I’ll do my best to answer your questions about the Jetson Orin Nano Super.
1. Raspberry Pi pin layout and voltage:
The Jetson Orin Nano Super does use a similar pin layout to the Raspberry Pi, but it’s not identical. The Jetson Orin Nano Super has a 40-pin GPIO header, which is similar to the Raspberry Pi’s 40-pin GPIO header. However, the voltage requirements are different. The Jetson Orin Nano Super requires a 5V power supply, whereas the Raspberry Pi typically uses a 5V power supply as well, but can also be powered by a 3.3V supply in some cases.
2. Camera compatibility:
Cameras designed for the Raspberry Pi may work on the Jetson Orin Nano Super, but it’s not guaranteed. The Jetson Orin Nano Super uses a different camera interface than the Raspberry Pi, so some cameras may not be compatible. However, many cameras that use the MIPI CSI-2 interface should work on the Jetson Orin Nano Super.
3. Power supply and voltage:
The barrel jack on the Jetson Orin Nano Super is indeed 19V, and the maximum voltage is 20V. The power supply that comes with the device supports up to 65W. While it’s possible to use a more powerful power supply, it’s not necessary unless you’re planning to use the device in a configuration that requires more power than the standard supply can provide.
4. JetPack and software support:
JetPack is NVIDIA’s software development kit for the Jetson platform, and it provides a comprehensive set of tools and libraries for developing AI applications. The Jetson Orin Nano Super is supported by JetPack 5.0 and later versions. The pinned comment you mentioned may be referring to an older version of JetPack that only supported the Xavier series, but that’s not relevant to the Jetson Orin Nano Super.
5. Driver update schedule:
NVIDIA typically releases new versions of JetPack every 6-12 months, and each version includes new features, bug fixes, and performance improvements. The Jetson Orin Nano Super will likely receive driver updates for several years, but the exact schedule is not publicly available.
6. USB port speed and power:
The Jetson Orin Nano Super has several USB ports, including USB 3.2 Gen 2, USB 3.2 Gen 1, and USB 2.0. The speed of each port is as follows:
* USB 3.2 Gen 2: up to 20 Gbps
* USB 3.2 Gen 1: up to 5 Gbps
* USB 2.0: up to 480 Mbps
Each USB port can draw up to 2.5W of power, and the power is not shared between ports.
7. Distros and Arm64 drivers:
Yes, other distros can be installed on the Jetson Orin Nano Super using the normal Arm64 drivers. However, NVIDIA only provides official support for the Ubuntu-based distro that comes with JetPack.
8. WIFI and BT:
The Jetson Orin Nano Super does include WIFI and BT capabilities, but they are not enabled by default. You’ll need to install the necessary drivers and configure the WIFI and BT settings to use these features.
9. NVML:
NVML (NVIDIA Management Library) is a set of APIs that provide access to NVIDIA GPU management functionality. The Jetson Orin Nano Super supports NVML, but the exact version and features may vary depending on the JetPack version you’re using.
I hope this answers all your questions about the Jetson Orin Nano Super!
