OpenACC-CUDA interoperability within the same file
I was trying to reproduce the idea from pgcc compile error in OpenACC-CUDA interoperabily example of having CUDA kernels + OpenACC pragmas in the same file. Using NVCC as the main compiler with PGC++ as the host-compiler.
But I’m struggling to make it to work with cuda 8.0 and PGI 16.9.
#include <stdio.h>
#include <cuda_runtime.h>
__global__ void
vectorAdd(const float *A, const float *B, float *C, int numElements)
    int i = blockDim.x * blockIdx.x + threadIdx.x;
    if (i < numElements)
        C[i] = A[i] + B[i];
 * Host main routine
int
main(void)
    cudaError_t err = cudaSuccess;
    int numElements = 50000;
    size_t size = numElements * sizeof(float);
    printf("[Vector addition of %d elements]\n", numElements);
    float *h_A = (float *)malloc(size);
    float *h_B = (float *)malloc(size);
    float *h_C = (float *)malloc(size);
    for (int i = 0; i < numElements; ++i)
        h_A[i] = rand()/(float)RAND_MAX;
        h_B[i] = rand()/(float)RAND_MAX;
    #pragma acc data copyin(h_A[0:numElements],h_B[0:numElements]), copyout(h_C[0:numElements])
    #pragma acc host_data use_device(h_A,h_B,h_C)
        // Launch the Vector Add CUDA Kernel
        int threadsPerBlock = 256;
        int blocksPerGrid =(numElements + threadsPerBlock - 1) / threadsPerBlock;
        printf("CUDA kernel launch with %d blocks of %d threadsn\n", blocksPerGrid, threadsPerBlock);
        vectorAdd<<<blocksPerGrid, threadsPerBlock>>>(h_A, h_B, h_C, numElements);
        err = cudaGetLastError();
        if (err != cudaSuccess)
            exit(EXIT_FAILURE);
    } // end host_data
    } // end acc data region
        if (fabs(h_A[i] + h_B[i] - h_C[i]) > 1e-5)
            exit(EXIT_FAILURE);
    printf("Test PASSED\n");
    // Free host memory
    free(h_A);
    free(h_B);
    free(h_C);
    printf("Done\n");
    return 0;
Compiled with:
/usr/local/cuda-8.0/bin/nvcc -x cu -ccbin pgc++ -Xcompiler -ta=tesla:cuda8.0 -Xcompiler -Mcuda -Xcompiler -Minfo=accel -gencode arch=compute_35,code=sm_35 vecAdd.cpp
and error:
"/usr/local/cuda-8.0/bin/..//include/host_config.h", line 119: catastrophic
          error: #error directive: -- unsupported GNU version! gcc versions
          later than 5 are not supported!
  #error -- unsupported GNU version! gcc versions later than 5 are not supported!
1 catastrophic error detected in the compilation of "vecAdd.cpp".
Compilation terminated.
It seems that pgc++ defines GNUC > 5. Is this behaviour correct? (It has any relation that my system has g++ 6.1.1 installed?)
I tried regenerating the file
/bin/localrc
using gcc 5 information (with makelocalrc).
Also I added some symlinks (nvlink & fatbinary) of some binaries that were missing in pgi/linux86_64/2016/cuda8.0/bin pointing to binaries of cuda 8 installation.
(I was trying to mimic the /opt/pgi/linux86-64/2016/cuda/7.5/bin/ layout -cudafe,fatbinary,nvlink & ptxas-)
Now I’m able to compile but the kernel launch breaks:
LD_LIBRARY_PATH=/usr/local/cuda-8.0/lib64 cuda-memcheck ./a.out
========= CUDA-MEMCHECK
[Vector addition of 50000 elements]
CUDA kernel launch with 196 blocks of 256 threadsn
========= Program hit cudaErrorInvalidDeviceFunction (error 8) due to "invalid device function" on CUDA API call to cudaLaunch.
=========     Saved host backtrace up to driver entry point at error
=========     Host Frame:/usr/lib/x86_64-linux-gnu/libcuda.so [0x2e7c03]
=========     Host Frame:./a.out [0x3358e]
=========     Host Frame:./a.out [0x3af9]
=========     Host Frame:./a.out [0x3ae5]
=========     Host Frame:./a.out [0x3b09]
=========     Host Frame:./a.out [0x3745]
=========     Host Frame:/lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main + 0xf0) [0x20700]
=========     Host Frame:./a.out [0x3299]
========= Program hit cudaErrorInvalidDeviceFunction (error 8) due to "invalid device function" on CUDA API call to cudaGetLastError.
=========     Host Frame:./a.out [0x35683]
=========     Host Frame:./a.out [0x374c]
========= ERROR SUMMARY: 2 errors
compilation output:
"vecAdd.cpp", line 1: warning: unrecognized GCC pragma
  #pragma GCC diagnostic ignored "-Wunused-local-typedefs"
  #pragma GCC diagnostic push
  #pragma GCC diagnostic ignored "-Wunused-variable"
  #pragma GCC diagnostic ignored "-Wunused-function"
  #pragma GCC diagnostic pop
"/usr/local/cuda-8.0/bin/..//include/cuda_runtime.h", line 56: warning:
"/usr/local/cuda-8.0/bin/..//include/cuda_runtime.h", line 59: warning:
"/usr/local/cuda-8.0/bin/..//include/cuda_runtime.h", line 1899: warning:
"/tmp/tmpxft_0000442c_00000000-4_vecAdd.cudafe1.stub.c", line 1: warning:
"/tmp/tmpxft_0000442c_00000000-4_vecAdd.cudafe1.stub.c", line 2: warning:
"/tmp/tmpxft_0000442c_00000000-4_vecAdd.cudafe1.stub.c", line 3: warning:
  #pragma GCC diagnostic ignored "-Wcast-qual"
"/tmp/tmpxft_0000442c_00000000-4_vecAdd.cudafe1.stub.c", line 4: warning:
main:
      1, include "tmpxft_0000442c_00000000-4_vecAdd.cudafe1.cpp"
           4, include "vecAdd.cpp"
               60, include "device_types.h"
                    69, include "builtin_types.h"
                         65, include "host_runtime.h"
                              72, include "stddef.h"
                                  218, include "driver_types.h"
                                      1481, include "surface_types.h"
                                            114, include "texture_types.h"
                                                 212, include "vector_types.h"
                                                       33, include "vecAdd.cpp"
                                                            35, Generating copyin(h_A[:numElements],h_B[:numElements])
        Generating copyout(h_C[:numElements])
"/usr/local/cuda-8.0/bin/crt/link.stub", line 6: warning: unrecognized GCC
          pragma
"/usr/local/cuda-8.0/bin/crt/link.stub", line 9: warning: unrecognized GCC
          pragma
"/usr/local/cuda-8.0/bin/crt/link.stub", line 10: warning: unrecognized GCC
          pragma
  #pragma GCC diagnostic ignored "-Wunused-parameter"
"/usr/local/cuda-8.0/bin/crt/link.stub", line 11: warning: unrecognized GCC
          pragma
"/usr/local/cuda-8.0/bin/crt/link.stub", line 12: warning: unrecognized GCC
          pragma
"/usr/local/cuda-8.0/bin/crt/link.stub", line 127: warning: unrecognized GCC
          pragma
Hi pfarre83876,
Something else is going on since pgc++ version 16.9 sets GNUC = 4 since we only officially interoperate up to GNU 4.9.3. Most likely nvcc is getting it from your GNU install.
Can you post what modification you made to your installation as well as your compilation line?
I’m able to build and run the example without issue.
% nvcc -x cu -ccbin pgc++ -Xcompiler -ta=tesla:cuda8.0 -Xcompiler -Mcuda -Xcompiler -Minfo=accel -Xcompiler -w -Xcompiler -V16.9 -gencode arch=compute_60,code=sm_60 vecAdd.cpp
main:
      1, include "tmpxft_00003c18_00000000-4_vecAdd.cudafe1.cpp"
                                  213, include "driver_types.h"
                                      1502, include "surface_types.h"
                                                            36, Generating copyin(h_A[:numElements],h_B[:numElements])
% a.out        [Vector addition of 50000 elements]
__GNUC__ = 4
Test PASSED
Done
  • Mat
/opt/pgi/linux86-64/16.9/bin/localrc was generated using makelocalrc
set LFC=-lgfortran;
set LDSO=/lib64/ld-linux-x86-64.so.2;
set GCCDIR=/usr/lib/gcc/x86_64-linux-gnu/5;
set GPPDIR32= /usr/include/c++/5 /usr/include/x86_64-linux-gnu/c++/5/32 /usr/include/c++/5/backward /usr/lib/gcc/x86_64-linux-gnu/5/include /usr/local/include /usr/lib/gcc/x86_64-linux-gnu/5/include-fixed /usr/include;
set GPPDIR64= /usr/include/c++/5 /usr/include/x86_64-linux-gnu/c++/5 /usr/include/c++/5/backward /usr/lib/gcc/x86_64-linux-gnu/5/include /usr/local/include /usr/lib/gcc/x86_64-linux-gnu/5/include-fixed /usr/include/x86_64-linux-gnu /usr/include;
set GCCINC32= /usr/lib/gcc/x86_64-linux-gnu/5/include /usr/local/include /usr/lib/gcc/x86_64-linux-gnu/5/include-fixed /usr/include;
set GCCINC64= /usr/lib/gcc/x86_64-linux-gnu/5/include /usr/local/include /usr/lib/gcc/x86_64-linux-gnu/5/include-fixed /usr/include/x86_64-linux-gnu /usr/include;
set G77DIR=/usr/lib/gcc/x86_64-linux-gnu/6/;
set OEM_INFO=64-bit target on x86-64 Linux $INFOTPVAL;
set GCCINC= /usr/lib/gcc/x86_64-linux-gnu/5/include /usr/local/include /usr/lib/gcc/x86_64-linux-gnu/5/include-fixed /usr/include/x86_64-linux-gnu /usr/include;
set GPPDIR= /usr/include/c++/5 /usr/include/x86_64-linux-gnu/c++/5 /usr/include/c++/5/backward /usr/lib/gcc/x86_64-linux-gnu/5/include /usr/local/include /usr/lib/gcc/x86_64-linux-gnu/5/include-fixed /usr/include/x86_64-linux-gnu /usr/include;
set LOCALRC=YES;
set THROW=__THROW=;
set EXTENSION=__extension__=;
set COMPGCCINCDIR=include-gcc50;
set LC=$if(-Bstatic,-lgcc -lgcc_eh -lc -lgcc -lgcc_eh -lc, -lgcc -lc -lgcc -lgcc_s);
set DEFSTDOBJDIR=/usr/lib/x86_64-linux-gnu;
# GLIBC version 2.23
# GCC version 5.4.1
set GCCVERSION=50401;
set LOCALDEFS=__STDC_HOSTED__;
export PGI=$COMPBASE;
# makelocalrc executed by root vie nov 4 17:32:40
Yes, It was my fault. I was compiling for kepler architecture and the machine has maxwells.
With
 /usr/local/cuda-8.0/bin/nvcc -x cu -ccbin pgc++ -Xcompiler -ta=tesla:cuda8.0 -Xcompiler -Mcuda -Xcompiler -Minfo=accel  -gencode arch=compute_50,code=sm_52 vecAdd.cpp
works well.
Thank you.
No worries. Glad you got it working.
