I’m running 4 5MP cameras in parallell on the Xavier 8GB, streaming 24FPS video. With this setup i should be able to make 24FPS because the Xavier 8GB is rated to 2x464MP/s. However, I’m not able to utilize the NVENC1 chip, running tegrastats I only get load on the NVENC. It should be mentioned that I have patched gstreamer to run the NVENC on max frequency such that it is always reporting 499, examble tegrastats:
RAM 1450/7764MB (lfb 1459x4MB) SWAP 0/3882MB (cached 0MB) CPU [1%@2035,31%@2035,29%@2035,32%@2035,0%@2035,off] EMC_FREQ 12%@1331 GR3D_FREQ 0%@905 NVENC 499 APE 75 MTS fg 0% bg 4% AO@36.5C GPU@37C Tdiode@39.75C PMIC@100C AUX@36.5C CPU@37.5C thermal@36.95C Tboard@37C GPU 657/657 CPU 1314/1345 SOC 2065/2065 CV 0/0 VDDRQ 657/657 SYS5V 2312/2312
How can I utilize the full encoding potential of Xavier running through GStreamer?
Edit:
Also, with this setup I’m only managing ~13fps on each camera, which corresponds to ~260MP/s. Why am I not getting better results? There is no large different utilizing a high/medium/low bitrate or baseline/main/high profile.
Do you run each encoding thread in individual process? Or 4 encoding threads in single process? If you run each encoding thread in individual process, it should trigger NVENC1
I tried running four instances of the app, thus launching all encoders in their own process. However, I could not trigger NVENC1.
top - 06:36:16 up 3 min, 5 users, load average: 4.11, 2.14, 0.85
Threads: 469 total, 5 running, 460 sleeping, 0 stopped, 4 zombie
%Cpu(s): 1.0 us, 17.6 sy, 0.0 ni, 81.2 id, 0.0 wa, 0.2 hi, 0.0 si, 0.0 st
KiB Mem : 7950020 total, 5217768 free, 2095676 used, 636576 buff/cache
KiB Swap: 3975000 total, 3975000 free, 0 used. 5740164 avail Mem
PID USER PR NI VIRT RES SHR P S %CPU %MEM TIME+ COMMAND
4608 root -21 0 1137728 298544 58848 1 S 26.6 3.8 0:53.60 source_element:
4848 root -21 0 1156832 297620 58912 3 S 25.0 3.7 0:28.01 source_element:
4676 root -21 0 1137040 301776 58912 2 S 24.7 3.8 0:47.00 source_element:
4923 root -21 0 1156832 301688 58848 4 R 24.3 3.8 0:15.65 source_element:
4603 root -21 0 1137728 298544 58848 1 S 0.7 3.8 0:00.90 video_encoder:s
4844 root -21 0 1156832 297620 58912 3 S 0.7 3.7 0:00.46 camera_app
4850 root -21 0 1156832 297620 58912 3 S 0.7 3.7 0:00.38 NVMVidEncInputT
4924 root -21 0 1156832 301688 58848 4 S 0.7 3.8 0:00.28 video_encoder:s
4605 root -21 0 1137728 298544 58848 1 S 0.3 3.8 0:00.91 camera_app
4606 root -21 0 1137728 298544 58848 1 S 0.3 3.8 0:00.19 queue_video:src
4607 root -21 0 1137728 298544 58848 1 S 0.3 3.8 0:00.52 queue_image:src
4609 root -21 0 1137728 298544 58848 1 S 0.3 3.8 0:00.78 NVMVidEncInputT
4622 root -2 0 1137040 301776 58912 0 S 0.3 3.8 0:00.32 camera_app
4671 root -21 0 1137040 301776 58912 2 S 0.3 3.8 0:00.80 video_encoder:s
4673 root -21 0 1137040 301776 58912 2 S 0.3 3.8 0:00.73 camera_app
4675 root -21 0 1137040 301776 58912 2 S 0.3 3.8 0:00.48 queue_image:src
4679 root -21 0 1137040 301776 58912 2 S 0.3 3.8 0:00.64 NVMVidEncInputT
4847 root -21 0 1156832 297620 58912 3 S 0.3 3.7 0:00.28 queue_image:src
4849 root -21 0 1156832 297620 58912 3 S 0.3 3.7 0:00.45 video_encoder:s
4863 root -2 0 1156832 301688 58848 0 S 0.3 3.8 0:00.15 camera_app
4920 root -21 0 1156832 301688 58848 4 R 0.3 3.8 0:00.26 camera_app
4925 root -21 0 1156832 301688 58848 4 S 0.3 3.8 0:00.21 NVMVidEncInputT
RAM 2089/7764MB (lfb 1264x4MB) SWAP 0/3882MB (cached 0MB) CPU [2%@2035,26%@2035,26%@2035,28%@2035,25%@2035,0%@2035] EMC_FREQ 14%@1331 GR3D_FREQ 0%@905 NVENC 499 NVJPG 294 APE 75 MTS fg 0% bg 6% AO@36C GPU@36.5C Tdiode@39.25C PMIC@100C AUX@36C CPU@37.5C thermal@36.45C Tboard@37C GPU 657/657 CPU 1501/1501 SOC 2251/2251 CV 0/0 VDDRQ 750/750 SYS5V 2352/2352
Any suggestions? Would it be possible to adapt the gstomx code to actively control which encoder to use?
We can see both NVENC and NVENC1 activated on Xavier 8GB/r32.3.1:
$ gst-launch-1.0 videotestsrc ! video/x-raw,width=3840,height=2160 ! nvvidconv ! nvv4l2h264enc maxperf-enable=1 ! h264parse ! fakesink
RAM 2538/7763MB (lfb 114x4MB) SWAP 0/3881MB (cached 0MB) CPU [0%@2034,0%@2034,0%@2035,0%@2034,87%@2034,4%@2034] EMC_FREQ 8%@1331 GR3D_FREQ 0%@905 NVENC 499 NVENC1 499 APE 75 MTS fg 0% bg 2% AO@24C GPU@26C Tdiode@28.75C PMIC@100C AUX@25.5C CPU@26.5C thermal@25.95C Tboard@27C GPU 457/457 CPU 1527/866 SOC 1526/1253 CV 0/0 VDDRQ 610/344 SYS5V 2009/1916
FYR.
