I have a host machine, Hardware name: System manufacturer System Product Name/ROG STRIX Z390-E GAMING, BIOS 1502 02/21/2020, bios enabled VT-d, 5.8.0 mainline kernel with vfio-pci modules loaded for the host nvidia card,
I’m running the host kernel on the inbuilt intel graphics adapter.
I’m created a ubuntu-20.04 amd64 host-passthrough guest. The guest kernel is failing to load the driver. I’m not sure where to go from here.
[ 3.537108] [drm] [nvidia-drm] [GPU ID 0x00000700] Loading driver
[ 3.537110] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:07:00.0 on minor 0
[ 3.561282] nvidia-uvm: Loaded the UVM driver, major device number 236.
[ 4.100322] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.7/0000:08:00.0/sound/card1/input5
[ 4.100356] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.7/0000:08:00.0/sound/card1/input6
[ 4.100393] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.7/0000:08:00.0/sound/card1/input7
[ 4.100423] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.7/0000:08:00.0/sound/card1/input8
[ 5.059112] audit: type=1400 audit(1597567787.684:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=647 comm="apparmor_parser"
[ 5.059231] audit: type=1400 audit(1597567787.684:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=651 comm="apparmor_parser"
[ 5.059418] audit: type=1400 audit(1597567787.684:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=649 comm="apparmor_parser"
[ 5.059420] audit: type=1400 audit(1597567787.684:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=649 comm="ap
parmor_parser"
[ 5.059421] audit: type=1400 audit(1597567787.684:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=650 comm="apparmor_parser"
[ 5.059422] audit: type=1400 audit(1597567787.684:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=650 comm="apparmor_parser"
[ 5.059423] audit: type=1400 audit(1597567787.684:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=650 comm="apparmor_parser"
[ 5.060042] audit: type=1400 audit(1597567787.684:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=653 comm="apparmor_parser"
[ 5.060044] audit: type=1400 audit(1597567787.684:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=653 comm="apparmor_parser"
[ 5.332680] kauditd_printk_skb: 34 callbacks suppressed
[ 5.332681] audit: type=1400 audit(1597567787.956:45): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=781 comm="cups-browsed" capability=23 capname="sys_nice"
[ 6.146010] Lockdown: Xorg: raw io port access is restricted; see man kernel_lockdown.7
[ 6.179765] NVRM: GPU 0000:07:00.0: RmInitAdapter failed! (0x23:0x56:515)
[ 6.179845] NVRM: GPU 0000:07:00.0: rm_init_adapter failed, device minor number 0
[ 6.225947] Lockdown: Xorg: raw io port access is restricted; see man kernel_lockdown.7
[ 6.296582] NVRM: GPU 0000:07:00.0: RmInitAdapter failed! (0x23:0x56:515)
[ 6.296671] NVRM: GPU 0000:07:00.0: rm_init_adapter failed, device minor number 0
nvidia-bug-report.log.gz (93.6 KB)
libvirt definition of guest ubunt2004.xml.gz (1.6 KB)
iommu groups on host (2.4 KB)
