I’m getting Error from VI, I tried receving video in xavier NX using
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-mmap -d /dev/video0 --set-ctrl bypass_mode=0 --stream-count=3 --stream-to=Vid.raw
The camera getting initialized but i’m getting the below Error from Vi
1800.342385] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 10485856
[ 1801.809036] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 10485856
[ 1801.975685] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 10485856
[ 1802.159028] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 10485856
[ 1802.342350] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 112, err_data 10485856
[ 1804.852012] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 1804.852161] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 1804.852299] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 1804.892362] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 1807.411998] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 1807.412170] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 1807.412332] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 1807.414657] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 1809.971994] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 1809.972179] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
