• Hardware Platform (Jetson / GPU). GPU
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) docker
• TensorRT Version 10.3.0.26-1+cuda12.5
• NVIDIA GPU Driver Version (valid for GPU only) 575.51.03
• Issue Type( questions, new requirements, bugs) questions
**• How to reproduce the issue ? **
my enviroment is docker, from nvcr.io/nvidia/deepstream:7.1-gc-triton-devel ,dockerfile is:
FROM nvcr.io/nvidia/deepstream:7.1-gc-triton-devel
RUN apt-get update && apt-get install -y \
python3-pip \
ffmpeg \
libopencv-dev \
libgl1 \
libglib2.0-0 \
libsm6 && \
apt-get clean && rm -rf /var/lib/apt/lists/*
RUN pip3 install --no-cache-dir \
pyzmq \
pyyaml \
numpy \
opencv-python \
numpy \
msgpack \
ultralytics \
onnxruntime \
onnx \
mycode is :
import sys
import gi
import pyds
import math
import time
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
RTSP_STREAMS = [
"rtsp://admin:admin123@168.168.34.3:554/cam/realmonitor?channel=39&subtype=0",
"rtsp://admin:admin123@168.168.34.4:554/cam/realmonitor?channel=32&subtype=0"
# for vido file
# RTSP_STREAMS = [
# "file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4"
YOLOV8_CONFIG = "/sgx/prod/estellar/agent/config/config_infer_primary_yoloV8.txt" # for yolov8 nvinfer
# ====== infer callback ======
def pgie_src_pad_buffer_probe(pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer")
return Gst.PadProbeReturn.OK
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
class_id = obj_meta.class_id
left = int(obj_meta.rect_params.left)
top = int(obj_meta.rect_params.top)
width = int(obj_meta.rect_params.width)
height = int(obj_meta.rect_params.height)
confidence = float(obj_meta.confidence)
label = obj_meta.obj_label if obj_meta.obj_label else str(class_id)
print(f"[infer] Stream {frame_meta.pad_index} | Frame {frame_number} | Class: {label} | Conf: {confidence:.3f} | BBox: [{left},{top},{width},{height}]")
try:
l_obj = l_obj.next
except StopIteration:
break
try:
l_frame = l_frame.next
break
# ====== create source bin ======
def create_source_bin(index, uri):
bin_name = f"source-bin-{index:02d}"
nbin = Gst.Bin.new(bin_name)
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", None)
uri_decode_bin.set_property("uri", uri)
uri_decode_bin.connect("pad-added", lambda dbin, pad, bin: bin.get_static_pad("src").set_target(pad), nbin)
Gst.Bin.add(nbin, uri_decode_bin)
nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
return nbin
# ====== main ======
def main():
Gst.init(None)
pipeline = Gst.Pipeline()
streammux = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
streammux.set_property('batch-size', len(RTSP_STREAMS))
streammux.set_property('width', 1920)
streammux.set_property('height', 1080)
streammux.set_property('batched-push-timeout', 33000)
# use this if inppt is video file
# streammux.set_property('live-source', 0)
# use this if inppt is rtsp
streammux.set_property('live-source', 1)
pipeline.add(streammux)
# add source bin
for i, uri in enumerate(RTSP_STREAMS):
src_bin = create_source_bin(i, uri)
pipeline.add(src_bin)
sinkpad = streammux.request_pad_simple(f"sink_{i}")
srcpad = src_bin.get_static_pad("src")
srcpad.link(sinkpad)
queue1 = Gst.ElementFactory.make("queue", None)
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
pgie.set_property('config-file-path', YOLOV8_CONFIG)
tiler = Gst.ElementFactory.make("nvmultistreamtiler", None)
tiler.set_property('rows', 1)
tiler.set_property('columns', len(RTSP_STREAMS))
tiler.set_property('width', 1280)
tiler.set_property('height', 720)
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", None)
nvosd = Gst.ElementFactory.make("nvdsosd", None)
sink = Gst.ElementFactory.make("fakesink", None)
for elem in [queue1, pgie, tiler, nvvidconv, nvosd, sink]:
pipeline.add(elem)
streammux.link(queue1)
queue1.link(pgie)
pgie.link(tiler)
tiler.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(sink)
# add probe
pgie_src_pad = pgie.get_static_pad("src")
pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, pgie_src_pad_buffer_probe, 0)
# event loop
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
def bus_call(bus, message, loop):
t = message.type
if t == Gst.MessageType.EOS:
print('End-of-stream')
loop.quit()
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print(f'Error: {err}, {debug}')
loop.quit()
return True
bus.connect("message", bus_call, loop)
print("start pipeline ...")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
print("quit")
if __name__ == "__main__":
main()
the error is:
root@2288H-V6:/sgx/prod/estellar/agent# python3 test_rtsp_inter.py
start pipeline ...
0:00:00.396288068 3598 0x5a379a2980f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/sgx/prod/estellar/agent/models/yolov8s_ds.engine
Implicit layer support has been deprecated
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [Implicit Engine Info]: layers num: 0
0:00:00.396366568 3598 0x5a379a2980f0 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /sgx/prod/estellar/agent/models/yolov8s_ds.engine
0:00:00.404686756 3598 0x5a379a2980f0 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:/sgx/prod/estellar/agent/config/config_infer_primary_yoloV8.txt sucessfully
Aborted (core dumped)
if i change rtsp to video file, this code run OK.
config_infer_primary_yoloV8.txt is:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
#onnx-file=/sgx/prod/estellar/agent/models/yolov8s.onnx
model-engine-file=/sgx/prod/estellar/agent/models/yolov8s_ds.engine
#int8-calib-file=calib.table
labelfile-path=/sgx/prod/estellar/agent/models/labels.txt
batch-size=1
network-mode=0
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
#workspace-size=2000
parse-bbox-func-name=NvDsInferParseYolo
#parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=/sgx/prod/estellar/agent/lib/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.25
topk=300
how to fix it? thanks
