NVDEC segfaults with 430.xx drivers on GK104
I’m using Arch Linux and have a GTX 760. Since the 430.14 driver GPU video decoding is not working in mpv (hwdec option set to nvdec/cuda). The last working driver was 418.74. After a call to cuvidCreateDecoder the process will always segfault in libnvcuvid.so.1. Decoding via VDPAU works without any issues.
It looks like NVENC on GK104 GPUs segfaults as well:
https://devtalk.nvidia.com/default/topic/1054759/linux/nvenc-fails-on-latest-archlinux-nvidia-driver-430-26/
Packages:
  • nvidia 430.26-2
  • nvidia-utils 430.26-1
  • ffmpeg 1:4.1.3-1
  • mpv 1:0.29.1-6
mpv output:
[~]» mpv -v --hwdec=nvdec test.mp4
[cplayer] Command line options: '-v' '--hwdec=nvdec' 'test.mp4'
[cplayer] mpv 0.29.1 Copyright © 2000-2018 mpv/MPlayer/mplayer2 projects
[cplayer]  built on Fri Apr 19 20:49:51 UTC 2019
[cplayer] ffmpeg library versions:
[cplayer]    libavutil       56.22.100
[cplayer]    libavcodec      58.35.100
[cplayer]    libavformat     58.20.100
[cplayer]    libswscale      5.3.100
[cplayer]    libavfilter     7.40.101
[cplayer]    libswresample   3.3.100
[cplayer] ffmpeg version: n4.1.3
[cplayer]
[cplayer] Configuration: ./waf configure --prefix=/usr --confdir=/etc/mpv --enable-cdda --enable-dvb --enable-dvdnav --enable-libarchive --enable-libmpv-shared --enable-libsmbclient --enable-tv --enable-zsh-comp
[cplayer] List of enabled features: 52arch alsa asm atomics audio-input build-date caca cdda cplayer cplugins cuda-hwaccel debug-build drm drmprime dvbin dvdnav dvdread-common egl-drm egl-helpers egl-x11 fchmod ffmpeg ffnvcodec gbm gbm.h gl gl-wayland gl-x11 glibc-thread-name glob glob-posix gnuc gpl iconv jack jpeg lcms2 libaf libarchive libass libass-osd libav-any libavcodec libavdevice libbluray libdl libm libmpv-shared librt libsmbclient libv4l2 linux-fstatfs lua optimize oss-audio plain-gl posix posix-or-mingw posix-spawn posix-spawn-native pthreads pulse rubberband shaderc shaderc-shared stdatomic tv tv-v4l2 uchardet vaapi vaapi-drm vaapi-egl vaapi-glx vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vdpau-gl-x11 videodev vt.h vulkan wayland wayland-protocols x11 xv zlib zsh-comp
[cplayer] Reading config file /etc/mpv/encoding-profiles.conf
[cplayer] Reading config file /home/user/.config/mpv/mpv.conf
[cplayer] Waiting for scripts...
[stats] script-opts/stats.conf not found.
[stats] lua-settings/stats.conf not found.
[ytdl_hook] script-opts/ytdl_hook.conf not found.
[ytdl_hook] lua-settings/ytdl_hook.conf not found.
[osc] script-opts/osc.conf not found.
[osc] lua-settings/osc.conf not found.
[cplayer] Done loading scripts.
[cplayer] Playing: test.mp4
[cplayer] Running hook: ytdl_hook/on_load
[ytdl_hook] ytdl:// hook
[ytdl_hook] not a ytdl:// url
[osd/libass] Shaper: FriBidi 0.19.7 (SIMPLE) HarfBuzz-ng 2.5.1 (COMPLEX)
[osd/libass] Setting up fonts...
[ifo] Opening test.mp4
[ifo_dvdnav] Opening test.mp4
[bdmv/bluray] Opening test.mp4
[file] Opening test.mp4
[demux] Trying demuxers for level=normal.
[lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048.
[demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat)
[cplayer] Opening done: test.mp4
[find_files] Loading external files in .
[cplayer] Running hook: ytdl_hook/on_preloaded
[lavf] select track 0
[lavf] select track 1
[cplayer]  (+) Video --vid=1 (*) (h264 640x360 29.970fps)
[cplayer]  (+) Audio --aid=1 (*) (aac 2ch 44100Hz)
[vo/gpu] Probing for best GPU context.
[vo/gpu/opengl] Initializing GPU context 'x11probe'
[vo/gpu/x11] X11 opening display: :1
[vo/gpu/x11] X11 running at 1280x1024 (":1" => local display)
[osd/libass] Using font provider fontconfig
[osd/libass] Done.
[vo/gpu/x11] Detected wm supports NetWM.
[vo/gpu/x11] Detected wm supports FULLSCREEN state.
[vo/gpu/x11] Detected wm supports ABOVE state.
[vo/gpu/x11] Detected wm supports BELOW state.
[vo/gpu/x11] Display 0 (DVI-I-0): [0, 0, 1280, 1024] @ 75.024675 FPS
[vo/gpu/x11] Current display FPS: 75.024675
[vo/gpu/opengl] GLX chose FB config with ID 0x10d
[vo/gpu/opengl] GLX chose visual with ID 0x27
[vo/gpu/opengl] Creating OpenGL 4.4 context...
[vo/gpu] GL_VERSION='4.4.0 NVIDIA 430.26'
[vo/gpu] Detected desktop OpenGL 4.4.
[vo/gpu] GL_VENDOR='NVIDIA Corporation'
[vo/gpu] GL_RENDERER='GeForce GTX 760/PCIe/SSE2'
[vo/gpu] GL_SHADING_LANGUAGE_VERSION='4.40 NVIDIA via Cg compiler'
[vo/gpu] Loaded extension GLX_SGI_swap_control.
[vo/gpu] Loaded extension GLX_SGI_video_sync.
[vo/gpu] Loaded extension GL_NV_vdpau_interop.
[vo/gpu] Testing FBO format rgba16f
[vo/gpu] Using FBO format rgba16f.
[vo/gpu] No advanced processing required. Enabling dumb mode.
[vo/gpu] Assuming 75.024675 FPS for display sync.
[vd] Container reported FPS: 29.970030
[vd] Codec list:
[vd]     h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[vd]     h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper
[vd]     h264_cuvid (h264) - Nvidia CUVID H264 decoder
[vd] Opening decoder h264
[vd] Looking at hwdec h264-nvdec...
[vo/gpu] Loading hwdec driver 'vaapi-egl'
[vo/gpu] Loading failed.
[vo/gpu] Loading hwdec driver 'cuda-nvdec'
[vo/gpu] Loading hwdec driver 'vdpau-glx'
[vo/gpu] Loading hwdec driver 'drmprime-drm'
[vo/gpu/drmprime-drm] Failed to retrieve DRM fd from native display.
[vd] Trying hardware decoding via h264-nvdec.
[vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
[vf] User filter list:
[vf]   (empty)
[ad] Codec list:
[ad]     aac - AAC (Advanced Audio Coding)
[ad]     aac_fixed (aac) - AAC (Advanced Audio Coding)
[ad] Opening decoder aac
[ad] Requesting 1 threads for decoding.
[ad] Selected codec: aac (AAC (Advanced Audio Coding))
[af] User filter list:
[af]   (empty)
[cplayer] Starting playback...
[af] [in] 44100Hz stereo 2ch floatp
[af] [userspeed] 44100Hz stereo 2ch floatp
[af] [userspeed] (disabled)
[af] [convert] 44100Hz stereo 2ch floatp
[vd] Pixel formats supported by decoder: vdpau cuda vaapi_vld yuv420p
[vd] Codec profile: Main (0x4d)
[vd] Requesting pixfmt 'cuda' from decoder.
[1]    5916 segmentation fault (core dumped)  mpv -v --hwdec=nvdec test.mp4
coredumpctl output:
[~]» coredumpctl info
           PID: 5916 (mpv)
           UID: 1000 (user)
           GID: 1000 (user)
        Signal: 11 (SEGV)
     Timestamp: Thu 2019-06-13 17:02:02 CEST (5min ago)
  Command Line: mpv -v --hwdec=nvdec test.mp4
    Executable: /usr/bin/mpv
 Control Group: /user.slice/user-1000.slice/user@1000.service/dbus.service
          Unit: user@1000.service
     User Unit: dbus.service
         Slice: user-1000.slice
     Owner UID: 1000 (user)
       Boot ID: dde5d2b0bb98430d879fc607f43325a8
    Machine ID: 1c21780184db97a0adbcd43f1cc073f6
      Hostname: pc
       Storage: /var/lib/systemd/coredump/core.mpv.1000.dde5d2b0bb98430d879fc607f43325a8.5916.1560438122000000.lz4
       Message: Process 5916 (mpv) of user 1000 dumped core.
                Stack trace of thread 5916:
                #0  0x00007f81fe69c0c0 n/a (libnvcuvid.so.1)
                #1  0x00007f81fe683355 n/a (libnvcuvid.so.1)
                #2  0x00007f81fe670f75 n/a (libnvcuvid.so.1)
                #3  0x00007f81fe671a68 n/a (libnvcuvid.so.1)
                #4  0x00007f81fe67a24f n/a (libnvcuvid.so.1)
                #5  0x00007f81fe678575 n/a (libnvcuvid.so.1)
                #6  0x00007f81fe67933b n/a (libnvcuvid.so.1)
                #7  0x00007f81fe673ac4 cuvidCreateDecoder (libnvcuvid.so.1)
                #8  0x00007f82359f60d7 n/a (libavcodec.so.58)
                #9  0x00007f82356a877f n/a (libavcodec.so.58)
                #10 0x00007f82357bb646 n/a (libavcodec.so.58)
                #11 0x00007f82357bc4e4 n/a (libavcodec.so.58)
                #12 0x00007f82357c19d8 n/a (libavcodec.so.58)
                #13 0x00007f82357c5659 n/a (libavcodec.so.58)
                #14 0x00007f82356a6be0 n/a (libavcodec.so.58)
                #15 0x00007f82356a78e8 avcodec_send_packet (libavcodec.so.58)
                #16 0x000055c9a65dfd86 n/a (mpv)
                #17 0x000055c9a656d1f3 n/a (mpv)
                #18 0x000055c9a65749c2 n/a (mpv)
                #19 0x000055c9a6574a19 n/a (mpv)
                #20 0x000055c9a6574c0a n/a (mpv)
                #21 0x000055c9a6593fe9 n/a (mpv)
                #22 0x000055c9a65b4b5d n/a (mpv)
                #23 0x000055c9a65ab919 n/a (mpv)
                #24 0x000055c9a65affb9 n/a (mpv)
                #25 0x00007f8233986ce3 __libc_start_main (libc.so.6)
                #26 0x000055c9a653521e n/a (mpv)
                Stack trace of thread 5919:
                #0  0x00007f8234904f0b pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0)
                #1  0x000055c9a6594935 n/a (mpv)
                #2  0x000055c9a659677d mpv_wait_event (mpv)
                #3  0x000055c9a65ae013 n/a (mpv)
                #4  0x00007f8234e3f20e n/a (liblua5.2.so.5.2)
                #5  0x00007f8234e4afec n/a (liblua5.2.so.5.2)
                #6  0x00007f8234e3f5b8 n/a (liblua5.2.so.5.2)
                #7  0x00007f8234e3b68b lua_callk (liblua5.2.so.5.2)
                #8  0x000055c9a65ad096 n/a (mpv)
                #9  0x00007f8234e3f20e n/a (liblua5.2.so.5.2)
                #10 0x00007f8234e3f582 n/a (liblua5.2.so.5.2)
                #11 0x00007f8234e3eb30 n/a (liblua5.2.so.5.2)
                #12 0x00007f8234e3f7ff n/a (liblua5.2.so.5.2)
                #13 0x00007f8234e3b751 lua_pcallk (liblua5.2.so.5.2)
                #14 0x000055c9a65aed96 n/a (mpv)
                #15 0x00007f8234e3f20e n/a (liblua5.2.so.5.2)
                #16 0x00007f8234e3f582 n/a (liblua5.2.so.5.2)
                #17 0x00007f8234e3eb30 n/a (liblua5.2.so.5.2)
                #18 0x00007f8234e3f7ff n/a (liblua5.2.so.5.2)
                #19 0x00007f8234e3b751 lua_pcallk (liblua5.2.so.5.2)
                #20 0x000055c9a65af28c n/a (mpv)
                #21 0x000055c9a65b65ca n/a (mpv)
                #22 0x00007f82348fea92 start_thread (libpthread.so.0)
                #23 0x00007f8233a5dcd3 __clone (libc.so.6)
                Stack trace of thread 5923:
                #0  0x00007f8233a530d1 __poll (libc.so.6)
                #1  0x000055c9a6630dc1 n/a (mpv)
                #2  0x000055c9a66142c8 n/a (mpv)
                #3  0x00007f82348fea92 start_thread (libpthread.so.0)
                #4  0x00007f8233a5dcd3 __clone (libc.so.6)
                Stack trace of thread 5927:
                #1  0x00007f821cd61be7 n/a (libcuda.so.1)
                #2  0x00007f821cd07257 n/a (libcuda.so.1)
                #3  0x00007f821cd60e68 n/a (libcuda.so.1)
                #4  0x00007f82348fea92 start_thread (libpthread.so.0)
                #5  0x00007f8233a5dcd3 __clone (libc.so.6)
                Stack trace of thread 5924:
                #0  0x00007f8234907506 do_futex_wait.constprop.1 (libpthread.so.0)
                #1  0x00007f8234907608 __new_sem_wait_slow.constprop.0 (libpthread.so.0)
                #2  0x000055c9a662be49 n/a (mpv)
                Stack trace of thread 5920:
                Stack trace of thread 5922:
                #0  0x00007f8234904bac pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0)
                #1  0x000055c9a655250f n/a (mpv)
                #2  0x00007f82348fea92 start_thread (libpthread.so.0)
                #3  0x00007f8233a5dcd3 __clone (libc.so.6)
                Stack trace of thread 5918:
                Stack trace of thread 5917:
                #1  0x000055c9a6633e9c n/a (mpv)
                Stack trace of thread 5926:
                #1  0x00007f821cd5e7f3 n/a (libcuda.so.1)
                #2  0x00007f821cde706d n/a (libcuda.so.1)
                Stack trace of thread 5925:
                #0  0x00007f8233a5f677 accept4 (libc.so.6)
                #1  0x00007f821cd5f79a n/a (libcuda.so.1)
                #2  0x00007f821cd51a9d n/a (libcuda.so.1)
I just wanted to confirm this. I have the same issue with Fedora 30, 430.26 driver, GTX 760. I can provide a stack trace as well but it would be redundant. As the OP said, 418.74 is fine. I have not tried 430.14.
I’m still seeing this with the 430.40 driver. I’m not so hot with stack traces but I can try that if that would help. I suspect the crash is similar to the one posted above. Again, this is with a 760 GTX video card.
mpv output:
[   0.002][v][cplayer] mpv 0.29.0-369-g639ee55df7 Copyright © 2000-2019 mpv/MPlayer/mplayer2 projects
[   0.002][v][cplayer]  built on Wed Aug  7 09:05:52 EDT 2019
[   0.002][v][cplayer] ffmpeg library versions:
[   0.002][v][cplayer]    libavutil       56.33.100
[   0.002][v][cplayer]    libavcodec      58.55.100
[   0.002][v][cplayer]    libavformat     58.30.100
[   0.002][v][cplayer]    libswscale      5.6.100
[   0.002][v][cplayer]    libavfilter     7.58.100
[   0.002][v][cplayer]    libswresample   3.6.100
[   0.002][v][cplayer] ffmpeg version: N-94483-g98e419cbf5
[   0.002][v][cplayer] Configuration: ./waf configure --enable-libmpv-shared
[   0.002][v][cplayer] List of enabled features: alsa asm atomics build-date caca cplayer cplugins cuda-hwaccel debug-build drm egl-helpers egl-x11 fchmod ffmpeg ffnvcodec gl gl-x11 glibc-thread-name glob glob-posix gnuc gpl iconv jack jpeg libaf libass libass-osd libav-any libavcodec libavdevice libbluray libdl libm libmpv-shared librt linux-fstatfs optimize oss-audio plain-gl posix posix-or-mingw posix-spawn posix-spawn-native pthreads pulse stdatomic vaapi vaapi-egl vaapi-glx vaapi-x-egl vaapi-x11 vdpau vdpau-gl-x11 vt.h x11 xv zlib
[   0.002][v][cplayer] Command line options: '-v' '--hwdec=auto' '/storage/samba/videos/Misc/Jinx Squirrel 20151212.MOV' '--log-file=mpv_crash.log'
[   0.002][d][cplayer] Setting option 'v' = '' (flags = 8)
[   0.002][d][cplayer] Setting option 'hwdec' = 'auto' (flags = 8)
[   0.002][d][cplayer] Setting option 'log-file' = 'mpv_crash.log' (flags = 8)
[   0.003][d][global] user path: 'mpv_crash.log' -> 'mpv_crash.log'
[   0.003][d][global] config path: 'scripts' -/-> '/home/syn4pse/.config/mpv/scripts'
[   0.003][d][global] config path: 'scripts' -/-> '/home/syn4pse/.mpv/scripts'
[   0.003][d][global] config path: 'scripts' -/-> '/usr/local/etc/mpv/scripts'
[   0.003][d][global] config path: 'watch_later' -> '/home/syn4pse/.config/mpv/watch_later'
[   0.003][i][cplayer] Playing: /storage/samba/videos/Misc/Jinx Squirrel 20151212.MOV
[   0.003][v][bdmv/bluray] Opening /storage/samba/videos/Misc/Jinx Squirrel 20151212.MOV
[   0.004][v][file] Opening /storage/samba/videos/Misc/Jinx Squirrel 20151212.MOV
[   0.004][d][file] Stream opened successfully.
[   0.004][v][demux] Trying demuxers for level=normal.
[   0.004][d][demux] Trying demuxer: disc (force-level: normal)
[   0.004][d][demux] Trying demuxer: edl (force-level: normal)
[   0.004][d][demux] Trying demuxer: cue (force-level: normal)
[   0.004][d][demux] Trying demuxer: rawaudio (force-level: normal)
[   0.004][d][demux] Trying demuxer: rawvideo (force-level: normal)
[   0.004][d][demux] Trying demuxer: mkv (force-level: normal)
[   0.004][d][demux] Trying demuxer: rar (force-level: normal)
[   0.004][d][demux] Trying demuxer: lavf (force-level: normal)
[   0.005][v][lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048.
[   0.006][v][demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat)
[   0.006][v][cplayer] Opening done: /storage/samba/videos/Misc/Jinx Squirrel 20151212.MOV
[   0.007][v][find_files] Loading external files in /storage/samba/videos/Misc/
[   0.007][d][global] config path: 'sub' -/-> '/home/syn4pse/.config/mpv/sub'
[   0.007][d][global] config path: 'sub' -/-> '/home/syn4pse/.mpv/sub'
[   0.007][d][global] config path: 'sub' -/-> '/usr/local/etc/mpv/sub'
[   0.007][v][lavf] select track 0
[   0.007][v][lavf] select track 1
[   0.007][i][cplayer]  (+) Video --vid=1 (*) (h264 1920x1080 23.976fps)
[   0.007][i][cplayer]  (+) Audio --aid=1 --alang=eng (*) (pcm_s16le 2ch 48000Hz)
[   0.007][v][vo/gpu] Probing for best GPU context.
[   0.007][v][vo/gpu/opengl] Initializing GPU context 'x11probe'
[   0.007][v][vo/gpu/x11] X11 opening display: :0.0
[   0.011][v][vo/gpu/x11] X11 running at 1920x1080 (":0.0" => local display)
[   0.011][v][vo/gpu/x11] Detected wm supports NetWM.
[   0.011][v][vo/gpu/x11] Detected wm supports ABOVE state.
[   0.011][v][vo/gpu/x11] Detected wm supports BELOW state.
[   0.011][v][vo/gpu/x11] Detected wm supports FULLSCREEN state.
[   0.011][v][vo/gpu/x11] Display 0 (HDMI-0): [0, 0, 1920, 1080] @ 60.000000 FPS
[   0.011][v][vo/gpu/x11] Current display FPS: 60.000000
[   0.024][v][vo/gpu/opengl] GLX chose FB config with ID 0x10d
[   0.024][v][vo/gpu/opengl] GLX chose visual with ID 0x27
[   0.027][v][vo/gpu/opengl] Creating OpenGL 4.4 context...
[   0.060][v][vo/gpu] GL_VERSION='4.4.0 NVIDIA 430.40'
[   0.060][v][vo/gpu] Detected desktop OpenGL 4.4.
[   0.060][v][vo/gpu] GL_VENDOR='NVIDIA Corporation'
[   0.060][v][vo/gpu] GL_RENDERER='GeForce GTX 760/PCIe/SSE2'
[   0.060][v][vo/gpu] GL_SHADING_LANGUAGE_VERSION='4.40 NVIDIA via Cg compiler'
[   0.060][d][vo/gpu] Combined OpenGL extensions string:
[   0.060][d][vo/gpu] GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_video_sync GLX_SGI_swap_control GLX_EXT_swap_control GLX_EXT_swap_control_tear GLX_EXT_texture_from_pixmap GLX_EXT_buffer_age GLX_ARB_create_context GLX_ARB_create_context_profile GLX_EXT_create_context_es_profile GLX_EXT_create_context_es2_profile GLX_ARB_create_context_no_error GLX_ARB_create_context_robustness GLX_NV_delay_before_swap GLX_EXT_stereo_tree GLX_ARB_context_flush_control GLX_NV_robustness_video_memory_purge GLX_ARB_multisample GLX_NV_float_buffer GLX_ARB_fbconfig_float GLX_EXT_framebuffer_sRGB GLX_NV_multisample_coverage GLX_NV_copy_image GLX_ARB_get_proc_address  GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_clock GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_NV_robustness_video_memory_purge GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_EXT_memory_object GL_EXT_memory_object_fd GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_EXT_semaphore GL_EXT_semaphore_fd GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_draw_vulkan_image GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_feature_query GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vdpau_interop GL_NV_vdpau_interop2 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_nvenc_interop GL_NV_shader_thread_group GL_NV_shader_thread_shuffle GL_KHR_blend_equation_advanced GL_OVR_multiview GL_OVR_multiview2 GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
[   0.060][v][vo/gpu] Loaded extension GLX_SGI_swap_control.
[   0.060][v][vo/gpu] Loaded extension GLX_SGI_video_sync.
[   0.060][v][vo/gpu] Loaded extension GL_NV_vdpau_interop.
[   0.061][d][vo/gpu/opengl] Texture formats:
[   0.061][d][vo/gpu/opengl]   NAME       COMP*TYPE SIZE        DEPTH PER COMP.
[   0.061][d][vo/gpu/opengl]   r8         1*unorm   1B    LF CR {8}
[   0.061][d][vo/gpu/opengl]   rg8        2*unorm   2B    LF CR {8 8}
[   0.061][d][vo/gpu/opengl]   rgb8       3*unorm   3B    LF CR {8 8 8}
[   0.061][d][vo/gpu/opengl]   rgba8      4*unorm   4B    LF CR {8 8 8 8}
[   0.061][d][vo/gpu/opengl]   r16        1*unorm   2B    LF CR {16}
[   0.061][d][vo/gpu/opengl]   rg16       2*unorm   4B    LF CR {16 16}
[   0.061][d][vo/gpu/opengl]   rgb16      3*unorm   6B    LF CR {16 16 16}
[   0.061][d][vo/gpu/opengl]   rgba16     4*unorm   8B    LF CR {16 16 16 16}
[   0.061][d][vo/gpu/opengl]   r8ui       1*uint    1B       CR {8}
[   0.061][d][vo/gpu/opengl]   rg8ui      2*uint    2B       CR {8 8}
[   0.061][d][vo/gpu/opengl]   rgb8ui     3*uint    3B          {8 8 8}
[   0.061][d][vo/gpu/opengl]   rgba8ui    4*uint    4B       CR {8 8 8 8}
[   0.061][d][vo/gpu/opengl]   r16ui      1*uint    2B       CR {16}
[   0.061][d][vo/gpu/opengl]   rg16ui     2*uint    4B       CR {16 16}
[   0.061][d][vo/gpu/opengl]   rgb16ui    3*uint    6B          {16 16 16}
[   0.061][d][vo/gpu/opengl]   rgba16ui   4*uint    8B       CR {16 16 16 16}
[   0.061][d][vo/gpu/opengl]   r16f       1*float   4B    LF CR {32/16}
[   0.061][d][vo/gpu/opengl]   rg16f      2*float   8B    LF CR {32/16 32/16}
[   0.061][d][vo/gpu/opengl]   rgb16f     3*float  12B    LF CR {32/16 32/16 32/16}
[   0.061][d][vo/gpu/opengl]   rgba16f    4*float  16B    LF CR {32/16 32/16 32/16 32/16}
[   0.061][d][vo/gpu/opengl]   r32f       1*float   4B    LF CR {32}
[   0.061][d][vo/gpu/opengl]   rg32f      2*float   8B    LF CR {32 32}
[   0.061][d][vo/gpu/opengl]   rgb32f     3*float  12B    LF CR {32 32 32}
[   0.061][d][vo/gpu/opengl]   rgba32f    4*float  16B    LF CR {32 32 32 32}
[   0.061][d][vo/gpu/opengl]   rgb10_a2   4*unorm   4B    LF CR {0/10 0/10 0/10 0/2}
[   0.061][d][vo/gpu/opengl]   rgba12     4*unorm   8B    LF CR {16 16 16 16}
[   0.061][d][vo/gpu/opengl]   rgb10      3*unorm   6B    LF CR {16/10 16/10 16/10}
[   0.061][d][vo/gpu/opengl]   rgb565     3*unorm   2B    LF    {0/8 0/8 0/8}
[   0.061][d][vo/gpu/opengl]  LA = LUMINANCE_ALPHA hack format
[   0.061][d][vo/gpu/opengl]  LF = linear filterable
[   0.061][d][vo/gpu/opengl]  CR = can be used for render targets
[   0.061][d][vo/gpu/opengl] Image formats:
[   0.061][d][vo/gpu/opengl]   yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   gray => 1 planes 1x1 8/0 [r8] (r)
[   0.061][d][vo/gpu/opengl]   gray16 => 1 planes 1x1 16/0 [r16] (r)
[   0.061][d][vo/gpu/opengl]   uyvy422
[   0.061][d][vo/gpu/opengl]   nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb)
[   0.061][d][vo/gpu/opengl]   p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb)
[   0.061][d][vo/gpu/opengl]   nv24 => 2 planes 1x1 8/0 [r8/rg8] (r/gb)
[   0.061][d][vo/gpu/opengl]   argb => 1 planes 1x1 8/0 [rgba8] (argb)
[   0.061][d][vo/gpu/opengl]   bgra => 1 planes 1x1 8/0 [rgba8] (bgra)
[   0.061][d][vo/gpu/opengl]   abgr => 1 planes 1x1 8/0 [rgba8] (abgr)
[   0.061][d][vo/gpu/opengl]   rgba => 1 planes 1x1 8/0 [rgba8] (rgba)
[   0.061][d][vo/gpu/opengl]   bgr24 => 1 planes 1x1 8/0 [rgb8] (bgr)
[   0.061][d][vo/gpu/opengl]   rgb24 => 1 planes 1x1 8/0 [rgb8] (rgb)
[   0.061][d][vo/gpu/opengl]   0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb)
[   0.061][d][vo/gpu/opengl]   bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr)
[   0.061][d][vo/gpu/opengl]   0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr)
[   0.061][d][vo/gpu/opengl]   rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb)
[   0.061][d][vo/gpu/opengl]   rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba)
[   0.061][d][vo/gpu/opengl]   rgb565 => 1 planes 1x1 0/0 [rgb565] (rgb)
[   0.061][d][vo/gpu/opengl]   vdpau
[   0.061][d][vo/gpu/opengl]   vdpau_output
[   0.061][d][vo/gpu/opengl]   vaapi
[   0.061][d][vo/gpu/opengl]   dxva2_vld
[   0.061][d][vo/gpu/opengl]   mmal
[   0.061][d][vo/gpu/opengl]   videotoolbox
[   0.061][d][vo/gpu/opengl]   cuda
[   0.061][d][vo/gpu/opengl]   yuyv422
[   0.061][d][vo/gpu/opengl]   yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   monow
[   0.061][d][vo/gpu/opengl]   monob
[   0.061][d][vo/gpu/opengl]   pal8
[   0.061][d][vo/gpu/opengl]   yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   uyyvyy411
[   0.061][d][vo/gpu/opengl]   bgr8
[   0.061][d][vo/gpu/opengl]   bgr4
[   0.061][d][vo/gpu/opengl]   bgr4_byte
[   0.061][d][vo/gpu/opengl]   rgb4
[   0.061][d][vo/gpu/opengl]   rgb4_byte
[   0.061][d][vo/gpu/opengl]   nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg)
[   0.061][d][vo/gpu/opengl]   gray16be
[   0.061][d][vo/gpu/opengl]   yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   rgb48be
[   0.061][d][vo/gpu/opengl]   rgb48 => 1 planes 1x1 16/0 [rgb16] (rgb)
[   0.061][d][vo/gpu/opengl]   rgb565be
[   0.061][d][vo/gpu/opengl]   rgb555be
[   0.061][d][vo/gpu/opengl]   bgr565be
[   0.061][d][vo/gpu/opengl]   bgr555be
[   0.061][d][vo/gpu/opengl]   vaapi_moco
[   0.061][d][vo/gpu/opengl]   vaapi_idct
[   0.061][d][vo/gpu/opengl]   yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv420p16be
[   0.061][d][vo/gpu/opengl]   yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv422p16be
[   0.061][d][vo/gpu/opengl]   yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv444p16be
[   0.061][d][vo/gpu/opengl]   rgb444
[   0.061][d][vo/gpu/opengl]   rgb444be
[   0.061][d][vo/gpu/opengl]   bgr444
[   0.061][d][vo/gpu/opengl]   bgr444be
[   0.061][d][vo/gpu/opengl]   ya8 => 1 planes 1x1 8/0 [rg8] (ra)
[   0.061][d][vo/gpu/opengl]   bgr48be
[   0.061][d][vo/gpu/opengl]   bgr48 => 1 planes 1x1 16/0 [rgb16] (bgr)
[   0.061][d][vo/gpu/opengl]   yuv420p9be
[   0.061][d][vo/gpu/opengl]   yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv420p10be
[   0.061][d][vo/gpu/opengl]   yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv422p10be
[   0.061][d][vo/gpu/opengl]   yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv444p9be
[   0.061][d][vo/gpu/opengl]   yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv444p10be
[   0.061][d][vo/gpu/opengl]   yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv422p9be
[   0.061][d][vo/gpu/opengl]   yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r)
[   0.061][d][vo/gpu/opengl]   gbrp9be
[   0.061][d][vo/gpu/opengl]   gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r)
[   0.061][d][vo/gpu/opengl]   gbrp10be
[   0.061][d][vo/gpu/opengl]   gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r)
[   0.061][d][vo/gpu/opengl]   gbrp16be
[   0.061][d][vo/gpu/opengl]   gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r)
[   0.061][d][vo/gpu/opengl]   yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva420p9be
[   0.061][d][vo/gpu/opengl]   yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva422p9be
[   0.061][d][vo/gpu/opengl]   yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva444p9be
[   0.061][d][vo/gpu/opengl]   yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva420p10be
[   0.061][d][vo/gpu/opengl]   yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva422p10be
[   0.061][d][vo/gpu/opengl]   yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva444p10be
[   0.061][d][vo/gpu/opengl]   yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva420p16be
[   0.061][d][vo/gpu/opengl]   yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva422p16be
[   0.061][d][vo/gpu/opengl]   yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   yuva444p16be
[   0.061][d][vo/gpu/opengl]   yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a)
[   0.061][d][vo/gpu/opengl]   xyz12 => 1 planes 1x1 16/4 [rgb16] (rgb)
[   0.061][d][vo/gpu/opengl]   xyz12be
[   0.061][d][vo/gpu/opengl]   nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb)
[   0.061][d][vo/gpu/opengl]   nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb)
[   0.061][d][vo/gpu/opengl]   nv20be
[   0.061][d][vo/gpu/opengl]   rgba64be
[   0.061][d][vo/gpu/opengl]   bgra64be
[   0.061][d][vo/gpu/opengl]   bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra)
[   0.061][d][vo/gpu/opengl]   yvyu422
[   0.061][d][vo/gpu/opengl]   ya16be
[   0.061][d][vo/gpu/opengl]   ya16 => 1 planes 1x1 16/0 [rg16] (ra)
[   0.061][d][vo/gpu/opengl]   gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a)
[   0.061][d][vo/gpu/opengl]   gbrap16be
[   0.061][d][vo/gpu/opengl]   gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a)
[   0.061][d][vo/gpu/opengl]   qsv
[   0.061][d][vo/gpu/opengl]   d3d11va_vld
[   0.061][d][vo/gpu/opengl]   yuv420p12be
[   0.061][d][vo/gpu/opengl]   yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv420p14be
[   0.061][d][vo/gpu/opengl]   yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv422p12be
[   0.061][d][vo/gpu/opengl]   yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv422p14be
[   0.061][d][vo/gpu/opengl]   yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv444p12be
[   0.061][d][vo/gpu/opengl]   yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv444p14be
[   0.061][d][vo/gpu/opengl]   yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   gbrp12be
[   0.061][d][vo/gpu/opengl]   gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r)
[   0.061][d][vo/gpu/opengl]   gbrp14be
[   0.061][d][vo/gpu/opengl]   gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r)
[   0.061][d][vo/gpu/opengl]   yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b)
[   0.061][d][vo/gpu/opengl]   bayer_bggr8
[   0.061][d][vo/gpu/opengl]   bayer_rggb8
[   0.061][d][vo/gpu/opengl]   bayer_gbrg8
[   0.061][d][vo/gpu/opengl]   bayer_grbg8
[   0.061][d][vo/gpu/opengl]   bayer_bggr16
[   0.061][d][vo/gpu/opengl]   bayer_bggr16be
[   0.061][d][vo/gpu/opengl]   bayer_rggb16
[   0.061][d][vo/gpu/opengl]   bayer_rggb16be
[   0.061][d][vo/gpu/opengl]   bayer_gbrg16
[   0.061][d][vo/gpu/opengl]   bayer_gbrg16be
[   0.061][d][vo/gpu/opengl]   bayer_grbg16
[   0.061][d][vo/gpu/opengl]   bayer_grbg16be
[   0.061][d][vo/gpu/opengl]   xvmc
[   0.061][d][vo/gpu/opengl]   yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv440p10be
[   0.061][d][vo/gpu/opengl]   yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b)
[   0.061][d][vo/gpu/opengl]   yuv440p12be
[   0.061][d][vo/gpu/opengl]   ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb)
[   0.061][d][vo/gpu/opengl]   ayuv64be
[   0.061][d][vo/gpu/opengl]   videotoolbox_vl
[   0.061][d][vo/gpu/opengl]   p010be
[   0.061][d][vo/gpu/opengl]   gbrap12be
[   0.061][d][vo/gpu/opengl]   gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a)
[   0.061][d][vo/gpu/opengl]   gbrap10be
[   0.061][d][vo/gpu/opengl]   gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a)
[   0.061][d][vo/gpu/opengl]   mediacodec
[   0.061][d][vo/gpu/opengl]   gray12be
[   0.061][d][vo/gpu/opengl]   gray12 => 1 planes 1x1 16/-4 [r16] (r)
[   0.061][d][vo/gpu/opengl]   gray10be
[   0.061][d][vo/gpu/opengl]   gray10 => 1 planes 1x1 16/-6 [r16] (r)
[   0.061][d][vo/gpu/opengl]   p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb)
[   0.061][d][vo/gpu/opengl]   p016be
[   0.062][d][vo/gpu/opengl]   d3d11
[   0.062][d][vo/gpu/opengl]   gray9be
[   0.062][d][vo/gpu/opengl]   gray9 => 1 planes 1x1 16/-7 [r16] (r)
[   0.062][d][vo/gpu/opengl]   gbrpf32be
[   0.062][d][vo/gpu/opengl]   gbrpf32 => 3 planes 1x1 32/0 [r16f/r16f/r16f] (g/b/r)
[   0.062][d][vo/gpu/opengl]   gbrapf32be
[   0.062][d][vo/gpu/opengl]   gbrapf32 => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (g/b/r/a)
[   0.062][d][vo/gpu/opengl]   drm_prime
[   0.062][d][vo/gpu/opengl]   opencl
[   0.062][d][vo/gpu/opengl]   gray14be
[   0.062][d][vo/gpu/opengl]   gray14 => 1 planes 1x1 16/-2 [r16] (r)
[   0.062][d][vo/gpu/opengl]   grayf32be
[   0.062][d][vo/gpu/opengl]   grayf32 => 1 planes 1x1 32/0 [r16f] (r)
[   0.062][d][vo/gpu/opengl]   yuva422p12be
[   0.062][d][vo/gpu/opengl]   yuva422p12 => 4 planes 2x1 16/-4 [r16/r16/r16/r16] (r/g/b/a)
[   0.062][d][vo/gpu/opengl]   yuva444p12be
[   0.062][d][vo/gpu/opengl]   yuva444p12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (r/g/b/a)
[   0.062][d][vo/gpu/opengl]   nv42 => 2 planes 1x1 8/0 [r8/rg8] (r/bg)
[   0.062][v][vo/gpu] Testing FBO format rgba16f
[   0.062][d][vo/gpu] Resizing texture: 16x16
[   0.062][v][vo/gpu] Using FBO format rgba16f.
[   0.062][v][vo/gpu] No advanced processing required. Enabling dumb mode.
[   0.062][v][vo/gpu] Assuming 60.000000 FPS for display sync.
[   0.063][v][vd] Container reported FPS: 23.976025
[   0.063][v][vd] Codec list:
[   0.063][v][vd]     h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[   0.063][v][vd]     h264_crystalhd (h264) - CrystalHD H264 decoder
[   0.063][v][vd]     h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper
[   0.063][v][vd]     h264_cuvid (h264) - Nvidia CUVID H264 decoder
[   0.063][v][vd] Opening decoder h264
[   0.063][v][vd] Looking at hwdec h264-nvdec...
[   0.063][v][vo/gpu] Loading hwdec driver 'vaapi-egl'
[   0.064][v][vo/gpu] Loading failed.
[   0.064][v][vo/gpu] Loading hwdec driver 'cuda-nvdec'
[   0.090][v][vo/gpu] Loading hwdec driver 'vdpau-glx'
[   0.102][v][vd] Trying hardware decoding via h264-nvdec.
[   0.103][v][vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
[   0.103][v][vf] User filter list:
[   0.103][v][vf]   (empty)
[   0.103][v][ad] Codec list:
[   0.103][v][ad]     pcm_s16le - PCM signed 16-bit little-endian
[   0.103][v][ad] Opening decoder pcm_s16le
[   0.103][v][ad] Requesting 1 threads for decoding.
[   0.103][v][ad] Selected codec: pcm_s16le (PCM signed 16-bit little-endian)
[   0.103][v][af] User filter list:
[   0.103][v][af]   (empty)
[   0.103][v][cplayer] Starting playback...
[   0.104][v][af] [in] 48000Hz stereo 2ch s16
[   0.104][v][af] [userspeed] 48000Hz stereo 2ch s16
[   0.104][v][af] [userspeed] (disabled)
[   0.104][v][af] [convert] 48000Hz stereo 2ch s16
[   0.104][v][ao] Trying audio driver 'pulse'
[   0.104][v][ao/pulse] requested format: 48000 Hz, stereo channels, s16
[   0.105][v][ao/pulse] Library version: 12.2.0
[   0.105][v][ao/pulse] Proto: 32
[   0.105][v][ao/pulse] Server proto: 4294967295
[   0.106][v][ao/pulse] Channel layouts:
[   0.106][v][ao/pulse]  - #fl
[   0.106][v][ao/pulse]  - #fr
[   0.106][v][ao/pulse]  - #fc
[   0.106][v][ao/pulse]  - #lfe
[   0.106][v][ao/pulse]  - #bl
[   0.106][v][ao/pulse]  - #br
[   0.106][v][ao/pulse]  - #flc
[   0.106][v][ao/pulse]  - #frc
[   0.106][v][ao/pulse]  - #bc
[   0.106][v][ao/pulse]  - #sl
[   0.106][v][ao/pulse]  - #sr
[   0.106][v][ao/pulse]  - #tc
[   0.106][v][ao/pulse]  - #tfl
[   0.106][v][ao/pulse]  - #tfc
[   0.106][v][ao/pulse]  - #tfr
[   0.106][v][ao/pulse]  - #tbl
[   0.106][v][ao/pulse]  - #tbc
[   0.106][v][ao/pulse]  - #tbr
[   0.106][v][ao/pulse] result: stereo
[   0.107][v][ao/pulse] device buffer: 4800 samples.
[   0.107][v][ao/pulse] using soft-buffer of 9600 samples.
[   0.107][i][cplayer] AO: [pulse] 48000Hz stereo 2ch s16
[   0.107][v][cplayer] AO: Description: PulseAudio audio output
[   0.107][v][af] [convert] (disabled)
[   0.107][v][af] [out] 48000Hz stereo 2ch s16
[   0.107][v][vd] Pixel formats supported by decoder: vdpau cuda vaapi_vld yuvj420p
[   0.107][v][vd] Codec profile: Constrained Baseline (0x242)
[   0.107][v][vd] Requesting pixfmt 'cuda' from decoder.
[   0.111][d][ffmpeg/video] h264: NVDEC capabilities:
[   0.111][d][ffmpeg/video] h264: format supported: yes, max_mb_count: 65536
[   0.111][d][ffmpeg/video] h264: min_width: 48, max_width: 4096
[   0.111][d][ffmpeg/video] h264: min_height: 16, max_height: 4096
Nvidia staff already reproduced and confirmed this bug in a related thread, so just test any new driver.
