when updated from cuda 12. to cuda 12.5 and using cuda::std::complex <<, >> (ostream,istream) operator cause to compilation error.
My system
OS: rocky linux 9
Cuda version 12.5
C++ compiler clang or gcc11
The toy code to stimulate the issue is:
#include <iostream>
#include <cuda/std/complex>
int main()
using Complex = cuda::std::complex<float>;
Complex a(1,2);
std::cout<<a;
return 0;
The compilation error are:
home/Yehonatans/CLionProjects/ComplexJitLtoProject/main.cu(9): error: no operator "<<" matches these operands
operand types are: std::ostream << Complex
std::cout<<a;
/usr/include/c++/11/ostream(283): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(std::basic_ostream<_CharT, _Traits>::__streambuf_type *) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(__streambuf_type* __sb);
/usr/include/c++/11/ostream(250): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(std::nullptr_t) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(nullptr_t)
/usr/include/c++/11/ostream(245): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(const void *) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(const void* __p)
/usr/include/c++/11/ostream(232): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(long double) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(long double __f)
/usr/include/c++/11/ostream(224): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(float) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(float __f)
/usr/include/c++/11/ostream(220): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(double) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(double __f)
/usr/include/c++/11/ostream(205): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(unsigned long long) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(unsigned long long __n)
/usr/include/c++/11/ostream(201): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(long long) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(long long __n)
/usr/include/c++/11/ostream(192): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(unsigned int) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(unsigned int __n)
/usr/include/c++/11/ostream(189): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(int) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(int __n);
/usr/include/c++/11/ostream(181): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(unsigned short) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(unsigned short __n)
/usr/include/c++/11/ostream(178): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(short) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(short __n);
/usr/include/c++/11/ostream(174): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(bool) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(bool __n)
/usr/include/c++/11/ostream(170): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(unsigned long) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(unsigned long __n)
/usr/include/c++/11/ostream(166): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(long) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(long __n)
/usr/include/c++/11/ostream(127): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(std::ios_base &(*)(std::ios_base &)) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(ios_base& (*__pf) (ios_base&))
/usr/include/c++/11/ostream(117): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(std::basic_ostream<_CharT, _Traits>::__ios_type &(*)(std::basic_ostream<_CharT, _Traits>::__ios_type &)) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(__ios_type& (*__pf)(__ios_type&))
/usr/include/c++/11/ostream(108): note #3326-D: function "std::basic_ostream<_CharT, _Traits>::operator<<(std::basic_ostream<_CharT, _Traits>::__ostream_type &(*)(std::basic_ostream<_CharT, _Traits>::__ostream_type &)) [with _CharT=char, _Traits=std::char_traits<char>]" does not match because argument #1 does not match parameter
operator<<(__ostream_type& (*__pf)(__ostream_type&))
/opt/nvidia/hpc_sdk/Linux_x86_64/24.7/cuda/12.5/include/cuda/std/detail/libcxx/include/__type_traits/../cstddef(150): note #3326-D: function template "cuda::std::operator<<" does not match because argument #1 does not match parameter
operator<< (byte __lhs, _Integer __shift) noexcept
/usr/include/c++/11/cstddef(126): note #3326-D: function template "std::operator<<(std::byte, _IntegerType) noexcept" does not match because argument #1 does not match parameter
operator<<(byte __b, _IntegerType __shift) noexcept
/usr/include/c++/11/complex(555): note #3327-D: candidate function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, const std::complex<_Tp> &)" failed deduction
operator<<(basic_ostream<_CharT, _Traits>& __os, const complex<_Tp>& __x)
/usr/include/c++/11/ostream(750): note #3327-D: candidate function template "std::operator<<(_Ostream &&, const _Tp &)" failed deduction
operator<<(_Ostream&& __os, const _Tp& __x)
/usr/include/c++/11/ostream(629): note #3326-D: function template "std::operator<<(std::basic_ostream<char, _Traits> &, const unsigned char *)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<char, _Traits>& __out, const unsigned char* __s)
/usr/include/c++/11/ostream(624): note #3326-D: function template "std::operator<<(std::basic_ostream<char, _Traits> &, const signed char *)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<char, _Traits>& __out, const signed char* __s)
/usr/include/c++/11/ostream(611): note #3326-D: function template "std::operator<<(std::basic_ostream<char, _Traits> &, const char *)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<char, _Traits>& __out, const char* __s)
/usr/include/c++/11/bits/ostream.tcc(321): note #3326-D: function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, const char *)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<_CharT, _Traits>& __out, const char* __s)
/usr/include/c++/11/ostream(594): note #3327-D: candidate function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, const _CharT *)" failed deduction
operator<<(basic_ostream<_CharT, _Traits>& __out, const _CharT* __s)
/usr/include/c++/11/ostream(535): note #3326-D: function template "std::operator<<(std::basic_ostream<char, _Traits> &, unsigned char)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<char, _Traits>& __out, unsigned char __c)
/usr/include/c++/11/ostream(530): note #3326-D: function template "std::operator<<(std::basic_ostream<char, _Traits> &, signed char)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<char, _Traits>& __out, signed char __c)
/usr/include/c++/11/ostream(524): note #3326-D: function template "std::operator<<(std::basic_ostream<char, _Traits> &, char)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<char, _Traits>& __out, char __c)
/usr/include/c++/11/ostream(518): note #3326-D: function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, char)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<_CharT, _Traits>& __out, char __c)
/usr/include/c++/11/ostream(513): note #3327-D: candidate function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, _CharT)" failed deduction
operator<<(basic_ostream<_CharT, _Traits>& __out, _CharT __c)
/usr/include/c++/11/system_error(279): note #3326-D: function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, const std::error_code &)" does not match because argument #2 does not match parameter
operator<<(basic_ostream<_CharT, _Traits>& __os, const error_code& __e)
/usr/include/c++/11/bits/basic_string.h(6531): note #3327-D: candidate function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, const std::__cxx11::basic_string<_CharT, _Traits, _Alloc> &)" failed deduction
/usr/include/c++/11/string_view(670): note #3327-D: candidate function template "std::operator<<(std::basic_ostream<_CharT, _Traits> &, std::basic_string_view<_CharT, _Traits>)" failed deduction
/usr/include/c++/11/system_error(206): note #3328-D: built-in operator<<(<promoted integral>, <promoted integral>) does not match because argument #1 does not match parameter
enable_if<is_error_code_enum<_ErrorCodeEnum>::value>::type>
