vector_types.h error when using curand.h
Hi PGI,
I’m trying to use openACC to run a basic Pi estimation code but it will not compile. I’m using a slightly modified version of the code from a pervious forum post:
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <curand.h>
//#include "common.h" //Linux header??
// Iterate over pairs of (x,y) from [0,1] x [0,1]
// Increment pointer only if (x,y) is inside a circle with R = 0.5
long pi(float *dx, float *dy, long n)
    long i, s = 0;
    #pragma acc data deviceptr(dx, dy)
    #pragma acc kernels
    for (i = 0; i < n; i++) {
	float x = dx[i] - 0.5;
	float y = dy[i] - 0.5;
	s += (x*x + y*y < 0.25);
    return s;
int main(int argc, char **argv) {
    float *dx, *dy; // device arrays
    long s; // counter of successful tries
    long n; // number of tries
    if (argc < 2) {
   fprintf(stderr, "Usage: %s N\n", argv[0]);
   return EXIT_FAILURE;
    if ((n = atol(argv[1])) <= 0) {
   fprintf(stderr, "N must be positive\n");
    // Allocate memory for device arrays to be filled with random values
    cudaMalloc((void *)&dx, n * sizeof(float));
    cudaMalloc((void *)&dy, n * sizeof(float));
    // Initialize CURAND generator, seed it and generate data
    curandGenerator_t g;
    curandCreateGenerator(&g, CURAND_RNG_PSEUDO_DEFAULT);
    curandSetPseudoRandomGeneratorSeed(g, 0); //TEST SEED ZERO REPLACE WITH time(NULL) when ready.
    curandGenerateUniform(g, dx, n);
    curandGenerateUniform(g, dy, n);
    // Perform computations
    s = pi(dx, dy, n);
    // Free memory
    cudaFree(dx);
    cudaFree(dy);
    // Print out the result
    printf("%lf\n", (double) s / n * 4.0);
    return EXIT_SUCCESS;
I’m compiling this on a ASUS laptop using on windows 7 (64bit). Nvidia card is a Geforce GT520M. I’m also using PGI accelerator v12.8 (2wk trail version).
When I try to compile this at the command prompt, I recieve the following error.
PGI$ pgcc -acc -ta=nvidia -Minfo=all openACC_Pi_Estimation_Answer_MOD.c -I "C:\
Program Files\PGI\win64\2012\cuda\4.2\include" -L "C:\Program Files\PGI\win64\2
012\cuda\4.2\lib64"
NOTE: your trial license will expire in 13 days, 22.9 hours.
PGC-S-0037-Syntax error: Recovery attempted by deleting keyword struct (C:\Progr
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 105)
PGC-S-0036-Syntax error: Recovery attempted by inserting keyword struct before i
dentifier char2 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.h
: 105)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 110)
dentifier uchar2 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.
h: 110)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 125)
dentifier char4 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.h
: 125)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 130)
dentifier uchar4 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.
h: 130)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 145)
dentifier short2 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.
h: 145)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 150)
dentifier ushort2 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types
.h: 150)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 165)
dentifier short4 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.
h: 165)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 166)
dentifier ushort4 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types
.h: 166)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 178)
dentifier int2 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.h:
 178)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 179)
dentifier uint2 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.h
: 179)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 191)
dentifier int4 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.h:
 191)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 196)
dentifier uint4 (C:\Program Files\PGI\win64\2012\cuda\4.2\include\vector_types.h
: 196)
am Files\PGI\win64\2012\cuda\4.2\include\vector_types.h: 212)
PGC-F-0008-Error limit exceeded (C:\Program Files\PGI\win64\2012\cuda\4.2\includ
e\vector_types.h)
PGC/x86-64 Windows 12.8-0: compilation aborted
PGI$
I haven’t seen this error before. I’ve compiled other openACC programs without an issue on this computer. It’s only a problem when utilising curand.h.
Would you happen to have any ideas as to the cause?
Thank you and kind regards,
Paul
Hi Paul,
pgcc can’t compile CUDA C programs. So to get this to work, you need to compile the CUDA C portion with NVCC and the OpenACC portion with pgcc. Also currently we don’t support “long” types in reductions. We have an open ticket (TPR#18815) to add this. Finally, I fixed a typo where you need to adjust your cudaMalloc to pass in a “void **”. Here’s the full example:
% cat test.cu
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <curand.h>
extern "C" {
long pi(float *dx, float *dy, long n);
    if (argc < 2) {
    cudaMalloc((void **) &dx, n * sizeof(float));
    cudaMalloc((void **) &dy, n * sizeof(float));
    curandSetPseudoRandomGeneratorSeed(g, 123); //TEST SEED ZERO REPLACE WITH time(NULL) when ready.
    s = pi(dx, dy, n);
    // Free memory
    cudaFree(dx);
    cudaFree(dy);
% cat pi.c
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
    long i;
    int s2=0;
    s2 = 0;
    #pragma acc kernels
        s2 += (x*x + y*y < 0.25);
    return (long) s2;
% pgcc -c pi.c -Minfo=accel -V12.8 -acc
pi:
     16, Generating compute capability 1.3 binary
         Generating compute capability 2.0 binary
     17, Loop is parallelizable
         Accelerator kernel generated
         17, #pragma acc loop gang, vector(128) /* blockIdx.x threadIdx.x */
             CC 1.3 : 13 registers; 48 shared, 36 constant, 0 local memory bytes
             CC 2.0 : 14 registers; 0 shared, 72 constant, 0 local memory bytes
         20, Sum reduction generated for s2
% nvcc test.cu pi.o -lcurand -L/usr/pgi/linux86-64/12.8/lib -lacc1 -ldl -lpgc -o pi.out
% pi.out 64000
3.142438
Hope this helps,
Mat
