The only goal i want to do is to access metadata which its datatype is different from raw data from camera sensor.
I firstly use nvargus nvraw tool to test the ability of argus api to access metadata. But when i input the following command, it comes up some error.
pcai@pcai-desktop:~$ nvargus_nvraw --lps
nvargus_nvraw version 1.14.0
Number of supported sensor entries 0
Entry Source Mode Uniquename Resolution FR BitDepth Mode
Index Index Index CSI Dyn Type
pcai@pcai-desktop:~$ nvargus_nvraw --c 0 --mode 0 --file /home/pcai/wxx.nvra
("nvargus_nvraw") Error BadParameter (0x04): Provided sensor ID (0) is out of bounds. Total number of
sensors: 0
(in capture_nvraw/src/mobile/ArgusNvRawCapture.cpp, func initialize(), line 82)
("nvargus_nvraw") Error BadParameter (0x04): Unable to initialize (propagating from capture_nvraw/src/mobile/main.cpp,
func main(), line 91)
pcai@pcai-desktop:~$ v4l2-ctl --list-formats-ext -d /dev/video0
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'RG12' (12-bit Bayer RGRG/GBGB)
Interval: Discrete 0.033s (30.000 fps)
pcai@pcai-desktop:~$ v4l2-ctl --set-fmt-video=width=640,height=480,pixelformat=RG12 --stream-mmap --set-ctrl=sensor_mode=0 --stream-count=100 -d /dev/video0
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 42.80 fps
Although my /devi/video0 can run normally, but nvargus_nvraw couldn’t recognize my sensor, and i don’t know how to locate the reason.
By the way, am I on the right track?
Thanks a lot.
