I want to make a code rotates images with concurrncy. First I checked the code worked well in default stream version using nppiRotate_8u_C1R, and I’m changing it to 4-stream version. 32 images are copied into 4 streams and rotated using nppiRotate_8u_C1R_Ctx.
The size of input image is 2048*2048, but the result image looks weird unlike default stream version.
I profiled both codes with Nsight system and found the kernel launch configuration is different each other.
In default stream version, the number of threads is equal to the number of pixels (left). However, the number of threads is 128128, far less than the size of input image (right). The rotated image appears in 128128 upper-left region only.
How can I solve it? Or is there anyone experienced same problem to mine?
OS : Windows 10
GPU : RTX 3090
CUDA version : 11.1
#include <iostream>
#include <stdio.h>
#include "cuda_runtime.h"
#include "helper_cuda.h"
#include "helper_functions.h"
#include <opencv2/opencv.hpp>
#include <nppi.h>
#include <nppcore.h>
#include <nppdefs.h>
using namespace std;
using namespace cv;
Mat read_BMP_opencv(char* filename, int& w, int& h);
int main()
int f_width, f_height;
char buf[256];
cudaEvent_t start, stop;
float elapsedTime;
cudaEventCreate(&start);
cudaEventCreate(&stop);
int img_num = 32;
const int stream_num = 4;
int n_iter = 50;
cudaStream_t stream[stream_num];
NppStreamContext nppStreamContext[stream_num];
cudaDeviceProp oDeviceProperties;
for (int n = 0; n < stream_num; n++)
cudaStreamCreate(&stream[n]);
nppStreamContext[n].hStream = stream[n];
cudaDeviceGetAttribute(&nppStreamContext[n].nCudaDevAttrComputeCapabilityMajor,
cudaDevAttrComputeCapabilityMajor,
nppStreamContext[n].nCudaDeviceId);
cudaDeviceGetAttribute(&nppStreamContext[n].nCudaDevAttrComputeCapabilityMinor,
cudaDevAttrComputeCapabilityMinor,
cudaStreamGetFlags(nppStreamContext[n].hStream, &nppStreamContext[n].nStreamFlags);
cudaGetDevice(&nppStreamContext[n].nCudaDeviceId);
cudaGetDeviceProperties(&oDeviceProperties, nppStreamContext[n].nCudaDeviceId);
nppStreamContext[n].nMultiProcessorCount = oDeviceProperties.multiProcessorCount;
nppStreamContext[n].nMaxThreadsPerMultiProcessor = oDeviceProperties.maxThreadsPerMultiProcessor;
nppStreamContext[n].nMaxThreadsPerBlock = oDeviceProperties.maxThreadsPerBlock;
nppStreamContext[n].nSharedMemPerBlock = oDeviceProperties.sharedMemPerBlock;
cv::Mat::setDefaultAllocator(cv::cuda::HostMem::getAllocator(cv::cuda::HostMem::AllocType::PAGE_LOCKED));
double angle = 3.8;
///////////////////////////*********************** Memory Allocation ***********************/////////////////////////
NppiSize srcSize = { f_width, f_height };
NppiRect srcROI = { 0, 0, f_width, f_height };
NppiRect dstROI = { 0, 0, f_width, f_height };
Mat* img = new Mat[img_num];
Mat* result = new Mat[img_num];
Npp8u* *data = new Npp8u*[img_num];
Npp8u* *d_data = new Npp8u*[img_num];
Npp8u* *d_rotated = new Npp8u*[img_num];
Npp8u* *h_result = new Npp8u*[img_num];
for (int i = 0; i < img_num; i++)
img[i] = read_BMP_opencv("input_images/test_2048_2.bmp", f_width, f_height);
data[i] = img[i].data;
cudaMalloc((void**)&d_data[i], sizeof(Npp8u)*f_width*f_height);
cudaMalloc((void**)&d_rotated[i], sizeof(Npp8u)*f_width*f_height);
cudaMallocHost((void**)&h_result[i], sizeof(Npp8u)*f_width*f_height);
///////////////////////////*********************** NPP rotation ***********************/////////////////////////
cudaEventRecord(start, 0);
for (int n = 0; n < n_iter; n++)
for (int i = 0; i < int(img_num / stream_num); i++)
for (int j = 0; j < stream_num; j++)
cudaMemcpyAsync(d_data[i*stream_num+j], data[i*stream_num + j], sizeof(Npp8u)*f_width*f_height, cudaMemcpyHostToDevice, stream[j]);
// NPP 10.2 and beyond contain an additional element in the NppStreamContext structure
nppiRotate_8u_C1R_Ctx(d_data[i*stream_num + j], srcSize, f_width, srcROI, d_rotated[i*stream_num + j], f_width, dstROI, angle, 0, 0, NPPI_INTER_LINEAR, nppStreamContext[j]);
cudaMemcpyAsync(h_result[i*stream_num + j], d_rotated[i*stream_num + j], sizeof(Npp8u)*f_width*f_height, cudaMemcpyDeviceToHost, stream[j]);
cudaDeviceSynchronize();
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
cudaEventElapsedTime(&elapsedTime, start, stop);
printf("Average Rotation Time: %3.1f ms\n", elapsedTime / n_iter);
result[i] = Mat(f_height, f_width, CV_8UC1);
result[i].data = h_result[i];
sprintf(buf, "output_images/test2048_rotated_nppi_%d.bmp", i);
imwrite(buf, result[i]);
return 0;
Mat input_img = imread(filename, 0);
if (input_img.empty())
throw "Argument Exception";
// extract image height and width from header
int width = input_img.cols;
int height = input_img.rows;
w = width;
h = height;
return input_img;
