We have a sensor+ISP hardware that outputs 1920x1080 frames RGB888 format. We need to capture video, save the file and display it our TX2.
We already have a working driver. Camera streaming is working properly using qv4l2 interface. Frames are also successfully saved using the command:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=AR24 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=30 --stream-to=test.raw
However, we can’t figure out how to display the video or even to display a single RGB888 frame.
We have tried using gst-launch-1.0 but it always results to
erroneous pipeline: could not link nvcamerasrc0 to
erroneous pipeline: could not link v4l2src0 to
Can anyone guide us on this? Thanks!
