Use accelmath.h with pgc++
I was naively thinking that it’d be fine if I just simply replaced by <accelmath.h> for the acc code that used some (common and simple) math functions. For the following code sample, pgc++ complained that identifier “floorf” was not defined.
$ pgcc --version
pgcc 19.4-0 LLVM 64-bit target on x86-64 Linux -tp penryn
PGI Compilers and Tools
Copyright (c) 2019, NVIDIA CORPORATION.  All rights reserved.
pgc++ --version
pgc++ 19.4-0 LLVM 64-bit target on x86-64 Linux -tp penryn
pgcc -c -acc -ta:tesla eg.c
pgc++ -c -acc -ta:tesla eg.cc
#include <accelmath.h>
#pragma acc routine seq
float f1(float x) {
  float y;
  y = ceilf(x);
  return y;
float f2(float x) {
  float y;
  y = floorf(x);
  return y;
float f3(float x) {
  float y;
  y = sqrtf(x);
  return y;
I had suspected that this was a C++11 compatibility issue because float std::floorf(float) and float std::ceilf(float) only became available since C++11 (ref. std::ceil, std::ceilf, std::ceill - cppreference.com and std::floor, std::floorf, std::floorl - cppreference.com), but the source code (/opt/pgi/linux86-64-llvm/2019/include/accelmath.h) only safeguards “extern float floorf(float)” within #ifndef __cplusplus, which eventually confused me.
Apparently I cannot convert the whole project to C… What should I do to get around it?
stw
Hi stw,
The error looks to be coming from the host-side code generation. By default both a device and host version of the subroutine will be created. The solution is to include both “cmath” and “accelmath.h”:
% cat eg1.cc
#include <cmath>
#ifdef _OPENACC
#endif
float f1(float x) {
  float y;
  y = ceilf(x);
  return y;
float f2(float x) {
  float y;
  y = floorf(x);
  return y;
float f3(float x) {
  float y;
  y = sqrtf(x);
  return y;
% pgc++ eg1.cc -c -ta=tesla -Minfo -V19.4
f1(float):
      8, Generating acc routine seq
         Generating Tesla code
f2(float):
     15, Generating acc routine seq
f3(float):
     22, Generating acc routine seq
Hope this helps,
Mat
