No nvidia-smi output
Hi, my gpu on my nvidia orin nano works fine and I can run cuda program without any issues but when I query nvidia-smi I get N/A:
| NVIDIA-SMI 540.4.0 Driver Version: 540.4.0 CUDA Version: 12.6 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Orin (nvgpu) N/A | N/A N/A | N/A |
| N/A N/A N/A N/A / N/A | Not Supported | N/A N/A |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
@snakekabuto99 there is output, i.e. driver and cuda versions, name, etc. On an Orin a lot of options you’ll see when using the tool on a dGPU are not available!
As mentioned by @elsaco, the output is expected.
nvidia-smi has limited support on the Jetson platform.
