I’m trying to use the GPU Operator with vGPU support following this article on k3s. After I install the operator, vGPU pods stuck at init state, and then the CrashLoopBackoff happens to the vGPU manager pod. I couldn’t find the root cause or a similar issue from the forum/issues yet. I can provide outputs from the host if requested. Any kind of help is appreciated.
- The server is vGPU certified. (Supermicro 1029U-TR4 w/ two NVIDIA T4 GPUs)
- SR-IOV is enabled. (BIOS)
- VT-d is enabled. (BIOS)
intel_iommuis enabled. (/etc/default/grub)
gpu-operator gpu-operator-1727453251-node-feature-discovery-gc-854cf464lp2ck 1/1 Running 0 53m
gpu-operator gpu-operator-1727453251-node-feature-discovery-master-8656xbdjm 1/1 Running 0 53m
gpu-operator gpu-operator-1727453251-node-feature-discovery-worker-25mqp 1/1 Running 0 53m
gpu-operator gpu-operator-84c6b4697b-hlshg 1/1 Running 0 53m
gpu-operator nvidia-sandbox-device-plugin-daemonset-8vp72 1/1 Running 0 50m
gpu-operator nvidia-sandbox-validator-zw6w7 1/1 Running 0 53m
gpu-operator nvidia-vgpu-device-manager-zddgb 0/1 Init:0/1 0 40m
gpu-operator nvidia-vgpu-manager-daemonset-4cm5s 0/1 Init:0/1 12 (5m42s ago) 49m
When I check the allocatable resources on node, I can see the vGPU device that I try to use as below.
allocatable:
cpu: "80"
ephemeral-storage: "4411267110320"
hugepages-1Gi: "0"
hugepages-2Mi: 2Gi
memory: 261654520Ki
nvidia.com/GRID_T4-2Q: "1"
pods: "110"
Here is my installation command. I disabled the driver and the toolkit because they are available on the host.
helm install --wait --generate-name \
-n gpu-operator --create-namespace \
nvidia/gpu-operator \
--set sandboxWorkloads.enabled=true \
--set driver.enabled=false \
--set toolkit.enabled=false \
--set vgpuManager.enabled=true \
--set vgpuManager.repository=${PRIVATE_REGISTRY} \
--set vgpuManager.image=vgpu-manager \
--set vgpuManager.version=550.90.05 \
--set vgpuManager.imagePullSecrets={${REGISTRY_SECRET_NAME}}
Logs of the crashing/stucking pods
kubectl logs -f nvidia-vgpu-manager-daemonset-4cm5s -n gpu-operator -c k8s-driver-manager
NVIDIA GPU driver is already pre-installed on the node, disabling the containerized driver on the node
node/robolaunch-internal labeled
kubectl logs -f nvidia-vgpu-device-manager-zddgb -n gpu-operator -c vgpu-manager-validation
waiting for NVIDIA vGPU Manager to be setup
Verification of vGPU creation
mdevctl list
16d7dda2-f888-4c28-9c3c-2352daa88a8c 0000:af:00.0 nvidia-231 (defined)
Host driver
It’s installed using .deb file (Host Drivers) downloaded from NLP - Software Download with the command sudo apt install ./nvidia-vgpu-ubuntu-550_550.90.05_amd64.deb.
nvidia-smi
| NVIDIA-SMI 550.90.05 Driver Version: 550.90.05 CUDA Version: N/A |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Tesla T4 On | 00000000:AF:00.0 Off | Off |
| N/A 53C P8 18W / 70W | 97MiB / 16384MiB | 0% Default |
| | | N/A |
| 1 Tesla T4 On | 00000000:D8:00.0 Off | Off |
| N/A 54C P8 17W / 70W | 97MiB / 16384MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
