Verification that my GPU is working (or not)
Hi, I wonder if you could help me verify that my Jetson NX Orin is working or not, which I just received. I’ve installed the latest JetPack on it, this is the output from the nvidia-smi command. Is this dead on arrival? Or is there any other dianosis I should do?
sudo nvidia-smi -q
==============NVSMI LOG==============
Timestamp                                 : Mon Jul 22 22:27:08 2024
Driver Version                            : N/A
CUDA Version                              : 12.2
Attached GPUs                             : 1
GPU 00000000:00:00.0
    Product Name                          : Orin (nvgpu)
    Product Brand                         : Unknown Error
    Product Architecture                  : Ampere
    Display Mode                          : N/A
    Display Active                        : N/A
    Persistence Mode                      : N/A
    Addressing Mode                       : N/A
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : N/A
    Accounting Mode Buffer Size           : N/A
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : N/A
    GPU UUID                              : e8ea794e-041f-5c5b-8b76-5ab5907cc646
    Minor Number                          : N/A
    VBIOS Version                         : N/A
    MultiGPU Board                        : N/A
    Board ID                              : N/A
    Board Part Number                     : N/A
    GPU Part Number                       : N/A
    FRU Part Number                       : N/A
    Module ID                             : N/A
    Inforom Version
        Image Version                     : N/A
        OEM Object                        : N/A
        ECC Object                        : N/A
        Power Management Object           : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GSP Firmware Version                  : N/A
    GPU Virtualization Mode
        Virtualization Mode               : N/A
        Host VGPU Mode                    : N/A
    GPU Reset Status
        Reset Required                    : No
        Drain and Reset Recommended       : No
    IBMNPU
        Relaxed Ordering Mode             : Disabled
    PCI
        Bus                               : N/A
        Device                            : N/A
        Domain                            : N/A
        Device Id                         : N/A
        Bus Id                            : N/A
        Sub System Id                     : N/A
        GPU Link Info
            PCIe Generation
                Max                       : N/A
                Current                   : N/A
                Device Current            : N/A
                Device Max                : N/A
                Host Max                  : N/A
            Link Width
                Max                       : N/A
                Current                   : N/A
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : N/A
        Replay Number Rollovers           : N/A
        Tx Throughput                     : N/A
        Rx Throughput                     : N/A
        Atomic Caps Inbound               : N/A
        Atomic Caps Outbound              : N/A
    Fan Speed                             : N/A
    Performance State                     : N/A
    Clocks Event Reasons                  : N/A
    FB Memory Usage
        Total                             : N/A
        Reserved                          : N/A
        Used                              : N/A
        Free                              : N/A
    BAR1 Memory Usage
        Total                             : N/A
        Used                              : N/A
        Free                              : N/A
    Conf Compute Protected Memory Usage
        Total                             : N/A
        Used                              : N/A
        Free                              : N/A
    Compute Mode                          : N/A
    Utilization
        Gpu                               : N/A
        Memory                            : N/A
        Encoder                           : N/A
        Decoder                           : N/A
        JPEG                              : N/A
        OFA                               : N/A
    Encoder Stats
        Active Sessions                   : N/A
        Average FPS                       : N/A
        Average Latency                   : N/A
    FBC Stats
        Average FPS                       : N/A
    ECC Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Errors
        Volatile
            SRAM Correctable              : N/A
            SRAM Uncorrectable            : N/A
            DRAM Correctable              : N/A
            DRAM Uncorrectable            : N/A
        Aggregate
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : N/A
        GPU T.Limit Temp                  : N/A
        GPU Shutdown Temp                 : N/A
        GPU Slowdown Temp                 : N/A
        GPU Max Operating Temp            : N/A
        GPU Target Temperature            : N/A
        Memory Current Temp               : 0 C
        Memory Max Operating Temp         : N/A
    GPU Power Readings
        Power Draw                        : N/A
        Current Power Limit               : 538976.25 W
        Requested Power Limit             : 805515.25 W
        Default Power Limit               : NVML Shared Library Not Found
        Min Power Limit                   : 573932.69 W
        Max Power Limit                   : Unknown Error
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Min Power Limit                   : Unknown Error
    Clocks
        Graphics                          : N/A
        SM                                : N/A
        Memory                            : N/A
        Video                             : N/A
    Applications Clocks
        Graphics                          : Unknown Error
        Memory                            : Unknown Error
    Default Applications Clocks
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : N/A
        SM                                : N/A
        Memory                            : N/A
        Video                             : N/A
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
    Processes                             : None
Hello @djt1,
You could try using NVIDIA Nsight Systems.
Hopefully that can provide more information on your system.
Please keep us posted on how it goes.
And don’t hesitate to reach out if you require further help.
regards,
Andrew
Thanks. It turns out that nvidia-smi doesn’t really give any useful results on my platform :-( I’ve managed to verify everything is working successfuly otherwise.
