Hi.
Is it not possible to define a functor inside a function?
I’m trying to invoke Thrust::transform with a functor defined inside the same function.
But the compiler complains as below.
#include <stdlib.h>
#include <stdio.h>
#include <thrust/device_vector.h>
#include <thrust/transform.h>
#include <thrust/sequence.h>
#include <thrust/copy.h>
#include <thrust/fill.h>
#include <thrust/replace.h>
#include <thrust/functional.h>
int main(void) {
struct saxpy_functor : thrust::binary_function<float,float,float> {
const float a;
saxpy_functor ( float _a ) : a ( _a ) {}
__host__ __device__ float operator () ( const float & x , const float & y) const {
return a * x + y ;
thrust::device_vector <float> X(10) ;
thrust::device_vector <float> Y(10) ;
thrust::transform(X.begin(),X.end(),Y.begin(),Y.begin(), saxpy_functor(2.0f));
return 0;
error: no instance of overloaded function “thrust::transform” matches the argument list
argument types are: (thrust::detail::normal_iterator<thrust::device_ptr<float>>, thrust::detail::normal_iterator<thrust::device_ptr<float>>, thrust::detail::normal_iterator<thrust::device_ptr<float>>, thrust::detail::normal_iterator<thrust::device_ptr<float>>, saxpy_functor)
If the functor definition is taken out of the main function, it compiles fine.
Is there a way to define the functor inside the main function?
Without doing any work, I wonder if maybe you should use device_ptr instead of device_vector. See if that works.
Also, this seems like a lot of code to write for such a simple operation. Perhaps ArrayFire would make life easier (it’s free for most users):
#include <arrayfire.h>
int main(void) {
float a = 2.0;
array x = randu(10,1); array y = randu(10,1);
y += a*x;
return 0;
I believe that c++03 requires template parameters to have “linkage” [1], which function-scope types like your saxpy_functor lacks. So the short answer to your question is no. You can read more about it here [2].
For short arithmetic expressions like saxpy, you can use a placeholder expression [3] (warning, untested code):
int main(void)
using thrust::placeholders;
thrust::transform(X.begin(),X.end(),Y.begin(),Y.begin(), 2.0f * _1 + _2);
return 0;
[1] Linkage (software) - Wikipedia
[2] c++ - Why can't templates take function local types? - Stack Overflow
[3] Google Code Archive - Long-term storage for Google Code Project Hosting.
