Ramon: Ubuntu - Dual GPU Configuration - Black Screen with X
First of all: I checked Ubuntu - Dual GPU Configuration - Black Screen with X and that helped a bit
Situation:
AM4 board with AMD and 3 PCI express slots
2x PNY NVIDIA Quadro P400 V2 , each with 3 mini display ports
6x identical iiyama screens :Gmaster GE2488HS (24 inch, connected with HDMI)
the Nvidia software recognizes the 2 cards but the Xscreen 1 is not showing ( for the 3 screens )
Error
xrandr --setprovideroutputsource NVIDIA-G0 NVIDIA-0 && xrandr --auto
xrandr: Configure crtc 4 failed
Also with arandr
( screenshot will follow)
I set this in grub (and generated grub):
set kernel parameter nvidia-drm.modeset=1
If I delete the xorg.conf then commandline recoginizes the 2 cards:
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x218 cap: 0x1, Source Output crtcs: 4 outputs: 6 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x417 cap: 0x2, Sink Output crtcs: 4 outputs: 6 associated providers: 1 name:NVIDIA-G0
Other info:
cat /etc/issue*
Ubuntu 20.04.6 LTS \n \l
driver: 530.41.03-0ubuntu0.20.04.2 amd64 [installed,automatic]
second screenshot
Screenshot from 2023-05-04 16-12-32
This the syslog when I enter
May 8 11:06:10 devbak01 colord[1567]: failed to get session [pid 3019]: No data available
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: disconnected
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): connected
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): Internal TMDS
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): 165.0 MHz maximum pixel clock
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: disconnected
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): connected
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): Internal TMDS
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): 165.0 MHz maximum pixel clock
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: disconnected
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-5): connected
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-5): Internal TMDS
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-5): 165.0 MHz maximum pixel clock
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: randr: failed to create shared pixmap
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (EE) NVIDIA(G0): Failed to configure Reverse PRIME on output DP-1-1.
May 8 11:06:10 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (II) NVIDIA(0): Setting mode “DP-3: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-5: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Supervising 7 threads of 3 processes of 2 users.
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8806 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Supervising 8 threads of 3 processes of 2 users.
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8807 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (II) NVIDIA(0): Setting mode “DP-5: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8808 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (II) NVIDIA(0): Setting mode “NULL”
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (II) NVIDIA(0): Setting mode “DP-1: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8809 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (II) NVIDIA(0): Setting mode “DP-3: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-1: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8810 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8811 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (II) NVIDIA(0): Setting mode “DP-3: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-1: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-5: nvidia-auto-select @1920x1080 +3840+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}”
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8812 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 rtkit-daemon[1886]: Successfully made thread 8813 of process 2488 owned by ‘1000’ RT at priority 5.
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: disconnected
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): connected
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): Internal TMDS
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): 165.0 MHz maximum pixel clock
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: disconnected
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): connected
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): Internal TMDS
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): 165.0 MHz maximum pixel clock
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: disconnected
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
May 8 11:06:11 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-5): connected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-5): Internal TMDS
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-5): 165.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: disconnected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: Internal DisplayPort
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-0: 1440.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): connected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): Internal TMDS
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-1): 165.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: disconnected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-2: 1440.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): connected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): Internal TMDS
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): Idek Iiyama PL2488H (DFP-3): 165.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: disconnected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-0: disconnected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-0: Internal DisplayPort
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-0: 1440.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-1): connected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-1): Internal TMDS
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-1): 165.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-2: disconnected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-2: Internal DisplayPort
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-2: 1440.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-3): connected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-3): Internal TMDS
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-3): 165.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-4: disconnected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-4: Internal DisplayPort
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): DFP-4: 1440.0 MHz maximum pixel clock
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-5): connected
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-5): Internal TMDS
May 8 11:06:12 devbak01 /usr/lib/gdm3/gdm-x-session[2619]: (–) NVIDIA(GPU-1): Idek Iiyama PL2488H (DFP-5): 165.0 MHz maximum pixel clock
May 8 11:06:13 devbak01 gsd-color[3105]: could not find device: property match ‘XRANDR_name’=‘DP-1-1’ does not exist
May 8 11:06:13 devbak01 gsd-color[3105]: could not find device: property match ‘XRANDR_name’=‘DP-1-5’ does not exist
May 8 11:06:13 devbak01 gsd-color[3105]: could not find device: property match ‘XRANDR_name’=‘DP-3’ does not exist
May 8 11:06:13 devbak01 gsd-color[3105]: could not find device: property match ‘XRANDR_name’=‘DP-5’ does not exist
May 8 11:06:13 devbak01 gnome-shell[2768]: Object St.ScrollView (0x562c0c8dfe60), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
May 8 11:06:13 devbak01 gnome-shell[2768]: == Stack trace for context 0x562c05be22d0 ==
May 8 11:06:13 devbak01 gnome-shell[2768]: #0 562c0818ee70 i /usr/share/gnome-shell/extensions/ubuntu-dock@ubuntu.com/dash.js:965 (116de14ef538 @ 132)
May 8 11:06:13 devbak01 gnome-shell[2768]: #1 562c0818edd8 i /usr/share/gnome-shell/extensions/ubuntu-dock@ubuntu.com/dash.js:494 (116de14f4718 @ 30)
May 8 11:06:13 devbak01 gnome-shell[2768]: st_scroll_view_get_vscroll_bar: assertion ‘ST_IS_SCROLL_VIEW (scroll)’ failed
May 8 11:06:13 devbak01 gnome-shell[2768]: JS ERROR: TypeError: scrollView.get_vscroll_bar(…) is null#012ensureActorVisibleInScrollView@/usr/share/gnome-shell/extensions/ubuntu-dock@ubuntu.com/dash.js:965:34#012_createAppItem/</this._ensureAppIconVisibilityTimeoutId<@/usr/share/gnome-shell/extensions/ubuntu-dock@ubuntu.com/dash.js:494:21
May 8 11:06:13 devbak01 gnome-shell[2768]: Object St.Label (0x562c06b5c920), has been already deallocated — impossible to access it. This might be caused by the object having been destroyed from C code using something such as destroy(), dispose(), or remove() vfuncs.
May 8 11:06:13 devbak01 gnome-shell[2768]: #0 562c0818eef8 i /usr/share/gnome-shell/extensions/ubuntu-dock@ubuntu.com/appIcons.js:1156 (116de14f5808 @ 105)
May 8 11:06:13 devbak01 gnome-shell[2768]: #1 562c0818ee60 i /usr/share/gnome-shell/extensions/ubuntu-dock@ubuntu.com/dash.js:41 (116de14ef5b0 @ 27)
May 8 11:06:13 devbak01 gnome-shell[2768]: #2 562c0818edd8 i resource:///org/gnome/shell/ui/dash.js:529 (15b83601c790 @ 24)
May 8 11:06:13 devbak01 gnome-shell[2768]: clutter_actor_get_stage: assertion ‘CLUTTER_IS_ACTOR (actor)’ failed
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
May 8 11:06:13 devbak01 gnome-shell[2768]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
see attached bug report
nvidia-bug-report.log.gz (633.3 KB)
I could really use some help here
