VIC failure - tegra-mc: VPR violation
AGX Orin, Jetpack 6.2.1
2 x stereo + 4 x mono cameras
Failure: Infrequent but deadly. Kernel process left in D-state, cannot be killed.
It is unclear if this is related to in topic 375009. This failure does not coinside with the syncpt_load failed logs.
Jul 01 22:04:47 c010-0705 kernel: arm-smmu 8000000.iommu: Unhandled context fault: fsr=0x402, iova=0x3ff5bf3000, fsynr=0x4c0013, cbfrsynra=0x43b, cb=11
Jul 01 22:04:47 c010-0705 kernel: tegra-mc 2c00000.memory-controller: vicswr: secure write @0x00000003ffffff00: VPR violation ((null))
Jul 01 22:04:47 c010-0705 kernel: tegra-mc 2c00000.memory-controller: vicswr: secure write @0x00000003ffffff00: Route Sanity error ((null))
Jul 01 22:04:47 c010-0705 kernel: tegra-vic 15340000.vic: argus: job submission failed: host1x job submission failed: -4
Jul 01 22:04:47 c010-0705 kernel: tegra-vic 15340000.vic: V4L2_EncThread: job submission failed: host1x job submission failed: -4
[Thu Jul 2 14:12:58 2026] sysrq: Show Blocked State
[Thu Jul 2 14:12:58 2026] task:V4L2_EncThread state:D stack: 0 pid:373086 ppid:372952 flags:0x00000005
[Thu Jul 2 14:12:58 2026] Call trace:
[Thu Jul 2 14:12:58 2026] __switch_to+0x104/0x160
[Thu Jul 2 14:12:58 2026] __schedule+0x2e8/0x820
[Thu Jul 2 14:12:58 2026] schedule+0x90/0x110
[Thu Jul 2 14:12:58 2026] schedule_preempt_disabled+0x30/0x50
[Thu Jul 2 14:12:58 2026] __mutex_lock.constprop.0+0x198/0x600
[Thu Jul 2 14:12:58 2026] __mutex_lock_slowpath+0x2c/0x40
[Thu Jul 2 14:12:58 2026] mutex_lock+0x7c/0x90
[Thu Jul 2 14:12:58 2026] host1x_cdma_begin+0x3c/0x170 [host1x]
[Thu Jul 2 14:12:58 2026] channel_submit+0x1c4/0x810 [host1x]
[Thu Jul 2 14:12:58 2026] host1x_job_submit+0x40/0x50 [host1x]
[Thu Jul 2 14:12:58 2026] tegra_drm_ioctl_channel_submit+0xb84/0x1600 [tegra_drm]
[Thu Jul 2 14:12:58 2026] drm_ioctl_kernel+0xd4/0x130 [drm]
[Thu Jul 2 14:12:58 2026] drm_ioctl+0x2a8/0x5c0 [drm]
[Thu Jul 2 14:12:58 2026] __arm64_sys_ioctl+0xb4/0x100
[Thu Jul 2 14:12:58 2026] invoke_syscall+0x5c/0x130
[Thu Jul 2 14:12:58 2026] el0_svc_common.constprop.0+0x64/0x110
[Thu Jul 2 14:12:58 2026] do_el0_svc+0x74/0xa0
[Thu Jul 2 14:12:58 2026] el0_svc+0x28/0x80
[Thu Jul 2 14:12:58 2026] el0t_64_sync_handler+0xa4/0x130
[Thu Jul 2 14:12:58 2026] el0t_64_sync+0x1a4/0x1a8
[Thu Jul 2 14:12:58 2026] task:kworker/0:1 state:D stack: 0 pid:691052 ppid: 2 flags:0x00000008
[Thu Jul 2 14:12:58 2026] Workqueue: events cdma_update_work [host1x]
[Thu Jul 2 14:12:58 2026] schedule_timeout+0x18c/0x1d0
[Thu Jul 2 14:12:58 2026] wait_for_completion+0x8c/0x120
[Thu Jul 2 14:12:58 2026] host1x_job_put+0x124/0x170 [host1x]
[Thu Jul 2 14:12:58 2026] update_cdma_locked+0xec/0x1b0 [host1x]
[Thu Jul 2 14:12:58 2026] cdma_update_work+0x34/0x50 [host1x]
[Thu Jul 2 14:12:58 2026] process_one_work+0x208/0x4d0
[Thu Jul 2 14:12:58 2026] worker_thread+0x144/0x490
[Thu Jul 2 14:12:58 2026] kthread+0x184/0x190
[Thu Jul 2 14:12:58 2026] ret_from_fork+0x10/0x20
root@c010-0705:~# ps -eo pid,state,comm | grep '^.* D '
691052 D kworker/0:1+events
root@c010-0705:~#
This looks to be memory corruption and the PSIRT fix should help:
Tegra-host1x 13e00000.host1x: syncpt_load failed - #12 by DaneLLL
Would suggest upgrade to Jetpack 6.2.2 r36.5
Unable to upgrade due to:
Would suggest port pwm-config.c of Jetpack 6.2.1 to 6.2.2 and give it a try.
Similar failure:
[Fri Jul 17 05:16:10 2026] tegra-host1x 13e00000.host1x: syncpt_load failed: id=177, min=8011768, max=8011766
[Fri Jul 17 05:29:20 2026] arm-smmu 8000000.iommu: Unhandled context fault: fsr=0x402, iova=0x3ff5b75000, fsynr=0x4a0013, cbfrsynra=0x439, cb=8
[Fri Jul 17 05:29:20 2026] tegra-mc 2c00000.memory-controller: vicswr: secure write @0x00000003ffffff00: VPR violation ((null))
[Fri Jul 17 05:29:20 2026] tegra-mc 2c00000.memory-controller: vicswr: secure write @0x00000003ffffff00: Route Sanity error ((null))
[Fri Jul 17 05:29:21 2026] tegra-vic 15340000.vic: V4L2_EncThread: job submission failed: host1x job submission failed: -4
[Fri Jul 17 05:29:21 2026] tegra-vic 15340000.vic: argus: job submission failed: host1x job submission failed: -4
[Fri Jul 17 10:27:53 2026] sysrq: Show Blocked State
[Fri Jul 17 10:27:53 2026] task:argus           state:D stack:    0 pid:40567 ppid: 39907 flags:0x00000005
[Fri Jul 17 10:27:53 2026] Call trace:
[Fri Jul 17 10:27:53 2026]  __switch_to+0x104/0x150
[Fri Jul 17 10:27:53 2026]  __schedule+0x2e8/0x820
[Fri Jul 17 10:27:53 2026]  schedule+0x90/0x110
[Fri Jul 17 10:27:53 2026]  schedule_preempt_disabled+0x30/0x50
[Fri Jul 17 10:27:53 2026]  __mutex_lock.constprop.0+0x198/0x600
[Fri Jul 17 10:27:53 2026]  __mutex_lock_slowpath+0x2c/0x40
[Fri Jul 17 10:27:53 2026]  mutex_lock+0x7c/0x90
[Fri Jul 17 10:27:53 2026]  host1x_cdma_begin+0x3c/0x170 [host1x]
[Fri Jul 17 10:27:53 2026]  channel_submit+0x1c4/0x800 [host1x]
[Fri Jul 17 10:27:53 2026]  host1x_job_submit+0x40/0x50 [host1x]
[Fri Jul 17 10:27:53 2026]  tegra_drm_ioctl_channel_submit+0xc34/0x1730 [tegra_drm]
[Fri Jul 17 10:27:53 2026]  drm_ioctl_kernel+0xd4/0x130 [drm]
[Fri Jul 17 10:27:53 2026]  drm_ioctl+0x2a8/0x5c0 [drm]
[Fri Jul 17 10:27:53 2026]  __arm64_sys_ioctl+0xb4/0x100
[Fri Jul 17 10:27:53 2026]  invoke_syscall+0x5c/0x130
[Fri Jul 17 10:27:53 2026]  el0_svc_common.constprop.0+0x64/0x110
[Fri Jul 17 10:27:53 2026]  do_el0_svc+0x74/0xa0
[Fri Jul 17 10:27:53 2026]  el0_svc+0x28/0x80
[Fri Jul 17 10:27:53 2026]  el0t_64_sync_handler+0xa4/0x130
[Fri Jul 17 10:27:53 2026]  el0t_64_sync+0x1a4/0x1a8
[Fri Jul 17 10:27:53 2026] task:kworker/0:0     state:D stack:    0 pid:177631 ppid:     2 flags:0x00000008
[Fri Jul 17 10:27:53 2026] Workqueue: events cdma_update_work [host1x]
[Fri Jul 17 10:27:53 2026]  schedule_timeout+0x18c/0x1d0
[Fri Jul 17 10:27:53 2026]  wait_for_completion+0x8c/0x120
[Fri Jul 17 10:27:53 2026]  host1x_job_put+0x124/0x170 [host1x]
[Fri Jul 17 10:27:53 2026]  update_cdma_locked+0xec/0x1b0 [host1x]
[Fri Jul 17 10:27:53 2026]  cdma_update_work+0x34/0x50 [host1x]
[Fri Jul 17 10:27:53 2026]  process_one_work+0x208/0x4d0
[Fri Jul 17 10:27:53 2026]  worker_thread+0x144/0x490
[Fri Jul 17 10:27:53 2026]  kthread+0x184/0x190
[Fri Jul 17 10:27:53 2026]  ret_from_fork+0x10/0x20
Do you still see this error after applying the fix:
Tegra-host1x 13e00000.host1x: syncpt_load failed - #29 by Agtonomy
We’ve had it running on 2 benchtop systems for a couple of weeks with positive results - no failures, so there is a good chance it is indeed a fix. However since the failure was very intermittent (but fatal) I will confirm when it successfully runs in the field.
We are preparing to start rolling it out to the fleet next week.
