This would appear to be a longstanding bug in the nvarguscamerasrc gstreamer plugin.
Has NVIDIA listed it as such?
do they intend to fix it?
here is the relevant part of the test
<b>// connects to rpi camera in mode 4 as intended</b>
// gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)120/1' ! nvoverlaysink
#if 0
// <b>connects to rpi camera in mode 4 as intended</b>
caps = gst_caps_from_string("video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)120/1");
#else
// <b>recieves the following errors</b>
//(gsttest:8868): GStreamer-CRITICAL **: 00:19:52.400: gst_structure_new_empty: assertion 'gst_structure_validate_name (name)' failed
//** (gsttest:8868): CRITICAL **: 00:19:52.400: void print_caps(const GstCaps*, const gchar*): assertion 'caps != NULL' failed
//(gsttest:8868): GStreamer-CRITICAL **: 00:19:52.401: gst_mini_object_unref: assertion 'mini_object != NULL' failed
<b>// connects to rpi camera in mode 2 not as intended</b>
caps = gst_caps_new_simple ("video/x-raw(memory:NVMM)",
"width", G_TYPE_INT, 1280,
"height", G_TYPE_INT, 720,
"format", G_TYPE_STRING, "NV12",
"framerate", GST_TYPE_FRACTION, 120, 1,
NULL);
#endif
[b]// caps is NULL in the debugger when using gst_caps_new_simple
// and nothing is printed when using gst_caps_new_simple[/b]
print_caps (caps, " ");
Full compileable file.
change the define @ line 120 to see bug.
tested on jetson nano with rPi camera.
#include <gst/gst.h>
// gcc -g gsttest.cpp -o gsttest `pkg-config --cflags --libs gstreamer-1.0`
// gst-launch-1.0 nvarguscamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)120/1' ! autovideosink
// https://devtalk.nvidia.com/default/topic/934515/using-x-raw-memory-nvmm-in-gstreamer-program/
// gst-launch-1.0 nvarguscamerasrc ! "video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, format=(string)NV12, framerate=(fraction)120/1" ! nvoverlaysink -e
static gboolean
link_elements_with_filter (GstElement *element1, GstElement *element2);
int main(int argc, char *argv[]) {
GstElement *source,
*sink,
*pipeline;
GstBus *bus;
GstMessage *msg;
GstStateChangeReturn ret;
/* Initialize GStreamer */
gst_init (&argc, &argv);
/* Create the elements */
#if 0
source = gst_element_factory_make ("videotestsrc", "source");
g_object_set (source, "pattern", 0, NULL);
#else
source = gst_element_factory_make ("nvarguscamerasrc", "source");
#endif
sink = gst_element_factory_make ("nvoverlaysink", "sink");
/* Create the empty pipeline */
pipeline = gst_pipeline_new ("test-pipeline");
if (!pipeline || !source || !sink ) {
g_printerr ("!pipeline || !source || !sink \n");
return -1;
/* Build the pipeline */
gst_bin_add_many (GST_BIN (pipeline), source, sink, NULL);
if(link_elements_with_filter(source,sink) != TRUE){
g_printerr ("Elements source,sink could not be linked.\n");
gst_object_unref (pipeline);
return -1;
/* Start playing left*/
ret = gst_element_set_state (pipeline, GST_STATE_PLAYING);
if (ret == GST_STATE_CHANGE_FAILURE) {
g_printerr ("Unable to set the pipeline to the playing state.\n");
return -1;
/* Wait until error or EOS */
bus = gst_element_get_bus (pipeline);
msg = gst_bus_timed_pop_filtered (bus, GST_CLOCK_TIME_NONE, (GstMessageType)(GST_MESSAGE_ERROR | GST_MESSAGE_EOS));
/* Parse message */
if (msg != NULL) {
GError *err;
gchar *debug_info;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_ERROR:
gst_message_parse_error (msg, &err, &debug_info);
g_printerr ("Error received from element %s: %s\n", GST_OBJECT_NAME (msg->src), err->message);
g_printerr ("Debugging information: %s\n", debug_info ? debug_info : "none");
g_clear_error (&err);
g_free (debug_info);
break;
case GST_MESSAGE_EOS:
g_print ("End-Of-Stream reached.\n");
break;
default:
/* We should not reach here because we only asked for ERRORs and EOS */
g_printerr ("Unexpected message received.\n");
break;
gst_message_unref (msg);
/* Free resources */
gst_object_unref (bus);
gst_element_set_state (pipeline, GST_STATE_NULL);
return 0;
#if 0
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
format: { (string)NV12 }
framerate: [ 0/1, 120/1 ]
#endif
static void print_caps (const GstCaps * caps, const gchar * pfx);
static gboolean
gboolean link_ok;
GstCaps *caps;
#if 0
#else
// recieves the following errors
NULL);
#endif
link_ok = gst_element_link_filtered (element1, element2, caps);
gst_caps_unref (caps);
if (!link_ok) {
g_warning ("Failed to link element1 and element2!");
return link_ok;
/* Functions below print the Capabilities in a human-friendly format */
static gboolean print_field (GQuark field, const GValue * value, gpointer pfx) {
gchar *str = gst_value_serialize (value);
g_print ("%s %15s: %s\n", (gchar *) pfx, g_quark_to_string (field), str);
g_free (str);
return TRUE;
static void print_caps (const GstCaps * caps, const gchar * pfx) {
guint i;
g_return_if_fail (caps != NULL);
if (gst_caps_is_any (caps)) {
g_print ("%sANY\n", pfx);
return;
if (gst_caps_is_empty (caps)) {
g_print ("%sEMPTY\n", pfx);
return;
for (i = 0; i < gst_caps_get_size (caps); i++) {
GstStructure *structure = gst_caps_get_structure (caps, i);
g_print ("%s%s\n", pfx, gst_structure_get_name (structure));
gst_structure_foreach (structure, print_field, (gpointer) pfx);
