Using two NVIDIA GPUs monitor ok in the first gpu, one is always black on second gpu. ( Although shows the mouse cursor ok)
Using two NVIDIA GPUs with all monitors ok on the first gpu, one is always black on the second gpu. (Although the cursor does move between them and I can see it on the black monitor too - only wayland)
nvidia-bug-report:
nvidia-bug-report.log.gz (1.2 MB)
egl-wayland issue: Using two NVIDIA GPUs with all monitors ok in the first gpu, one is always black on second gpu. (Although the cursor does move between them and I can see it on the black monitor too - only wayland) · Issue #152 · NVIDIA/egl-wayland · GitHub
Hi @gilvbp,
Thank you for reporting the issue.
  1. Do all monitors connected to the second GPU fail to come up on Wayland?
  2. On your GNOME Xorg session, can you please launch nvidia-settings and navigate to the X Server Display Configuration tab. Does the failing monitor show up as a PRIME display? Please attach a screenshot of this tab.
Answers:
  1. Yes…
  2. Yes, It does.
Thank you. This is being tracked internally on NVBug #4910092. I’ll share Engineering feedback when available.
You’re welcome!
I have the same issue. My workstation has two Quadro RTX 5000 (NVLINK) and Two monitors (one per GPU). The system works fine under X11 but with Wayland only the cursor is showed on the second monitor.
Now I can see all the monitor’s display info (nvidia-settings) on the new driver 565.57.01 | BETA using Wayland.
@abchauhan any updates? Thanks.
No, Sorry. This is under investigation. We do not have any updates at this time.
Hi, on cosmic epoch is working fine, maybe sway too. They use vulkan (wlroots), not egl.
Just wanted to report in that I’m seeing this same issue on 565 with KDE and Wayland. Everything is fine when using X11. I can switch which GPU has working monitors by adjusting the KWIN_DRM_DEVICES variable, but I can never make both work.
My suggestion is that you should try cosmic or sway. Nvidia is focusing only on Vulkan. KDE Vulkan’s backend implementation doesn’t have a date. Here are more instructions: Support multi-gpu mosaic · Issue #91 · NVIDIA/egl-wayland · GitHub
dkorkmazturk
on Dec 13, 2024
“Thanks for reporting this issue. It seems like this issue has multiple components. We identified the driver side issue and have a fix for it, which will be released in an upcoming NVIDIA driver release. That fix allows the second monitor to work on KWin 6.2.4. However, Mutter needs some compositor side changes on top of the driver fix we have implemented. The required change can be found at https://gitlab.gnome.org/GNOME/mutter/-/merge_requests/4182
Well that’s a good sign at least. Eagerly awaiting that driver update.
Yes. I’m shocked by Nvidia and eager to see the new driver.
Oh! Exciting!
I’ve been trying to get my 2nd GPU to show me anything other than the mouse cursor in Wayland and it’s making me crazy!
Copypaste from my post on the KDE forums around this issue:
I’ve now tried on Arch, Endeavor, Ubuntu 24.10, Kionite, Neon, Bazzite, PopOS Cosmic, and Manjaro.
I’ve tried with NV 555, 560, and 565.
It’s always the same. Works fine in X, but Wayland is unable to display anything on the 2nd GPU, other than the mouse cursor.
Cosmic got the closest to working - wallpaper was visible, and I could see the window outlines if I dragged them to GPU2, but as soon as I drop them on the desktop the screen goes black - even the wallpaper goes away.
This is either a bug in the NV drivers, or a missing feature in Wayland. Either way, just have to stick with X for now.
Should probably submit a bugzilla, but I’m not even sure what to put the bug against - is this a NV issue? A wayland issue? A Vulkan issue?
It’s certainly NOT a KDE issue - it’s something deeper in the guts.
I’m using cosmic epoch (I’m a gnome user) until this issue is fixed, but you need to delete the Egl-Wayland package (to force you to use only Vulkan backend rendering). I got some rendering on the second GPU messing with the EGL Wayland code. Epoch is still missing some working features like screencast sharing teams, but that’s okay for an alpha release. Although comic-epoch is the only DE that has modern code. (100% Wayland and Vulkan based). Check this Support multi-gpu mosaic · Issue #91 · NVIDIA/egl-wayland · GitHub
Unfortunately, cosmic epoch wouldn’t let me run my monitor at native resolution (5120x1440@240) and ultimately just wasn’t the type of de I prefer to use. I’m switching to wayland for gaming on GPU 1’s monitors and switching back to x11 for productivity on all monitors for now, which should be fine until the fix can be released.
How did you remove EGL? When I try to apt remove it, apt wants to uninstall the nv drivers entirely…
Have another drive I’m messing around with Pop on, so trying your approach and not having much luck.
I am on archlinux, although you can remove it without its dependencies on Ubuntu as well, check: apt - How to remove a deb without removing its dependencies - Ask Ubuntu
