I’m working on my jetson-xavier module based custom design board and stuck at usb configuration, need support.
My Hardware Design like this:
- USB0 (F12-F13) - USB2.0 Flash/Debug port (No Vbus & no Pd controller). Xavier should be device
- USB3 (G10-G11) - USB2.0 Interface to STM32, Xavier should be host & STM32 is device
- USB3.1 (K16-K17 & B16-B17) USB3.0 interface to Rock chip module (which as type C Phy)
Currently my device tree:
* Common include DTS file for CVM:P2888-0001 and CVB:P2822-0000 variants.
* Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; version 2 of the License.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
#include "dt-bindings/extcon-ids.h"
#include "dt-bindings/gpio/tegra194-gpio.h"
#include "tegra194-p2888-0000-a00.dtsi"
#include <t19x-common-platforms/tegra194-platforms-eqos.dtsi>
#include "tegra194-p2822-0000-a00.dtsi"
#include "tegra194-power-tree-p2888-0001-p2822-1000.dtsi"
#include <t19x-common-platforms/tegra194-comms.dtsi>
#include "tegra194-thermal-p2888.dtsi"
#include "tegra194-plugin-manager-p2888-0000.dtsi"
#include "tegra194-plugin-manager-p2822-0000.dtsi"
#include "tegra194-super-module-e2614-p2888-0000.dtsi"
nvidia,dtsfilename = __FILE__;
nvidia,dtbbuildtime = __DATE__, __TIME__;
nvidia,fastboot-usb-vid = <0x0955>;
nvidia,fastboot-usb-pid = <0xee1e>;
model = "Jetson-AGX";
compatible = "nvidia,galen", "nvidia,jetson-xavier", "nvidia,p2822-0000+p2888-0001", "nvidia,tegra194";
chosen {
bootargs ="console=ttyTCU0,115200";
board-has-eeprom;
firmware {
android {
compatible = "android,firmware";
hardware = "jetson-xavier";
vbmeta {
compatible = "android,vbmeta";
parts = "vbmeta,kernel,kernel-dtb,APP,vendor,SOS";
fstab {
compatible = "android,fstab";
vendor {
compatible = "android,vendor";
dev = "/dev/block/platform/3460000.sdhci/by-name/vendor";
type = "ext4";
mnt_flags = "ro";
fsmgr_flags = "wait,avb";
odm {
compatible = "android,odm";
dev = "/dev/block/platform/3460000.sdhci/by-name/odm";
type = "ext4";
mnt_flags = "ro";
spi@c260000 {
status = "disabled";
spi@3210000 {
status = "okay";
spi@0 {
compatible = "spidev";
reg = <0x0>;
spi-max-frequency = <33000000>;
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x11>;
spi@3270000 {
spi@3300000 {
pmc@c370000 {
nvidia,invert-interrupt;
hdr40_i2c0: i2c@c240000 {
bmi160@69 {
compatible = "bmi,bmi160";
reg = <0x69>;
interrupt-parent = <&tegra_aon_gpio>;
interrupts = <TEGRA194_AON_GPIO(AA, 2) GPIO_ACTIVE_LOW>;
accelerometer_matrix = [01 00 00 00 01 00 00 00 01];
gyroscope_matrix = [01 00 00 00 01 00 00 00 01];
accelerometer_delay_us_min = <1250>;
gyroscope_delay_us_min = <1250>;
ucsi_ccg: ucsi_ccg@8 {
status = "okay";
typec-extcon {
typec_port0: port-0 {
status = "okay";
#extcon-cells = <1>;
typec_port1: port-1 {
status = "okay";
typec-pd {
typec_pd: pd {
status = "okay";
#if TEGRA_XUSB_PADCONTROL_VERSION >= DT_VERSION_2
xusb_padctl: xusb_padctl@3520000 {
status = "okay";
pads {
usb2 {
lanes {
usb2-0 {
nvidia,function = "xusb";
status = "okay";
usb2-1 {
status = "okay";
usb2-2 {
status = "okay";
usb2-3 {
status = "okay";
usb3 {
lanes {
usb3-0 {
status = "okay";
usb3-2 {
status = "okay";
usb3-3 {
status = "okay";
ports {
usb2-0 {
mode = "device";
//mode = "otg";
//vbus-supply = <&battery_reg>;
status = "okay";
usb2-1 {
mode = "host";
status = "okay";
usb2-2 {
mode = "host";
status = "okay";
usb2-3 {
mode = "host";
status = "okay";
usb3-0 {
nvidia,usb2-companion = <1>;
status = "okay";
usb3-2 {
//nvidia,usb2-companion = <0>;
nvidia,usb2-companion = <2>;
status = "okay";
usb3-3 {
//nvidia,usb2-companion = <3>;
//nvidia,usb3-gen1-only= <0>;
nvidia,usb3-gen1-only= <1>;
status = "okay";
#endif
tegra_xudc: xudc@3550000 {
/*extcon-cables = <&typec_port0 0>;
extcon-cable-names = "vbus";
#extcon-cells = <1>;*/
phys = <&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-0}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-2}>;
phy-names = "usb2", "usb3";
nvidia,xusb-padctl = <&xusb_padctl>;
#endif
nvidia,boost_cpu_freq = <1200>;
status = "okay";
tegra_xhci: xhci@3610000 {
/*extcon-cables = <&typec_port0 1>;
extcon-cable-names = "id";
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-1}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-3}>,
<&{/xusb_padctl@3520000/pads/usb2/lanes/usb2-2}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-2}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-0}>,
<&{/xusb_padctl@3520000/pads/usb3/lanes/usb3-3}>;
phy-names = "usb2-0", "usb2-1", "usb2-3", "usb2-2",
"usb3-2", "usb3-0", "usb3-3";
#endif
status = "okay";
arm-pmu {
status = "okay";
power-domain {
interrupt-controller {
mods-simple-bus {
eeprom-manager {
cpuidle {
compatible = "nvidia,tegra19x-cpuidle";
status = "okay";
thermal-zones {
reserved-memory {
ramoops_carveout {
status = "okay";
mttcan@c310000 {
status = "okay";
mttcan@c320000 {
status = "okay";
serial@3110000 {
status = "okay";
pwm@3280000 {
status = "okay";
pwm@32c0000 {
status = "okay";
pwm@32f0000 {
status = "okay";
hdr40_i2c1: i2c@31e0000 {
pinctrl-names = "default";
pinctrl-0 = <&dpaux_default>;
bmi160@69 {
reg = <0x69>;
host1x {
dpaux@155F0000 {
status = "okay";
compatible = "nvidia,tegra194-dpaux3-padctl";
/delete-property/ power-domains;
dpaux_default: pinmux@0 {
dpaux3_pins {
pins = "dpaux3-3";
function = "i2c";
hardwood {
compatible = "nvidia,denver-hardwood";
interrupts = <0 24 0x4>;
ufshci@2450000 {
nvidia,enable-hs-mode;
nvidia,cd-gpios = <&tegra_aon_gpio TEGRA194_AON_GPIO(EE, 0) GPIO_ACTIVE_HIGH>;
nvidia,cd-wakeup-capable;
pfsd {
pwm_polarity= <PWM_POLARITY_NORMAL>;
suspend_state = <0>;
&head0 {
extcon-cables = <&typec_port0 2 &typec_port1 2>;
extcon-cable-names = "typec0", "typec1";
&head1 {
&head2 {
&sor0 {
nvidia,typec-port = /bits/ 8 <0>;
&sor1 {
nvidia,typec-port = /bits/ 8 <1>;
#if LINUX_VERSION >= 414
#include <tegra194-linux-4.14.dtsi>
#endif
Can anyone spread some insight to configure device tree ?
Thanks,
