconnect, device number 69
[695260.091451] usb 1-1.4: new high-speed USB device number 70 using ehci-pci
[695260.200428] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[695260.200431] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[695260.200432] usb 1-1.4: Product: APX
[695260.200434] usb 1-1.4: Manufacturer: NVIDIA Corp.
[695260.200435] usb 1-1.4: SerialNumber: 00000
[695475.931602] usb 1-1.4: USB disconnect, device number 70
[696455.603422] usb 1-1.4: new high-speed USB device number 71 using ehci-pci
[696455.712209] usb 1-1.4: New USB device found, idVendor=0955, idProduct=7c18, bcdDevice= 0.00
[696455.712210] usb 1-1.4: New USB device st
[quote=“”]
Here is ifconfig on Host:
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 172.27.42.95  netmask 255.255.0.0  broadcast 172.27.255.255
        inet6 fe80::e2a2:a89e:a3e2:4106  prefixlen 64  scopeid 0x20<link>
        ether f8:b1:56:9a:0d:96  txqueuelen 1000  (Ethernet)
        RX packets 221679183  bytes 104581271221 (104.5 GB)
        RX errors 0  dropped 35  overruns 0  frame 0
        TX packets 21265640  bytes 8807187176 (8.8 GB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xf7f00000-f7f20000
enp5s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:0a:f7:2b:af:0a  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        device interrupt 18
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 2045680  bytes 427615911 (427.6 MB)
        TX packets 2045680  bytes 427615911 (427.6 MB)
Here is ifconfig on Jetson TX2 (target):
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:04:4b:c6:bd:a9  txqueuelen 1000  (Ethernet)
        device interrupt 41
l4tbr0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 192.168.55.1  netmask 255.255.255.0  broadcast 192.168.55.255
        inet6 fe80::1  prefixlen 128  scopeid 0x20<link>
        inet6 fe80::24e5:ff:fe46:e5b6  prefixlen 64  scopeid 0x20<link>
        ether 2a:f4:6c:cd:f6:ad  txqueuelen 1000  (Ethernet)
        TX packets 10  bytes 892 (892.0 B)
        loop  txqueuelen 1  (Local Loopback)
        RX packets 3902  bytes 279318 (279.3 KB)
        TX packets 3902  bytes 279318 (279.3 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
usb0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 2a:f4:6c:cd:f6:af  txqueuelen 1000  (Ethernet)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:04:4b:c6:bd:a7  txqueuelen 1000  (Ethernet)
Here is dmesg --follow on Jetson TX2:
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.9.140 (auvidea@auvidea-T5600) (gcc version 6.4.1 20170707 (Linaro GCC 6.4-2017.08) ) #1 SMP PREEMPT Fri May 17 15:57:52 CEST 2019
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[    0.000000] OF: fdt: - 80000000 ,  70000000
[    0.000000] OF: fdt: - f0200000 ,  185600000
[    0.000000] OF: fdt: - 275e00000 ,  200000
[    0.000000] OF: fdt: - 276600000 ,  200000
[    0.000000] OF: fdt: - 277000000 ,  200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] On node 0 totalpages: 2055168
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 523776 pages, LIFO batch:31
[    0.000000]   Normal zone: 24008 pages used for memmap
[    0.000000]   Normal zone: 1531392 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 23 pages/cpu @ffffffc1f6776000 s53400 r8192 d32616 u94208
[    0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2022968
[    0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.983055.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29484(89%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Memory: 7974752K/8220672K available (15038K kernel code, 2912K rwdata, 6728K rodata, 8512K init, 607K bss, 180384K reserved, 65536K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f30000   ( 15040 KB)
[    0.000000]     .rodata : 0xffffff8008f30000 - 0xffffff80095d0000   (  6784 KB)
[    0.000000]       .init : 0xffffff80095d0000 - 0xffffff8009e20000   (  8512 KB)
[    0.000000]       .data : 0xffffff8009e20000 - 0xffffff800a0f8008   (  2913 KB)
[    0.000000]        .bss : 0xffffff800a0f8008 - 0xffffff800a18fe3c   (   608 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf07dc8000   (   125 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc1f7200000   (  8050 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.010016] Console: colour dummy device 80x25
[    0.014678] console [tty0] enabled
[    0.018235] bootconsole [uart8250] disabled
[    0.022610] kmemleak: Kernel memory leak detector disabled
[    0.022626] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.022639] pid_max: default: 32768 minimum: 301
[    0.022960] Security Framework initialized
[    0.023124] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.023135] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[    0.023732] ftrace: allocating 46769 entries in 183 pages
[    0.147684] sched-energy: Sched-energy-costs installed from DT
[    0.147704] ASID allocator initialised with 65536 entries
[    0.184261] tegra-id: chipid=21817.
[    0.184276] tegra-id: opt_subrevision=1.
[    0.184298] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.184312] DTS File Name: /home/auvidea/Downloads/Kernel_4_9_TX2_Xavier_nano/Xavier_TX2_sources/public_sources/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[    0.184333] DTB Build time: May 24 2019 16:24:58
[    0.229931] CPU1: Booted secondary processor [4e0f0030]
[    0.261581] CPU2: Booted secondary processor [4e0f0030]
[    0.293423] CPU3: Booted secondary processor [411fd073]
[    0.325407] CPU4: Booted secondary processor [411fd073]
[    0.357414] CPU5: Booted secondary processor [411fd073]
[    0.357472] Brought up 6 CPUs
[    0.357520] SMP: Total of 6 processors activated.
[    0.357533] CPU features: detected feature: 32-bit EL0 Support
[    0.358344] CPU: All CPU(s) started at EL2
[    0.358396] alternatives: patching kernel code
[    0.367549] devtmpfs: initialized
[    0.405313] Initilizing CustomIPI irq domain
[    0.405524] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.405552] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.406448] pinctrl core: initialized pinctrl subsystem
[    0.406666] OS set in device tree is not L4T.
[    0.406840] regulator-dummy: no parameters
[    0.406992] Initializing plugin-manager
[    0.407055] Plugin module not found
[    0.407099] Plugin-manager status disabled
[    0.408908] NET: Registered protocol family 16
[    0.409636] pstore: using zlib compression
[    0.410033] console [pstore-1] enabled
[    0.410046] pstore: Registered ramoops as persistent store backend
[    0.410060] ramoops: attached 0x200000@0x275880000, ecc: 0/0
[    0.429075] cpuidle: using governor menu
[    0.430535] bpmp: waiting for handshake
[    0.430554] bpmp: handshake completed
[    0.430577] bpmp: synchronizing channels
[    0.430594] bpmp: channels synchronized
[    0.430606] bpmp: mail init ok
[    0.432646] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.432665] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.432680] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.432694] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.432707] arm-smmu 12000000.iommu: 	nested translation
[    0.432723] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.432743] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.432763] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.432778] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.432792] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.434954] vdso: 2 pages (1 code @ ffffff8008f37000, 1 data @ ffffff8009e24000)
[    0.434987] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.437255] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.439102] Registering BPMP clocks...
[    0.439212] tegra_bpmp_clk_init: clock init ok (636 clks)
[    0.439944] tegra_bpmp_of_clk_init: EMC proxy not found.
[    0.441435] tegra_powergate_init: DONE
[    0.441457] DTS File Name: /home/auvidea/Downloads/Kernel_4_9_TX2_Xavier_nano/Xavier_TX2_sources/public_sources/kernel_src/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[    0.441494] DTB Build time: May 24 2019 16:24:58
[    0.443495] Tegra reboot handler registered.
[    0.445019] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.445128] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.445155] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.445168] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[    0.445181] tegra-pmc: ### PMC reset status reg: 0x0
[    0.445348] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.445376] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.445724] iommu: Adding device 3460000.sdhci to group 0
[    0.446419] iommu: Adding device 3400000.sdhci to group 1
[    0.447513] iommu: Adding device 3507000.ahci-sata to group 2
[    0.447541] arm-smmu: forcing sodev map for 3507000.ahci-sata
[    0.447993] iommu: Adding device 3160000.i2c to group 3
[    0.448435] iommu: Adding device c240000.i2c to group 4
[    0.448799] iommu: Adding device 3180000.i2c to group 5
[    0.449183] iommu: Adding device 3190000.i2c to group 6
[    0.449631] iommu: Adding device 31b0000.i2c to group 7
[    0.449979] iommu: Adding device 31c0000.i2c to group 8
[    0.450323] iommu: Adding device c250000.i2c to group 9
[    0.450667] iommu: Adding device 31e0000.i2c to group 10
[    0.452157] iommu: Adding device 3210000.spi to group 11
[    0.452512] iommu: Adding device c260000.spi to group 12
[    0.452860] iommu: Adding device 3240000.spi to group 13
[    0.453596] iommu: Adding device 3100000.serial to group 14
[    0.453945] iommu: Adding device 3110000.serial to group 15
[    0.454295] iommu: Adding device c280000.serial to group 16
[    0.454641] iommu: Adding device 3130000.serial to group 17
[    0.455992] iommu: Adding device 2490000.ether_qos to group 18
[    0.456016] arm-smmu: forcing sodev map for 2490000.ether_qos
[    0.456619] iommu: Adding device b000000.rtcpu to group 19
[    0.458870] iommu: Adding device 13e10000.host1x to group 20
[    0.459195] iommu: Adding device 13e10000.host1x:ctx0 to group 21
[    0.459509] iommu: Adding device 13e10000.host1x:ctx1 to group 22
[    0.459836] iommu: Adding device 13e10000.host1x:ctx2 to group 23
[    0.460151] iommu: Adding device 13e10000.host1x:ctx3 to group 24
[    0.460465] iommu: Adding device 13e10000.host1x:ctx4 to group 25
[    0.460777] iommu: Adding device 13e10000.host1x:ctx5 to group 26
[    0.461137] iommu: Adding device 13e10000.host1x:ctx6 to group 27
[    0.461461] iommu: Adding device 13e10000.host1x:ctx7 to group 28
[    0.461944] iommu: Adding device 150c0000.nvcsi to group 29
[    0.462603] iommu: Adding device 15700000.vi to group 30
[    0.462966] iommu: Adding device 15600000.isp to group 31
[    0.463434] iommu: Adding device 15210000.nvdisplay to group 32
[    0.464051] iommu: Adding device 15340000.vic to group 33
[    0.464277] iommu: Adding device 154c0000.nvenc to group 34
[    0.464506] iommu: Adding device 15480000.nvdec to group 35
[    0.464859] iommu: Adding device 15380000.nvjpg to group 36
[    0.465118] iommu: Adding device 15500000.tsec to group 37
[    0.465350] iommu: Adding device 15100000.tsecb to group 38
[    0.466037] iommu: Adding device 15810000.se to group 39
[    0.466271] iommu: Adding device 15820000.se to group 40
[    0.466494] iommu: Adding device 15830000.se to group 41
[    0.466720] iommu: Adding device 15840000.se to group 42
[    0.467604] iommu: Adding device smmu_test to group 43
[    0.468215] mc: mapped MMIO address: 0xffffff800a680000 -> 0x2c10000
[    0.468240] mc: mapped MMIO address: 0xffffff800a6a0000 -> 0x2c20000
[    0.468261] mc: mapped MMIO address: 0xffffff800a6c0000 -> 0x2c30000
[    0.468282] mc: mapped MMIO address: 0xffffff800a6e0000 -> 0x2c40000
[    0.468303] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c50000
[    0.468322] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.468344] mc-err: mcerr ops are set to t18x
[    0.468500] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[    0.469648] iommu: Adding device 3530000.xhci to group 44
[    0.469673] arm-smmu: forcing sodev map for 3530000.xhci
[    0.470128] iommu: Adding device 3550000.xudc to group 45
[    0.470150] arm-smmu: forcing sodev map for 3550000.xudc
[    0.470871] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.470890] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.471473] iommu: Adding device 17000000.gp10b to group 46
[    0.472519] tegra-reset 5000000.clock: registered 193 resets.
[    0.474773] iommu: Adding device d000000.bpmp to group 47
[    0.474998] bpmp: ping status is 0
[    0.475102] bpmp d000000.bpmp: firmware tag is 69fa4e41a01fc02a4db1adf71922a54c
[    0.477552] bpmp d000000.bpmp: probe ok
[    0.480718] iommu: Adding device 2600000.dma to group 48
[    0.482024] GPIO line 461 (camera-control-output-low) hogged as output/low
[    0.482062] GPIO line 456 (camera-control-output-low) hogged as output/low
[    0.482095] GPIO line 457 (camera-control-output-low) hogged as output/low
[    0.482128] GPIO line 426 (camera-control-output-low) hogged as output/low
[    0.482163] GPIO line 424 (wifi-enable) hogged as output/high
[    0.482195] GPIO line 445 (sdmmc-wake-support-input) hogged as input
[    0.482228] GPIO line 446 (sdmmc-wake-support-output) hogged as output/low
[    0.482431] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[    0.486221] GPIO line 315 (wifi-wake-ap) hogged as input
[    0.486397] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[    0.488010] iommu: Adding device 10003000.pcie-controller to group 49
[    0.488039] arm-smmu: forcing sodev map for 10003000.pcie-controller
[    0.488368] iommu: Adding device sound to group 50
[    0.488741] iommu: Adding device 3510000.hda to group 51
[    0.496291] iommu: Adding device c1a0000.aon to group 52
[    0.496746] vdd-ac-bat: 5000 mV
[    0.498444] vdd-1v8-ap: 1800 mV
[    0.517594] random: fast init done
[    0.525628] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.528428] eventlib_kernel: keventlib is initialized, test id: 0
[    0.528636] SCSI subsystem initialized
[    0.528757] libata version 3.00 loaded.
[    0.528880] usbcore: registered new interface driver usbfs
[    0.528923] usbcore: registered new interface driver hub
[    0.529007] usbcore: registered new device driver usb
[    0.531009] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[    0.531055] pca953x 0-0074: failed reading register
[    0.531105] pca953x: probe of 0-0074 failed with error -121
[    0.531334] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[    0.531375] pca953x 0-0077: failed reading register
[    0.531414] pca953x: probe of 0-0077 failed with error -121
[    0.540454] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.545588] vddio-ddr: at 1125 mV
[    0.549454] avdd_dsi_csi: 1200 mV
[    0.553436] vdd-1v8: 1800 mV
[    0.557436] vdd-3v3-sys: 3300 mV
[    0.558538] spmic-ldo0: at 1800 mV
[    0.559237] spmic-ldo1: at 800 mV
[    0.561436] vddio-3v3: 3300 mV
[    0.562028] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.565437] vdd-rtc: at 800 mV
[    0.566199] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[    0.569436] spmic-ldo6: at 1500 mV
[    0.573436] vdd-pex-1v00: 1000 mV
[    0.574078] dvdd-pex: 1000 mV
[    0.574540] GPIO line 253 (spmic_gpio_input) hogged as input
[    0.574703] GPIO line 254 (spmic_gpio_input) hogged as input
[    0.574899] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[    0.576840] max77620 4-003c: max77620 probe successful
[    0.577209] media: Linux media interface: v0.10
[    0.577248] Linux video capture interface: v2.00
[    0.580856] pps_core: LinuxPPS API ver. 1 registered
[    0.580873] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.580899] PTP clock support registered
[    0.581271] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.581300] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.583742] tegra_fiq_debugger_init: found FIQ source (IRQ 386)
[    0.587869] Advanced Linux Sound Architecture Driver Initialized.
[    0.588190] Bluetooth: Core ver 2.22
[    0.588232] NET: Registered protocol family 31
[    0.588246] Bluetooth: HCI device and connection manager initialized
[    0.588263] Bluetooth: HCI socket layer initialized
[    0.588277] Bluetooth: L2CAP socket layer initialized
[    0.588301] Bluetooth: SCO socket layer initialized
[    0.589023] en-vdd-sd: 3300 mV
[    0.589407] vdd-usb0-5v: 5000 mV
[    0.589712] vdd-usb1-5v: 5000 mV
[    0.590173] vdd-3v3: 3300 mV
[    0.590422] en-vdd-vcm-2v8: 2800 mV
[    0.590677] vdd-sys-bl: 3300 mV
[    0.592629] camchar: rtcpu character device driver loaded
[    0.593133] gpio tegra-gpio wake53 for gpio=159(X:7)
[    0.594793] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[    0.595489] clocksource: Switched to clocksource arch_sys_counter
[    0.616749] VFS: Disk quotas dquot_6.6.0
[    0.616844] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.617094] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.617631] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[    0.617652] nvmap_page_pool_init: Total RAM pages: 2010072
[    0.617666] nvmap_page_pool_init: nvmap page pool size: 251259 pages (981 MB)
[    0.617819] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.620225] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    0.627037] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.627464] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.628382] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.628644] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.628922] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[    0.629139] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    0.630144] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[    0.630432] la/ptsa driver initialized.
[    0.630468] pre_t19x_iso_plat_init(): iso emc max clk=1866000KHz
[    0.630500] pre_t19x_iso_plat_init(): max_iso_bw=26870400KB
[    0.631714] NET: Registered protocol family 2
[    0.633840] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[    0.634510] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.635297] TCP: Hash tables configured (established 65536 bind 65536)
[    0.635377] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.635908] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.636826] NET: Registered protocol family 1
[    0.637945] RPC: Registered named UNIX socket transport module.
[    0.637982] RPC: Registered udp transport module.
[    0.638011] RPC: Registered tcp transport module.
[    0.638039] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.638077] PCI: CLS 0 bytes, default 64
[    0.638375] Trying to unpack rootfs image as initramfs...
[    0.664450] host1x 13e10000.host1x: initialized
[    0.666764] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.671109] audit: initializing netlink subsys (disabled)
[    0.671196] audit: type=2000 audit(0.552:1): initialized
[    0.672041] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    0.684955] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.687778] ntfs: driver 2.1.32 [Flags: R/W].
[    0.689452] 9p: Installing v9fs 9p2000 file system support
[    0.695431] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.695649] io scheduler noop registered
[    0.696325] io scheduler cfq registered (default)
[    0.701436] gic 2a41000.agic-controller: GIC IRQ controller registered
[    0.763234] iommu: Adding device aconnect@2a41000:adsp_audio to group 53
[    0.803177] iommu: Adding device 2993000.adsp to group 54
[    0.804412] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    0.808044] tegra-xusb-padctl 3520000.xusb_padctl: VBUS over-current detection enabled
[    0.812339] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.813854] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    0.815229] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.816634] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.819385] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[    0.820581] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[    0.821035] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[    0.821392] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.821612] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    0.821665] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
[    0.825592] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[    0.827308] tsec 15500000.tsec: initialized
[    0.828780] tsec 15100000.tsecb: initialized
[    0.833464] nvdec 15480000.nvdec: initialized
[    0.841380] falcon 15340000.vic: initialized
[    0.843303] falcon 154c0000.nvenc: initialized
[    0.845312] falcon 15380000.nvjpg: initialized
[    0.849961] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    0.852395] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    0.854012] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    0.855658] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    0.857278] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    0.858847] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    0.860458] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    0.862041] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    0.866248] tegradccommon 15200000.dc_common: host1x channel mapped
[    0.866350] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    0.866420] tegradccommon 15200000.dc_common: dma mapping done
[    0.867792] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor1
[    0.867901] generic_infoframe_type: 0x87
[    0.868044] tegradc 15210000.nvdisplay: DT parsed successfully
[    0.868098] tegradc 15210000.nvdisplay: Display dc.ffffff800b610000 registered with id=0
[    0.878159] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[    0.878253] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[    0.878297] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[    0.878620] tegradc 15210000.nvdisplay: vblank syncpt # 8 for dc 1
[    0.878662] tegradc 15210000.nvdisplay: vpulse3 syncpt # 9 for dc 1
[    0.880354] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[    0.880452] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 10 channels
[    0.881753] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    0.882976] kfuse 3830000.kfuse: initialized
[    0.885069] tegradc 15210000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
[    0.885143] tegradc 15210000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[    0.885657] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.892102] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.895545] console [ttyS0] disabled
[    0.895622] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 36, base_baud = 25500000) is a Tegra
[    0.925955] tegradc 15210000.nvdisplay: probed
[    1.347568] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.754333] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    2.161573] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    2.163626] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[    2.569815] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[    2.978163] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[    3.168698] console [ttyS0] enabled
[    3.169432] Console: switching to colour frame buffer device 240x67
[    3.175008] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 37, base_baud = 0) is a TEGRA_UART
[    3.176639] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 38, base_baud = 0) is a TEGRA_UART
[    3.179783] serial-tegra 3130000.serial: RX in PIO mode
[    3.180864] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 39, base_baud = 0) is a TEGRA_UART
[    3.189711] [drm] Initialized
[    3.214661] tegradc 15210000.nvdisplay: fb registered
[    3.218402] brd: module loaded
[    3.223229] gpio tegra-gpio wake21 for gpio=121(P:1)
[    3.229358] loop: module loaded
[    3.229992] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    3.230094] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    3.230194] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[    3.238114] Parent Clock set for DC plld2
[    3.242584] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[    3.244024] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[    3.244032] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[    3.247899] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    3.247903] Extcon AUX1(HDMI) enable
[    3.287939] tegra_profiler: version: 1.132, samples/io: 46/26
[    3.293927] tegra_profiler: auth: init
[    3.298132] nct1008_nct72 7-004c: starting parse dt
[    3.298560] THERMAL EST: found 3 subdevs
[    3.298565] THERMAL EST num_resources: 0
[    3.298569] [THERMAL EST subdev 0]
[    3.298574] [THERMAL EST subdev 1]
[    3.298577] [THERMAL EST subdev 2]
[    3.298973] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[    3.298976] THERMAL EST: thz register success.
[    3.299172] THERMAL EST: end of probe, return err: 0
[    3.300285] hisi_sas: driver version v1.6
[    3.304265] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[    3.304276] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[    3.305301] scsi host0: tegra_ahci
[    3.306241] scsi host1: tegra_ahci
[    3.306432] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 24
[    3.306436] ata2: DUMMY
[    3.312435] libphy: Fixed MDIO Bus: probed
[    3.312927] tun: Universal TUN/TAP device driver, 1.6
[    3.312929] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.313659] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    3.313662] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    3.313695] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    3.313697] igb: Copyright (c) 2007-2014 Intel Corporation.
[    3.313727] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    3.313730] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    3.313765] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[    3.313767] Copyright(c) 1999 - 2017 Intel Corporation.
[    3.315043] eqos 2490000.ether_qos: no PHY interrupt found
[    3.315263] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[    3.319075] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c6 bd a9
[    3.319201] libphy: dwc_phy: probed
[    3.319663] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[    3.321956] PPP generic driver version 2.4.2
[    3.322149] PPP BSD Compression module registered
[    3.322153] PPP Deflate Compression module registered
[    3.322201] PPP MPPE Compression module registered
[    3.322205] NET: Registered protocol family 24
[    3.322258] usbcore: registered new interface driver r8152
[    3.322302] usbcore: registered new interface driver asix
[    3.322338] usbcore: registered new interface driver ax88179_178a
[    3.322368] usbcore: registered new interface driver cdc_ether
[    3.322405] usbcore: registered new interface driver net1080
[    3.322441] usbcore: registered new interface driver cdc_subset
[    3.322485] usbcore: registered new interface driver zaurus
[    3.322532] usbcore: registered new interface driver cdc_ncm
[    3.330978] VFIO - User Level meta-driver version: 0.3
[    3.332762] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.332781] ehci-pci: EHCI PCI platform driver
[    3.332809] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.332833] ohci-pci: OHCI PCI platform driver
[    3.332860] ohci-platform: OHCI generic platform driver
[    3.338744] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[    3.341090] tegra-xusb 3530000.xhci: extcon 0: ffffffc1ead5f400 id
[    3.341188] tegra-xusb 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[    3.341192] tegra-xusb 3530000.xhci: Falling back to user helper
[    3.341643] usbcore: registered new interface driver uas
[    3.341723] usbcore: registered new interface driver usb-storage
[    3.341798] usbcore: registered new interface driver usbserial
[    3.346423] tegra-xudc-new 3550000.xudc: device count: 1
[    3.347696] tegra-xudc-new 3550000.xudc: vbus state: 0
[    3.348119] tegra-xudc-new 3550000.xudc: entering ELPG
[    3.348284] mousedev: PS/2 mouse device common for all mice
[    3.348360] usbcore: registered new interface driver xpad
[    3.350345] tegra-xudc-new 3550000.xudc: entering ELPG done
[    3.443286] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    3.444633] Wake73 for irq=42
[    3.446085] rtc rtc1: alarm rtc device
[    3.446100] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    3.446125] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    3.446388] i2c /dev entries driver
[    3.450383] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    3.455191] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[    3.455934] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[    3.457457] parse_throttle_dt_data: Num cap clks = 4
[    3.457461] parse_throttle_dt_data: clk=mcpu type=1
[    3.457464] parse_throttle_dt_data: clk=bcpu type=2
[    3.457472] parse_throttle_dt_data: clk=gpu type=4
[    3.457475] parse_throttle_dt_data: clk=emc type=3
[    3.458705] tegra_throttle_probe: probe successful. #cdevs=4
[    3.459156] PWM shared data node NULL, parse phandle failed
[    3.459167] pwm_fan_driver: probe of fixed-regulators:regulator@13 failed with error -22
[    3.459351] FAN: coudln't get the regulator
[    3.461907] device-mapper: uevent: version 1.0.3
[    3.462830] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    3.478839] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[    3.479228] cpufreq: platform driver Initialization: pass
[    3.483611] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[    3.483620] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[    3.483688] cpuidle: Initializing cpuidle driver init for Denver cluster
[    3.483868] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[    3.483885] cpuidle: Initializing cpuidle driver init for A57 cluster
[    3.489438] sdhci: Secure Digital Host Controller Interface driver
[    3.489440] sdhci: Copyright(c) Pierre Ossman
[    3.489441] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.491074] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    3.493025] CMDQ: cmdq_platfm_init successful
[    3.494211] CQE: CMD_TIMING bit set for R1B DCMD
[    3.495979] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    3.501596] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    3.501645] sdhci-tegra 3400000.sdhci: Got WP GPIO
[    3.503570] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    3.505257] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 257
[    3.509585] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    3.511051] tegra-se-nvhost 15810000.se: initialized
[    3.512297] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    3.512915] tegra-se-nvhost 15820000.se: initialized
[    3.514031] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    3.514874] tegra-se-nvhost 15830000.se: initialized
[    3.515782] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    3.516516] tegra-se-nvhost 15840000.se: initialized
[    3.517478] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    3.517929] hidraw: raw HID events driver (C) Jiri Kosina
[    3.521297] usbcore: registered new interface driver usbhid
[    3.521299] usbhid: USB HID core driver
[    3.523767] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[    3.523800] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[    3.523997] ina3221x: probe of 0-0042 failed with error -121
[    3.524326] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[    3.524356] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[    3.524579] ina3221x: probe of 0-0043 failed with error -121
[    3.527536] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    3.530946] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[    3.531267] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    3.531561] tegra-ivc ivc-b000000.rtcpu:i2c@480: i2c: ver=0 grp=1 RX[8x128]=0x1900-0x1d80 TX[8x128]=0x1d80-0x2200
[    3.532052] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x2200-0x4280 TX[64x128]=0x4280-0x6300
[    3.533226] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x6300-0x63c0 TX[1x64]=0x63c0-0x6480
[    3.533316] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x6480-0x7900 TX[16x320]=0x7900-0x8d80
[    3.533390] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8d80-0x9200 TX[16x64]=0x9200-0x9680
[    3.533452] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x9680-0x9880 TX[1x384]=0x9880-0x9a80
[    3.533747] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9a80-0xbb00 TX[1x8192]=0xbb00-0xdb80
[    3.534286] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (51)
[    3.534289] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    3.535199] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=3ecb1dca25fa98771f988f238c025334776c9a96
[    3.536631] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    3.537186] tegra186-aondbg aondbg: aondbg driver probe() OK
[    3.537944] register_ari_mca_banks: Registered MCA ROC:IOB
[    3.538015] register_ari_mca_banks: Registered MCA ROC:CCE
[    3.538363] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538366] tegra18-bridge 2390000.axi2apb: enabled timeout = 11155000
[    3.538369] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    3.538433] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538436] tegra18-bridge 23a0000.axi2apb: enabled timeout = 11155000
[    3.538439] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    3.538503] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538505] tegra18-bridge 23b0000.axi2apb: enabled timeout = 11155000
[    3.538507] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    3.538565] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538568] tegra18-bridge 23c0000.axi2apb: enabled timeout = 11155000
[    3.538570] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    3.538625] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538627] tegra18-bridge 23d0000.axi2apb: enabled timeout = 11155000
[    3.538629] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    3.538686] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538691] tegra18-bridge 2100000.axip2p: enabled timeout = 11155000
[    3.538694] tegra18-bridge 2100000.axip2p: bridge probed OK
[    3.538753] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538759] tegra18-bridge 2110000.axip2p: enabled timeout = 11155000
[    3.538761] tegra18-bridge 2110000.axip2p: bridge probed OK
[    3.538819] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538824] tegra18-bridge 2120000.axip2p: enabled timeout = 11155000
[    3.538826] tegra18-bridge 2120000.axip2p: bridge probed OK
[    3.538959] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.538964] tegra18-bridge 2130000.axip2p: enabled timeout = 11155000
[    3.538966] tegra18-bridge 2130000.axip2p: bridge probed OK
[    3.539035] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.539039] tegra18-bridge 2140000.axip2p: enabled timeout = 11155000
[    3.539041] tegra18-bridge 2140000.axip2p: bridge probed OK
[    3.539099] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.539104] tegra18-bridge 2150000.axip2p: enabled timeout = 11155000
[    3.539106] tegra18-bridge 2150000.axip2p: bridge probed OK
[    3.539162] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.539168] tegra18-bridge 2160000.axip2p: enabled timeout = 11155000
[    3.539170] tegra18-bridge 2160000.axip2p: bridge probed OK
[    3.539229] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.539234] tegra18-bridge 2170000.axip2p: enabled timeout = 11155000
[    3.539236] tegra18-bridge 2170000.axip2p: bridge probed OK
[    3.539295] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.539300] tegra18-bridge 2180000.axip2p: enabled timeout = 11155000
[    3.539302] tegra18-bridge 2180000.axip2p: bridge probed OK
[    3.539361] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 115 MHZ, timeout = 97000 useconds
[    3.539366] tegra18-bridge 2190000.axip2p: enabled timeout = 11155000
[    3.539368] tegra18-bridge 2190000.axip2p: bridge probed OK
[    3.539421] tegra18_a57_serr_init: on CPU 2 a Denver Core
[    3.539477] tegra18x_actmon d230000.actmon: in actmon_register()...
[    3.540131] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    3.543857] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    3.543959] denver_knobs_init:MTS_VERSION:43068234
[    3.548957] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.549002] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.550784] nvpmodel: initialized successfully
[    3.552741] usbcore: registered new interface driver snd-usb-audio
[    3.559583] gpio tegra-gpio wake71 for gpio=125(P:5)
[    3.559645] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    3.567602] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    3.567724] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    3.575849] OPE platform probe
[    3.575917] OPE platform probe successful
[    3.577900] tegra-asoc: sound: This is a dummy codec
[    3.623698] ata1: SATA link down (SStatus 0 SControl 300)
[    3.625420] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    3.635737] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    3.635806] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    3.635871] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    3.635938] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    3.636003] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    3.636067] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    3.636139] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    3.636202] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    3.636264] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    3.636331] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    3.636396] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    3.636463] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    3.636525] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    3.636590] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    3.636655] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    3.636719] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    3.636785] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    3.636849] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    3.636913] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    3.636978] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    3.638635] mmc0: periodic cache flush enabled
[    3.638648] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    3.639429] mmcblk0: mmc0:0001 032G34 29.1 GiB
[    3.639691] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[    3.639841] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[    3.640094] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[    3.642884]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31
[    3.670294] u32 classifier
[    3.670296]     Actions configured
[    3.670417] Initializing XFRM netlink socket
[    3.675950] NET: Registered protocol family 10
[    3.677481] NET: Registered protocol family 17
[    3.677489] NET: Registered protocol family 15
[    3.677546] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.678267] Bluetooth: RFCOMM socket layer initialized
[    3.678275] Bluetooth: RFCOMM ver 1.11
[    3.678286] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.678289] Bluetooth: HIDP socket layer initialized
[    3.678303] 9pnet: Installing 9P2000 support
[    3.678342] Key type dns_resolver registered
[    3.680271] Registered cp15_barrier emulation handler
[    3.680317] Registered setend emulation handler
[    3.681129] registered taskstats version 1
[    3.685256] isp 15600000.isp: initialized
[    3.689711] nvcsi 150c0000.nvcsi: initialized
[    3.695975] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[    3.696049] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[    3.696115] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[    3.696253] input: gpio-keys as /devices/gpio-keys/input/input2
[    3.699007] tegra-vi4 15700000.vi: initialized
[    3.699788] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[    3.699791] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@1/endpoint.
[    3.729291] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-02 02:42:30 UTC (946780950)
[    3.730610] mmcblk mmc0:0001: Card claimed for testing.
[    3.759239] bpmp: mounted debugfs mirror
[    3.760444] bwmgr: missing cdev-type property
[    3.765386] spmic-ldo0: disabling
[    3.765928] spmic-ldo1: disabling
[    3.766967] vdd-usb0-5v: disabling
[    3.766968] vdd-usb1-5v: disabling
[    3.766970] vdd-3v3: disabling
[    3.766971] en-vdd-vcm-2v8: disabling
[    3.766972] vdd-sys-bl: disabling
[    3.766974] ALSA device list:
[    3.766976]   #0: tegra-hda at 0x3518000 irq 383
[    3.766977]   #1: tegra-snd-t186ref-mobile-rt565x
[    3.830485] mmc1: hw tuning done ...
[    4.013349] mmc2: hw tuning done ...
[    4.013394] mmc2: new ultra high speed SDR50 SDHC card at address aaaa
[    4.013589] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    4.013890] mmcblk2: mmc2:aaaa SS16G 14.8 GiB
[    4.016710]  mmcblk2: p1 p2
[    4.936115] tegradc 15210000.nvdisplay: blank - powerdown
[    4.939810] nct1008_nct72 7-004c: !!!Found deprecated property!!!
[    4.939815] nct1008_nct72 7-004c: success parsing dt
[    4.939949] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[    4.972291] nct1008_nct72 7-004c: LOC shutdown limit 107
[    4.972862] nct1008_nct72 7-004c: EXT shutdown limit 107
[    4.977704] extcon-disp-state external-connection:disp-state: cable 47 state 0
[    4.977706] Extcon AUX1(HDMI) disable
[    4.999988] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[    5.000086] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[    5.000832] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[    5.005774] nct1008_nct72 7-004c: initial LOC temp: 28000
[    5.006100] nct1008_nct72 7-004c: initial EXT temp: 42500
[    5.006758] nct1008_nct72 7-004c: hi_b:-11, lo_b:0
[    5.007182] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[    5.007387] nct1008_nct72 7-004c: nct1008_probe: initialized
[    5.012730] tegradc 15210000.nvdisplay: unblank
[    5.013661] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    5.013757] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    5.013847] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[    5.015359] Parent Clock set for DC plld2
[    5.018759] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[    5.020154] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[    5.020162] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[    5.023758] extcon-disp-state external-connection:disp-state: cable 47 state 1
[    5.023760] Extcon AUX1(HDMI) enable
[    7.227079] extcon-disp-state external-connection:disp-state: cable 40 state 1
[    7.235733] Extcon HDMI: HPD enabled
[    7.240738] tegradc 15210000.nvdisplay: hdmi: plugged
[    7.266934] EXT4-fs (mmcblk0p1): 2 orphan inodes deleted
[    7.273802] EXT4-fs (mmcblk0p1): recovery complete
[    7.285449] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.295112] VFS: Mounted root (ext4 filesystem) on device 179:1.
[    7.308854] devtmpfs: mounted
[    7.315167] Freeing unused kernel memory: 8512K
[    7.450077] systemd[1]: System time before build time, advancing clock.
[    7.494191] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.544587] cgroup: cgroup2: unknown option "nsdelegate"
[    7.576512] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    7.607069] systemd[1]: Detected architecture arm64.
[    7.705476] systemd[1]: Set hostname to <sadaf-desktop>.
[    7.802467] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    7.821260] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    8.025209] random: systemd: uninitialized urandom read (16 bytes read)
[    8.039237] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    8.052569] random: systemd: uninitialized urandom read (16 bytes read)
[    8.060978] systemd[1]: Reached target Swap.
[    8.068958] random: systemd: uninitialized urandom read (16 bytes read)
[    8.077361] systemd[1]: Reached target User and Group Name Lookups.
[    8.090441] systemd[1]: Created slice System Slice.
[    8.099710] systemd[1]: Listening on udev Control Socket.
[    8.193729] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[    8.207163] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    8.355693] random: crng init done
[    8.360942] random: 7 urandom warning(s) missed due to ratelimiting
[    8.544913] systemd-journald[2294]: Received request to flush runtime journal from PID 1
[    9.187717] using random self ethernet address
[    9.194726] using random host ethernet address
[    9.236407] Mass Storage Function, version: 2009/09/11
[    9.236412] LUN: removable file: (no medium)
[    9.247125] using random self ethernet address
[    9.247126] using random host ethernet address
[    9.285828] rndis0: HOST MAC 2a:f4:6c:cd:f6:ac
[    9.290339] rndis0: MAC 2a:f4:6c:cd:f6:ad
[    9.291057] usb0: HOST MAC 2a:f4:6c:cd:f6:ae
[    9.291254] usb0: MAC 2a:f4:6c:cd:f6:af
[    9.291276] tegra-xudc-new 3550000.xudc: exiting ELPG
[    9.317407] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    9.317426] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[    9.317454] tegra-xudc-new 3550000.xudc: entering ELPG
[    9.318632] tegra-xudc-new 3550000.xudc: entering ELPG done
[    9.318654] tegra-xudc-new 3550000.xudc: exiting ELPG
[    9.321730] tegra-xudc-new 3550000.xudc: exiting ELPG done
[    9.321751] tegra-xudc-new 3550000.xudc: entering ELPG
[    9.322702] tegra-xudc-new 3550000.xudc: entering ELPG done
[    9.371174] l4tbr0: port 1(rndis0) entered blocking state
[    9.371181] l4tbr0: port 1(rndis0) entered disabled state
[    9.372113] device rndis0 entered promiscuous mode
[    9.386975] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    9.407896] l4tbr0: port 2(usb0) entered blocking state
[    9.407902] l4tbr0: port 2(usb0) entered disabled state
[    9.408072] device usb0 entered promiscuous mode
[    9.420230] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    9.420237] l4tbr0: port 2(usb0) entered blocking state
[    9.420241] l4tbr0: port 2(usb0) entered forwarding state
[    9.617114] tegra-xusb 3530000.xhci: cannot find firmware....retry after 1 second
[    9.718670] nvgpu: 17000000.gp10b             railgate_enable_store:343  [INFO]  railgate is disabled.
[    9.973620] tegra-i2c c240000.i2c: no acknowledge from address 0x69
[    9.987068] bmi160 1-0069: bmi_i2c_rd ERR: 0x00
[   10.003222] bmi160 1-0069: bmi_init _id_i2c ERR
[   10.003286] bmi160 1-0069: bmi_remove
[   10.003288] bmi160 1-0069: bmi_probe done
[   10.195856] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.226621] dhd_module_init in
[   10.226695] found wifi platform device bcmdhd_wlan
[   10.229288] wifi_platform_get_country_code_map: could not get country_code_map
[   10.229294] wifi_plat_dev_drv_probe:platform country code map is not available
[   10.229309] Power-up adapter 'DHD generic adapter'
[   10.229318] wifi_platform_set_power = 1
[   10.272691] gpio tegra-gpio wake18 for gpio=101(M:5)
[   10.276157] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.291759] l4tbr0: port 2(usb0) entered disabled state
[   10.320388] CPU1: shutdown
[   10.324857] psci: CPU1 killed.
[   10.373444] CPU2: shutdown
[   10.378057] psci: CPU2 killed.
[   10.435542] wifi_platform_bus_enumerate device present 1
[   10.465121] wifi_platform_bus_enumerate device present 0
[   10.465719] F1 signature read @0x18000000=0x17214354
[   10.473797] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[   10.474497] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   10.477458] wifi_platform_get_mac_addr
[   10.515647] ids dhd_log_netlink_init
[   10.519533]  wl_event_handler :
[   10.519538] tsk Enter, tsk = 0xffffffc1e0d01a90
[   10.519545] wl_create_event_handler(): thread:wl_event_handler:1512 started
[   10.523608] dhd_attach(): thread:dhd_watchdog_thread:1514 started
[   10.525485] dhd_attach(): thread:dhd_dpc:1515 started
[   10.526990] dhd_attach(): thread:dhd_rxf:1516 started
[   10.526998] dhd_deferred_work_init: work queue initialized
[   10.528321]
               Dongle Host Driver, version 1.201.82 (r)
               Compiled from
[   10.528995] Register interface [wlan0]  MAC: 00:04:4b:c6:bd:a7
[   10.529000] dhd_prot_ioctl : bus is down. we have nothing to do
[   10.529163] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 60
[   10.530213] wifi_platform_set_power = 0
[   10.627457] tegra-xusb 3530000.xhci: Firmware timestamp: 2018-12-26 10:30:04 UTC, Version: 55.12 release
[   10.683546] tegra-xusb 3530000.xhci: xHCI Host Controller
[   10.683565] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[   10.684374] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[   10.684407] tegra-xusb 3530000.xhci: irq 70, io mem 0x03530000
[   10.684524] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[   10.684528] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.684531] usb usb1: Product: xHCI Host Controller
[   10.684533] usb usb1: Manufacturer: Linux 4.9.140 xhci-hcd
[   10.684535] usb usb1: SerialNumber: 3530000.xhci
[   10.684878] hub 1-0:1.0: USB hub found
[   10.684903] hub 1-0:1.0: 4 ports detected
[   10.685201] tegra-xusb 3530000.xhci: xHCI Host Controller
[   10.685208] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[   10.687963] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[   10.687969] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   10.687971] usb usb2: Product: xHCI Host Controller
[   10.687973] usb usb2: Manufacturer: Linux 4.9.140 xhci-hcd
[   10.687975] usb usb2: SerialNumber: 3530000.xhci
[   10.688295] hub 2-0:1.0: USB hub found
[   10.688353] hub 2-0:1.0: 3 ports detected
[   10.692539] Wake76 for irq=199
[   10.692542] Wake77 for irq=199
[   10.692543] Wake78 for irq=199
[   10.692544] Wake79 for irq=199
[   10.692545] Wake80 for irq=199
[   10.692546] Wake81 for irq=199
[   10.692547] Wake82 for irq=199
[   10.791731] usb usb2: usb_suspend_both: status 0
[   11.011530] usb 1-2: new low-speed USB device number 2 using tegra-xusb
[   11.036498] usb 1-2: New USB device found, idVendor=0461, idProduct=4d22
[   11.036503] usb 1-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[   11.036505] usb 1-2: Product: USB Optical Mouse
[   11.040502] input: USB Optical Mouse as /devices/3530000.xhci/usb1/1-2/1-2:1.0/0003:0461:4D22.0001/input/input3
[   11.040728] hid-generic 0003:0461:4D22.0001: input,hidraw0: USB HID v1.11 Mouse [USB Optical Mouse] on usb-3530000.xhci-2/input0
[   11.159549] usb 1-3: new low-speed USB device number 3 using tegra-xusb
[   11.186880] usb 1-3: New USB device found, idVendor=0461, idProduct=0010
[   11.186886] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   11.186888] usb 1-3: Product: USB Keyboard
[   11.186891] usb 1-3: Manufacturer: NOVATEK
[   11.191694] input: NOVATEK USB Keyboard as /devices/3530000.xhci/usb1/1-3/1-3:1.0/0003:0461:0010.0002/input/input4
[   11.225950] tegradc 15210000.nvdisplay: blank - powerdown
[   11.252092] hid-generic 0003:0461:0010.0002: input,hidraw1: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-3530000.xhci-3/input0
[   11.259664] input: NOVATEK USB Keyboard as /devices/3530000.xhci/usb1/1-3/1-3:1.1/0003:0461:0010.0003/input/input5
[   11.287052] extcon-disp-state external-connection:disp-state: cable 47 state 0
[   11.287054] Extcon AUX1(HDMI) disable
[   11.309595] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[   11.309680] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[   11.310318] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[   11.310686] tegradc 15210000.nvdisplay: unblank
[   11.312353] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[   11.312439] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[   11.312524] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[   11.314140] Parent Clock set for DC plld2
[   11.318487] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[   11.319744] hid-generic 0003:0461:0010.0003: input,hidraw2: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-3530000.xhci-3/input1
[   11.319816] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[   11.319822] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[   11.327872] extcon-disp-state external-connection:disp-state: cable 47 state 1
[   11.327874] Extcon AUX1(HDMI) enable
[   11.328444] tegradc 15210000.nvdisplay: unblank
[   11.762972] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   11.763098]
               Compiled from
[   11.763108] wl_android_wifi_on in
[   11.763112] wifi_platform_set_power = 1
[   11.915458] fuse init (API version 7.26)
[   11.971150] vdd-1v8: voltage operation not allowed
[   11.976033] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[   12.003742] vdd-1v8: voltage operation not allowed
[   12.008571] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[   12.032571] vdd-1v8: voltage operation not allowed
[   12.037406] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[   12.046600] vdd-1v8: voltage operation not allowed
[   12.051648] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[   12.157954] vdd-1v8: voltage operation not allowed
[   12.162790] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[   12.171532] vdd-1v8: voltage operation not allowed
[   12.176417] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[   12.184709] vdd-1v8: voltage operation not allowed
[   12.189532] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[   12.196194] sdhci-tegra 3440000.sdhci: Tuning done, restoring the best tap value : 60
[   12.196726] F1 signature read @0x18000000=0x17214354
[   12.201058] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[   12.201675] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[   12.275582] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[   12.337493] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[   12.337832] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[   12.337890] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[   12.337892] Enabling wake69
[   12.339326] wifi_platform_get_mac_addr
[   12.341003] Firmware up: op_mode=0x0005, MAC=00:04:4b:c6:bd:a7
[   12.345418] clm path from default:/lib/firmware/brcm/bcmdhd.clm_blob
[   12.345447] Skipping the clm download. len:0 memblk:          (null)
[   12.347756] dhd_preinit_ioctls pspretend_threshold for HostAPD failed  -23
[   12.352966] Firmware version = wl0: Oct 31 2018 11:34:03 version 7.35.349.66 (r708495 CY) FWID 01-ade683bb
[   12.355401] dhd_interworking_enable: failed to set WNM info, ret=-23
[   12.458408] CFGP2P-ERROR) wl_cfgp2p_add_p2p_disc_if :
[   12.458411] P2P interface registered
[   12.476094] WLC_E_IF: NO_IF set, event Ignored
[   12.495964] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   26.750443] tegradc 15210000.nvdisplay: blank - powerdown
[   26.811840] extcon-disp-state external-connection:disp-state: cable 47 state 0
[   26.811853] Extcon AUX1(HDMI) disable
[   26.825406] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[   26.825491] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[   26.826120] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[   26.948252] tegradc 15210000.nvdisplay: blank - powerdown
[   26.948269] tegradc 15210000.nvdisplay: unblank
[   26.949094] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[   26.949195] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[   26.949284] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[   26.950655] Parent Clock set for DC plld2
[   26.953781] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[   26.955556] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[   26.955563] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[   26.962743] extcon-disp-state external-connection:disp-state: cable 47 state 1
[   26.962745] Extcon AUX1(HDMI) enable
[   26.962846] tegradc 15210000.nvdisplay: unblank
[   29.425992] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   29.426004] Bluetooth: BNEP socket layer initialized
[   29.725689] tegradc 15210000.nvdisplay: unblank
[   32.248964] FAT-fs (mmcblk2p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
ifconfig on Host:
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 172.27.42.95  netmask 255.255.0.0  broadcast 172.27.255.255
            inet6 fe80::e2a2:a89e:a3e2:4106  prefixlen 64  scopeid 0x20<link>
            ether f8:b1:56:9a:0d:96  txqueuelen 1000  (Ethernet)
            RX packets 221679183  bytes 104581271221 (104.5 GB)
            RX errors 0  dropped 35  overruns 0  frame 0
            TX packets 21265640  bytes 8807187176 (8.8 GB)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
            device interrupt 20  memory 0xf7f00000-f7f20000
    enp5s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            ether 00:0a:f7:2b:af:0a  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 0  bytes 0 (0.0 B)
            device interrupt 18
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 2045680  bytes 427615911 (427.6 MB)
            TX packets 2045680  bytes 427615911 (427.6 MB)
It seems there are some problems in your host side. Please try with linuxdev’s comment first.
If it is working, then there should be a interface with IP 192.168.55.100 on your host.
Could you please check the outputs that I have attached in the thread. I’m not able to sort this out. It would be great if you could help me. Thanks.
Actually, back to your original topic, you just want to install the sdk from sdkmanager.
You don’t necessarily use usb device mode to transfer the data.
When sdkmanager ask you to enter the ip address, just find a ethernet cable, connect it to tegra and use the ethernet ip in the prompt.
If you intend to use usb device mode, what linuxdev said is to click the ethernet connction button on your host’s ubuntu desktop. It is on the upper right corner. After you click it, you shall see something like “wired connection”, “edit connections” …etc. Please click the “edit connection” and see if there are other connections.
To confirm what I saw in the most recent logs it appears the only network interface with an address assigned on the Jetson is the micro-B USB connector virtual device (other network interfaces exist, but were not assigned an address, e.g., no router attached…the USB virtual ethernet does not need a router to get an address). As @WayneWWW mentions, you could use the regular wired ethernet connector if you have a router to assign an address to it (such as connecting the wired ethernet to the same router the host PC is connected to). Without some sort of network interface between host and Jetson there is no possibility of adding packages.
Note that the ifconfig logs of your host PC did not have any of the micro-B USB cable virtual ethernet showing (even if the interface can work the interface is disabled…seeing the device in lsusb is a first step, and then enabling its use is the next step; default Ubuntu hosts will simply enable the interface by default). Generally speaking, this is often because the host PC did not allow the interface to be used (e.g., security settings or defaults prevent this without user intervention). If the USB listing shows the device, but the device is not used, then you must either activate that device (allow the device), or else add an alternative ethernet route. This would be the above mentioned “wired connection…” editing note.
I also saw you have some SElinux audit rules (and apparmor). I did not see anything which indicated that this was interfering with the package addition steps, but in the past I have seen apparmor cause issues. Do beware that if you’ve enabled or customized SElinux or apparmor that this could potentially get in the way since this would be one method by which enabling the virtual USB ethernet could be denied.
I also see reference to a corrupt VFAT filesystem on an SD card, and you should probably disconnect this if it is a USB card reader (at least while working on this issue). I also see a number of USB errors, and I’m wondering if perhaps the host would use the virtual wired USB ethernet if that error were gone. An actual defect related to the SD card, if USB, could also interfere with other USB devices in some cases.
From the host, with the Jetson fully booted and the micro-B USB cable inserted, what do you see from this (I am curious if perhaps the USB does not show up due to USB errors…this result will be very important in knowing if the USB side is valid or not):
sudo lsusb -d 0955: -vvv
