Use MPS in ffmpeg with NVDEC error.
I use ffmpeg compiled with cuda, support nvdec to decode h264 in gpu devices. MPS(Multi-Process Service :: GPU Deployment and Management Documentation) can share context with different processes, and this can use less gpu storage when use multi-process to decode h264 stream. But when I use ffmpeg in this mode, error got like this.
Input #0, mpeg, from ‘/data/yt_traffic/media/nianjianbiao.mp4’:
Duration: 00:16:57.97, start: 7833.134000, bitrate: 4219 kb/s
Stream #0:0[0x1e0]: Video: h264 (High), yuv420p(progressive), 1920x1080, 25 fps, 25 tbr, 90k tbn, 50 tbc
File ‘1.yuv’ already exists. Overwrite ? [y/N] y
[AVHWDeviceContext @ 0x4444840] Could not initialize the CUDA driver API
Stream mapping:
Stream #0:0 → #0:0 (h264 (h264_cuvid) → rawvideo (native))
Error while opening decoder for input stream #0:0 : Unknown error occurred
And, when mps is shutdown, ffmpeg works fine. Anyone can help?
Can you specify which GPU and driver version you are using?
Thanks for rely, my gpu device is GeForce GTX 1080 Ti, driver version is 396.24.02
