Hardware Info:
Operating System: CachyOS Linux
KDE Plasma Version: 6.5.4
KDE Frameworks Version: 6.20.0
Qt Version: 6.10.1
Kernel Version: 6.18.0-5-cachyos (64-bit)
Graphics Platform: Wayland
Processors: 16 × AMD Ryzen 7 7800X3D 8-Core Processor
Memory: 32 GiB of RAM (30.5 GiB usable)
Graphics Processor 1: NVIDIA GeForce RTX 5080
Graphics Processor 2: AMD Ryzen 7 7800X3D 8-Core Processor
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: X670E AORUS MASTER
System Version: -CF
NVIDIA Driver Version: 580.105.08
Gamescope seems to hard crash whenever a scaling filter is applied. Output when running testing vkcube:
❯ gamescope -h 1440 --filter nis --expose-wayland – vkcube
[gamescope] [Info] console: gamescope version 3.16.17 (gcc 15.2.1)
No CAP_SYS_NICE, falling back to regular-priority compute and threads.
Performance will be affected.
[gamescope] [Info] scriptmgr: Loading scripts from: ‘/usr/share/gamescope/scripts’
[gamescope] [Info] scriptmgr: Loading scripts from: ‘/usr/share/gamescope/scripts/00-gamescope’
[gamescope] [Info] scriptmgr: Loading scripts from: ‘/usr/share/gamescope/scripts/00-gamescope/common’
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/common/inspect.lua’ (id: 0)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/common/modegen.lua’ (id: 1)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/common/util.lua’ (id: 2)
[gamescope] [Info] scriptmgr: Loading scripts from: ‘/usr/share/gamescope/scripts/00-gamescope/displays’
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/displays/asus.rogally.lcd.lua’ (id: 3)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/displays/deckhd.steamdeck.deckhd-lcd.lua’ (id: 4)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/displays/gpd.win4.lcd.lua’ (id: 5)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/displays/lenovo.legiongo.lcd.lua’ (id: 6)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/displays/lenovo.legiongos.lcd.lua’ (id: 7)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/displays/valve.steamdeck.lcd.lua’ (id: 8)
[gamescope] [Info] scriptmgr: Running script file ‘/usr/share/gamescope/scripts/00-gamescope/displays/valve.steamdeck.oled.lua’ (id: 9)
[gamescope] [Info] scriptmgr: Loading scripts from: ‘/etc/gamescope/scripts’
[gamescope] [Warn] scriptmgr: Directory ‘/etc/gamescope/scripts’ does not exist
[gamescope] [Info] scriptmgr: Loading scripts from: ‘/home/moomew/.config/gamescope/scripts’
[gamescope] [Warn] scriptmgr: Directory ‘/home/moomew/.config/gamescope/scripts’ does not exist
[gamescope] [Info] vulkan: selecting physical device ‘NVIDIA GeForce RTX 5080’: queue family 2 (general queue family 0)
[gamescope] [Info] vulkan: physical device supports DRM format modifiers
[gamescope] [Info] wlserver: [backend/headless/backend.c:67] Creating headless backend
[gamescope] [Info] xdg_backend: Seat name: seat0
[gamescope] [Error] vulkan: vkGetPhysicalDeviceFormatProperties2 returned zero modifiers for DRM format 0x38344241 (VkResult: 0)
[gamescope] [Error] vulkan: vkGetPhysicalDeviceFormatProperties2 returned zero modifiers for DRM format 0x38344258 (VkResult: 0)
[gamescope] [Info] vulkan: supported DRM formats for sampling usage:
[gamescope] [Info] vulkan: AR24 (0x34325241)
[gamescope] [Info] vulkan: XR24 (0x34325258)
[gamescope] [Info] vulkan: AB24 (0x34324241)
[gamescope] [Info] vulkan: XB24 (0x34324258)
[gamescope] [Info] vulkan: RG16 (0x36314752)
[gamescope] [Info] vulkan: NV12 (0x3231564E)
[gamescope] [Info] vulkan: AB4H (0x48344241)
[gamescope] [Info] vulkan: XB4H (0x48344258)
[gamescope] [Info] vulkan: AB30 (0x30334241)
[gamescope] [Info] vulkan: XB30 (0x30334258)
[gamescope] [Info] vulkan: AR30 (0x30335241)
[gamescope] [Info] vulkan: XR30 (0x30335258)
[gamescope] [Info] wlserver: Using explicit sync when available
[gamescope] [Info] wlserver: Running compositor on wayland display ‘gamescope-0’
[gamescope] [Info] wlserver: [backend/headless/backend.c:17] Starting headless backend
[gamescope] [Info] wlserver: Successfully initialized libei for input emulation!
[gamescope] [Info] wlserver: [xwayland/server.c:107] Starting Xwayland on :1
The XKEYBOARD keymap compiler (xkbcomp) reports:Warning: Could not resolve keysym XF86OK
Warning: Could not resolve keysym XF86GoTo
Warning: Could not resolve keysym XF86VendorLogo
Warning: Could not resolve keysym XF86MediaSelectProgramGuide
Warning: Could not resolve keysym XF86MediaSelectHome
Warning: Could not resolve keysym XF86MediaLanguageMenu
Warning: Could not resolve keysym XF86MediaTitleMenu
Warning: Could not resolve keysym XF86AudioChannelMode
Warning: Could not resolve keysym XF86MediaSelectPC
Warning: Could not resolve keysym XF86MediaSelectTV
Warning: Could not resolve keysym XF86MediaSelectCable
Warning: Could not resolve keysym XF86MediaSelectVCR
Warning: Could not resolve keysym XF86MediaSelectVCRPlus
Warning: Could not resolve keysym XF86MediaSelectSatellite
Warning: Could not resolve keysym XF86MediaSelectCD
Warning: Could not resolve keysym XF86MediaSelectTape
Warning: Could not resolve keysym XF86MediaSelectRadio
Warning: Could not resolve keysym XF86MediaSelectTuner
Warning: Could not resolve keysym XF86MediaPlayer
Warning: Could not resolve keysym XF86MediaSelectTeletext
Warning: Could not resolve keysym XF86MediaSelectAuxiliary
Warning: Could not resolve keysym XF86MediaPlaySlow
Warning: Could not resolve keysym XF86NumberEntryMode
Warning: Could not resolve keysym XF86RefreshRateToggle
Warning: Could not resolve keysym XF86Accessibility
Warning: Could not resolve keysym XF86DoNotDisturb
Errors from xkbcomp are not fatal to the X server
[gamescope] [Info] pipewire: stream state changed: connecting
[gamescope] [Info] pipewire: stream state changed: paused
[gamescope] [Info] pipewire: stream available on node ID: 105
[gamescope] [Info] xdg_backend: uMaxContentLightLevel: 80
[gamescope] [Info] xdg_backend: HDR INFO
[gamescope] [Info] xdg_backend: cv_hdr_enabled: false
[gamescope] [Info] xdg_backend: uTF: GAMMA22
[gamescope] [Info] xdg_backend: bExposeHDRSupport: false
[gamescope] [Info] xdg_backend: uMaxContentLightLevel: 710
[gamescope] [Info] edid: Patching res 800x1280 → 2560x1440
[gamescope] [Info] vblank: Using timerfd.
Selected WSI platform: wayland
ATTENTION: default value of option vk_xwayland_wait_ready overridden by environment.
[Gamescope WSI] Application info:
pApplicationName: vkcube
applicationVersion: 0
pEngineName: vkcube
engineVersion: 0
apiVersion: 4194304
[Gamescope WSI] Executable name: vkcube
[Gamescope WSI] Surface state:
steam app id: 0
window xid: 0x0
wayland surface res id: 3
layer client flags: 0x0
server hdr output enabled: false
hdr formats exposed to client: false
Selected GPU 0: NVIDIA GeForce RTX 5080, type: DiscreteGpu
[Gamescope WSI] Forcing on VK_EXT_swapchain_maintenance1.
[Gamescope WSI] Creating swapchain for xid: 0x0 - oldSwapchain: (nil) - provided minImageCount: 3 - minImageCount: 3 - format: VK_FORMAT_B8G8R8A8_UNORM - colorspace: VK_COLOR_SPACE_SRGB_NONLINEAR_KHR - flip: true
[Gamescope WSI] Created swapchain for xid: 0x0 swapchain: 0x561a47b932c0 - imageCount: 3
[gamescope] [Error] xwm: NO CURSOR IMPL XDG
[gamescope] [Warn] xwm: D-Bus call to get unit corresponding to pid 4294967295 failed!The XKEYBOARD keymap compiler (xkbcomp) reports:
Warning: Unsupported maximum keycode 708, clipping.
X11 cannot support keycodes above 255.
Warning: Virtual modifier Hyper multiply defined
Using 0, ignoring 0
Warning: Virtual modifier ScrollLock multiply defined
Using 0, ignoring 0
[gamescope] [Info] xdg_backend: Changed refresh to: 240.016hz
[Gamescope WSI] Swapchain received new refresh cycle: 16.67ms
[gamescope] [Error] vulkan: vkImportSemaphoreFdKHR failed (VkResult: -3)
[gamescopereaper] [Info] reaper: Parent of gamescopereaper was killed. Killing children.
(EE) failed to read Wayland events: Broken pipe
fish: Job 1, ‘gamescope -h 1440 --filter nis …’ terminated by signal SIGSEGV (Address boundary error)
This occurs on SDL and Wayland backends. DRM backend also has the same issue but that backend’s been a pain point for a while, so I haven’t tested it much due to gamescope-session image corruptions when running above 1440p. In my experience, –expose-wayland is needed to get certain apps to launch even without scaling filters. Launching certain apps like vkcube without –expose-wayland results in:
❯ gamescope – vkcube
[gamescope] [Info] pipewire: stream available on node ID: 112
[gamescope] [Info] edid: Patching res 800x1280 → 1280x720
pEngineName: vkcube
engineVersion: 0
apiVersion: 4194304
[Gamescope WSI] Failed to get Wayland objects
[gamescope] [Info] launch: Primary child shut down!
Interestingly enough, this could be a Vulkan issue. Although running glxgears with the above settings results in a black screen, enabling scaling after gamescope has launched seems to result in a perfectly fine result. It also seems to not need the –expose-wayland variable:
❯ gamescope -h 1440 – glxgears
[gamescope] [Info] pipewire: stream available on node ID: 101
[gamescope] [Warn] xwm: got the same buffer committed twice, ignoring.
sd_bus_call(g_dbus, message, UINT64_MAX, NULL, &reply)failed with ret -30
Using 0, ignoring 0
Using 0, ignoring 0
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
1209 frames in 5.0 seconds = 241.785 FPS
1201 frames in 5.0 seconds = 240.115 FPS
1202 frames in 5.0 seconds = 240.341 FPS
