Using a Functor in CUDA Kernel
I am implementing the following function:
template <typename IndexType, typename BinaryType, typename... TupleTypes>
__global__ void apply_predicate_knl(cuda::std::tuple<const TupleTypes*...> data, const IndexType num, bool (*predicate)(cuda::std::tuple<TupleTypes...>), BinaryType* binary_flag)
  for (IndexType idx = blockIdx.x * blockDim.x + threadIdx.x; idx < num; idx += gridDim.x * blockDim.x)
    // get the total dimension of the current tuple (sequence)
    constexpr size_t num_dim = cuda::std::tuple_size<cuda::std::tuple<const TupleTypes...>>::value;
    if (num_dim == 0) // return true if input is empty set
      binary_flag[idx] = static_cast<BinaryType>(1);
    else
      cuda::std::tuple<TupleTypes...> input_object = get_tuple_from_ptr_tuple(data, idx);
      binary_flag[idx] = static_cast<BinaryType>(predicate(input_object));
The idea is, to group pointers of an DoA object into a cuda::std::tuple and apply some predicate to each object in the DoA and set 0 or 1 for that object. I am thinking about how to pass in the function pointer bool (*predicate)(cuda::std::tuple<TupleTypes...>). The first thing I thought of is a functor on device, e.g.,
struct predicate_on_tuple
    __host__ __device__ bool operator()(cuda::std::tuple<uint32_t, uint64_t, uint16_t> input)
    uint32_t some_var;
In this case, I am assuming that the functor object has to be created on device then somehow be passed in as a pointer. Is there a better way to do this?
you can (should?) declare your functor just like that, and pass it (ie. the enclosing object) by value to a kernel that needs it.
Here is an example of what I mean, perhaps that doesn’t line up with what you are asking:
# cat t278.cu
#include <iostream>
#include <cuda/std/tuple>
typedef cuda::std::tuple<int, int> my_tuple;
struct my_func
  int scale;
  my_func(int _s):scale(_s) {};
  __host__ __device__ int operator()(my_tuple &t) { return cuda::std::get<0>(t)*cuda::std::get<1>(t)*scale;}
template <class f>
__global__ void k(int *a, int *b, int *c, f op){
  int idx = blockDim.x*blockIdx.x+threadIdx.x;
  my_tuple i = cuda::std::make_tuple(a[idx], b[idx]);
  c[idx] = op(i);
int main(){
  const int ds  = 1;
  int *a, *b, *c;
  cudaMallocManaged(&a, sizeof(a[0])*ds);
  cudaMallocManaged(&b, sizeof(b[0])*ds);
  cudaMallocManaged(&c, sizeof(c[0])*ds);
  a[0] = 1;
  b[0] = 2;
  k<<<1,1>>>(a, b, c, my_func(3));
  cudaDeviceSynchronize();
  std::cout << c[0]  << std::endl;
# nvcc  t278.cu -o t278
# compute-sanitizer ./t278
========= COMPUTE-SANITIZER
6
========= ERROR SUMMARY: 0 errors
lambdas are another option people frequently discuss in similar context to functors:
# cat t278.cu
#include <iostream>
template <class f>
  c[idx] = op(i);
int main(){
  const int ds  = 1;
  int *a, *b, *c;
  a[0] = 1;
  b[0] = 2;
  const int scale = 3;
  k<<<1,1>>>(a, b, c,
    [=] __device__ (my_tuple t) { return cuda::std::get<0>(t)*cuda::std::get<1>(t)*scale; }
# nvcc  t278.cu -o t278 -extended-lambda
6
