inmei
December 9, 2014, 9:47pm
1
Hey there,
after days of googleing and trying i’m out of ideas. I own a Asus N76VB Notebook with nvidia GT740M and i7. The Linux distribution is Kubuntu 14.04.
Kernel: 3.13.0-40-generic
Nvidida-Drivers: 346.22 (trying anything below also)
$ export VDPAU_TRACE=2
$ export VDPAU_NVIDIA_DEBUG=3
$ vdpauinfo
display: :0 screen: 0
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 346.22 Tue Dec 2 10:23:46 PST 2014
VDPAU nvidia: Error detected 9 326 5
VDPAU nvidia: Backtrace:
–: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f748d78d000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f748d7c061f]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f748d7af693]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f748d794c03] vdp_imp_device_create_x11
Error creating VDPAU device: 1
nvidia-bug-report file shows nothing.
mplayer -vo vdpau movie.mkv
[vdpau] Error when calling vdp_device_create_x11: 1
$ prime-select query
nvidia
$ glxinfo |grep render
direct rendering: Yes
OpenGL renderer string: GeForce GT 740M/PCIe/SSE2
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_KTX_buffer_region, GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image,
GL_NV_path_rendering, GL_NV_pixel_data_range, GL_NV_point_sprite,
any help would be greatly appreciated
rz2k
December 27, 2014, 2:44pm
2
I have exact same problem, 740M and VAAPI not working on Ubuntu.
rz2k@victorique:~$ vainfo
libva info: VA-API version 0.35.1
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/nvidia_drv_video.so
libva info: Found init function __vaDriverInit_0_35
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0b0d721000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0b0d75461f]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0b0d743693]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0b0d728c03] vdp_imp_device_create_x11
libva error: /usr/lib/x86_64-linux-gnu/dri/nvidia_drv_video.so init failed
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
strace http://pastebin.com/NMbnL43q .
Please help,
Best Regards,
Dmitry Beykun
Can you please generate and attach an nvidia-bug-report.log.gz file?
rz2k
January 10, 2015, 3:21pm
5
fratti
January 18, 2015, 7:14pm
6
I’ve got the same issue, GTX 840M (GM108M), xorg-server 1.16.3, libvdpau 0.8, nvidia 343.36
fratti, can you please post a bug report and the exact error message you’re getting, too?
fratti
January 26, 2015, 8:41pm
8
Sure.
✓ fratti@archbook ~ $ export VDPAU_TRACE=2
✓ fratti@archbook ~ $ export VDPAU_NVIDIA_DEBUG=3
✓ fratti@archbook ~ $ vdpauinfo
VDPAU capture: Enabled
vdp_imp_device_create_x11(0x7f35c74b5010, 0, -, -)
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 346.35 Sat Jan 10 20:57:09 PST 2015
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f35c4743000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f35c477661f]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f35c4765693]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f35c474ac03] vdp_imp_device_create_x11
-> 1
All outputs of this laptop are connected to the Intel GPU, by the way. Might be relevant:
✓ fratti@archbook ~ $ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x1f5 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x46 cap: 0x2, Sink Output crtcs: 3 outputs: 4 associated providers: 1 name:modesetting
nvidia-bug-report.sh generated log:
http://fratti.ch/tmp/optimus-vdpau.log.gz
rz2k
January 29, 2015, 7:12pm
9
its interesting how my system has 346.22 and yours 346.35, but offset in libvdpau (which I believe was updated in last release) is the same.
karuonu
February 12, 2015, 7:05pm
10
The same issue here with GT640 on desktop. Tried with 304.125, 331.113 and 340.76. Might be relevant that older GS8400 runs VDPAU on the same setup with no problems (after only card swap)!
Error with GT640:
ott@kroku:~$ vdpauinfo
vdp_imp_device_create_x11(0xeb5010, 0, -, -)
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 340.76 Thu Jan 22 11:28:21 PST 2015
VDPAU nvidia: Error detected 10 357 5
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f9cbc33c000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f9cbc371fbd]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f9cbc361903]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f9cbc346013] vdp_imp_device_create_x11
-> 1
bug-report: Dropbox - nvidia-bug-report.log.gz - Simplify your life
rz2k
February 24, 2015, 8:48pm
11
so its not only mobile versions.
fratti
March 27, 2015, 4:40pm
13
Can confirm this is still present with libvdpau 1.1 and nvidia 349.12.
vdp_imp_device_create_x11(0x7f6be3f1d010, 0, -, -)
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 349.12 Sun Mar 22 07:43:37 PDT 2015
VDPAU nvidia: Error detected 9 334 5
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f6be0a2b000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f6be0a5f3df]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f6be0a4e453]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f6be0a33123] vdp_imp_device_create_x11
-> 1
✗ fratti@archbook ~ $ vainfo
libva info: VA-API version 0.37.0
libva info: Trying to open /usr/lib/dri/nvidia_drv_video.so
vdp_imp_device_create_x11(0x1e69c80, 0, -, -)
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f61ef9a7000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f61ef9db3df]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f61ef9ca453]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f61ef9af123] vdp_imp_device_create_x11
-> 1
Floating point exception (core dumped)
Core dump of vainfo (xz-compressed):
http://fratti.ch/tmp/vainfo.dump.xz
Test hardware: ASUS UX32L (the 1920x1080 IPS panel version); GeForce 840M (GM108M)
Bug report log: http://fratti.ch/tmp/optimus-vdpau-2.log.gz
We will check this issue internally. Tracking this issue in bug 1629911
fratti
May 19, 2015, 6:57pm
15
Issue still persists on 352.09, in case anyone is wondering.
vdp_imp_device_create_x11(0x22cf010, 0, -, -)
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 352.09 Tue May 12 14:21:07 PDT 2015
VDPAU nvidia: Error detected 9 355 5
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f8765844000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f87658746ec]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f8765865933]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f876584bdd3] vdp_imp_device_create_x11
-> 1
fratti
June 17, 2015, 5:32pm
16
For completeness’ sake, here’s the same thing from 352.21:
✗ fratti@archbook ~ $ export VDPAU_TRACE=2
vdp_imp_device_create_x11(0x10dcc20, 0, -, -)
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 352.21 Tue Jun 9 21:26:39 PDT 2015
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0783d1b000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0783d4b93c]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0783d3ca03]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f0783d22dd3] vdp_imp_device_create_x11
-> 1
horchi
October 25, 2015, 2:47pm
18
same here:
vdp_imp_device_create_x11(0x2582010, 0, -, -)
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 346.96 Sun Aug 23 21:58:31 PDT 2015
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f4a8f456000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f4a8f48985f]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f4a8f478753]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f4a8f45dc03] vdp_imp_device_create_x11
-> 1
any news to this issue?
rz2k
November 22, 2015, 4:21pm
19
Any news?
Still the same Ubuntu 15.10 + 352.63
rz2k@victorique:~$ vdpauinfo
display: :1 screen: 0
vdp_imp_device_create_x11(0x737c20, 0, -, -)
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 352.63 Sat Nov 7 20:55:40 PST 2015
VDPAU nvidia: Error detected 9 349 5
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fe32f52b000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fe32f55baec]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fe32f54cb33]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fe32f532de3] vdp_imp_device_create_x11
-> 1
rz2k@victorique:~$ glxinfo | grep OpenGL
OpenGL vendor string: NVIDIA Corporation
OpenGL core profile version string: 4.4.0 NVIDIA 352.63
OpenGL core profile shading language version string: 4.40 NVIDIA via Cg compiler
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.5.0 NVIDIA 352.63
OpenGL shading language version string: 4.50 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.1 NVIDIA 352.63
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
ahh, bump
i’m not the only one here
370.23 driver 4.7.0 kernel ubuntu xenial gf940mx thinkpad t460
kinda relieved
vdpauinfo
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library 370.23 Mon Aug 8 17:28:47 PDT 2016
VDPAU nvidia: Error detected 9 351 5
--: /usr/lib/x86_64-linux-gnu/libvdpau_nvidia.so [0x7fdcd1348000] DSO load base
00: /usr/lib/x86_64-linux-gnu/libvdpau_nvidia.so [0x7fdcd1376563]
01: /usr/lib/x86_64-linux-gnu/libvdpau_nvidia.so [0x7fdcd1368fc3]
02: /usr/lib/x86_64-linux-gnu/libvdpau_nvidia.so [0x7fdcd1350d7c] vdp_imp_device_create_x11
glxinfo|grep OpenGL
OpenGL renderer string: GeForce 940MX/PCIe/SSE2
OpenGL core profile version string: 4.5.0 NVIDIA 370.23
OpenGL core profile shading language version string: 4.50 NVIDIA
OpenGL version string: 4.5.0 NVIDIA 370.23
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 370.23
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
