We are experiencing VIDIOC_DQBUF ioctl’s returning before the frame is ready.
Perhaps related, the v4l2_buffer’s timestamp is not set.
According to ShaneCCC
https://devtalk.nvidia.com/default/topic/1020202/jetson-tx1/v4l2-time-stamp-does-not-work-for-l4t-28-1-jetpack-3-1-/post/5199386/#5199386
“the kernel-4.4 have new define /kernel/include/media/videobuf2-v4l2.h I think the user space need to change too. Could you use the vb2_v4l2_buffer instead of v4l2_buffer.”
I’m confused: vb2_v4l2_buffer is not part of the userspace API.
Does anyone have an example of its use in a userspace program?
@hollense
For your case you can debug from the CSI/VI kernel driver to check. Otherwise if you can’t include vb2_v4l2_buffer you can just copy this struct to your user space APP to define it to try.
Are you saying that vb2_v4l2_buffer can be passed to VIDIOC_QBUF and VIDIOC_DQBUF ioctls?
Otherwise what should they be passed to?
OK, Please forgot my early comment.
Could you trace and make some log in __fill_v4l2_buffer() the …/drivers/media/v4l2-core/videobuf2-v4l2.c to check the timestamp is validate in there.
