Hello All, I have just installed the Jetson TX2 on the Orbitty Carrier board but I found out that the usb port is not wokring and I am not able to use the keyboard/mouse.
the lsusb shows nothing while dmesg output is as follows below, anyone can point to me a solution to to fix it?
nvidia@tegra-ubuntu:~ lsusb
nvidia@tegra-ubuntu:~ dmesg | grep -i usb
[ 0.142939] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.300976] usbcore: registered new interface driver usbfs
[ 0.301040] usbcore: registered new interface driver hub
[ 0.301156] usbcore: registered new device driver usb
[ 0.363656] vdd-usb0-5v: 5000 mV
[ 0.363829] vdd-usb1-5v: 5000 mV
[ 2.570256] usbcore: registered new interface driver r8152
[ 2.570290] usbcore: registered new interface driver asix
[ 2.570320] usbcore: registered new interface driver ax88179_178a
[ 2.570373] usbcore: registered new interface driver cdc_ether
[ 2.570412] usbcore: registered new interface driver smsc75xx
[ 2.570441] usbcore: registered new interface driver net1080
[ 2.570467] usbcore: registered new interface driver cdc_subset
[ 2.570493] usbcore: registered new interface driver zaurus
[ 2.570537] usbcore: registered new interface driver cdc_ncm
[ 2.570841] tegra-xotg xotg: usb2 phy is not available yet
[ 2.571594] usbcore: registered new interface driver cdc_acm
[ 2.571597] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.571634] usbcore: registered new interface driver usb-storage
[ 2.571690] usbcore: registered new interface driver usbserial
[ 2.571713] usbcore: registered new interface driver cp210x
[ 2.571735] usbserial: USB Serial support registered for cp210x
[ 2.571761] usbcore: registered new interface driver ftdi_sio
[ 2.571778] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.571800] usbcore: registered new interface driver option
[ 2.571816] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.571838] usbcore: registered new interface driver pl2303
[ 2.571853] usbserial: USB Serial support registered for pl2303
[ 2.572034] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.592879] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.725957] usbcore: registered new interface driver gspca_zc3xx
[ 2.735065] usbcore: registered new interface driver usbhid
[ 2.735067] usbhid: USB HID core driver
[ 4.336411] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 4.336415] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.528325] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.530557] tegra-xotg xotg: usb2 phy is not available yet
[ 4.530688] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.531059] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.531246] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 4.531249] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.534491] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.535994] tegra-xotg xotg: usb2 phy is not available yet
[ 4.536107] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.536468] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.536639] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 4.536642] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.539587] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.604533] vdd-usb0-5v: disabling
[ 4.604534] vdd-usb1-5v: disabling
[ 4.612613] tegra-xotg xotg: usb2 phy is not available yet
[ 4.612829] tegra-usb-cd usb_cd: otg phy is not available yet
[ 4.613252] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 4.613457] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 4.613460] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.616854] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 6.991819] tegra-xotg xotg: usb2 phy is not available yet
[ 6.992072] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.992624] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 6.992939] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 6.992942] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 6.996780] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 7.580994] tegra-xotg xotg: usb2 phy is not available yet
[ 7.581303] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.581994] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 7.582496] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 7.582499] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 7.590082] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 7.960599] tegra-xotg xotg: usb2 phy is not available yet
[ 7.963124] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.964390] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 7.966188] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 7.966192] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 7.996300] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 8.003441] tegra-xotg xotg: usb2 phy is not available yet
[ 8.204891] tegra-usb-cd usb_cd: otg phy is not available yet
[ 8.205622] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 8.206019] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab095
[ 8.206022] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 8.221172] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 8.235588] tegra-xotg xotg: usb2 phy is not available yet
nvidia@tegra-ubuntu:~$
