Hi there,
I’m having some problems building the examples from TRT 5.0.2GA. After copying the tensorrt directory somewhere else and trying to build the examples I get:
g++ -MM -MF ../../bin/dchobj/sampleINT8API.d -MP -MT ../../bin/dchobj/sampleINT8API.o -Wall -std=c++11 -I"/usr/local/cuda/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda/include" -I"../../include" -D_REENTRANT sampleINT8API.cpp
Compiling: sampleINT8API.cpp
g++ -Wall -std=c++11 -I"/usr/local/cuda/include" -I"/usr/local/include" -I"../include" -I"../common" -I"/usr/local/cuda/include" -I"../../include" -D_REENTRANT -g -c -o ../../bin/dchobj/sampleINT8API.o sampleINT8API.cpp
sampleINT8API.cpp: In member function ‘bool sampleINT8API::build()’:
sampleINT8API.cpp:448:102: error: cannot convert ‘nvinfer1::INetworkDefinition’ to ‘nvinfer1::INetworkDefinition*’ for argument ‘1’ to ‘nvonnxparser::IParser* nvonnxparser::{anonymous}::createParser(nvinfer1::INetworkDefinition*, nvinfer1::ILogger&)’
auto parser = SampleUniquePtr<nvonnxparser::IParser>(nvonnxparser::createParser(*network, gLogger));
../Makefile.config:172: recipe for target '../../bin/dchobj/sampleINT8API.o' failed
make[1]: *** [../../bin/dchobj/sampleINT8API.o] Error 1
make[1]: Leaving directory '/home/bpinaya/Documents/tensorrt/samples/sampleINT8API'
Makefile:38: recipe for target 'all' failed
make: *** [all] Error 2
Building each example individually does work, but for sampleINT8API I get the following error:
../Makefile.config:5: CUDA_INSTALL_DIR variable is not specified, using /usr/local/cuda by default, use CUDA_INSTALL_DIR=<cuda_directory> to change.
../Makefile.config:8: CUDNN_INSTALL_DIR variable is not specified, using $CUDA_INSTALL_DIR by default, use CUDNN_INSTALL_DIR=<cudnn_directory> to change.
make: *** [../../bin/dchobj/sampleINT8API.o] Error 1
Also for sampleOnnxMNIST I get:
Compiling: sampleOnnxMNIST.cpp
sampleOnnxMNIST.cpp: In function ‘void onnxToTRTModel(const string&, unsigned int, nvinfer1::IHostMemory*&)’:
sampleOnnxMNIST.cpp:45:63: error: cannot convert ‘nvinfer1::INetworkDefinition’ to ‘nvinfer1::INetworkDefinition*’ for argument ‘1’ to ‘nvonnxparser::IParser* nvonnxparser::{anonymous}::createParser(nvinfer1::INetworkDefinition*, nvinfer1::ILogger&)’
auto parser = nvonnxparser::createParser(*network, gLogger);
../Makefile.config:172: recipe for target '../../bin/dchobj/sampleOnnxMNIST.o' failed
make: *** [../../bin/dchobj/sampleOnnxMNIST.o] Error 1
It seems to be onnx-trt related, as I said I built it from source, maybe a version mismatch? Any help is appreciated.
I’m using TensorRT 18.11 container (TensorRT 5 GA). and am able to build sampleINT8API and sampleOnnxMNIST . Can you try it with the container, so to rule out any specific issues with your build environment?
== NVIDIA TensorRT ==
NVIDIA Release 18.11 (build 817536)
NVIDIA TensorRT 5.0.2 (c) 2016-2018, NVIDIA CORPORATION. All rights reserved.
Container image (c) 2018, NVIDIA CORPORATION. All rights reserved.
https://developer.nvidia.com/tensorrt
To install Python sample dependencies, run /opt/tensorrt/python/python_setup.sh
root@2715ee833917:/workspace# cd tensorrt/samples/
Makefile getDigits/ sampleFasterRCNN/ sampleINT8API/ sampleMNISTAPI/ sampleNMT/ sampleSSD/ trtexec/
Makefile.config python/ sampleGoogleNet/ sampleMLP/ sampleMovieLens/ sampleOnnxMNIST/ sampleUffMNIST/
common/ sampleCharRNN/ sampleINT8/ sampleMNIST/ sampleMovieLensMPS/ samplePlugin/ sampleUffSSD/
root@2715ee833917:/workspace# cd tensorrt/samples/sampleINT8API/
root@2715ee833917:/workspace/tensorrt/samples/sampleINT8API# make clean
Cleaning...
Linking: ../../bin/sample_int8_api_debug
# Copy every EXTRA_FILE of this sample to bin dir
root@2715ee833917:/workspace/tensorrt/samples/sampleOnnxMNIST# ls
Makefile README sampleOnnxMNIST.cpp
root@2715ee833917:/workspace/tensorrt/samples/sampleOnnxMNIST# make
Linking: ../../bin/sample_onnx_mnist_debug
Hi there, thanks for the quick answer! And indeed with the container, it works perfectly. This is the output:
root@b2cb8f8f0dc5:/workspace/tensorrt/bin# ./sample_onnx_mnist
Input filename: ../data/mnist/mnist.onnx
ONNX IR version: 0.0.3
Opset version: 1
Producer name: CNTK
Producer version: 2.4
Domain:
Model version: 1
Doc string:
----- Parsing of ONNX model ../data/mnist/mnist.onnx is Done ----
Prob 0 0.9998 Class 0: **********
Prob 1 0.0000 Class 1:
Prob 2 0.0000 Class 2:
Prob 3 0.0000 Class 3:
Prob 4 0.0000 Class 4:
Prob 5 0.0000 Class 5:
Prob 6 0.0002 Class 6:
Prob 7 0.0000 Class 7:
Prob 8 0.0000 Class 8:
Prob 9 0.0000 Class 9:
Just found out about ngc.nvidia.com, it’s a very useful resource to stop fighting with versions installation steps.
Are the docker files going to be available? I’d really like to know where I messed up my installation, I think it was in onnx-tensorrt.
discussed in a separate thread, but from ngc.nvidia.com, you can also view the “layer” of the image you are pulling, which should give you an idea of how the image is constructed.
