Must someone use vGPU with a guest OS(each vgpu profile has to boot into a guest OS so it can be consumed) even when its intended for kubernetes? (Should not be mistaken for MIG). Or the vGPU manager runs on the host OS and can expose the vGPU profiles to kubernetes with GPU Operator directly?
daya.s
2
Yes, with vGPU, you still need a guest OS (VM) to consume each vGPU profile. The vGPU Manager runs on the host hypervisor, but Kubernetes only sees GPUs inside the guest VM, not directly from the host.
If you want Kubernetes to run directly on bare-metal with GPU partitioning, you should be looking at MIG, not vGPU.
Related topics
| Kubernetes vGPU required drivers | 0 | 101 | November 25, 2025 | |
| vGPU Manager on Flatcar - kubernetes and kubevirt - Possible or not? | 0 | 946 | June 2, 2023 | |
| Orchestrating Accelerated Virtual Machines with Kubernetes Using NVIDIA GPU Operator | 0 | 422 | October 31, 2022 | |
| Inquiries about deploying GPU OPERATOR in a Kubernetes environment | 1 | 417 | July 13, 2023 | |
| Installing NVIDIA vGPU on Kubernetes Cluster with RTX 6000 Ada Without Hypervisor | 0 | 269 | February 13, 2025 | |
| NVIDIA VGPU for L40s baremetal | 0 | 558 | October 28, 2024 | |
| A100 vGPU vs MIG in KVM | 1 | 1960 | August 13, 2025 | |
| Hello world! Can vGPU uses GPUs from multiple machines? | 2 | 835 | February 11, 2023 | |
| Support for K8 and GPU operator | 5 | 951 | July 20, 2023 | |
| Is it possible to virtualize GPU on Jetson agx xavier with k8s cluster | 1 | 722 | August 25, 2022 |
