We are working for OV5647 on jetson nano.
Save raw file via v4l2 is done.
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=BG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
V4L2 stream is fine.
h@h-desktop:/var/log$ v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap
<<<<<<<<<<<<<<<<< 15.38 fps
<<<<<<<<<<<<<<< 15.34 fps
<<<<<<<<<<<<<<< 15.33 fps
<<<<<<<<<<<<<<<< 15.34 fps
But argus streaming is failed.
h@h-desktop:/lib/modules$ gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12’ ! nvvidconv flip-method=0 ! ‘video/x-raw,width=960, height=616’ ! nvvidconv ! nvegltransform ! nveglglessink -e
Setting pipeline to PAUSED …Using winsys: x11
Pipeline is live and does not need PREROLL …
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING …
New clock: GstSystemClock
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:532 No cameras available
Got EOS from element “pipeline0”.
Execution ended after 0:00:00.313184895
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
Below is nvargus-daemon log
=== NVIDIA Libargus Camera Service (0.97.3)=== Listening for connections…=== gst-launch-1.0[8595]: Connection established (7F9A6FF1D0)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 106)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 582)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 437)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 295)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 458)
Acquiring SCF Camera device source via index 0 has failed. === gst-launch-1.0[8595]: CameraProvider initialized (0x7f94835610)=== gst-launch-1.0[8595]: CameraProvider destroyed (0x7f94835610)=== gst-launch-1.0[8595]: Connection closed (7F9A6FF1D0)=== gst-launch-1.0[8595]: Connection cleaned up (7F9A6FF1D0)
Below is the dtsi file
include <dt-bindings/media/camera.h>
include <dt-bindings/platform/t210/t210.h>/ {
host1x {
vi_base: vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
rbpcv2_ov5647_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&rbpcv2_ov5647_csi_out0>;
};csi_base: nvcsi { num-channels = <1>; #address-cells = <1>; #size-cells = <0>; csi_chan0: channel@0 { reg = <0>; ports { #address-cells = <1>; #size-cells = <0>; csi_chan0_port0: port@0 { reg = <0>; rbpcv2_ov5647_csi_in0: endpoint@0 { port-index = <0>; bus-width = <2>; remote-endpoint = <&rbpcv2_ov5647_out0>; }; }; csi_chan0_port1: port@1 { reg = <1>; rbpcv2_ov5647_csi_out0: endpoint@1 { remote-endpoint = <&rbpcv2_ov5647_vi_in0>; }; }; }; }; }; i2c@546c0000 { ov5647_single_cam0: rbpcv2_ov5647_a@10 { compatible = "nvidia,ov5647"; /* I2C device address */ reg = <0x36>; /* V4L2 device node location */ devnode = "video0"; /* Physical dimensions of sensor */ physical_w = "3.674"; physical_h = "2.738"; sensor_model = "ov5647"; use_sensor_mode_id = "true"; mode0 { mclk_khz = "25000"; num_lanes = "2"; tegra_sinterface = "serial_a"; phy_mode = "DPHY"; discontinuous_clk = "yes"; dpcm_enable = "false"; cil_settletime = "0"; active_w = "1920"; active_h = "1080"; pixel_t = "bayer_bggr"; readout_orientation = "90"; line_length = "2688"; inherent_gain = "1"; pix_clk_hz = "68000000"; gain_factor = "10"; min_gain_val = "10";/* 1DB*/ max_gain_val = "160";/* 16DB*/ step_gain_val = "1"; default_gain = "80"; min_hdr_ratio = "1"; max_hdr_ratio = "1"; framerate_factor = "1000000"; min_framerate = "1816577";/*1.816577 */ max_framerate = "30000000";/*15*/ step_framerate = "1"; default_framerate = "30000000"; exposure_factor = "1000000"; min_exp_time = "34";/* us */ max_exp_time = "550385";/* us */ step_exp_time = "1"; default_exp_time = "33334";/* us */ embedded_metadata_height = "0"; }; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; rbpcv2_ov5647_out0: endpoint { port-index = <0>; bus-width = <2>; remote-endpoint = <&rbpcv2_ov5647_csi_in0>; }; }; }; }; }; };lens_ov5647@RBPCV2 {
min_focus_distance = “0.0”;
hyper_focal = “0.0”;
focal_length = “2.67”;
f_number = “2.0”;
aperture = “2.0”;
tcp: tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
modules {
cam_module0: module0 {
badge = “porg_front_RBPCV2”;
position = “front”;
orientation = “1”;
cam_module0_drivernode0: drivernode0 {
pcl_id = “v4l2_sensor”;
devname = “ov5647 6-0010”;
proc-device-tree = “/proc/device-tree/host1x/i2c@546c0000/rbpcv2_ov5647_a@10”;
cam_module0_drivernode1: drivernode1 {
pcl_id = “v4l2_lens”;
proc-device-tree = “/proc/device-tree/lens_ov5647@RBPCV2/”;
Thanks a lot for you help!
