• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 4070 Laptop GPU
• DeepStream Version 7.0
• TensorRT Version 8.6.1.6-1+cuda12.0
• NVIDIA GPU Driver Version (valid for GPU only) 535.216.01
Trying to use Caffe model as a Sgie got the follow ERROR:
Starting pipeline
0:00:00.160375924 74812 0x564c68ae23e0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger: NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2109> [UID = 4]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:164 Could not find output layer ‘prob’
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:976 failed to build network since parsing model errors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:809 failed to build network.
0:00:04.490086938 74812 0x564c68ae23e0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 4]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2129> [UID = 4]: build engine file failed
0:00:04.608419023 74812 0x564c68ae23e0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 4]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2215> [UID = 4]: build backend context failed
0:00:04.610564605 74812 0x564c68ae23e0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger: NvDsInferContext[UID 4]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1352> [UID = 4]: generate backend failed, check config file settings
0:00:04.610595067 74812 0x564c68ae23e0 WARN nvinfer gstnvinfer.cpp:912:gst_nvinfer_start: error: Failed to create NvDsInferContext instance
0:00:04.610599912 74812 0x564c68ae23e0 WARN nvinfer gstnvinfer.cpp:912:gst_nvinfer_start: error: Config file path: /home/eduardo/Devel/Models/AMFG/config_age_amfg.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Error: gst-resource-error-quark: Failed to create NvDsInferContext instance (1): gstnvinfer.cpp(912): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:secondary-inference3:
Here is the config file for the Sgie files:
config_age_amfg.txt (772 Bytes)
Caffe model age classification deploy prototext that I’m using can be downloaded from here: Age and Gender Classification Using Convolutional Neural Networks - Tal Hassner
