VDPAU problems on 17.10 NVIDIA GM108M [GeForce 840M]
After upgrade forom 17.04 to 17.10 this problem showed up. I disabled wayland, but hardware acceleration is still not working. The machine tries to decode on GPU, it fails and no video is shown.
My setup
System:    Host: acer Kernel: 4.13.0-17-generic x86_64 bits: 64 gcc: 7.2.0 Desktop: Gnome 3.26.1 (Gtk 3.22.25)
           Distro: Ubuntu 17.10
Machine:   Device: laptop System: Acer product: Aspire V3-572G v: V1.26 serial: N/A
           Mobo: Acer model: EA50_HB v: V1.26 serial: N/A UEFI: Insyde v: V1.26 date: 12/18/2014
CPU:       Dual core Intel Core i3-4005U (-HT-MCP-) arch: Haswell rev.1 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 6783
           clock speeds: max: 1700 MHz 1: 1695 MHz 2: 1695 MHz 3: 1695 MHz 4: 1695 MHz
Graphics:  Card-1: Intel Haswell-ULT Integrated Graphics Controller bus-ID: 00:02.0
           Card-2: NVIDIA GM108M [GeForce 840M] bus-ID: 03:00.0
           Display Server: x11 (X.Org 1.19.5 ) drivers: modesetting,nvidia Resolution: 1920x1080@60.28hz
           OpenGL: renderer: GeForce 840M/PCIe/SSE2 version: 4.5.0 NVIDIA 387.34 Direct Render: Yes
Vdpauinfo:
display: :0   screen: 0
GPU at BusId 0x3 doesn't have a supported video decoder
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library  387.34  Tue Nov 21 02:08:49 PST 2017
VDPAU nvidia: Error detected 9 319  3
VDPAU nvidia: Backtrace:
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7ff4ea78b000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7ff4ea7c19f9]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7ff4ea7b1673]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7ff4ea795951] vdp_imp_device_create_x11
Error creating VDPAU device: 1
Vainfo:
libva info: VA-API version 0.40.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'nvidia'
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/nvidia_drv_video.so
libva info: Found init function __vaDriverInit_0_39
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fc61dc4f000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fc61dc859f9]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fc61dc75673]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7fc61dc59951] vdp_imp_device_create_x11
libva error: /usr/lib/x86_64-linux-gnu/dri/nvidia_drv_video.so init failed
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
Is there any solution to this problem
To have a bit more info, what’s the output of
find /usr/lib/ -name "libvdpau*" -exec ls -l {} \;
Thank you for the respose … the requested output is …
lrwxrwxrwx 1 root root 21 dec  1 21:28 /usr/lib/libvdpau_nvidia.so.1 -> libvdpau_nvidia.soOLD
lrwxrwxrwx 1 root root 25 nov 24 23:00 /usr/lib/nvidia-387/vdpau/libvdpau_nvidia.so.1 -> libvdpau_nvidia.so.387.34
-rw-r--r-- 1 root root 889504 nov 21 11:08 /usr/lib/nvidia-387/vdpau/libvdpau_nvidia.so.387.34
lrwxrwxrwx 1 root root 20 nov 24 23:00 /usr/lib/nvidia-387/vdpau/libvdpau_nvidia.so -> libvdpau_nvidia.so.1
lrwxrwxrwx 1 root root 53 nov 24 12:59 /usr/lib/libvdpau_nvidia.soOLD -> /etc/alternatives/x86_64-linux-gnu_libvdpau_nvidia.so
lrwxrwxrwx 1 root root 55 dec  1 21:28 /usr/lib/vdpau/libvdpau_nvidia.so.1 -> /etc/alternatives/x86_64-linux-gnu_libvdpau_nvidia.so.1
lrwxrwxrwx 1 root root 53 dec  1 21:28 /usr/lib/libvdpau_nvidia.so -> /etc/alternatives/x86_64-linux-gnu_libvdpau_nvidia.so
lrwxrwxrwx 1 root root 17 feb 19  2016 /usr/lib/x86_64-linux-gnu/libvdpau.so.1 -> libvdpau.so.1.0.0
-rw-r--r-- 1 root root 55376 feb 19  2016 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_trace.so.1.0.0
lrwxrwxrwx 1 root root 23 feb 19  2016 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_trace.so.1 -> libvdpau_trace.so.1.0.0
-rw-r--r-- 4 root root 4890600 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_radeonsi.so.1.0.0
lrwxrwxrwx 1 root root 25 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_nouveau.so.1.0 -> libvdpau_nouveau.so.1.0.0
lrwxrwxrwx 1 root root 25 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_nouveau.so.1 -> libvdpau_nouveau.so.1.0.0
lrwxrwxrwx 1 root root 22 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r600.so.1 -> libvdpau_r600.so.1.0.0
-rw-r--r-- 4 root root 4890600 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_nouveau.so.1.0.0
lrwxrwxrwx 1 root root 25 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_nouveau.so -> libvdpau_nouveau.so.1.0.0
lrwxrwxrwx 1 root root 22 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r600.so -> libvdpau_r600.so.1.0.0
lrwxrwxrwx 1 root root 22 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r300.so -> libvdpau_r300.so.1.0.0
lrwxrwxrwx 1 root root 22 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r300.so.1.0 -> libvdpau_r300.so.1.0.0
lrwxrwxrwx 1 root root 26 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_radeonsi.so.1 -> libvdpau_radeonsi.so.1.0.0
-rw-r--r-- 1 root root 237072 okt  7  2016 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_va_gl.so.1
lrwxrwxrwx 1 root root 19 okt  7  2016 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_va_gl.so -> libvdpau_va_gl.so.1
-rw-r--r-- 4 root root 4890600 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r300.so.1.0.0
lrwxrwxrwx 1 root root 26 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_radeonsi.so -> libvdpau_radeonsi.so.1.0.0
lrwxrwxrwx 1 root root 26 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_radeonsi.so.1.0 -> libvdpau_radeonsi.so.1.0.0
-rw-r--r-- 4 root root 4890600 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r600.so.1.0.0
lrwxrwxrwx 1 root root 22 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r600.so.1.0 -> libvdpau_r600.so.1.0.0
lrwxrwxrwx 1 root root 22 okt  3 14:49 /usr/lib/x86_64-linux-gnu/vdpau/libvdpau_r300.so.1 -> libvdpau_r300.so.1.0.0
-rw-r--r-- 1 root root 10360 sep  5 19:37 /usr/lib/x86_64-linux-gnu/vlc/plugins/vdpau/libvdpau_adjust_plugin.so
-rw-r--r-- 1 root root 22944 sep  5 19:37 /usr/lib/x86_64-linux-gnu/vlc/plugins/vdpau/libvdpau_display_plugin.so
-rw-r--r-- 1 root root 2047576 sep  5 19:37 /usr/lib/x86_64-linux-gnu/vlc/plugins/vdpau/libvdpau_avcodec_plugin.so
-rw-r--r-- 1 root root 10384 sep  5 19:37 /usr/lib/x86_64-linux-gnu/vlc/plugins/vdpau/libvdpau_sharpen_plugin.so
-rw-r--r-- 1 root root 10272 sep  5 19:37 /usr/lib/x86_64-linux-gnu/vlc/plugins/vdpau/libvdpau_deinterlace_plugin.so
-rw-r--r-- 1 root root 22760 sep  5 19:37 /usr/lib/x86_64-linux-gnu/vlc/plugins/vdpau/libvdpau_chroma_plugin.so
-rw-r--r-- 1 root root 14696 feb 19  2016 /usr/lib/x86_64-linux-gnu/libvdpau.so.1.0.0
Looks ok. Can you please attach the Xorg.0.log and the Xorg.1.log from /var/log to your post?
I suspect this could be related to drm permissions.
Thank you, here it goes …
cat Xorg.0.log
[    69.481] (--) Log file renamed from "/var/log/Xorg.pid-1450.log" to "/var/log/Xorg.0.log"
[    69.497]
X.Org X Server 1.19.5
Release Date: 2017-10-12
[    69.497] X Protocol Version 11, Revision 0
[    69.497] Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
[    69.497] Current Operating System: Linux acer 4.13.0-17-generic #20-Ubuntu SMP Mon Nov 6 10:04:08 UTC 2017 x86_64
[    69.497] Kernel command line: BOOT_IMAGE=/vmlinuz-4.13.0-17-generic root=/dev/mapper/ubuntu--vg-root ro quiet splash vt.handoff=7
[    69.497] Build Date: 15 October 2017  05:51:19PM
[    69.497] xorg-server 2:1.19.5-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[    69.497] Current version of pixman: 0.34.0
[    69.497] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    69.497] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    69.497] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Dec  2 09:47:29 2017
[    69.753] (==) Using config file: "/etc/X11/xorg.conf"
[    69.753] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    69.986] (==) ServerLayout "layout"
[    69.986] (**) |-->Screen "nvidia" (0)
[    69.986] (**) |   |-->Monitor "<default monitor>"
[    70.011] (**) |   |-->Device "nvidia"
[    70.011] (**) |   |-->GPUDevice "nvidia"
[    70.011] (==) No monitor specified for screen "nvidia".
	Using a default monitor configuration.
[    70.011] (**) |-->Inactive Device "intel"
[    70.011] (==) Automatically adding devices
[    70.011] (==) Automatically enabling devices
[    70.011] (==) Automatically adding GPU devices
[    70.011] (==) Automatically binding GPU devices
[    70.011] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    70.147] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    70.147] 	Entry deleted from font path.
[    70.147] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[    70.147] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[    70.152] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[    70.152] 	Entry deleted from font path.
[    70.152] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[    70.152] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[    70.152] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[    70.152] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    70.174] (II) Loader magic: 0x55d9cbc0d020
[    70.174] (II) Module ABI versions:
[    70.174] 	X.Org ANSI C Emulation: 0.4
[    70.174] 	X.Org Video Driver: 23.0
[    70.174] 	X.Org XInput driver : 24.1
[    70.174] 	X.Org Server Extension : 10.0
[    70.176] (++) using VT number 1
[    70.179] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    70.180] (II) xfree86: Adding drm device (/dev/dri/card1)
[    70.182] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[    70.182] (II) xfree86: Adding drm device (/dev/dri/card0)
[    70.184] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[    70.185] (--) PCI:*(0:0:2:0) 8086:0a16:1025:0866 rev 11, Mem @ 0xb3000000/4194304, 0xc0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[    70.185] (--) PCI: (0:3:0:0) 10de:1341:1025:0867 rev 162, Mem @ 0xb2000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128
[    70.185] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[    70.185] (II) "glx" will be loaded by default.
[    70.185] (II) LoadModule: "glx"
[    70.241] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[    71.059] (II) Module glx: vendor="NVIDIA Corporation"
[    71.060] 	compiled for 4.0.2, module version = 1.0.0
[    71.060] 	Module class: X.Org Server Extension
[    71.069] (II) NVIDIA GLX Module  387.34  Tue Nov 21 02:04:31 PST 2017
[    71.082] (II) LoadModule: "nvidia"
[    71.082] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[    71.154] (II) Module nvidia: vendor="NVIDIA Corporation"
[    71.154] 	compiled for 4.0.2, module version = 1.0.0
[    71.154] 	Module class: X.Org Video Driver
[    71.157] (II) LoadModule: "modesetting"
[    71.215] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    71.237] (II) Module modesetting: vendor="X.Org Foundation"
[    71.237] 	compiled for 1.19.5, module version = 1.19.5
[    71.237] 	Module class: X.Org Video Driver
[    71.237] 	ABI class: X.Org Video Driver, version 23.0
[    71.237] (II) NVIDIA dlloader X Driver  387.34  Tue Nov 21 01:38:22 PST 2017
[    71.237] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    71.238] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    71.238] (II) systemd-logind: releasing fd for 226:0
[    71.263] (II) Loading sub module "fb"
[    71.263] (II) LoadModule: "fb"
[    71.264] (II) Loading /usr/lib/xorg/modules/libfb.so
[    71.265] (II) Module fb: vendor="X.Org Foundation"
[    71.265] 	compiled for 1.19.5, module version = 1.0.0
[    71.266] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    71.266] (II) Loading sub module "wfb"
[    71.266] (II) LoadModule: "wfb"
[    71.279] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    71.306] (II) Module wfb: vendor="X.Org Foundation"
[    71.306] 	compiled for 1.19.5, module version = 1.0.0
[    71.306] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    71.307] (II) Loading sub module "ramdac"
[    71.307] (II) LoadModule: "ramdac"
[    71.307] (II) Module "ramdac" already built-in
[    71.368] (II) modeset(G0): using drv /dev/dri/card1
[    71.368] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"nvidia" for depth/fbbpp 24/32
[    71.368] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    71.368] (==) NVIDIA(0): RGB weight 888
[    71.368] (==) NVIDIA(0): Default visual is TrueColor
[    71.368] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    71.369] (**) NVIDIA(0): Option "ConstrainCursor" "off"
[    71.369] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
[    71.369] (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
[    71.369] (**) NVIDIA(0): Enabling 2D acceleration
[    71.598] (II) NVIDIA(0): NVIDIA GPU GeForce 840M (GM108-A) at PCI:3:0:0 (GPU-0)
[    71.598] (--) NVIDIA(0): Memory: 2097152 kBytes
[    71.598] (--) NVIDIA(0): VideoBIOS: 82.08.15.00.2a
[    71.598] (II) NVIDIA(0): Detected PCI Express Link width: 4X
[    71.598] (II) NVIDIA(0): Validated MetaModes:
[    71.598] (II) NVIDIA(0):     "NULL"
[    71.598] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    71.598] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[    71.598] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    71.598] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    71.598] (**) modeset(G0): Option "AccelMethod" "None"
[    71.598] (==) modeset(G0): RGB weight 888
[    71.598] (==) modeset(G0): Default visual is TrueColor
[    71.598] (**) modeset(G0): glamor disabled
[    71.598] (II) modeset(G0): ShadowFB: preferred YES, enabled YES
[    71.599] (II) modeset(G0): Double-buffered shadow updates: off
[    71.600] (II) modeset(G0): Output eDP-1-1 has no monitor section
[    71.600] (II) modeset(G0): Output DP-1-1 has no monitor section
[    71.784] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[    71.792] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[    71.793] (II) modeset(G0): EDID for output eDP-1-1
[    71.793] (II) modeset(G0): Manufacturer: AUO  Model: 31ed  Serial#: 0
[    71.793] (II) modeset(G0): Year: 2012  Week: 0
[    71.793] (II) modeset(G0): EDID Version: 1.4
[    71.793] (II) modeset(G0): Digital Display Input
[    71.793] (II) modeset(G0): 6 bits per channel
[    71.793] (II) modeset(G0): Digital interface is DisplayPort
[    71.793] (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    71.793] (II) modeset(G0): Gamma: 2.20
[    71.793] (II) modeset(G0): No DPMS capabilities specified
[    71.793] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[    71.793] (II) modeset(G0): First detailed timing is preferred mode
[    71.793] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[    71.793] (II) modeset(G0): redX: 0.620 redY: 0.349   greenX: 0.324 greenY: 0.606
[    71.793] (II) modeset(G0): blueX: 0.152 blueY: 0.118   whiteX: 0.313 whiteY: 0.329
[    71.793] (II) modeset(G0): Manufacturer's mask: 0
[    71.793] (II) modeset(G0): Supported detailed timing:
[    71.793] (II) modeset(G0): clock: 145.0 MHz   Image Size:  344 x 193 mm
[    71.793] (II) modeset(G0): h_active: 1920  h_sync: 1968  h_sync_end 2068 h_blank_end 2110 h_border: 0
[    71.793] (II) modeset(G0): v_active: 1080  v_sync: 1083  v_sync_end 1084 v_blanking: 1140 v_border: 0
[    71.793] (II) modeset(G0): Unknown vendor-specific block f
[    71.793] (II) modeset(G0):  AUO
[    71.794] (II) modeset(G0):  B156HTN03.1
[    71.794] (II) modeset(G0): EDID (in hex):
[    71.794] (II) modeset(G0): 	00ffffffffffff0006afed3100000000
[    71.794] (II) modeset(G0): 	001601049522137802d1159e59539b27
[    71.794] (II) modeset(G0): 	1e505400000001010101010101010101
[    71.794] (II) modeset(G0): 	010101010101a43880be70383c403064
[    71.794] (II) modeset(G0): 	310058c1100000180000000f00000000
[    71.794] (II) modeset(G0): 	00000000000000000020000000fe0041
[    71.794] (II) modeset(G0): 	554f0a202020202020202020000000fe
[    71.794] (II) modeset(G0): 	004231353648544e30332e31200a00de
[    71.794] (II) modeset(G0): Printing probed modes for output eDP-1-1
[    71.794] (II) modeset(G0): Modeline "1920x1080"x60.3  145.00  1920 1968 2068 2110  1080 1083 1084 1140 -hsync -vsync (68.7 kHz eP)
[    71.794] (II) modeset(G0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    71.794] (II) modeset(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    71.794] (II) modeset(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    71.794] (II) modeset(G0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
[    71.794] (II) modeset(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    71.794] (II) modeset(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    71.794] (II) modeset(G0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)
[    71.794] (II) modeset(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    71.794] (II) modeset(G0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)
[    71.794] (II) modeset(G0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)
[    71.794] (II) modeset(G0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)
[    71.794] (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    71.794] (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    71.794] (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    71.794] (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    71.794] (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    71.795] (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    71.795] (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    71.795] (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    71.795] (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    71.795] (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    71.795] (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    71.795] (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    71.795] (II) modeset(G0): Modeline "800x512"x120.3   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[    71.795] (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    71.795] (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    71.795] (II) modeset(G0): Modeline "720x450"x119.8   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[    71.795] (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    71.795] (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    71.795] (II) modeset(G0): Modeline "680x384"x119.6   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[    71.795] (II) modeset(G0): Modeline "680x384"x119.9   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[    71.795] (II) modeset(G0): Modeline "576x432"x120.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[    71.795] (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    71.795] (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    71.795] (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    71.795] (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    71.795] (II) modeset(G0): EDID for output DP-1-1
[    71.976] (II) modeset(G0): EDID for output HDMI-1-1
[    71.984] (II) modeset(G0): EDID for output HDMI-1-2
[    71.984] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    71.984] (==) modeset(G0): DPI set to (96, 96)
[    71.984] (II) Loading sub module "fb"
[    71.984] (II) LoadModule: "fb"
[    71.984] (II) Loading /usr/lib/xorg/modules/libfb.so
[    71.984] (II) Module fb: vendor="X.Org Foundation"
[    71.984] 	compiled for 1.19.5, module version = 1.0.0
[    71.984] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    71.984] (II) Loading sub module "shadow"
[    71.984] (II) LoadModule: "shadow"
[    71.985] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    72.008] (II) Module shadow: vendor="X.Org Foundation"
[    72.008] 	compiled for 1.19.5, module version = 1.1.0
[    72.008] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    72.008] (--) Depth 24 pixmap format is 32 bpp
[    72.030] (==) modeset(G0): Backing store enabled
[    72.030] (==) modeset(G0): Silken mouse enabled
[    72.031] (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    72.097] (==) modeset(G0): DPMS enabled
[    72.097] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[    72.097] (WW) modeset(G0): Option "IgnoreDisplayDevices" is not used
[    72.098] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[    72.098] (II) NVIDIA:     access.
[    72.177] (II) NVIDIA(0): Setting mode "NULL"
[    72.196] (==) NVIDIA(0): Disabling shared memory pixmaps
[    72.196] (==) NVIDIA(0): Backing store enabled
[    72.196] (==) NVIDIA(0): Silken mouse enabled
[    72.197] (==) NVIDIA(0): DPMS enabled
[    72.197] (II) Loading sub module "dri2"
[    72.197] (II) LoadModule: "dri2"
[    72.197] (II) Module "dri2" already built-in
[    72.197] (II) NVIDIA(0): [DRI2] Setup complete
[    72.197] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    72.197] (--) RandR disabled
[    72.223] (II) SELinux: Disabled on system
[    72.225] (II) Initializing extension GLX
[    72.225] (II) Indirect GLX disabled.
[    72.503] (II) modeset(G0): Damage tracking initialized
[    73.034] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    73.034] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    73.034] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    73.034] (II) LoadModule: "libinput"
[    73.034] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    73.129] (II) Module libinput: vendor="X.Org Foundation"
[    73.129] 	compiled for 1.19.3, module version = 0.25.0
[    73.129] 	Module class: X.Org XInput Driver
[    73.129] 	ABI class: X.Org XInput driver, version 24.1
[    73.129] (II) Using input driver 'libinput' for 'Power Button'
[    73.131] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 39 paused 0
[    73.131] (**) Power Button: always reports core events
[    73.131] (**) Option "Device" "/dev/input/event3"
[    73.131] (**) Option "_source" "server/udev"
[    73.132] (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    73.133] (II) event3  - (II) Power Button: (II) device is a keyboard
[    73.133] (II) event3  - (II) Power Button: (II) device removed
[    73.133] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    73.133] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    73.133] (**) Option "xkb_model" "pc105"
[    73.133] (**) Option "xkb_layout" "si"
[    73.155] (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    73.155] (II) event3  - (II) Power Button: (II) device is a keyboard
[    73.156] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[    73.156] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    73.156] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    73.156] (II) Using input driver 'libinput' for 'Video Bus'
[    73.157] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 42 paused 0
[    73.157] (**) Video Bus: always reports core events
[    73.157] (**) Option "Device" "/dev/input/event6"
[    73.157] (**) Option "_source" "server/udev"
[    73.158] (II) event6  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[    73.158] (II) event6  - (II) Video Bus: (II) device is a keyboard
[    73.158] (II) event6  - (II) Video Bus: (II) device removed
[    73.158] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input6/event6"
[    73.158] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    73.158] (**) Option "xkb_model" "pc105"
[    73.158] (**) Option "xkb_layout" "si"
[    73.159] (II) event6  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[    73.159] (II) event6  - (II) Video Bus: (II) device is a keyboard
[    73.159] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    73.159] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    73.159] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    73.159] (II) Using input driver 'libinput' for 'Power Button'
[    73.161] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 43 paused 0
[    73.161] (**) Power Button: always reports core events
[    73.161] (**) Option "Device" "/dev/input/event1"
[    73.161] (**) Option "_source" "server/udev"
[    73.161] (II) event1  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    73.161] (II) event1  - (II) Power Button: (II) device is a keyboard
[    73.161] (II) event1  - (II) Power Button: (II) device removed
[    73.161] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input1/event1"
[    73.161] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    73.161] (**) Option "xkb_model" "pc105"
[    73.161] (**) Option "xkb_layout" "si"
[    73.162] (II) event1  - (II) Power Button: (II) is tagged by udev as: Keyboard
[    73.162] (II) event1  - (II) Power Button: (II) device is a keyboard
[    73.163] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    73.163] (II) No input driver specified, ignoring this device.
[    73.163] (II) This device may have been added with another device file.
[    73.163] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[    73.163] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    73.163] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    73.163] (II) Using input driver 'libinput' for 'Sleep Button'
[    73.164] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 44 paused 0
[    73.164] (**) Sleep Button: always reports core events
[    73.164] (**) Option "Device" "/dev/input/event2"
[    73.164] (**) Option "_source" "server/udev"
[    73.165] (II) event2  - (II) Sleep Button: (II) is tagged by udev as: Keyboard
[    73.165] (II) event2  - (II) Sleep Button: (II) device is a keyboard
[    73.165] (II) event2  - (II) Sleep Button: (II) device removed
[    73.165] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0E:00/input/input2/event2"
[    73.165] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    73.165] (**) Option "xkb_model" "pc105"
[    73.165] (**) Option "xkb_layout" "si"
[    73.166] (II) event2  - (II) Sleep Button: (II) is tagged by udev as: Keyboard
[    73.166] (II) event2  - (II) Sleep Button: (II) device is a keyboard
[    73.167] (II) config/udev: Adding input device Video Bus (/dev/input/event5)
[    73.167] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    73.167] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    73.167] (II) Using input driver 'libinput' for 'Video Bus'
[    73.169] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 45 paused 0
[    73.169] (**) Video Bus: always reports core events
[    73.169] (**) Option "Device" "/dev/input/event5"
[    73.170] (**) Option "_source" "server/udev"
[    73.170] (II) event5  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[    73.170] (II) event5  - (II) Video Bus: (II) device is a keyboard
[    73.170] (II) event5  - (II) Video Bus: (II) device removed
[    73.170] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:38/LNXVIDEO:00/input/input5/event5"
[    73.170] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 10)
[    73.170] (**) Option "xkb_model" "pc105"
[    73.170] (**) Option "xkb_layout" "si"
[    73.172] (II) event5  - (II) Video Bus: (II) is tagged by udev as: Keyboard
[    73.172] (II) event5  - (II) Video Bus: (II) device is a keyboard
[    73.173] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[    73.173] (II) No input driver specified, ignoring this device.
[    73.173] (II) This device may have been added with another device file.
[    73.173] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event10)
[    73.174] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event11)
[    73.174] (II) No input driver specified, ignoring this device.
[    73.174] (II) This device may have been added with another device file.
[    73.174] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event12)
[    73.175] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event13)
[    73.175] (II) No input driver specified, ignoring this device.
[    73.175] (II) This device may have been added with another device file.
[    73.176] (II) config/udev: Adding input device OM (/dev/input/event7)
[    73.176] (**) OM: Applying InputClass "evdev pointer catchall"
[    73.176] (**) OM: Applying InputClass "libinput pointer catchall"
[    73.176] (II) Using input driver 'libinput' for 'OM'
[    73.178] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 46 paused 0
[    73.178] (**) OM: always reports core events
[    73.178] (**) Option "Device" "/dev/input/event7"
[    73.178] (**) Option "_source" "server/udev"
[    73.178] (II) event7  - (II) OM: (II) is tagged by udev as: Mouse
[    73.179] (II) event7  - (II) OM: (II) device is a pointer
[    73.179] (II) event7  - (II) OM: (II) device removed
[    73.179] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:04F3:0235.0002/input/input7/event7"
[    73.179] (II) XINPUT: Adding extended input device "OM" (type: MOUSE, id 11)
[    73.179] (**) Option "AccelerationScheme" "none"
[    73.179] (**) OM: (accel) selected scheme none/0
[    73.179] (**) OM: (accel) acceleration factor: 2.000
[    73.179] (**) OM: (accel) acceleration threshold: 4
[    73.180] (II) event7  - (II) OM: (II) is tagged by udev as: Mouse
[    73.180] (II) event7  - (II) OM: (II) device is a pointer
[    73.181] (II) config/udev: Adding input device OM (/dev/input/mouse0)
[    73.181] (II) No input driver specified, ignoring this device.
[    73.181] (II) This device may have been added with another device file.
[    73.182] (II) config/udev: Adding input device HD WebCam: HD WebCam (/dev/input/event14)
[    73.182] (**) HD WebCam: HD WebCam: Applying InputClass "evdev keyboard catchall"
[    73.182] (**) HD WebCam: HD WebCam: Applying InputClass "libinput keyboard catchall"
[    73.182] (II) Using input driver 'libinput' for 'HD WebCam: HD WebCam'
[    73.182] (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 47 paused 0
[    73.182] (**) HD WebCam: HD WebCam: always reports core events
[    73.183] (**) Option "Device" "/dev/input/event14"
[    73.183] (**) Option "_source" "server/udev"
[    73.183] (II) event14 - (II) HD WebCam: HD WebCam: (II) is tagged by udev as: Keyboard
[    73.183] (II) event14 - (II) HD WebCam: HD WebCam: (II) device is a keyboard
[    73.183] (II) event14 - (II) HD WebCam: HD WebCam: (II) device removed
[    73.183] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/input/input19/event14"
[    73.183] (II) XINPUT: Adding extended input device "HD WebCam: HD WebCam" (type: KEYBOARD, id 12)
[    73.183] (**) Option "xkb_model" "pc105"
[    73.183] (**) Option "xkb_layout" "si"
[    73.184] (II) event14 - (II) HD WebCam: HD WebCam: (II) is tagged by udev as: Keyboard
[    73.184] (II) event14 - (II) HD WebCam: HD WebCam: (II) device is a keyboard
[    73.185] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event15)
[    73.185] (II) No input driver specified, ignoring this device.
[    73.185] (II) This device may have been added with another device file.
[    73.185] (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/event8)
[    73.185] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "evdev touchpad catchall"
[    73.185] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "libinput touchpad catchall"
[    73.185] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "touchpad catchall"
[    73.185] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "Default clickpad buttons"
[    73.185] (II) LoadModule: "synaptics"
[    73.186] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[    73.197] (II) Module synaptics: vendor="X.Org Foundation"
[    73.197] 	compiled for 1.19.3, module version = 1.9.0
[    73.197] 	Module class: X.Org XInput Driver
[    73.197] 	ABI class: X.Org XInput driver, version 24.1
[    73.197] (II) Using input driver 'synaptics' for 'SYN1B7E:01 06CB:2970 Touchpad'
[    73.221] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 48 paused 0
[    73.221] (**) SYN1B7E:01 06CB:2970 Touchpad: always reports core events
[    73.221] (**) Option "Device" "/dev/input/event8"
[    73.221] (II) synaptics: SYN1B7E:01 06CB:2970 Touchpad: found clickpad property
[    73.221] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: x-axis range 0 - 1236 (res 12)
[    73.221] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: y-axis range 0 - 898 (res 12)
[    73.221] (II) synaptics: SYN1B7E:01 06CB:2970 Touchpad: device does not report pressure, will use touch data.
[    73.221] (II) synaptics: SYN1B7E:01 06CB:2970 Touchpad: device does not report finger width.
[    73.221] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: buttons: left double triple
[    73.221] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: Vendor 0x6cb Product 0x2970
[    73.221] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: invalid pressure range.  defaulting to 0 - 255
[    73.221] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: invalid finger width range.  defaulting to 0 - 15
[    73.221] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[    73.221] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: touchpad found
[    73.222] (**) SYN1B7E:01 06CB:2970 Touchpad: always reports core events
[    73.222] (**) Option "config_info" "udev:/sys/devices/pci0000:00/INT33C3:00/i2c-0/i2c-SYN1B7E:01/0018:06CB:2970.0001/input/input9/event8"
[    73.222] (II) XINPUT: Adding extended input device "SYN1B7E:01 06CB:2970 Touchpad" (type: TOUCHPAD, id 13)
[    73.222] (**) synaptics: SYN1B7E:01 06CB:2970 Touchpad: (accel) MinSpeed is now constant deceleration 2.5
[    73.222] (**) synaptics: SYN1B7E:01 06CB:2970 Touchpad: (accel) MaxSpeed is now 1.75
[    73.222] (**) synaptics: SYN1B7E:01 06CB:2970 Touchpad: (accel) AccelFactor is now 0.131
[    73.222] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) keeping acceleration scheme 1
[    73.222] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration profile 1
[    73.222] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration factor: 2.000
[    73.222] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration threshold: 4
[    73.222] (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: touchpad found
[    73.223] (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/mouse1)
[    73.223] (**) SYN1B7E:01 06CB:2970 Touchpad: Ignoring device from InputClass "touchpad ignore duplicates"
[    73.224] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    73.224] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    73.224] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    73.224] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    73.226] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 49 paused 0
[    73.226] (**) AT Translated Set 2 keyboard: always reports core events
[    73.226] (**) Option "Device" "/dev/input/event4"
[    73.226] (**) Option "_source" "server/udev"
[    73.227] (II) event4  - (II) AT Translated Set 2 keyboard: (II) is tagged by udev as: Keyboard
[    73.227] (II) event4  - (II) AT Translated Set 2 keyboard: (II) device is a keyboard
[    73.227] (II) event4  - (II) AT Translated Set 2 keyboard: (II) device removed
[    73.227] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    73.227] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 14)
[    73.227] (**) Option "xkb_model" "pc105"
[    73.227] (**) Option "xkb_layout" "si"
[    73.229] (II) event4  - (II) AT Translated Set 2 keyboard: (II) is tagged by udev as: Keyboard
[    73.229] (II) event4  - (II) AT Translated Set 2 keyboard: (II) device is a keyboard
[    73.233] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event16)
[    73.233] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    73.233] (**) Acer WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    73.233] (II) Using input driver 'libinput' for 'Acer WMI hotkeys'
[    73.234] (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 50 paused 0
[    73.234] (**) Acer WMI hotkeys: always reports core events
[    73.234] (**) Option "Device" "/dev/input/event16"
[    73.234] (**) Option "_source" "server/udev"
[    73.234] (II) event16 - (II) Acer WMI hotkeys: (II) is tagged by udev as: Keyboard
[    73.234] (II) event16 - (II) Acer WMI hotkeys: (II) device is a keyboard
[    73.234] (II) event16 - (II) Acer WMI hotkeys: (II) device removed
[    73.234] (**) Option "config_info" "udev:/sys/devices/virtual/input/input21/event16"
[    73.234] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 15)
[    73.234] (**) Option "xkb_model" "pc105"
[    73.234] (**) Option "xkb_layout" "si"
[    73.235] (II) event16 - (II) Acer WMI hotkeys: (II) is tagged by udev as: Keyboard
[    73.235] (II) event16 - (II) Acer WMI hotkeys: (II) device is a keyboard
[    74.831] randr: falling back to unsynchronized pixmap sharing
and
[  3894.121] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[  3894.121] _XSERVTransMakeAllCOTSServerListeners: server already running
[  3894.121] (--) Log file renamed from "/var/log/Xorg.pid-27861.log" to "/var/log/Xorg.1.log"
[  3894.122]
[  3894.122] X Protocol Version 11, Revision 0
[  3894.122] Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
[  3894.122] Current Operating System: Linux acer 4.13.0-17-generic #20-Ubuntu SMP Mon Nov 6 10:04:08 UTC 2017 x86_64
[  3894.122] Kernel command line: BOOT_IMAGE=/vmlinuz-4.13.0-17-generic root=/dev/mapper/ubuntu--vg-root ro quiet splash vt.handoff=7
[  3894.122] Build Date: 15 October 2017  05:51:19PM
[  3894.122] xorg-server 2:1.19.5-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
[  3894.122] Current version of pixman: 0.34.0
[  3894.122] 	Before reporting problems, check http://wiki.x.org
[  3894.122] Markers: (--) probed, (**) from config file, (==) default setting,
[  3894.122] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Dec  1 15:11:25 2017
[  3894.122] (==) Using config file: "/etc/X11/xorg.conf"
[  3894.122] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[  3894.123] (==) ServerLayout "layout"
[  3894.123] (**) |-->Screen "nvidia" (0)
[  3894.123] (**) |   |-->Monitor "<default monitor>"
[  3894.123] (**) |   |-->Device "nvidia"
[  3894.123] (**) |   |-->GPUDevice "nvidia"
[  3894.123] (==) No monitor specified for screen "nvidia".
[  3894.123] (**) |-->Inactive Device "intel"
[  3894.123] (==) Automatically adding devices
[  3894.123] (==) Automatically enabling devices
[  3894.123] (==) Automatically adding GPU devices
[  3894.123] (==) Automatically binding GPU devices
[  3894.123] (==) Max clients allowed: 256, resource mask: 0x1fffff
[  3894.123] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[  3894.123] 	Entry deleted from font path.
[  3894.123] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[  3894.123] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[  3894.123] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[  3894.123] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[  3894.123] (==) FontPath set to:
	built-ins
[  3894.123] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[  3894.123] (II) The server relies on udev to provide the list of input devices.
[  3894.123] (II) Loader magic: 0x561ef48d0020
[  3894.123] (II) Module ABI versions:
[  3894.123] 	X.Org ANSI C Emulation: 0.4
[  3894.123] 	X.Org Video Driver: 23.0
[  3894.123] 	X.Org XInput driver : 24.1
[  3894.123] 	X.Org Server Extension : 10.0
[  3894.125] (++) using VT number 2
[  3894.128] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_315
[  3894.129] (II) xfree86: Adding drm device (/dev/dri/card0)
[  3894.131] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[  3894.131] (II) xfree86: Adding drm device (/dev/dri/card1)
[  3894.132] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
[  3894.134] (--) PCI:*(0:0:2:0) 8086:0a16:1025:0866 rev 11, Mem @ 0xb3000000/4194304, 0xc0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[  3894.134] (--) PCI: (0:3:0:0) 10de:1341:1025:0867 rev 162, Mem @ 0xb2000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128
[  3894.134] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[  3894.134] (II) "glx" will be loaded by default.
[  3894.134] (II) LoadModule: "glx"
[  3894.135] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[  3894.136] (II) Module glx: vendor="X.Org Foundation"
[  3894.136] 	compiled for 1.19.5, module version = 1.0.0
[  3894.136] 	ABI class: X.Org Server Extension, version 10.0
[  3894.136] (II) LoadModule: "nvidia"
[  3894.137] (WW) Warning, couldn't open module nvidia
[  3894.137] (II) UnloadModule: "nvidia"
[  3894.137] (II) Unloading nvidia
[  3894.137] (EE) Failed to load module "nvidia" (module does not exist, 0)
[  3894.137] (II) LoadModule: "modesetting"
[  3894.137] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  3894.137] (II) Module modesetting: vendor="X.Org Foundation"
[  3894.137] 	compiled for 1.19.5, module version = 1.19.5
[  3894.137] 	Module class: X.Org Video Driver
[  3894.137] 	ABI class: X.Org Video Driver, version 23.0
[  3894.137] (==) Matched nvidia as autoconfigured driver 0
[  3894.137] (==) Matched nouveau as autoconfigured driver 1
[  3894.137] (==) Matched modesetting as autoconfigured driver 2
[  3894.137] (==) Matched fbdev as autoconfigured driver 3
[  3894.137] (==) Matched vesa as autoconfigured driver 4
[  3894.137] (==) Assigned the driver to the xf86ConfigLayout
[  3894.137] (II) LoadModule: "nvidia"
[  3894.138] (II) UnloadModule: "nvidia"
[  3894.138] (II) Unloading nvidia
[  3894.138] (EE) Failed to load module "nvidia" (module does not exist, 0)
[  3894.138] (II) LoadModule: "nouveau"
[  3894.138] (WW) Warning, couldn't open module nouveau
[  3894.138] (II) UnloadModule: "nouveau"
[  3894.138] (II) Unloading nouveau
[  3894.138] (EE) Failed to load module "nouveau" (module does not exist, 0)
[  3894.138] (II) LoadModule: "modesetting"
[  3894.138] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[  3894.138] (II) Module modesetting: vendor="X.Org Foundation"
[  3894.138] 	compiled for 1.19.5, module version = 1.19.5
[  3894.138] 	Module class: X.Org Video Driver
[  3894.138] 	ABI class: X.Org Video Driver, version 23.0
[  3894.138] (II) UnloadModule: "modesetting"
[  3894.138] (II) Unloading modesetting
[  3894.138] (II) Failed to load module "modesetting" (already loaded, 0)
[  3894.138] (II) LoadModule: "fbdev"
[  3894.138] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[  3894.138] (II) Module fbdev: vendor="X.Org Foundation"
[  3894.139] 	compiled for 1.19.3, module version = 0.4.4
[  3894.139] 	Module class: X.Org Video Driver
[  3894.139] 	ABI class: X.Org Video Driver, version 23.0
[  3894.139] (II) LoadModule: "vesa"
[  3894.139] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[  3894.139] (II) Module vesa: vendor="X.Org Foundation"
[  3894.139] 	compiled for 1.19.3, module version = 2.3.4
[  3894.139] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[  3894.139] (II) FBDEV: driver for framebuffer: fbdev
[  3894.139] (II) VESA: driver for VESA chipsets: vesa
[  3894.139] (II) modeset(G0): using drv /dev/dri/card0
[  3894.139] (WW) Falling back to old probe method for fbdev
[  3894.139] (II) Loading sub module "fbdevhw"
[  3894.139] (II) LoadModule: "fbdevhw"
[  3894.139] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[  3894.139] (II) Module fbdevhw: vendor="X.Org Foundation"
[  3894.139] 	compiled for 1.19.5, module version = 0.0.2
[  3894.140] (WW) Falling back to old probe method for vesa
[  3894.140] (EE) No devices detected.
[  3894.140] (EE)
Fatal server error:
[  3894.140] (EE) no screens found(EE)
[  3894.140] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[  3894.140] (EE) Please also check the log file at "/var/log/Xorg.1.log" for additional information.
[  3894.140] (EE)
[  3894.164] (EE) Server terminated with error (1). Closing log file.
Unfortunately, those are old logfiles. Seems that 17.10 has incorporated them into journal. See, if you can get a current one using
journalctl -b 0 --no-pager _COMM=gdm-x-session
Run vdpauinfo a few times before to maybe have some error messages in it.
Thank you again for your answer … Here it goes
-- Logs begin at Tue 2017-12-05 07:45:02 CET, end at Tue 2017-12-05 18:01:20 CET. --
dec 05 07:45:49 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) Log file renamed from "/var/log/Xorg.pid-1387.log" to "/var/log/Xorg.0.log"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: X.Org X Server 1.19.5
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: Release Date: 2017-10-12
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: X Protocol Version 11, Revision 0
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: Build Operating System: Linux 4.4.0-97-generic x86_64 Ubuntu
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: Current Operating System: Linux acer 4.13.0-17-generic #20-Ubuntu SMP Mon Nov 6 10:04:08 UTC 2017 x86_64
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: Kernel command line: BOOT_IMAGE=/vmlinuz-4.13.0-17-generic root=/dev/mapper/ubuntu--vg-root ro quiet splash vt.handoff=7
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: Build Date: 15 October 2017  05:51:19PM
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: xorg-server 2:1.19.5-0ubuntu2 (For technical support please see http://www.ubuntu.com/support)
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: Current version of pixman: 0.34.0
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]:         Before reporting problems, check http://wiki.x.org
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]:         to make sure that you have the latest version.
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: Markers: (--) probed, (**) from config file, (==) default setting,
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]:         (++) from command line, (!!) notice, (II) informational,
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec  5 07:45:50 2017
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Using config file: "/etc/X11/xorg.conf"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) ServerLayout "layout"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) |-->Screen "nvidia" (0)
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) |   |-->Monitor "<default monitor>"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) |   |-->Device "nvidia"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) |   |-->GPUDevice "nvidia"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) No monitor specified for screen "nvidia".
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]:         Using a default monitor configuration.
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) |-->Inactive Device "intel"
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Automatically adding devices
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Automatically enabling devices
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Automatically adding GPU devices
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Automatically binding GPU devices
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) Max clients allowed: 256, resource mask: 0x1fffff
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]:         Entry deleted from font path.
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
dec 05 07:45:50 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         Entry deleted from font path.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) FontPath set to:
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         /usr/share/fonts/X11/misc,
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         /usr/share/fonts/X11/Type1,
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         built-ins
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) The server relies on udev to provide the list of input devices.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         If no devices become available, reconfigure udev or disable AutoAddDevices.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loader magic: 0x562e3627a020
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module ABI versions:
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         X.Org ANSI C Emulation: 0.4
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         X.Org Video Driver: 23.0
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         X.Org XInput driver : 24.1
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]:         X.Org Server Extension : 10.0
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (++) using VT number 1
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) xfree86: Adding drm device (/dev/dri/card0)
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) xfree86: Adding drm device (/dev/dri/card1)
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) PCI:*(0:0:2:0) 8086:0a16:1025:0866 rev 11, Mem @ 0xb3000000/4194304, 0xc0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) PCI: (0:3:0:0) 10de:1341:1025:0867 rev 162, Mem @ 0xb2000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) "glx" will be loaded by default.
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "glx"
dec 05 07:45:51 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module glx: vendor="NVIDIA Corporation"
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]:         compiled for 4.0.2, module version = 1.0.0
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]:         Module class: X.Org Server Extension
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA GLX Module  387.34  Tue Nov 21 02:04:31 PST 2017
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "nvidia"
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module nvidia: vendor="NVIDIA Corporation"
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]:         Module class: X.Org Video Driver
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "modesetting"
dec 05 07:45:53 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module modesetting: vendor="X.Org Foundation"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]:         compiled for 1.19.5, module version = 1.19.5
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]:         Module class: X.Org Video Driver
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]:         ABI class: X.Org Video Driver, version 23.0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA dlloader X Driver  387.34  Tue Nov 21 01:38:22 PST 2017
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: releasing fd for 226:1
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading sub module "fb"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "fb"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/xorg/modules/libfb.so
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module fb: vendor="X.Org Foundation"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]:         compiled for 1.19.5, module version = 1.0.0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]:         ABI class: X.Org ANSI C Emulation, version 0.4
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading sub module "wfb"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "wfb"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/xorg/modules/libwfb.so
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module wfb: vendor="X.Org Foundation"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading sub module "ramdac"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "ramdac"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module "ramdac" already built-in
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): using drv /dev/dri/card0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): Creating default Display subsection in Screen section
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]:         "nvidia" for depth/fbbpp 24/32
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): RGB weight 888
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): Default visual is TrueColor
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) NVIDIA(0): Option "ConstrainCursor" "off"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration" "on"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) NVIDIA(0): Option "IgnoreDisplayDevices" "CRT"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) NVIDIA(0): Enabling 2D acceleration
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): NVIDIA GPU GeForce 840M (GM108-A) at PCI:3:0:0 (GPU-0)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) NVIDIA(0): Memory: 2097152 kBytes
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) NVIDIA(0): VideoBIOS: 82.08.15.00.2a
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): Detected PCI Express Link width: 4X
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): Validated MetaModes:
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0):     "NULL"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) NVIDIA(0): Unable to get display device for DPI computation.
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) modeset(G0): Option "AccelMethod" "None"
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): RGB weight 888
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): Default visual is TrueColor
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) modeset(G0): glamor disabled
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): ShadowFB: preferred YES, enabled YES
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Double-buffered shadow updates: off
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Output eDP-1-1 has no monitor section
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Output DP-1-1 has no monitor section
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Output HDMI-1-1 has no monitor section
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Output HDMI-1-2 has no monitor section
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): EDID for output eDP-1-1
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Manufacturer: AUO  Model: 31ed  Serial#: 0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Year: 2012  Week: 0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): EDID Version: 1.4
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Digital Display Input
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): 6 bits per channel
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Digital interface is DisplayPort
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Gamma: 2.20
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): No DPMS capabilities specified
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Supported color encodings: RGB 4:4:4
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): First detailed timing is preferred mode
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Preferred mode is native pixel format and refresh rate
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): redX: 0.620 redY: 0.349   greenX: 0.324 greenY: 0.606
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): blueX: 0.152 blueY: 0.118   whiteX: 0.313 whiteY: 0.329
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Manufacturer's mask: 0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Supported detailed timing:
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): clock: 145.0 MHz   Image Size:  344 x 193 mm
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): h_active: 1920  h_sync: 1968  h_sync_end 2068 h_blank_end 2110 h_border: 0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): v_active: 1080  v_sync: 1083  v_sync_end 1084 v_blanking: 1140 v_border: 0
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Unknown vendor-specific block f
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):  AUO
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):  B156HTN03.1
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): EDID (in hex):
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         00ffffffffffff0006afed3100000000
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         001601049522137802d1159e59539b27
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         1e505400000001010101010101010101
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         010101010101a43880be70383c403064
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         310058c1100000180000000f00000000
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         00000000000000000020000000fe0041
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         554f0a202020202020202020000000fe
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0):         004231353648544e30332e31200a00de
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Printing probed modes for output eDP-1-1
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1920x1080"x60.3  145.00  1920 1968 2068 2110  1080 1083 1084 1140 -hsync -vsync (68.7 kHz eP)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "800x512"x120.3   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "720x450"x119.8   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "680x384"x119.6   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "680x384"x119.9   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "576x432"x120.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
dec 05 07:45:54 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): EDID for output DP-1-1
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): EDID for output HDMI-1-1
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): EDID for output HDMI-1-2
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): DPI set to (96, 96)
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading sub module "fb"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "fb"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/xorg/modules/libfb.so
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module fb: vendor="X.Org Foundation"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]:         compiled for 1.19.5, module version = 1.0.0
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]:         ABI class: X.Org ANSI C Emulation, version 0.4
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading sub module "shadow"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "shadow"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/xorg/modules/libshadow.so
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module shadow: vendor="X.Org Foundation"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]:         compiled for 1.19.5, module version = 1.1.0
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) Depth 24 pixmap format is 32 bpp
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): Backing store enabled
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): Silken mouse enabled
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) modeset(G0): DPMS enabled
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (WW) modeset(G0): Option "IgnoreDisplayDevices" is not used
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA:     access.
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): Setting mode "NULL"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): Disabling shared memory pixmaps
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): Backing store enabled
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): Silken mouse enabled
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (==) NVIDIA(0): DPMS enabled
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading sub module "dri2"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "dri2"
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module "dri2" already built-in
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): [DRI2] Setup complete
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) RandR disabled
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) SELinux: Disabled on system
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Initializing extension GLX
dec 05 07:45:55 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Indirect GLX disabled.
dec 05 07:45:56 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) modeset(G0): Damage tracking initialized
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device Power Button (/dev/input/event3)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Power Button: Applying InputClass "evdev keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "libinput"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module libinput: vendor="X.Org Foundation"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]:         compiled for 1.19.3, module version = 0.25.0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]:         Module class: X.Org XInput Driver
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]:         ABI class: X.Org XInput driver, version 24.1
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'libinput' for 'Power Button'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 39 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Power Button: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event3"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "_source" "server/udev"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event3  - (II) Power Button: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event3  - (II) Power Button: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event3  - (II) Power Button: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "xkb_model" "pc105"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "xkb_layout" "si"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device Video Bus (/dev/input/event6)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Video Bus: Applying InputClass "evdev keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Video Bus: Applying InputClass "libinput keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'libinput' for 'Video Bus'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 42 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Video Bus: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event6"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event6  - (II) Video Bus: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event6  - (II) Video Bus: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event6  - (II) Video Bus: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input6/event6"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device Power Button (/dev/input/event1)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 43 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event1"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event1  - (II) Power Button: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event1  - (II) Power Button: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event1  - (II) Power Button: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input1/event1"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) No input driver specified, ignoring this device.
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) This device may have been added with another device file.
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'libinput' for 'Sleep Button'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 44 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Sleep Button: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event2"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event2  - (II) Sleep Button: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event2  - (II) Sleep Button: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event2  - (II) Sleep Button: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0E:00/input/input2/event2"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device Video Bus (/dev/input/event5)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 45 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event5"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event5  - (II) Video Bus: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event5  - (II) Video Bus: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event5  - (II) Video Bus: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:38/LNXVIDEO:00/input/input5/event5"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 10)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event10)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event11)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=10 (/dev/input/event12)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event8)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event9)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device OM (/dev/input/event7)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) OM: Applying InputClass "evdev pointer catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) OM: Applying InputClass "libinput pointer catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'libinput' for 'OM'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 46 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) OM: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event7"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event7  - (II) OM: (II) is tagged by udev as: Mouse
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event7  - (II) OM: (II) device is a pointer
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event7  - (II) OM: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:04F3:0235.0002/input/input7/event7"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "OM" (type: MOUSE, id 11)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "AccelerationScheme" "none"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) OM: (accel) selected scheme none/0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) OM: (accel) acceleration factor: 2.000
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) OM: (accel) acceleration threshold: 4
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device OM (/dev/input/mouse0)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device HD WebCam: HD WebCam (/dev/input/event15)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) HD WebCam: HD WebCam: Applying InputClass "evdev keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) HD WebCam: HD WebCam: Applying InputClass "libinput keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'libinput' for 'HD WebCam: HD WebCam'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 47 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) HD WebCam: HD WebCam: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event15"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event15 - (II) HD WebCam: HD WebCam: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event15 - (II) HD WebCam: HD WebCam: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event15 - (II) HD WebCam: HD WebCam: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/input/input20/event15"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "HD WebCam: HD WebCam" (type: KEYBOARD, id 12)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/event14)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "evdev touchpad catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "libinput touchpad catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "touchpad catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "Default clickpad buttons"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) LoadModule: "synaptics"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Module synaptics: vendor="X.Org Foundation"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]:         compiled for 1.19.3, module version = 1.9.0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'synaptics' for 'SYN1B7E:01 06CB:2970 Touchpad'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 48 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event14"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) synaptics: SYN1B7E:01 06CB:2970 Touchpad: found clickpad property
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: x-axis range 0 - 1236 (res 12)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: y-axis range 0 - 898 (res 12)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) synaptics: SYN1B7E:01 06CB:2970 Touchpad: device does not report pressure, will use touch data.
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) synaptics: SYN1B7E:01 06CB:2970 Touchpad: device does not report finger width.
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: buttons: left double triple
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: Vendor 0x6cb Product 0x2970
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: invalid pressure range.  defaulting to 0 - 255
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: invalid finger width range.  defaulting to 0 - 15
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (--) synaptics: SYN1B7E:01 06CB:2970 Touchpad: touchpad found
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/INT33C3:00/i2c-0/i2c-SYN1B7E:01/0018:06CB:2970.0001/input/input15/event14"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "SYN1B7E:01 06CB:2970 Touchpad" (type: TOUCHPAD, id 13)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) synaptics: SYN1B7E:01 06CB:2970 Touchpad: (accel) MinSpeed is now constant deceleration 2.5
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) synaptics: SYN1B7E:01 06CB:2970 Touchpad: (accel) MaxSpeed is now 1.75
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) synaptics: SYN1B7E:01 06CB:2970 Touchpad: (accel) AccelFactor is now 0.131
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) keeping acceleration scheme 1
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration profile 1
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration factor: 2.000
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration threshold: 4
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/mouse1)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) SYN1B7E:01 06CB:2970 Touchpad: Ignoring device from InputClass "touchpad ignore duplicates"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 49 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) AT Translated Set 2 keyboard: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event4"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event4  - (II) AT Translated Set 2 keyboard: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event4  - (II) AT Translated Set 2 keyboard: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event4  - (II) AT Translated Set 2 keyboard: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 14)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event16)
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Acer WMI hotkeys: Applying InputClass "libinput keyboard catchall"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) Using input driver 'libinput' for 'Acer WMI hotkeys'
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) systemd-logind: got fd for /dev/input/event16 13:80 fd 50 paused 0
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Acer WMI hotkeys: always reports core events
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "Device" "/dev/input/event16"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event16 - (II) Acer WMI hotkeys: (II) is tagged by udev as: Keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event16 - (II) Acer WMI hotkeys: (II) device is a keyboard
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) event16 - (II) Acer WMI hotkeys: (II) device removed
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (**) Option "config_info" "udev:/sys/devices/virtual/input/input21/event16"
dec 05 07:45:57 acer /usr/lib/gdm3/gdm-x-session[1385]: (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 15)
dec 05 07:45:58 acer /usr/lib/gdm3/gdm-x-session[1385]: rm: cannot remove '/var/log/prime-supported.log': Permission denied
dec 05 07:45:58 acer /usr/lib/gdm3/gdm-x-session[1385]: /usr/bin/prime-supported: 35: /usr/bin/prime-supported: cannot create /var/log/prime-supported.log: Permission denied
dec 05 07:45:59 acer /usr/lib/gdm3/gdm-x-session[1385]: randr: falling back to unsynchronized pixmap sharing
dec 05 07:46:01 acer /usr/lib/gdm3/gdm-x-session[1385]: /etc/gdm3/Xsession: Beginning session setup...
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: localuser:bp being added to access control list
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting DISPLAY=:0
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XAUTHORITY=/run/user/1000/gdm/Xauthority
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: /etc/X11/Xsession.d/50_check_unity_support: vrstica 6: /usr/lib/nux/unity_support_test: Datoteka ali imenik s tem imenom ne obstaja
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting GTK_MODULES=gail:atk-bridge
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting CLUTTER_IM_MODULE=xim
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting LIBVA_DRIVER_NAME=nvidia
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting LANG=sl_SI.UTF-8
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting GTK2_MODULES=overlay-scrollbar
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting USERNAME=bp
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting JAVA_HOME=/usr/lib/jvm/java-8-oracle
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting J2SDKDIR=/usr/lib/jvm/java-8-oracle
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting DERBY_HOME=/usr/lib/jvm/java-8-oracle/db
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting USER=bp
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting DESKTOP_SESSION=ubuntu
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting QT4_IM_MODULE=xim
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting TEXTDOMAINDIR=/usr/share/locale/
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting QT_QPA_PLATFORMTHEME=appmenu-qt5
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting PWD=/home/bp
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting HOME=/home/bp
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting JOURNAL_STREAM=9:26922
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting TEXTDOMAIN=im-config
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting J2REDIR=/usr/lib/jvm/java-8-oracle/jre
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting VDPAU_DRIVER=nvidia
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting LIBVIRT_DEFAULT_URI=qemu:///system
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XDG_SESSION_TYPE=x11
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/ubuntu:/usr/local/share:/usr/share:/var/lib/snapd/desktop:/var/lib/snapd/desktop
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XDG_SESSION_DESKTOP=ubuntu
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting WINDOWPATH=1
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting SHELL=/bin/bash
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting QT_IM_MODULE=ibus
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XMODIFIERS=@im=ibus
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting IM_CONFIG_PHASE=2
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XDG_CURRENT_DESKTOP=ubuntu:GNOME
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting SHLVL=1
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting GDMSESSION=ubuntu
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting LIBGL_ALWAYS_SOFTWARE=1
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting LOGNAME=bp
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg/xdg-ubuntu:/etc/xdg
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting PATH=/home/bp/bin:/home/bp/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/lib/jvm/java-8-oracle/bin:/usr/lib/jvm/java-8-oracle/db/bin:/usr/lib/jvm/java-8-oracle/jre/bin
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting GTK_IM_MODULE=ibus
dec 05 07:46:05 acer /usr/lib/gdm3/gdm-x-session[1385]: dbus-update-activation-environment: setting _=/usr/bin/dbus-update-activation-environment
vdpauinfo returns the following, but id does not seem to add anything to the above log output
[code]
isplay: :0 screen: 0
GPU at BusId 0x3 doe
Since you’re running a driver new enough to support the GPU, this just means your GPU doesn’t have a video decoder at all.
Forgive my ignorance, but VDPAU worked flawlessly on 17.04? I’ve also seen working setups with the same chipset on other distoros? What are you suggesting? That my GPU has some sort of flaw?
Blaz
Unfortunately, logs show no trace of what could be wrong. So please some more infos, all run as normal user
udevadm info -n /dev/dri/card1
udevadm info -n /dev/dri/card0
getfacl /dev/dri/*
getfacl /dev/nv*
I wonder if you were previously using a build of VDPAU that supported the Intel chip. Is there any way you could get the output from vdpauinfo and/or vainfo from 17.04 on that system?
output attached …
P: /devices/pci0000:00/0000:00:1c.4/0000:03:00.0/drm/card1
N: dri/card1
S: dri/by-path/pci-0000:03:00.0-card
E: DEVLINKS=/dev/dri/by-path/pci-0000:03:00.0-card
E: DEVNAME=/dev/dri/card1
E: DEVPATH=/devices/pci0000:00/0000:00:1c.4/0000:03:00.0/drm/card1
E: DEVTYPE=drm_minor
E: ID_FOR_SEAT=drm-pci-0000_03_00_0
E: ID_PATH=pci-0000:03:00.0
E: ID_PATH_TAG=pci-0000_03_00_0
E: MAJOR=226
E: MINOR=1
E: SUBSYSTEM=drm
E: TAGS=:seat:uaccess:master-of-seat:
E: USEC_INITIALIZED=2073882
P: /devices/pci0000:00/0000:00:02.0/drm/card0
N: dri/card0
S: dri/by-path/pci-0000:00:02.0-card
E: DEVLINKS=/dev/dri/by-path/pci-0000:00:02.0-card
E: DEVNAME=/dev/dri/card0
E: DEVPATH=/devices/pci0000:00/0000:00:02.0/drm/card0
E: ID_FOR_SEAT=drm-pci-0000_00_02_0
E: ID_PATH=pci-0000:00:02.0
E: ID_PATH_TAG=pci-0000_00_02_0
E: MAJOR=226
E: MINOR=0
E: PRIMARY_DEVICE_FOR_DISPLAY=1
E: SUBSYSTEM=drm
E: TAGS=:uaccess:seat:master-of-seat:
E: USEC_INITIALIZED=2783185
getfacl /dev/dri/*
getfacl: Removing leading '/' from absolute path names
# file: dev/dri/by-path
# owner: root
# group: root
user::rwx
group::r-x
other::r-x
# file: dev/dri/card0
# owner: root
# group: video
user::rw-
user:bp:rw-
group::rw-
mask::rw-
other::---
# file: dev/dri/card1
# owner: root
# group: video
user::rw-
user:bp:rw-
group::rw-
mask::rw-
other::---
# file: dev/dri/renderD128
# owner: root
# group: video
user::rw-
user:bp:rw-
group::rw-
mask::rw-
other::---
# file: dev/dri/renderD129
# owner: root
# group: video
user::rw-
user:bp:rw-
group::rw-
mask::rw-
other::---
getfacl /dev/nv*
# file: dev/nvidia0
# owner: root
# group: root
user::rw-
group::rw-
other::rw-
# file: dev/nvidiactl
# owner: root
# group: root
user::rw-
group::rw-
other::rw-
# file: dev/nvidia-modeset
# owner: root
# group: root
user::rw-
group::rw-
other::rw-
# file: dev/nvidia-uvm
# owner: root
# group: root
user::rw-
group::rw-
other::rw-
@aplattner
sorry, i have no idea how to get the old 17.04 setup logs if they exist. Honestlly, I don’t really care which card does the hardware decoding … or if it is done at all … the problem I’ve got is that the system is convinced, that the NVIDA card is capable of VDPAU, but then the decoding fails … so whan i run gstreamer, it refuses to play video, all i get is sound …
gst-play-1.0 udp://@239.18.2.248:5000
Press 'k' to see a list of keyboard shortcuts.
Now playing udp://@239.18.2.248:5000
Pipeline is live.
DtsGetHWFeatures: Create File Failed
Running DIL (3.22.0) Version
DtsDeviceOpen: Opening HW in mode 0
DtsDeviceOpen: Create File Failed
WARNING Za vrsto "video/x-h264, stream-format=(string)byte-stream, alignment=(string)nal, parsed=(boolean)true" ni ustreznega odkodirnika.
WARNING debug information: gsturidecodebin.c(931): unknown_type_cb (): /GstPlayBin:playbin/GstURIDecodeBin:uridecodebin0
Redistribute latency...
Preroll
same thing with ffmpeg:
ffmpeg -i udp://@239.18.2.248:5000
ffmpeg version 3.3.4-2 Copyright (c) 2000-2017 the FFmpeg developers
  built with gcc 7 (Ubuntu 7.2.0-8ubuntu2)
  configuration: --prefix=/usr --extra-version=2 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
  WARNING: library configuration mismatch
  avcodec     configuration: --prefix=/usr --extra-version=2 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared --enable-version3 --disable-doc --disable-programs --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libtesseract --enable-libvo_amrwbenc --enable-netcdf
  libavutil      55. 58.100 / 55. 58.100
  libavcodec     57. 89.100 / 57. 89.100
  libavformat    57. 71.100 / 57. 71.100
  libavdevice    57.  6.100 / 57.  6.100
  libavfilter     6. 82.100 /  6. 82.100
  libavresample   3.  5.  0 /  3.  5.  0
  libswscale      4.  6.100 /  4.  6.100
  libswresample   2.  7.100 /  2.  7.100
  libpostproc    54.  5.100 / 54.  5.100
[h264 @ 0x55e050b95de0] SPS unavailable in decode_picture_timing
[h264 @ 0x55e050b95de0] non-existing PPS 0 referenced
[h264 @ 0x55e050b95de0] decode_slice_header error
[h264 @ 0x55e050b95de0] no frame!
[h264 @ 0x55e050b95de0] Increasing reorder buffer to 2
Input #0, mpegts, from 'udp://@239.18.2.248:5000':
  Duration: N/A, start: 78671.243433, bitrate: N/A
  Program 1
    Metadata:
      service_name    : rokus TV
      service_provider: skrutos
    Stream #0:0[0xc8]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuvj420p(pc, bt470bg, progressive), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x12c]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 122 kb/s
At least one output file must be specified
The only thing that works is VLC, which - as I understand - packs it’s own codecs? But I really need gstreamer to work for a particular project.
Looks also okayish. I’m out of ideas now, you can just check if you’re member of the video group and if not, adding your user to it. Though that shouldn’t have an effect then.
I added myself to the video group, but i am the only member. I’m under the impression that the group did not exist piror to adding the main account. Did not make any difference however …
i suspect the issue is connected to
https://devtalk.nvidia.com/default/topic/794999/linux/can-t-get-to-work-vdpau-on-optimus-notebook-but-everything-else-works-fine/2
which has been reported for a few recent drivers on ubuntu
Bump. I have a very similar problem.
OS: Xubuntu 19.04
Kernel: 5.0.0-20-lowlatency kernel.
Hardware: GTX 940M (I think) on a Zenbook UX303L laptop.
Starting playback of any video seems to have became software for the last few weeks - all the CPU cores are maxed for 2k video while before the computer would remain perfectly fine.
Is there a fix for this?
vdpauinfo
display: :0.0   screen: 0
VDPAU capture: Enabled
vdp_imp_device_create_x11(0x559c9d583e70, 0, -, -)
GPU at BusId 0x3 doesn't have a supported video decoder
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library  430.26  Tue Jun  4 17:43:17 CDT 2019
VDPAU nvidia: Error detected 9 373  3
VDPAU nvidia: Backtrace:
--: /lib/x86_64-linux-gnu/vdpau/libvdpau_nvidia.so.1 [0x7f62102b1000] DSO load base
00: /lib/x86_64-linux-gnu/vdpau/libvdpau_nvidia.so.1 [0x7f62102e820c]
01: /lib/x86_64-linux-gnu/vdpau/libvdpau_nvidia.so.1 [0x7f62102d6b33]
02: /lib/x86_64-linux-gnu/vdpau/libvdpau_nvidia.so.1 [0x7f62102b9611] vdp_imp_device_create_x11
    -> 1
Error creating VDPAU device: 1
vainfo
libva info: VA-API version 1.4.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/nvidia_drv_video.so
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
This is also what I encountered with 940MX with prime setup enabled, totally disastrous.
While the matrix [url]https://developer.nvidia.com/video-encode-decode-gpu-support-matrix[/url] tell us 940m/mx ARE supported.
Can someone from NVidia tell us what happen, or at least, what to check ?
