Using Jetson orin nano for IMX294 camera binning mode on version R35.4.1, nvraw cannot be captured
After the driver is loaded successfully, the v4l2 command is used to print the frame rate, but the frame rate cannot be printed, and the dmesg is displayed as follows:
[   94.617806] imx294 10-001a: sensor_set_mode:
[   94.672450] imx294 10-001a: sensor_start_streaming:
[   94.726516] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[   94.763831] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[   94.801492] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[   94.838988] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
The trace log is as follows:
trace.txt (276.3 KB)
However, using argus_camera can preview normally, and the picture is normal. When using nvargus_nvraw to grab raw images, the corresponding error also occurs:
nvidia@nvidia-desktop:~$ nvargus_nvraw --c 1 --mode 1 --file /home/nvidia/imx294.nvraw --exp0 "0.01,2" --skipframes 10
nvargus_nvraw version 1.14.0
capture: Total captured frame count 11
("nvargus_nvraw") Error BadParameter (0x04): Embedded data size (7,552) is not a perfect multiple of
     row width (4,176)
 (in capture_nvraw/src/mobile/ArgusNvRawInterface.cpp, func getPrivateMetadata(),
     line 337)
("nvargus_nvraw") Error BadParameter (0x04):  (propagating from capture_nvraw/src/mobile/ArgusNvRawInterface.cpp,
     func addFrame(), line 244)
("nvargus_nvraw") Error BadParameter (0x04):  (propagating from capture_nvraw/src/mobile/ArgusNvRawCapture.cpp,
     func acquireFrames(), line 872)
     func capture(), line 817)
("nvargus_nvraw") Error BadParameter (0x04): Unable to capture (propagating from capture_nvraw/src/mobile/main.cpp,
     func main(), line 97)
Here are the main configurations of my device tree:
mode1 { /*mode IMX294_MODE_3840X2160_30FPS_RAW10_BINNING*/
					mclk_khz = "27000";
					num_lanes = "4";
					tegra_sinterface = "serial_c";
					phy_mode = "DPHY";
					discontinuous_clk = "no";
					dpcm_enable = "false";
					cil_settletime = "0";
					lane_polarity = "0";
					active_w = "2088";
					active_h = "1096";
					mode_type = "bayer";
					pixel_phase = "rggb";
					csi_pixel_bit_depth = "10";
					dynamic_pixel_bit_depth = "10";
					readout_orientation = "0";
					line_length = "3000";
					inherent_gain = "1";
					mclk_multiplier = "7";//600000 Khz / 25 =24000 Khz
					pix_clk_hz = "240000000";
					gain_factor = "1000";
					min_gain_val = "1000"; /* 0dB */
					max_gain_val = "22000"; /* 22 X */
					step_gain_val = "1"; /*  */
					default_gain = "1000";
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
					framerate_factor = "1000000";
					min_framerate = "30000000";
					max_framerate = "30000000";
					step_framerate = "1";
					default_framerate = "30000000";
					exposure_factor = "1000000";
					min_exp_time = "36"; /* us, min 8 lines */
					max_exp_time = "33000"; /* us, max number of lines per frame - 4 */
					step_exp_time = "1";
					default_exp_time = "36";/* us */
					embedded_metadata_height = "1";
I have two questions that need to be addressed:
  1. The sensor cannot print the frame rate using the v4l2 command
  2. The nvraw graph cannot be captured using nvargus_nvraw
    Thank you for your help!!
Sorry for the late response.
Boost the clocks to try if the CHANSEL_SHORT_FRAME still shows in trace log, then that tell the output size less than driver reported.
Also need to make sure the embedded data line to define the embedded_data_height in device tree.
     kworker/3:2-116     [003] ....   157.635895: rtcpu_vinotify_event: tstamp:5522946469 cch:0 vi:1 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:0 vi_tstamp:176728388352 data:0x0000200001000000
