i getting low utilization on my test VM’s,
I’m using VM Profile of :
- NVIDIA GRID vGPU grid_rtx8000p-4q
- NVIDIA GRID vGPU grid_rtx8000p-2q
Cinebench R15 : OpenGL 59 +/- no more !!!
Does someone have the same problem ???
NVSMI LOG:
nvidia-smi -q
==============NVSMI LOG==============
Timestamp : Wed Dec 23 09:04:45 2020
Driver Version : 450.89
CUDA Version : Not Found
Attached GPUs : 2
GPU 00000000:25:00.0
Product Name : Quadro RTX 8000
Product Brand : Tesla
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : Enabled
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Enabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 1325219085576
GPU UUID : GPU-9c213c49-3b61-10dc-4e1b-d32b2e9c1ae7
Minor Number : 0
VBIOS Version : 90.02.4E.00.03
MultiGPU Board : No
Board ID : 0x2500
GPU Part Number : 900-2G150-0150-030
Inforom Version
Image Version : G150.0231.00.02
OEM Object : 1.1
ECC Object : 5.0
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization Mode : Host VGPU
Host VGPU Mode : Non SR-IOV
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x25
Device : 0x00
Domain : 0x0000
Device Id : 0x1E7810DE
Bus Id : 00000000:25:00.0
Sub System Id : 0x13D810DE
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : N/A
Performance State : P8
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 46079 MiB
Used : 5995 MiB
Free : 40084 MiB
BAR1 Memory Usage
Total : 32768 MiB
Used : 45 MiB
Free : 32723 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
SRAM Correctable : 0
SRAM Uncorrectable : 0
DRAM Correctable : 0
DRAM Uncorrectable : 0
Aggregate
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending Page Blacklist : No
Remapped Rows : N/A
Temperature
GPU Current Temp : 31 C
GPU Shutdown Temp : 87 C
GPU Slowdown Temp : 84 C
GPU Max Operating Temp : 82 C
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : 26.68 W
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 150.00 W
Max Power Limit : 250.00 W
Clocks
Graphics : 300 MHz
SM : 300 MHz
Memory : 405 MHz
Video : 540 MHz
Applications Clocks
Graphics : 1230 MHz
Memory : 6501 MHz
Default Applications Clocks
Graphics : 1230 MHz
Memory : 6501 MHz
Max Clocks
Graphics : 1620 MHz
SM : 1620 MHz
Memory : 6501 MHz
Video : 1500 MHz
Max Customer Boost Clocks
Graphics : 1620 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 2104744
Type : C+G
Used GPU Memory : 1900 MiB
Process ID : 2105231
Type : C+G
Process ID : 2105630
Type : C+G
GPU 00000000:81:00.0
MIG Mode
Current : N/A
Pending : N/A
Driver Model
Current : N/A
Pending : N/A
Serial Number : 1325219085762
GPU UUID : GPU-20880b45-4e0e-bf33-ee89-9277cfe9e04c
Minor Number : 1
MultiGPU Board : No
Board ID : 0x8100
Inforom Version
OEM Object : 1.1
ECC Object : 5.0
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x81
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:81:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Fan Speed : N/A
Idle : Active
FB Memory Usage
Total : 46079 MiB
Used : 7895 MiB
Free : 38184 MiB
BAR1 Memory Usage
Total : 32768 MiB
Used : 31 MiB
Free : 32737 MiB
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 1
Average FPS : 301
Average Latency : 3023
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
Aggregate
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Remapped Rows : N/A
Temperature
Power Readings
Power Draw : 26.26 W
Clocks
Graphics : 300 MHz
SM : 300 MHz
Memory : 405 MHz
Video : 540 MHz
Applications Clocks
Graphics : 1230 MHz
Memory : 6501 MHz
Graphics : 1230 MHz
Memory : 6501 MHz
Max Clocks
Graphics : 1620 MHz
SM : 1620 MHz
Memory : 6501 MHz
Video : 1500 MHz
Graphics : 1620 MHz
Clock Policy
Auto Boost : N/A
Processes
Process ID : 2105606
Type : C+G
Used GPU Memory : 3800 MiB
Process ID : 2105645
Type : C+G
