Originally published at: https://developer.nvidia.com/blog/calibration-translate-video-data/
DeepStream SDK 3.0 is about seeing beyond pixels. DeepStream exists to make it easier for you to go from raw video data to metadata that can be analyzed for actionable insights. Calibration is a key step in this process, in which the location of objects present in a video stream is translated into real-world geo-coordinates.…
Excellent and in-detail article. Many thanks.
Do you happen to have an example of a final application/configuration for this? I want to try it out but I'm unclear what an example of an app with proper configuration. Thanks for the article.
Do you know how to use this method now?I also want to know how to use it.
Is any approach available for moving objects in case of calibration to translate video data to the real world using DeepStream?
Regrads
Hi paravarz,
Please help to open a new topic at DeepStream SDK forum, be sure to describe the use case further, we will support you via there.
Hi, I did make a new topic, Thank you so much
