Error creating VDPAU device: 1, VDPAU not working.
export VDPAU_TRACE=2
export VDPAU_NVIDIA_DEBUG=3
export VDPAU_TRACE_FILE=vdpau.log
export VDPAU_DRIVER=nvidia
vdpauinfo
display: :0.0   screen: 0
VDPAU nvidia: Version: NVIDIA VDPAU Driver Shared Library  370.28  Thu Sep  1 19:18:08 PDT 2016
VDPAU nvidia: Error detected 9 351  5
VDPAU nvidia: Backtrace:
--: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f6020297000] DSO load base
00: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f60202c5563]
01: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f60202b7fc3]
02: /usr/lib/vdpau/libvdpau_nvidia.so.1 [0x7f602029fd7c] vdp_imp_device_create_x11
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x1f1 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x46 cap: 0x2, Sink Output crtcs: 3 outputs: 4 associated providers: 1 name:modesetting
sudo lspci -vv
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
	Subsystem: Acer Incorporated [ALI] Device 0940
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
	Latency: 0
	Capabilities: [e0] Vendor Specific Information: Len=0c <?>
	Kernel driver in use: bdw_uncore
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 5500 (rev 09) (prog-if 00 [VGA controller])
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 50
	Region 0: Memory at c2000000 (64-bit, non-prefetchable)
	Region 2: Memory at d0000000 (64-bit, prefetchable)
	Region 4: I/O ports at 5000
	[virtual] Expansion ROM at 000c0000 [disabled]
	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee00018  Data: 0000
	Capabilities: [d0] Power Management version 2
		Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
		Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [a4] PCI Advanced Features
		AFCap: TP+ FLR+
		AFCtrl: FLR-
		AFStatus: TP-
	Kernel driver in use: i915
	Kernel modules: i915
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 53
	Region 0: Memory at c4210000 (64-bit, non-prefetchable)
	Capabilities: [50] Power Management version 2
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee003d8  Data: 0000
	Capabilities: [70] Express (v1) Root Complex Integrated Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0
			ExtTag- RBE-
		DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
			RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 128 bytes, MaxReadReq 128 bytes
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03) (prog-if 30 [XHCI])
	Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 47
	Region 0: Memory at c4200000 (64-bit, non-prefetchable)
	Capabilities: [70] Power Management version 2
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
		Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
	Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
		Address: 00000000fee00318  Data: 0000
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
	Latency: 0
	Interrupt: pin A routed to IRQ 49
	Region 0: Memory at c421a000 (64-bit, non-prefetchable)
	Capabilities: [50] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
	Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee00358  Data: 0000
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
	Latency: 64, Cache Line Size: 64 bytes
	Interrupt: pin A routed to IRQ 52
	Region 0: Memory at c4214000 (64-bit, non-prefetchable)
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=55mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee003b8  Data: 0000
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3) (prog-if 00 [Normal decode])
	Interrupt: pin A routed to IRQ 42
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 00002000-00002fff
	Memory behind bridge: a0100000-a02fffff
	Prefetchable memory behind bridge: 00000000a0300000-00000000a04fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
	BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
		PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
	Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
			ExtTag- RBE+
		DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
		LnkCap:	Port #1, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <1us, L1 <4us
			ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
		LnkCtl:	ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk-
			ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x0, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+
			Slot #0, PowerLimit 0.000W; Interlock- NoCompl+
		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet+ CmdCplt- HPIrq+ LinkChg+
			Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
			Changed: MRL- PresDet- LinkState-
		RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
		RootCap: CRSVisible-
		RootSta: PME ReqID 0000, PMEStatus- PMEPending-
		DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR+, OBFF Via WAKE# ARIFwd-
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR+, OBFF Disabled ARIFwd-
		LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
			 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
			 Compliance De-emphasis: -6dB
		LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
			 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
		Address: fee00238  Data: 0000
	Capabilities: [90] Subsystem: Acer Incorporated [ALI] Device 0940
	Capabilities: [a0] Power Management version 3
	Kernel driver in use: pcieport
	Kernel modules: shpchp
00:1c.2 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3) (prog-if 00 [Normal decode])
	Interrupt: pin C routed to IRQ 43
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 00004000-00004fff
	Memory behind bridge: c4100000-c41fffff
			ExtTag- RBE+
		LnkCap:	Port #3, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <16us
		LnkCtl:	ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
		SltCap:	AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
			Slot #2, PowerLimit 10.000W; Interlock- NoCompl+
		SltCtl:	Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
		SltSta:	Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
			Changed: MRL- PresDet- LinkState+
		DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd-
		Address: fee00278  Data: 0000
	Capabilities: [100 v0] #00
	Capabilities: [200 v1] L1 PM Substates
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
			  PortCommonModeRestoreTime=40us PortTPowerOnTime=10us
00:1c.3 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #4 (rev e3) (prog-if 00 [Normal decode])
	Interrupt: pin D routed to IRQ 44
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	Memory behind bridge: c4000000-c40fffff
	Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
			ExtTag- RBE+
		LnkCap:	Port #4, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <16us
			Slot #3, PowerLimit 10.000W; Interlock- NoCompl+
		Address: fee002b8  Data: 0000
00:1c.4 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #5 (rev e3) (prog-if 00 [Normal decode])
	Interrupt: pin A routed to IRQ 45
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: c3000000-c3ffffff
	Prefetchable memory behind bridge: 00000000b0000000-00000000c1ffffff
			ExtTag- RBE+
		LnkCap:	Port #5, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 <16us
		LnkSta:	Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt+
			Slot #4, PowerLimit 25.000W; Interlock- NoCompl+
		Address: fee002d8  Data: 0000
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
	Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03) (prog-if 01 [AHCI 1.0])
	Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin B routed to IRQ 48
	Region 0: I/O ports at 5088
	Region 1: I/O ports at 5094
	Region 2: I/O ports at 5080
	Region 3: I/O ports at 5090
	Region 4: I/O ports at 5060
	Region 5: Memory at c4218000 (32-bit, non-prefetchable)
		Address: fee00338  Data: 0000
	Capabilities: [70] Power Management version 3
		Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
	Capabilities: [a8] SATA HBA v1.0 BAR4 Offset=00000004
	Kernel driver in use: ahci
	Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
	Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
	Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Interrupt: pin C routed to IRQ 18
	Region 0: Memory at c4219000 (64-bit, non-prefetchable)
	Region 4: I/O ports at 5040
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. Device 5287 (rev 01)
	Interrupt: pin B routed to IRQ 46
	Region 0: Memory at c4105000 (32-bit, non-prefetchable)
	Expansion ROM at c4110000 [disabled]
	Capabilities: [40] Power Management version 3
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0-,D1+,D2+,D3hot+,D3cold+)
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee002f8  Data: 0000
	Capabilities: [70] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
			ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 10.000W
			RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop-
			MaxPayload 128 bytes, MaxReadReq 512 bytes
		DevSta:	CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr+ TransPend-
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
			ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
		LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Via message/WAKE#
		LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
		LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
	Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
		Vector table: BAR=0 offset=00000000
		PBA: BAR=0 offset=00000000
	Capabilities: [d0] Vital Product Data
pcilib: sysfs_read_vpd: read failed: Input/output error
		Not readable
	Capabilities: [100 v2] Advanced Error Reporting
		UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
		UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
		AERCap:	First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
	Capabilities: [140 v1] Virtual Channel
		Caps:	LPEVC=0 RefClk=100ns PATEntryBits=1
		Arb:	Fixed- WRR32- WRR64- WRR128-
		Ctrl:	ArbSelect=Fixed
		Status:	InProgress-
		VC0:	Caps:	PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
			Arb:	Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
			Ctrl:	Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
			Status:	NegoPending- InProgress-
	Capabilities: [160 v1] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [170 v1] Latency Tolerance Reporting
		Max snoop latency: 3145728ns
		Max no snoop latency: 3145728ns
	Capabilities: [178 v1] L1 PM Substates
			  PortCommonModeRestoreTime=150us PortTPowerOnTime=150us
	Kernel driver in use: rtsx_pci
	Kernel modules: rtsx_pci
02:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 12)
	Interrupt: pin A routed to IRQ 51
	Region 0: I/O ports at 4000
	Region 2: Memory at c4104000 (64-bit, non-prefetchable)
	Region 4: Memory at c4100000 (64-bit, non-prefetchable)
		Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
		Address: 00000000fee00378  Data: 0000
	Capabilities: [70] Express (v2) Endpoint, MSI 01
			MaxPayload 128 bytes, MaxReadReq 4096 bytes
		DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
	Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
		Vector table: BAR=4 offset=00000000
		PBA: BAR=4 offset=00000800
		Not readable
	Capabilities: [160 v1] Device Serial Number 01-00-00-00-68-4c-e0-00
	Kernel driver in use: r8169
	Kernel modules: r8169
03:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
	Subsystem: Lite-On Communications Inc Device 0642
	Interrupt: pin A routed to IRQ 19
	Region 0: Memory at c4000000 (64-bit, non-prefetchable)
	Expansion ROM at c4080000 [disabled]
	Capabilities: [40] Power Management version 2
	Capabilities: [50] MSI: Enable- Count=1/4 Maskable+ 64bit+
		Address: 0000000000000000  Data: 0000
		Masking: 00000000  Pending: 00000000
		DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
		DevCap2: Completion Timeout: Not Supported, TimeoutDis+, LTR-, OBFF Not Supported
	Capabilities: [100 v1] Advanced Error Reporting
		CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
		AERCap:	First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
		Status:	InProgress-
	Kernel driver in use: ath9k
	Kernel modules: ath9k
04:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)
	Subsystem: Acer Incorporated [ALI] Device 0942
	Latency: 0
	Interrupt: pin A routed to IRQ 54
	Region 0: Memory at c3000000 (32-bit, non-prefetchable)
	Region 1: Memory at b0000000 (64-bit, prefetchable)
	Region 3: Memory at c0000000 (64-bit, prefetchable)
	Region 5: I/O ports at 3000
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
		Address: 00000000fee003f8  Data: 0000
	Capabilities: [78] Express (v2) Endpoint, MSI 00
		DevCap:	MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
			ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 25.000W
			RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
		LnkCap:	Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <512ns, L1 unlimited
		LnkSta:	Speed 2.5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
		DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Via message
	Capabilities: [100 v1] Virtual Channel
		Status:	InProgress-
	Capabilities: [250 v1] Latency Tolerance Reporting
		Max snoop latency: 34326183936ns
		Max no snoop latency: 34326183936ns
	Capabilities: [258 v1] L1 PM Substates
			  PortCommonModeRestoreTime=255us PortTPowerOnTime=10us
	Capabilities: [128 v1] Power Budgeting <?>
	Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Kernel driver in use: nvidia
	Kernel modules: nouveau, nvidia_drm, nvidia
uname -a
Linux Object 4.8.4-4-ck #1 SMP PREEMPT Mon Oct 24 17:19:24 EDT 2016 x86_64 GNU/Linux
nvidia-settings --version
nvidia-settings:  version 370.28  (builduser@felix)  Fri Sep  9 15:21:20 CST 2016
glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
    GLX_ARB_context_flush_control, GLX_ARB_create_context,
    GLX_ARB_create_context_profile, GLX_ARB_create_context_robustness,
    GLX_ARB_fbconfig_float, GLX_ARB_multisample, GLX_EXT_buffer_age,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd,
    GLX_EXT_stereo_tree, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
    GLX_NV_robustness_video_memory_purge, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGI_swap_control, GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
    GLX_ARB_fbconfig_float, GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
    GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_stereo_tree,
    GLX_NV_copy_buffer, GLX_NV_copy_image, GLX_NV_delay_before_swap,
    GLX_NV_float_buffer, GLX_NV_multisample_coverage, GLX_NV_present_video,
    GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
    GLX_NV_video_capture, GLX_NV_video_out, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_EXT_create_context_es_profile, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
    GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_image,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 840M/PCIe/SSE2
OpenGL core profile version string: 4.5.0 NVIDIA 370.28
OpenGL core profile shading language version string: 4.50 NVIDIA
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
    GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
    GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
    GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
    GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
    GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_depth_texture, GL_ARB_derivative_control,
    GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
    GL_ARB_geometry_shader4, GL_ARB_get_program_binary,
    GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv, GL_ARB_gpu_shader5,
    GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64, GL_ARB_half_float_pixel,
    GL_ARB_half_float_vertex, GL_ARB_imaging, GL_ARB_indirect_parameters,
    GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
    GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
    GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,
    GL_ARB_multi_draw_indirect, GL_ARB_multisample, GL_ARB_multitexture,
    GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
    GL_ARB_parallel_shader_compile, GL_ARB_pipeline_statistics_query,
    GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
    GL_ARB_query_buffer_object, GL_ARB_robust_buffer_access_behavior,
    GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
    GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
    GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
    GL_ARB_shader_atomic_counters, GL_ARB_shader_ballot,
    GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
    GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
    GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
    GL_ARB_shader_objects, GL_ARB_shader_precision,
    GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
    GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
    GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
    GL_ARB_shading_language_include, GL_ARB_shading_language_packing,
    GL_ARB_shadow, GL_ARB_sparse_buffer, GL_ARB_sparse_texture,
    GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
    GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
    GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
    GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
    GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
    GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
    GL_ARB_texture_stencil8, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
    GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
    GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_draw_buffers,
    GL_ATI_texture_float, GL_ATI_texture_mirror_once,
    GL_EXTX_framebuffer_mixed_formats, GL_EXT_Cg_shader, GL_EXT_abgr,
    GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
    GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
    GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
    GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
    GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
    GL_EXT_import_sync_object, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_polygon_offset_clamp, GL_EXT_provoking_vertex,
    GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_shader_objects, GL_EXT_separate_specular_color,
    GL_EXT_shader_image_load_formatted, GL_EXT_shader_image_load_store,
    GL_EXT_shader_integer_mix, GL_EXT_shadow_funcs, GL_EXT_stencil_two_side,
    GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_array,
    GL_EXT_texture_buffer_object, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
    GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
    GL_EXT_texture_object, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shared_exponent, GL_EXT_texture_storage,
    GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback2,
    GL_EXT_vertex_array, GL_EXT_vertex_array_bgra, GL_EXT_vertex_attrib_64bit,
    GL_EXT_window_rectangles, GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_KHR_blend_equation_advanced,
    GL_KHR_blend_equation_advanced_coherent, GL_KHR_context_flush_control,
    GL_KHR_debug, GL_KHR_no_error, GL_KHR_robust_buffer_access_behavior,
    GL_KHR_robustness, GL_KTX_buffer_region, GL_NVX_conditional_render,
    GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop, GL_NV_ES1_1_compatibility,
    GL_NV_ES3_1_compatibility, GL_NV_alpha_to_coverage_dither_control,
    GL_NV_bindless_multi_draw_indirect,
    GL_NV_bindless_multi_draw_indirect_count, GL_NV_bindless_texture,
    GL_NV_blend_equation_advanced, GL_NV_blend_equation_advanced_coherent,
    GL_NV_blend_square, GL_NV_command_list, GL_NV_compute_program5,
    GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image,
    GL_NV_depth_buffer_float, GL_NV_depth_clamp, GL_NV_draw_texture,
    GL_NV_draw_vulkan_image, GL_NV_explicit_multisample, GL_NV_fence,
    GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
    GL_NV_fragment_program2, GL_NV_fragment_program_option,
    GL_NV_framebuffer_multisample_coverage, GL_NV_geometry_shader4,
    GL_NV_gpu_program4, GL_NV_gpu_program4_1, GL_NV_gpu_program5,
    GL_NV_gpu_program5_mem_extended, GL_NV_gpu_program_fp64,
    GL_NV_gpu_shader5, GL_NV_half_float, GL_NV_internalformat_sample_query,
    GL_NV_light_max_exponent, GL_NV_multisample_coverage,
    GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
    GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
    GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
    GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
    GL_NV_register_combiners, GL_NV_register_combiners2,
    GL_NV_robustness_video_memory_purge, GL_NV_shader_atomic_counters,
    GL_NV_shader_atomic_float, GL_NV_shader_atomic_int64,
    GL_NV_shader_buffer_load, GL_NV_shader_storage_buffer_object,
    GL_NV_shader_thread_group, GL_NV_shader_thread_shuffle,
    GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
    GL_NV_texture_multisample, GL_NV_texture_rectangle, GL_NV_texture_shader,
    GL_NV_texture_shader2, GL_NV_texture_shader3, GL_NV_transform_feedback,
    GL_NV_transform_feedback2, GL_NV_uniform_buffer_unified_memory,
    GL_NV_vdpau_interop, GL_NV_vertex_array_range, GL_NV_vertex_array_range2,
    GL_NV_vertex_attrib_integer_64bit, GL_NV_vertex_buffer_unified_memory,
    GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_NV_vertex_program2,
    GL_NV_vertex_program2_option, GL_NV_vertex_program3, GL_S3_s3tc,
    GL_SGIS_generate_mipmap, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
    GL_SGIX_shadow, GL_SUN_slice_accum
OpenGL version string: 4.5.0 NVIDIA 370.28
OpenGL shading language version string: 4.50 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
    GL_ARB_color_buffer_float, GL_ARB_compatibility,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
    GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
    GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
    GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
    GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 370.28
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
    GL_ANDROID_extension_pack_es31a, GL_EXT_base_instance,
    GL_EXT_blend_func_extended, GL_EXT_blend_minmax, GL_EXT_buffer_storage,
    GL_EXT_color_buffer_float, GL_EXT_color_buffer_half_float,
    GL_EXT_copy_image, GL_EXT_debug_label, GL_EXT_discard_framebuffer,
    GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers_indexed,
    GL_EXT_draw_elements_base_vertex, GL_EXT_float_blend, GL_EXT_frag_depth,
    GL_EXT_geometry_point_size, GL_EXT_geometry_shader, GL_EXT_gpu_shader5,
    GL_EXT_map_buffer_range, GL_EXT_multi_draw_indirect,
    GL_EXT_multisample_compatibility, GL_EXT_occlusion_query_boolean,
    GL_EXT_primitive_bounding_box, GL_EXT_render_snorm, GL_EXT_robustness,
    GL_EXT_sRGB, GL_EXT_sRGB_write_control, GL_EXT_separate_shader_objects,
    GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
    GL_EXT_shader_io_blocks, GL_EXT_shader_texture_lod,
    GL_EXT_shadow_samplers, GL_EXT_sparse_texture,
    GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
    GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_format_BGRA8888, GL_EXT_texture_norm16, GL_EXT_texture_rg,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_storage, GL_EXT_texture_view,
    GL_EXT_unpack_subimage, GL_EXT_window_rectangles,
    GL_KHR_blend_equation_advanced, GL_KHR_blend_equation_advanced_coherent,
    GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
    GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness, GL_NV_bgr,
    GL_NV_bindless_texture, GL_NV_blend_equation_advanced,
    GL_NV_blend_equation_advanced_coherent, GL_NV_conditional_render,
    GL_NV_copy_buffer, GL_NV_copy_image, GL_NV_draw_buffers,
    GL_NV_draw_instanced, GL_NV_draw_texture, GL_NV_draw_vulkan_image,
    GL_NV_explicit_attrib_location, GL_NV_fbo_color_attachments,
    GL_NV_framebuffer_blit, GL_NV_framebuffer_multisample,
    GL_NV_generate_mipmap_sRGB, GL_NV_gpu_shader5, GL_NV_image_formats,
    GL_NV_instanced_arrays, GL_NV_internalformat_sample_query,
    GL_NV_non_square_matrices, GL_NV_occlusion_query_samples,
    GL_NV_pack_subimage, GL_NV_packed_float, GL_NV_packed_float_linear,
    GL_NV_path_rendering, GL_NV_pixel_buffer_object, GL_NV_polygon_mode,
    GL_NV_read_buffer, GL_NV_read_depth, GL_NV_read_depth_stencil,
    GL_NV_read_stencil, GL_NV_sRGB_formats,
    GL_NV_shader_noperspective_interpolation, GL_NV_shadow_samplers_array,
    GL_NV_shadow_samplers_cube, GL_NV_texture_array,
    GL_NV_texture_border_clamp, GL_NV_texture_compression_latc,
    GL_NV_texture_compression_s3tc, GL_NV_texture_compression_s3tc_update,
    GL_NV_timer_query, GL_NV_viewport_array,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
    GL_OES_depth32, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
    GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
    GL_OES_geometry_point_size, GL_OES_geometry_shader,
    GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
    GL_OES_rgb8_rgba8, GL_OES_sample_shading, GL_OES_sample_variables,
    GL_OES_shader_image_atomic, GL_OES_shader_io_blocks,
    GL_OES_shader_multisample_interpolation, GL_OES_standard_derivatives,
    GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
    GL_OES_texture_border_clamp, GL_OES_texture_buffer,
    GL_OES_texture_cube_map_array, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
    GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float
132 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x059 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x05a 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x05c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x05d 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x05e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x05f 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x060 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x061 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x062 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x063 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x064 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x065 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x066 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x067 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x068 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x069 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x06a 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x06b 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x06c 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x06d 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x06e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x06f 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x070 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x071 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x072 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x073 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x074 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x075 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x076 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x077 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x078 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x079 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x07a 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x07b 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x07c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x07d 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x07e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x07f 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x080 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x081 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x082 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x083 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x084 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x085 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x086 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x087 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x088 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x089 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x08a 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x08b 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x08c 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x08d 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x08e 24 dc  0  24  0 r
nvidia-bug-report.log.gz (150 KB)
I met exactly the same problem with GeForce 940MX with version 381.22.
May nVidia shed some more light into this issue?
Thank you.
I really want to follow the guide line of “If you have a problem, PLEASE read this first”…
Only if I could upload a nvidia-bug-report properly…(sigh)
What’s wrong with you guys’ attachment scanning?
All I upload is a gzipped file generated from your utility.
GM108 chips don’t have any video decoding hardware. You’re expected to use the intel GPU for that.
