Has anybody had any luck getting the Sense HAT to run on Nano?
Hi Jason_Grayson,
We haven’t tried this on Jetson Nano, may other developers share their experience or you could provide the steps once you managed to get it works.
Hi Jason. I would like to work on this one with you.
I have a Jetson Nano and bought a SenseHat. It connects physically.
I would like to use the Sensehat.jl packahe for the Julia language with the SenseHat.
I assume the GPIO pins will read out the temperature and humidity sensore, but have not done this.
Now comes the bad news - it looks like to use the LED display and the joystick you need specific drivers:
./drivers/mfd/rpisense-core.c
./drivers/video/fbdev/rpisense-fb.c
./drivers/input/joystick/rpisense-js.c
./include/linux/mfd/rpisense
These are found in the kernel code in GitHub - raspberrypi/linux: Kernel source tree for Raspberry Pi-provided kernel builds. Issues unrelated to the linux kernel should be posted on the community forum at https://forums.raspberrypi.com/
The only ways I see forward here are:
A) building these drivers using the Ubuntu kernel sources on the Jetson
B) getting the Raspberry Pi folks to submit those drivers to the mainstream Linux kernel
IT puzzles me that those drivers are not in the main Linux kernel.
FOrgive me if they already are, but it seems short sighted to develop these drivers then restrict them to the Raspperry Pi only.
I believe it is not shortsightedness but more of a marketing decision to release the drivers only for the Raspberry Pi. The SenseHat came from the Astro Pi project which was very RasPi focused. However, the Sense Hat is just a bunch of i2C sensors that can be communicated with directly via a i2C connection.
This is an example of what someone wrote to control the SenseHat without the RasPi software.
[url]https://github.com/bitbank2/sense_hat_unchained[/url]
Jonny, thankyou
Is there an easier way to do this? Make a senseHaT python library specific for nano? From github:https://github.com/RPi-Distro/python-sense-hat/blob/master/sense_hat/sense_hat.py
Don’t we need to just convert custom RTIMU (see below) to something friendly to Nano? Then can’t we just make a Nano Python Library? Forgive me is this very wrong. Limited Python skills.
JG
#!/usr/bin/python
import struct
import os
import sys
import math
import time
import numpy as np
import shutil
import glob
import RTIMU # custom version
import pwd
import array
import fcntl
from PIL import Image # pillow
from copy import deepcopy
from .stick import SenseStick
class SenseHat(object):
SENSE_HAT_FB_NAME = 'RPi-Sense FB'
SENSE_HAT_FB_FBIOGET_GAMMA = 61696
SENSE_HAT_FB_FBIOSET_GAMMA = 61697
SENSE_HAT_FB_FBIORESET_GAMMA = 61698
SENSE_HAT_FB_GAMMA_DEFAULT = 0
SENSE_HAT_FB_GAMMA_LOW = 1
SENSE_HAT_FB_GAMMA_USER = 2
SETTINGS_HOME_PATH = '.config/sense_hat'
def __init__(
self,
imu_settings_file='RTIMULib',
text_assets='sense_hat_text'
self._fb_device = self._get_fb_device()
if self._fb_device is None:
raise OSError('Cannot detect %s device' % self.SENSE_HAT_FB_NAME)
if not glob.glob('/dev/i2c*'):
raise OSError('Cannot access I2C. Please ensure I2C is enabled in raspi-config')
# 0 is With B+ HDMI port facing downwards
pix_map0 = np.array([
[0, 1, 2, 3, 4, 5, 6, 7],
[8, 9, 10, 11, 12, 13, 14, 15],
[16, 17, 18, 19, 20, 21, 22, 23],
[24, 25, 26, 27, 28, 29, 30, 31],
[32, 33, 34, 35, 36, 37, 38, 39],
[40, 41, 42, 43, 44, 45, 46, 47],
[48, 49, 50, 51, 52, 53, 54, 55],
[56, 57, 58, 59, 60, 61, 62, 63]
], int)
pix_map90 = np.rot90(pix_map0)
pix_map180 = np.rot90(pix_map90)
pix_map270 = np.rot90(pix_map180)
self._pix_map = {
0: pix_map0,
90: pix_map90,
180: pix_map180,
270: pix_map270
self._rotation = 0
# Load text assets
dir_path = os.path.dirname(__file__)
self._load_text_assets(
os.path.join(dir_path, '%s.png' % text_assets),
os.path.join(dir_path, '%s.txt' % text_assets)
# Load IMU settings and calibration data
self._imu_settings = self._get_settings_file(imu_settings_file)
self._imu = RTIMU.RTIMU(self._imu_settings)
self._imu_init = False # Will be initialised as and when needed
self._pressure = RTIMU.RTPressure(self._imu_settings)
self._pressure_init = False # Will be initialised as and when needed
self._humidity = RTIMU.RTHumidity(self._imu_settings)
self._humidity_init = False # Will be initialised as and when needed
self._last_orientation = {'pitch': 0, 'roll': 0, 'yaw': 0}
raw = {'x': 0, 'y': 0, 'z': 0}
self._last_compass_raw = deepcopy(raw)
self._last_gyro_raw = deepcopy(raw)
self._last_accel_raw = deepcopy(raw)
self._compass_enabled = False
self._gyro_enabled = False
self._accel_enabled = False
self._stick = SenseStick()
# Text assets
# Text asset files are rotated right through 90 degrees to allow blocks of
# 40 contiguous pixels to represent one 5 x 8 character. These are stored
# in a 8 x 640 pixel png image with characters arranged adjacently
# Consequently we must rotate the pixel map left through 90 degrees to
# compensate when drawing text
def _load_text_assets(self, text_image_file, text_file):
Internal. Builds a character indexed dictionary of pixels used by the
show_message function below
text_pixels = self.load_image(text_image_file, False)
with open(text_file, 'r') as f:
loaded_text = f.read()
self._text_dict = {}
for index, s in enumerate(loaded_text):
start = index * 40
end = start + 40
char = text_pixels[start:end]
self._text_dict[s] = char
def _trim_whitespace(self, char): # For loading text assets only
Internal. Trims white space pixels from the front and back of loaded
text characters
psum = lambda x: sum(sum(x, []))
if psum(char) > 0:
is_empty = True
while is_empty: # From front
row = char[0:8]
is_empty = psum(row) == 0
if is_empty:
del char[0:8]
is_empty = True
while is_empty: # From back
row = char[-8:]
if is_empty:
del char[-8:]
return char
def _get_settings_file(self, imu_settings_file):
Internal. Logic to check for a system wide RTIMU ini file. This is
copied to the home folder if one is not already found there.
ini_file = '%s.ini' % imu_settings_file
home_dir = pwd.getpwuid(os.getuid())[5]
home_path = os.path.join(home_dir, self.SETTINGS_HOME_PATH)
if not os.path.exists(home_path):
os.makedirs(home_path)
home_file = os.path.join(home_path, ini_file)
home_exists = os.path.isfile(home_file)
system_file = os.path.join('/etc', ini_file)
system_exists = os.path.isfile(system_file)
if system_exists and not home_exists:
shutil.copyfile(system_file, home_file)
return RTIMU.Settings(os.path.join(home_path, imu_settings_file)) # RTIMU will add .ini internally
def _get_fb_device(self):
Internal. Finds the correct frame buffer device for the sense HAT
and returns its /dev name.
device = None
for fb in glob.glob('/sys/class/graphics/fb*'):
name_file = os.path.join(fb, 'name')
if os.path.isfile(name_file):
with open(name_file, 'r') as f:
name = f.read()
if name.strip() == self.SENSE_HAT_FB_NAME:
fb_device = fb.replace(os.path.dirname(fb), '/dev')
if os.path.exists(fb_device):
device = fb_device
break
return device
# Joystick
@property
def stick(self):
return self._stick
# LED Matrix
@property
def rotation(self):
return self._rotation
@rotation.setter
def rotation(self, r):
self.set_rotation(r, True)
def set_rotation(self, r=0, redraw=True):
Sets the LED matrix rotation for viewing, adjust if the Pi is upside
down or sideways. 0 is with the Pi HDMI port facing downwards
if r in self._pix_map.keys():
if redraw:
pixel_list = self.get_pixels()
self._rotation = r
if redraw:
self.set_pixels(pixel_list)
else:
raise ValueError('Rotation must be 0, 90, 180 or 270 degrees')
def _pack_bin(self, pix):
Internal. Encodes python list [R,G,B] into 16 bit RGB565
r = (pix[0] >> 3) & 0x1F
g = (pix[1] >> 2) & 0x3F
b = (pix[2] >> 3) & 0x1F
bits16 = (r << 11) + (g << 5) + b
return struct.pack('H', bits16)
def _unpack_bin(self, packed):
Internal. Decodes 16 bit RGB565 into python list [R,G,B]
output = struct.unpack('H', packed)
bits16 = output[0]
r = (bits16 & 0xF800) >> 11
g = (bits16 & 0x7E0) >> 5
b = (bits16 & 0x1F)
return [int(r << 3), int(g << 2), int(b << 3)]
def flip_h(self, redraw=True):
Flip LED matrix horizontal
flipped = []
for i in range(8):
offset = i * 8
flipped.extend(reversed(pixel_list[offset:offset + 8]))
if redraw:
self.set_pixels(flipped)
return flipped
def flip_v(self, redraw=True):
Flip LED matrix vertical
flipped = []
for i in reversed(range(8)):
offset = i * 8
flipped.extend(pixel_list[offset:offset + 8])
if redraw:
return flipped
def set_pixels(self, pixel_list):
Accepts a list containing 64 smaller lists of [R,G,B] pixels and
updates the LED matrix. R,G,B elements must intergers between 0
and 255
if len(pixel_list) != 64:
raise ValueError('Pixel lists must have 64 elements')
for index, pix in enumerate(pixel_list):
if len(pix) != 3:
raise ValueError('Pixel at index %d is invalid. Pixels must contain 3 elements: Red, Green and Blue' % index)
for element in pix:
if element > 255 or element < 0:
raise ValueError('Pixel at index %d is invalid. Pixel elements must be between 0 and 255' % index)
with open(self._fb_device, 'wb') as f:
map = self._pix_map[self._rotation]
# Two bytes per pixel in fb memory, 16 bit RGB565
f.seek(map[index // 8][index % 8] * 2) # row, column
f.write(self._pack_bin(pix))
def get_pixels(self):
Returns a list containing 64 smaller lists of [R,G,B] pixels
representing what is currently displayed on the LED matrix
pixel_list = []
with open(self._fb_device, 'rb') as f:
for row in range(8):
for col in range(8):
f.seek(map[row][col] * 2) # row, column
pixel_list.append(self._unpack_bin(f.read(2)))
return pixel_list
def set_pixel(self, x, y, *args):
Updates the single [R,G,B] pixel specified by x and y on the LED matrix
Top left = 0,0 Bottom right = 7,7
e.g. ap.set_pixel(x, y, r, g, b)
or
pixel = (r, g, b)
ap.set_pixel(x, y, pixel)
pixel_error = 'Pixel arguments must be given as (r, g, b) or r, g, b'
if len(args) == 1:
pixel = args[0]
if len(pixel) != 3:
raise ValueError(pixel_error)
elif len(args) == 3:
pixel = args
else:
if x > 7 or x < 0:
raise ValueError('X position must be between 0 and 7')
if y > 7 or y < 0:
raise ValueError('Y position must be between 0 and 7')
for element in pixel:
raise ValueError('Pixel elements must be between 0 and 255')
f.seek(map[y][x] * 2) # row, column
f.write(self._pack_bin(pixel))
def get_pixel(self, x, y):
Returns a list of [R,G,B] representing the pixel specified by x and y
on the LED matrix. Top left = 0,0 Bottom right = 7,7
if x > 7 or x < 0:
if y > 7 or y < 0:
pix = None
pix = self._unpack_bin(f.read(2))
return pix
def load_image(self, file_path, redraw=True):
Accepts a path to an 8 x 8 image file and updates the LED matrix with
the image
if not os.path.exists(file_path):
raise IOError('%s not found' % file_path)
img = Image.open(file_path).convert('RGB')
pixel_list = list(map(list, img.getdata()))
if redraw:
return pixel_list
def clear(self, *args):
Clears the LED matrix with a single colour, default is black / off
e.g. ap.clear()
or
ap.clear(r, g, b)
or
colour = (r, g, b)
ap.clear(colour)
black = (0, 0, 0) # default
if len(args) == 0:
colour = black
elif len(args) == 1:
colour = args[0]
colour = args
else:
raise ValueError('Pixel arguments must be given as (r, g, b) or r, g, b')
self.set_pixels([colour] * 64)
def _get_char_pixels(self, s):
Internal. Safeguards the character indexed dictionary for the
if len(s) == 1 and s in self._text_dict.keys():
return list(self._text_dict[s])
else:
return list(self._text_dict['?'])
def show_message(
self,
text_string,
scroll_speed=.1,
text_colour=[255, 255, 255],
back_colour=[0, 0, 0]
Scrolls a string of text across the LED matrix using the specified
speed and colours
# We must rotate the pixel map left through 90 degrees when drawing
# text, see _load_text_assets
previous_rotation = self._rotation
self._rotation -= 90
if self._rotation < 0:
self._rotation = 270
dummy_colour = [None, None, None]
string_padding = [dummy_colour] * 64
letter_padding = [dummy_colour] * 8
# Build pixels from dictionary
scroll_pixels = []
scroll_pixels.extend(string_padding)
for s in text_string:
scroll_pixels.extend(self._trim_whitespace(self._get_char_pixels(s)))
scroll_pixels.extend(letter_padding)
# Recolour pixels as necessary
coloured_pixels = [
text_colour if pixel == [255, 255, 255] else back_colour
for pixel in scroll_pixels
# Shift right by 8 pixels per frame to scroll
scroll_length = len(coloured_pixels) // 8
for i in range(scroll_length - 8):
start = i * 8
end = start + 64
self.set_pixels(coloured_pixels[start:end])
time.sleep(scroll_speed)
self._rotation = previous_rotation
def show_letter(
self,
s,
Displays a single text character on the LED matrix using the specified
colours
if len(s) > 1:
raise ValueError('Only one character may be passed into this method')
pixel_list = [dummy_colour] * 8
pixel_list.extend(self._get_char_pixels(s))
pixel_list.extend([dummy_colour] * 16)
coloured_pixels = [
for pixel in pixel_list
self.set_pixels(coloured_pixels)
@property
def gamma(self):
buffer = array.array('B', [0]*32)
with open(self._fb_device) as f:
fcntl.ioctl(f, self.SENSE_HAT_FB_FBIOGET_GAMMA, buffer)
return list(buffer)
@gamma.setter
def gamma(self, buffer):
if len(buffer) is not 32:
raise ValueError('Gamma array must be of length 32')
if not all(b <= 31 for b in buffer):
raise ValueError('Gamma values must be bewteen 0 and 31')
if not isinstance(buffer, array.array):
buffer = array.array('B', buffer)
fcntl.ioctl(f, self.SENSE_HAT_FB_FBIOSET_GAMMA, buffer)
def gamma_reset(self):
Resets the LED matrix gamma correction to default
fcntl.ioctl(f, self.SENSE_HAT_FB_FBIORESET_GAMMA, self.SENSE_HAT_FB_GAMMA_DEFAULT)
@property
def low_light(self):
return self.gamma == [0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 3, 3, 3, 4, 4, 5, 5, 6, 6, 7, 7, 8, 8, 9, 10, 10]
@low_light.setter
def low_light(self, value):
cmd = self.SENSE_HAT_FB_GAMMA_LOW if value else self.SENSE_HAT_FB_GAMMA_DEFAULT
fcntl.ioctl(f, self.SENSE_HAT_FB_FBIORESET_GAMMA, cmd)
# Environmental sensors
def _init_humidity(self):
Internal. Initialises the humidity sensor via RTIMU
if not self._humidity_init:
self._humidity_init = self._humidity.humidityInit()
raise OSError('Humidity Init Failed')
def _init_pressure(self):
Internal. Initialises the pressure sensor via RTIMU
if not self._pressure_init:
self._pressure_init = self._pressure.pressureInit()
raise OSError('Pressure Init Failed')
def get_humidity(self):
Returns the percentage of relative humidity
self._init_humidity() # Ensure humidity sensor is initialised
humidity = 0
data = self._humidity.humidityRead()
if (data[0]): # Humidity valid
humidity = data[1]
return humidity
@property
def humidity(self):
return self.get_humidity()
def get_temperature_from_humidity(self):
Returns the temperature in Celsius from the humidity sensor
temp = 0
if (data[2]): # Temp valid
temp = data[3]
return temp
def get_temperature_from_pressure(self):
Returns the temperature in Celsius from the pressure sensor
self._init_pressure() # Ensure pressure sensor is initialised
temp = 0
data = self._pressure.pressureRead()
temp = data[3]
return temp
def get_temperature(self):
return self.get_temperature_from_humidity()
@property
def temp(self):
@property
def temperature(self):
def get_pressure(self):
Returns the pressure in Millibars
pressure = 0
if (data[0]): # Pressure valid
pressure = data[1]
return pressure
@property
def pressure(self):
return self.get_pressure()
# IMU Sensor
def _init_imu(self):
Internal. Initialises the IMU sensor via RTIMU
if not self._imu_init:
self._imu_init = self._imu.IMUInit()
if self._imu_init:
self._imu_poll_interval = self._imu.IMUGetPollInterval() * 0.001
# Enable everything on IMU
self.set_imu_config(True, True, True)
else:
raise OSError('IMU Init Failed')
def set_imu_config(self, compass_enabled, gyro_enabled, accel_enabled):
Enables and disables the gyroscope, accelerometer and/or magnetometer
input to the orientation functions
# If the consuming code always calls this just before reading the IMU
# the IMU consistently fails to read. So prevent unnecessary calls to
# IMU config functions using state variables
self._init_imu() # Ensure imu is initialised
if (not isinstance(compass_enabled, bool)
or not isinstance(gyro_enabled, bool)
or not isinstance(accel_enabled, bool)):
raise TypeError('All set_imu_config parameters must be of boolean type')
if self._compass_enabled != compass_enabled:
self._compass_enabled = compass_enabled
self._imu.setCompassEnable(self._compass_enabled)
if self._gyro_enabled != gyro_enabled:
self._gyro_enabled = gyro_enabled
self._imu.setGyroEnable(self._gyro_enabled)
if self._accel_enabled != accel_enabled:
self._accel_enabled = accel_enabled
self._imu.setAccelEnable(self._accel_enabled)
def _read_imu(self):
Internal. Tries to read the IMU sensor three times before giving up
attempts = 0
success = False
while not success and attempts < 3:
success = self._imu.IMURead()
attempts += 1
time.sleep(self._imu_poll_interval)
return success
def _get_raw_data(self, is_valid_key, data_key):
Internal. Returns the specified raw data from the IMU when valid
result = None
if self._read_imu():
data = self._imu.getIMUData()
if data[is_valid_key]:
raw = data[data_key]
result = {
'x': raw[0],
'y': raw[1],
'z': raw[2]
return result
def get_orientation_radians(self):
Returns a dictionary object to represent the current orientation in
radians using the aircraft principal axes of pitch, roll and yaw
raw = self._get_raw_data('fusionPoseValid', 'fusionPose')
if raw is not None:
raw['roll'] = raw.pop('x')
raw['pitch'] = raw.pop('y')
raw['yaw'] = raw.pop('z')
self._last_orientation = raw
return deepcopy(self._last_orientation)
@property
def orientation_radians(self):
return self.get_orientation_radians()
def get_orientation_degrees(self):
in degrees, 0 to 360, using the aircraft principal axes of
pitch, roll and yaw
orientation = self.get_orientation_radians()
for key, val in orientation.items():
deg = math.degrees(val) # Result is -180 to +180
orientation[key] = deg + 360 if deg < 0 else deg
return orientation
def get_orientation(self):
return self.get_orientation_degrees()
@property
def orientation(self):
def get_compass(self):
Gets the direction of North from the magnetometer in degrees
self.set_imu_config(True, False, False)
orientation = self.get_orientation_degrees()
if type(orientation) is dict and 'yaw' in orientation.keys():
return orientation['yaw']
else:
return None
@property
def compass(self):
return self.get_compass()
def get_compass_raw(self):
Magnetometer x y z raw data in uT (micro teslas)
raw = self._get_raw_data('compassValid', 'compass')
if raw is not None:
self._last_compass_raw = raw
return deepcopy(self._last_compass_raw)
@property
def compass_raw(self):
return self.get_compass_raw()
def get_gyroscope(self):
Gets the orientation in degrees from the gyroscope only
self.set_imu_config(False, True, False)
@property
def gyro(self):
return self.get_gyroscope()
@property
def gyroscope(self):
def get_gyroscope_raw(self):
Gyroscope x y z raw data in radians per second
raw = self._get_raw_data('gyroValid', 'gyro')
if raw is not None:
self._last_gyro_raw = raw
return deepcopy(self._last_gyro_raw)
@property
def gyro_raw(self):
return self.get_gyroscope_raw()
@property
def gyroscope_raw(self):
def get_accelerometer(self):
Gets the orientation in degrees from the accelerometer only
self.set_imu_config(False, False, True)
@property
def accel(self):
return self.get_accelerometer()
@property
def accelerometer(self):
def get_accelerometer_raw(self):
Accelerometer x y z raw data in Gs
raw = self._get_raw_data('accelValid', 'accel')
if raw is not None:
self._last_accel_raw = raw
return deepcopy(self._last_accel_raw)
@property
def accel_raw(self):
return self.get_accelerometer_raw()
@property
def accelerometer_raw(self):
Yes. But the framebuffer device is not present till the driver is loaded.
Look at the code above - it has
SENSE_HAT_FB_NAME = ‘RPi-Sense FB’
raise OSError(‘Cannot detect %s device’ % self.SENSE_HAT_FB_NAME)
So the code is looking for a device named RPi-Sense FB
You need to load the device driver then that device becomes present.
Okay. Thank you for pointing that out to me! I have a lot to learn!
No problems! I too would like the SenseHat to work - it would be very interesting to get this working alongside the deep learning capabilities of the Nano
Is there any update on the usage of Sensehat on Jetson Nano. This would of great help, please let us know the latest update.
