[ 99.647926] tegra-xusb 3530000.xhci: controller firmware hang
[ 99.653674] tegra-xusb 3530000.xhci: hcd_reinit is disabled or in progress
[ 103.753396] tegra-xusb 3530000.xhci: xHCI host not responding to stop endpoint command.
[ 103.761395] tegra-xusb 3530000.xhci: Assuming host is dying, halting host.
root@tegra-ubuntu:/home/asus# lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/3p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
root@tegra-ubuntu:/home/asus# ./diagnostic_client_cu -a
Data are saved to “xusb_diag_fw_cu.log”.
Just to double confirm, can we use the original usb hub on the devkit to reproduce this issue?
I mean it seems you have a different hub in below.
Connect U3 hub to usb30_0 port is required, we can reproduce this issue with three different usb 3.0 hubs. Since we need produce a heavy traffic by u3 ethernet dongle.
Hi~Wayne,
Yes, you can use the original USB30 hub (RTS5489-GR) of the devkit to reproduce this issue. You can see the below block diagram. This is how we reproduce this issue on devkit. About the USB20 hub of the USB2_2 bus, You can use any USB30 or USB20 hub connected to the USB20_2 bus. We use transcend and DigFusion USB30 hub connected to USB20_2 bus. This issue also can be reproduced. So, I believe the USB issues also can reproduce on any USB20 or USB30 hub.
Our board USB test configration:
USB30_0+USB20_1 → USB30 hub - GL3523T-OTY20
USB20_2–> USB20 hub - GL852GT-OHG12
Devkit USB test configration:
USB30_0+USB20_1 → USB30 hub (RTS5489-GR)
USB20_2–>
DigFusion USB30 hub http://www.galileo.com.tw/U3H04FF.html
Transcend USB30 hub
Do I also need a LTE module? TzuWen mentioned it but I didn’t see it in your picture. Is that USB to mini-pcie card for this LTE module?
Yes, LTE/GPS module is also required. You need to connect BT and LTE/GPS module to the USB20 hub of the USB20_2 bus. We use Quectel EG25-G LTE/GPS module.
Hi~Wayne,
TX2_180-13636-DAAA-A03 + devkit with our software image test result.
I will upload the other software image test result tomorrow. TX2_180-13636-DAAA-A03_with devkit_20220317.log (90.0 KB)
By the way, Do you know how many parameters of USB controller that we can fine-tune in the software??
I think we can test these parameters when we have time.
[ 2760.512449] tegra-xusb 3530000.xhci: controller firmware hang
[ 2760.518193] tegra-xusb 3530000.xhci: hcd_reinit is disabled or in progress
[ 2764.617926] tegra-xusb 3530000.xhci: xHCI host not responding to stop endpoint command.
[ 2764.625925] tegra-xusb 3530000.xhci: Assuming host is dying, halting host.
[ 2764.648809] tegra-xusb 3530000.xhci: Host not halted after 16000 microseconds.
[ 2764.656024] tegra-xusb 3530000.xhci: Non-responsive xHCI host is not halting.
[ 2764.663145] tegra-xusb 3530000.xhci: Completing active URBs anyway.
[ 2764.708406] tegra-xusb 3530000.xhci: HC died; cleaning up
[ 2764.713820] tegra-xusb 3530000.xhci: hcd_reinit is disabled or in progress
[ 2772.714901] tegra-xusb 3530000.xhci: Stopped the command ring failed, maybe the host is dead
No, that won’t update the usb firmware. USB firmware is inside initrd. Use below method to open the initrd and put the new usb fw into it. If the firmware is changed correctly, your dmesg shall see different usb firmware info.
Is “xusb_sil_prod_fw-new” the same as what you provided(xusb_sil_rel_fw) earlier?
I have generated the l4t_initrd.img. Could you please tell me how to burn this image?
