I successfully installed NGC container for tensorflow by using the follower command: docker pull nvcr.io/nvidia/tensorflow:18.03-py3
Could some one please guide me as to how can I:
Upload my data to this container, and
Use a Jupyter Notebook from within the container to analyze the data?
Thanks,
Akhil
Yes! This is very important to data scientists, I hope we hear soon - Iâll keep trying, and post here if I can work it out :) Thanks for raising this Akhil.
Yes, Iâm also looking on how to achieve this.
Any ideas on how to combine the tensorflow docker image together with Jupyter Notebooks, Tensorboard and Keras?
For all of you struggling with this as well. I solved it by building my own container and adding some flags when running the container.
An example, adding Keras to the nvidia tensorflow container.
Create a file called "Dockerfile"
Enter the following
FROM nvcr.io/nvidia/tensorflow:18.08-py3
WORKDIR /my-ml-files
RUN pip install jupyter
EXPOSE 8888
RUN pip install keras
Run the following in a terminal inside of the folder where you saved the "Dockerfile"
docker build -t my-nvidia-container .
The container is now built. To run it run the following
docker run --runtime=nvidia -it my-nvidia-container
If youâre looking to add a folder with files to the docker container
Run the following command when starting the docker container instead
docker run --runtime=nvidia -it -v "/my-local-computer-files/:/my-docker-container/" my-nvidia-container
. Where if you change directory to
inside of the container, your files in
should be visible and accessible.
Access jupyter notebook
Add the flag
-p 8888:8888
to the command. You may combine this with the one above (
Example:
docker run --runtime=nvidia -it -p "8888:8888" -v "/my-local-computer-files/:/my-docker-container/" my-nvidia-container
And when youâre inside of the docker container run
jupyter notebook --port=8888 --ip=0.0.0.0 --allow-root --no-browser .
and then youâll be able to access it from your local browser at http://localhost:8888
Hope that helps.
Victor
Wow ⊠awesome ⊠I will soon give this a try. Thanks a lot for this.
tkocou
November 21, 2018, 2:25am
6
Just a quick question: does the host need the Nvidia drivers installed to use the above docker base image? (nvcr.io/nvidia/tensorflow:18.08-py3 )
With your instructions I was able to launch a jupyter notebook from within a docker image. Also, the instructions you gave are spot on! Thanks a lot.
Enter the following
EXPOSE 8888
Add the flag
-p 8888:8888
Example:
Hope that helps.
Victor
I think you have to install the drivers prior to using the docker image.
In followup â FYI, we now include Jupyter (and JupyterLab) by default in our DL Frameworks containers, so you can skip many of the steps that used to be required as documented in this thread. See [url]https://devtalk.nvidia.com/default/topic/1049001/container-nvcaffe/how-to-use-jupyter-notebook-with-nvcaffe/post/5323778/#5323778[/url] for updated instructions.
Awesome ⊠even better. Canât wait to give it a try. Thanks for iterative progress / updates on this.
